查看: 4418|回复: 22
[Pads_VX.2x] MTK8665\MT8665+MT6328E1+MT6169参考设计 PCB文件共享
社区居民忠实会员终身成就奖
发表于 2019-6-15 08:33 | 显示全部楼层 |阅读模式
以下内容由管理员 @老吴   整理补充
NamePCB DecalValuePart Type
ANT1501RF_3PIN_3X3RF_3PIN_3X3
CON1DIP-PH-1X4P-LDIP-PH-1X4P-LDIP-PH-1X4P-L
CON19DIP-PH-1X6P-LDIP-PH-1X6P-LDIP-PH-1X6P-L
CON1602SIM_016-7PSIM_CARDSIM-016-P7
CON3302RF_TEST_PAD_4MMRF_TEST_PAD_4MM_A_1
CON3303RF_3PIN_3X3RF_3PIN_3X3
CON3401RF_TEST_PAD_4MMRF_TEST_PAD_4MM_A_1
CON6404FFC-6PIN-0.5MMFFC-6PIN-0.5MMFFC-6PIN-0.5MM
CON9005COAXIAL/SMD/TA-RF02-001-03-811TA-RF02-001-03-811CON_/_4_/_TP-RF005-001-03-815_1
D1DO-214ACSS34D_SS34_DO214AC
D21N4148IN4148D_IN4148_LL34
D3SUP4059WB5819WSUP4059W
D4SUP4059WB5819WSUP4059W
D5SUP4059WB5819WSUP4059W
D7DO-214ACSS34D_SS34_DO214AC
D13DO-214ACSMAJ15CAB340A-E3/61T
D21LED0603BLUEDLED_0603_BYS
D22LED0603REDDLED_0603_RYS
D601SOT23BAT54SBAT54S
D602SOD323SUP38N20VDIODE_SCHOTTKY_3
D603SOT23BAT54SBAT54S
D604SOD323SUP38N6VDIODE_SCHOTTKY_3
D605SOD123B5819WDIODE_SCHOTTKY_3
D2024SOD323NCDIODE_SCHOTTKY_3
ED25D0402ESD0402V24C03ESD0402V24C03
F1F-12100RSMD1210P150TF/16
F5002DIPLEXER/6P/SMD/DPX165950DTRFDIP160806BLM5T62BL1608-05K2450_0
FD9101FDTP / 40 / milTP_R_1MM
FD9102FDTP / 40 / milTP_R_1MM
FD9103FDTP / 40 / milTP_R_1MM
FD9104FDTP / 40 / milTP_R_1MM
J1FPC30P_05FPC30PIN_0.5MM_RFPC30PIN_0.5MM_R
J2USB_AUSB-4S4USB_A
J3CON2X11PIN_2_0MMNCCON2X11PIN_2_0MM
J5CON2X17PIN_2_0MMPHB-200217SCU8-05CON2X17PIN_2_0MM
J3401RF_3PIN_3X3RF_3PIN_3X3
L1R06030RZR0603
L2L-8040S1.5uHSWPA8040S1R5NT
L3L-6028S2.2uHSMDRH8D43
L4L/IND/SMD/LVS252010-2R24.7uHINDUCTOR
L6GRC0603-A1K600OHM/1A/SMD0805
L602L4X4N10uHINDUCTOR_0_2
L1801L04021K/100MHzFB_/_BLM15AG121SN1
L2001L/IND/SMD/VLS201610E330nHL_/_MDMK2020TR68MM_/_SMD2520
MIC2-1PIN-1.2X2TEST POINTTEST_POINT_DIP0_4.6
NTC2000R0402ERTJ0ER104FNTC_/_NCP15WF104F03RC_/_0402__0
NTC3201R0201ERTJ0ER104FNTC_/_NCP15WF104F03RC_/_0402_
PA402PAD2_60XCAPACITOR_2
Q1SOT233904Q_3904_SOT23
Q2SOT232N7002LNMOS
Q3SOT233904Q_3904_SOT23
Q4SOT23NCNMOS
Q5SOT23NCNMOS
Q6SOT232N7002LNMOS
Q20SOT233904Q_3904_SOT23
Q1512SOT23SI2301Q_SI2301_SOT23
Q1513SOT233904Q_3904_SOT23
Q1528SOT23SI2301Q_SI2301_SOT23
Q1529SOT23NCQ_3904_SOT23
SC9185CABLE_CLIP/3P/SMD/PCV1003SC / PCV1003CON/CABLE_CLIP/PCV1003
SH901CON_PAD_DOTNO PAD 0402CON_PAD_DOT
SH902CON_PAD_DOTNO PAD 0402CON_PAD_DOT
SH5001R04020RZR0402
SH5002R04020RZR0402
SHR1RFSHORTRFSHORT
SHR2RFSHORTRFSHORT
TP6506TP1MMTPTP-1.0MM
U1TSOT23-8MP1495MP1495
U2GL850G-SSOP28GL850GGL850G-SSOP28
U3SOT23-5AF6221-33CRT9179_1
U4SOT23-5AF6221-33CRT9179_1
U7TSOT23-6MP1470MP1470
U9BISS0001BISS0001RT9167-NNCB_8_4
U25EXC14CE_0302NCTLSDCW_1
U47SOT23-5AF6221-33CRT9179_1
U401SOT23_6SY7200AMP3202
U603SOT23-5TCS23351_EMP3202_0
U902DFN2X2_6L_PNMT6N1PNMT6N1PNMT6N1
U1001MT8665/VFBGA641/P0.4/B0.25/12.6X12.6IC-MT8665-LP3-SBSIC-MT8735_0
U1011EXC14CE_0302NCTLSDCW_1
U1012EXC14CE_0302NCTLSDCW_1
U1013EXC14CE_0302NCTLSDCW_1
U1014EXC14CE_0302NCTLSDCW_1
U1015EXC14CE_0302NCTLSDCW_1
U1401SDMMC_SLOT_11SDMMC_SLOT_11MS110-C10B-C13-A_2
U1601UTQFN10LHR1532TQFNDSPDT_1
U2001MT6328/VFBGA205/P0.4/B0.25/6.6X6.6MT6328E1IC/MT6328-E1/XXXMM_0
U3101MT6169/VFBGA175/P0.4/B0.25/6.2X5.4MT616960118A_22
U3102TCXO/SMD/2.5X2.0/KT2520F26MHZKT2520F26000DCW28QAK
U3203SKY77643PA_/_SKY77590_9
U3210BALUN/SMD/HHM22112A2RFLPF16082G5WM0T29LF1608-B2R5KCB
U3215FILTER/SMD/885049SAFEA2G35MF0F0ASAW_3
U3216FILTER/SMD/LFB212G49CG7D755NCDEA102700LT-6307_0
U3224FILTER/SMD/885049SAFEA2G60MA0F0ASAW_3
U3301DUPLEXER/8P/SMD/SAYEY710MBA0F0ANCDPX_/_SAYFH1G74BA0B0A_0
U3302RF1628HS8728SPDT_/_BGS12SL6_2
U3303DUPLEXER/8P/SMD/SAYEY710MBA0F0ANCDPX_/_SAYFH1G74BA0B0A_0
U3304RF1628NCSPDT_/_BGS12SL6_2
U3305SAWFILTER/SMD/SAWFD1G90BH0F0ASAWFD1G90BK0F0ASAWFD1G90BH0F0A_0
U3306DUPLEXER/8P/SMD/SAYEY710MBA0F0ASAYEY1G95HA0F0ASAW-DPX-RX-BAL_1
U3307SKY77910HS8916ASM_/_SKY13492_7
U3308DUPLEXER/8P/SMD/SAYEY710MBA0F0ANCSAW-DPX-RX-BAL_1
U3309DUPLEXER/8P/SMD/SAYEY710MBA0F0ASAYEY1G74BC0B0ADPX_/_B8627_0
U3310DUPLEXER/8P/SMD/SAYEY710MBA0F0ANCDPX_/_B8627_0
U3311DUPLEXER/8P/SMD/SAYEY710MBA0F0ANCSAW-DPX-RX-BAL_1
U3313DUPLEXER/8P/SMD/SAYEY710MBA0F0AHDDB05NSB-B11SAW-DPX-RX-BAL_1
U3314DUPLEXER/8P/SMD/SAYEY710MBA0F0ASAYEY897MCA0B0ASAW-DPX-RX-BAL_1
U3315TSLP10/SMD/P0.4/BGS22WL10MXD8650XM0860SH-DL0601_21
U3320FILTER/SMD/TFSL06050915-4108B1NCSAW_0
U3323BALUN/SMD/TFSZ06052460-3310A2RFBLN06052G5WM9T16TDK-BALUN_0
U3324BALUN/SMD/TFSZ06051897-3317A1RFBLN06051G8DM1T69BAL_/_TFSZ06051897-3317A1
U3325BALUN/SMD/TFSZ06052460-3310A2NCTDK-BALUN_0
U3332SKY13489NCSPDT_/_BGS12SL6_0
U3402RF1628HS8728SPDT_/_BGS12SL6_2
U3403QFN14_2X2X06HS8718XM0860SH-DL0601_1
U3404RF1628HS8728SPDT_/_BGS12SL6_2
U3405SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB2G35AA0F0ASAW_7
U3406SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB1G84FL0F0ASAW_3_3
U3407SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB1G90FB0F0ASAW_2
U3408SAWFILTER/SMD/F6QB2G595P2BSHDFB07RSB-B5SAW_1_2
U3409BALUN/SMD/TFSZ06051897-3317A1RFBLN06052G5WM9T16BAL_/_TFSZ06051897-3317A1
U3410SAWFILTER/SMD/F6QB2G595P2BSSAFFB2G14FA0F0ASAW_4_2
U3411RF1628HS8728SPDT_/_BGS12SL6_2
U3412SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB740MAA0F0ASAW_5
U3413SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB806MAA0F0ASAW_6
U3414FILTER/SMD/TFSL06050915-4108B1RFLPF06050G9D0TSAW_0
U3415BALUN/SMD/TFSZ06051897-3317A1RFBLN0605040YM9T16BAL_/_TFSZ06051897-3317A1
U3416SAWFILTER/SMD/SAFFB1G90FB0F0ANCSAW_3_3
U3417SAWFILTER/SMD/F5QB2G595P2BSHDFB05RSB-B5SAW_1
U3418SAWFILTER/SMD/F6QB2G595P2BSSAFFB2G60AA1F0ASAW_6_2
U3419SAWFILTER/SMD/F5QB2G595P2BSSAFFB942MFL0F0ASAW_2_2
U3420QFN14_2X2X06HS8713XM0860SH-DL0601_1
U3424TSLP10/SMD/P0.4/BGS22WL10MXD8650XM0860SH-DL0601_21
U4102FBGA178/SMDK4E6E304E3-EGCELP_DDR2(JEDEC_162B)_5
U5001MT6625/SQFN40/SMD/P0.4/5X5MT6625LMT6611_SMD_WLCSP-61_0
U5002TCXO/SMD/2.5X2.0/IT2205BE26MHzTCXO_RAKON_SMD_4P
U5005FILTER/SMD/ACPF-7124HDF2442E-B2SAFEB1G57KA0F00
U5102SAW_42X53HDF1588E-B2GPS-FILTER_0
U5103QFN6_15_10_08HS1100MAX2657_0
U6316BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBAKLMAG2GEND-B031169_BALL_EMMC_1
U6317LQFP48-7X7STM8S005C6T6STM8S005C6
U6320SOT23-5NCRT9179_1
U6443TSLP6/SMD/P0.4/BGA725L6/SBGA729N6NJG1107HB3_0
VD401SOD123B5819WDIODE_0_2
VD704SOD123SUP58N5V1DIODE_0
VD707SOD123SUP58N2V4DIODE_0
VR1521R0402NC/EZJZ0V500AAVR0402
VR1552R0402NC/EZJZ0V500AAVR0402
X1OSC322512MCRYSTAL-4_0
X2001CRYS/SMD/3.2X1.5/9H032000XX/TXC32.768KHzCM7V-T1A
X2002OSC3225NCCRYSTAL-4_0
购买主题 本主题需向作者支付 20 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
  • 打卡总天数:1
  • 打卡总奖励:3
  • 最近打卡:2024-08-07 10:43:46
发表于 2019-6-15 08:43 | 显示全部楼层
  • 打卡总天数:520
  • 打卡月天数:13
  • 打卡总奖励:1724
  • 最近打卡:2026-11-13 09:07:13
发表于 2019-6-15 08:57 | 显示全部楼层
1元学习Allegro(1期)
发表于 2019-6-15 09:11 | 显示全部楼层
发表于 2019-6-15 09:47 | 显示全部楼层
  • 打卡总天数:1
  • 打卡总奖励:4
  • 最近打卡:2025-02-06 11:33:10
1元学习PADS(5期)
发表于 2019-10-31 11:51 | 显示全部楼层
发表于 2019-11-27 09:08 | 显示全部楼层
多谢楼主,希望能有规格书之类的资料在里面
  • 打卡总天数:12
  • 打卡总奖励:50
  • 最近打卡:2025-08-29 11:10:46
22
发表于 2020-10-28 06:14 | 显示全部楼层
  • 打卡总天数:886
  • 打卡月天数:13
  • 打卡总奖励:2995
  • 最近打卡:2026-11-13 13:39:07
23
发表于 2020-10-28 08:17 | 显示全部楼层
  • 打卡总天数:193
  • 打卡月天数:1
  • 打卡总奖励:613
  • 最近打卡:2026-11-11 12:59:27
9571
7万
发表于 2020-10-28 08:54 | 显示全部楼层
有的贵,看不截图,不敢买
