查看: 5131|回复: 21
[AD格式] RTM_4SFP_3QSFP
  • 打卡总天数:2
  • 打卡总奖励:3
  • 最近打卡:2025-11-25 15:59:54
33
发表于 2019-7-13 19:09 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
RTM_4SFP_3QSFP is simple RTM module with SFP+ and QSFP cages. It is compatible with AFCZ and Sayma AMC modules. Features:
    [li]4 SFP+ cages[/li][li]3 QSFP cages[/li][li]RF backplane support for White Rabbit clock distributed by low jitter WR receiver[/li][li]all SFP and QSFP signals controlled by I2C[/li]
Schematic.rar
267 KB, 下载次数: 17, 下载积分:金币 -5 枚
RTM_4SFP_3QSFP.rar
6.8 MB, 下载次数: 18, 下载积分:金币 -5 枚
BOM
CommentDescriptionDesignatorFootprintLibRefQuantity
10uFNon-polarised capacitorC1, C2, C3, C4, C12A, C12B, C12C, C12D, C14A, C14B, C14C, C14D, C23A, C23B, C23C, C23D, C33A, C33B, C33C, C35A, C35B, C35C, C41A, C41B, C41C, C43A, C43B, C43CCAPC2012X135NCC0805_10UF_10V_10%_X7R28
100uFPolarised capacitorC5CAPAE660X540NCAE660-540_100UF_16V_20%1
10uFNon-polarised capacitorC6, C7CAPC3216X140NCC1206_10UF_16V_10%_X7R2
100nFNon-polarised capacitorC8, C10, C13A, C13B, C13C, C13D, C20A, C20B, C20C, C20D, C21, C22A, C22B, C22C, C22D, C24A, C24B, C24C, C24D, C25, C26, C27, C29CAPC1005X55NCC0402_100NF_16V_10%_X5R, CC0402_100NF_16V_10%_X7R23
1nFNon-polarised capacitorC9CAPC1005X55NCC0402_1NF_50V_10%_X7R1
12pFNon-polarised capacitorC11CAPC1005X55NCC0402_12PF_50V_5%_C0G1
1uFNon-polarised capacitorC15A, C15B, C15C, C15D, C36A, C36B, C36C, C37A, C37B, C37CCAPC1608X87NCC0603_1UF_25V_10%_X7R10
100nFNon-polarised capacitorC16, C17, C28, C34A, C34B, C34C, C38A, C38B, C38C, C39A, C39B, C39C, C40A, C40B, C40C, C42A, C42B, C42C, C44A, C44B, C44C, C402CAPC0603X33NCC0201_100NF_6.3V_10%_X5R22
10nFNon-polarised capacitorC18, C19CAPC1005X55NCC0402_10NF_16V_10%_X7R2
zQSFP+QSFP+ 1x3 Cage (23Pins)Cage1TYCO_2170737-1TYCO_2170737-11
SFP+SFP+  1x4 Cage (46 Pins)Cage2TYCO_2007132-1TYCO_2007132-11
1888247-120 Position SFP+ Connector (Small Form-factor Pluggable)CON1A, CON1B, CON1C, CON1DTYCO_1888247-1TYCO_1888247-14
BAT165Schottky DiodeD1SOD2512X110NBAT1651
220R@100MHzInductorFB1A, FB1B, FB1C, FB1D, FB2A, FB2B, FB2C, FB3A, FB3B, FB3C, FB4A, FB4B, FB4C, FB5A, FB5B, FB5C, FB5DINDC2012X105NIND0805_MURATA_BLM21PG221SN1D17
RTM_FRONTPANELRTM FrontpanelFP1RTM_FRONTPANELRTM_FRONTPANEL1
Use only in PCBFiducial TargetFTG1, FTG2, FTG3, FTG4, FTG5, FTG6, FTG7, FTG8FIDUCIAL_TOP_S100-200FIDUCIAL_TARGET_S100-2008
MIC45116-1YMP0.8V to 85% PVIN (4.75-19V), 6A Synchronous Step-Down Regulator ModuleIC1MICROCHIP_H3QFN88-52LD-PL-3MIC45116-1YMP1
PCA9534PW8-Bit I2C-Bus and SMBus Low Power I/O Port with InterruptIC2A, IC2B, IC2C, IC3A, IC3B, IC3C, IC3DSOP65P640X110-16NPCA9534PW7
LM75AIMM/NOPBDigital Temperature Sensor and Thermal Watchdog with Two-Wire InterfaceIC4, IC6, IC8SOP65P490X109-8NLM75AIMM/NOPB3
AT24MAC402-XHM1.7V to 5.5V, I2C-Compatible (2-wire) 2-Kbit (256 x 8) Serial EEPROMIC10SOP65P640X120-8NAT24MAC402-XHM1
PCA9554DB8-bit I2C-bus SMBus I/O port with interruptIC14SOP65P640X120-16NPCA9554D1
MAX7357ETG+8-channel I2C-bus multiplexer with reset, INT and timeoutIC39HVQFN24IIC_MUX_MAX7357ETG+1
#NAME?Single Pin MaleJ1TYCO_1469265-1TYCO_1469265-11
Advanced TCAConnector 60 ATCA Male 30 Pairs (60 Signals) + 3x10 GroundJ2, J4TYCO_6469183-1TYCO_6469183-12
SMAJ3AMPHENOL_132203AMPHENOL_1322031
zQSFP+38Position QSFP Connector  (Quad Small Form-factor Pluggable)J5A, J5B, J5CTYCO_1551920-2TYCO_1551920-23
Hard Metric Type ZD90 Contacts, 6 Rows  (a,b,c,d,e,f) of 10 positions + 3 Shield Rows (ab, cd, ef) of 10 Positions, Pitch 2.5 mm,  Press-Fit, Right Angle ERmet ZD High Speed Differential Hard Metric Female ConnectorJ8ERNI_973028ERNI_9730281
LED_AVAGO_HSME-C120LED Green 1C 2ALD1A, LD1B, LD1C, LD3A, LD3B, LD3C, LD3DLED_AVAGO_HSME-C120LED_AVAGO_HSME-C1207
RedLED Red Avago C120LD2A, LD2B, LD2C, LD4A, LD4B, LD4C, LD4DLED_AVAGO_HSME-C120rev7
GreenLED Green Avago C120LDxLED_AVAGO_HSME-C120rev1
BlueLED Blue Avago C120LDyLED_AVAGO_HSME-C120rev1
LED0603-P-RW120 or LYN971-ZLED 0603 redLED17led_0603RLED_0603R1
Push ButtonPush-Button Switch SPDTPB1SW_C&K_HDT0001SW_C&K_HDT00011
7k5Resistor - 1%R1RESC1005X40NR0402_7K5_1%_0.0625W_100PPM1
100kResistor - 1%R2RESC1005X40NR0402_100K_1%_0.0625W_100PPM1
2k4Resistor - 1%R3RESC1005X40NR0402_2K4_1%_0.0625W_100PPM1
10kResistor - 1%R4, R5, R10A, R10B, R10C, R11A, R11B, R11C, R12A, R12B, R12C, R13A, R13B, R13C, R14, R15, R16, R17A, R17B, R17C, R25, R26, R28, R31, R32, R33, R34, R35, R36, R37A, R37B, R37C, R37D, R38A, R38B, R38C, R38D, R39A, R39B, R39C, R39D, R40A, R40B, R40C, R40D, R41A, R41B, R41C, R41D, R45, R46, R48, R74, R75, R316, R317, R318, R319, R320, R321, R322, R323, R324, R325, R326, R327, R328, R329, R330, R331, R332, R333, R334, R335, R336RESC1005X40NR0402_10K_1%_0.0625W_100PPM75
1k6Resistor - 1%R6RESC1005X40NR0402_1K6_1%_0.0625W_100PPM1
330Resistor - 1%R7, R8, R9, R18A, R18B, R18C, R29A, R29B, R29C, R42A, R42B, R42C, R42D, R43A, R43B, R43C, R43DRESC1608X55NR0603_330R_1%_0.1W_100PPM17
1MResistor - 1%R19, R20, R21, R22RESC3216X65NR1206_1M_1%_0.25W_100PPM4
0ResistorR23, R24, R27, R30, R44, R47, R73RESC1608X55NR0603_0R_JUMPER7
BSS138LT1GN-CHANNEL MOSFET WITH DIODET1, T2SOT95P240X110-3NBSS138LT1G2
TPTestpointTP1, TP2, TP3, TP4TPTP4
#NAME?50 Ohm 3 to 300MHz RF TransformersTR1XFMR_MINI-CIRCUITS_AT1521XFMR_MINI-CIRCUITS_TC2-1TX+1
重要提示:PCB作品文件展下载说明
  • 打卡总天数:400
  • 打卡总奖励:1334
  • 最近打卡:2025-11-20 23:18:22
69
社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
发表于 2019-7-13 19:55 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:44
  • 打卡总奖励:124
  • 最近打卡:2026-08-04 11:48:06
51
社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
发表于 2019-7-13 21:03 | 显示全部楼层
1元学习Allegro(1期)
发表于 2019-7-13 21:04 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:78
  • 打卡总奖励:262
  • 最近打卡:2026-04-21 17:03:37
终身成就奖社区居民优秀斑竹奖
发表于 2019-7-13 22:51 | 显示全部楼层
  • 打卡总天数:565
  • 打卡月天数:8
  • 打卡总奖励:1682
  • 最近打卡:2026-11-12 09:00:45
43
7万
发表于 2019-7-14 06:26 | 显示全部楼层
发表于 2019-7-14 08:28 | 显示全部楼层
发表于 2019-7-14 08:41 | 显示全部楼层
  • 打卡总天数:533
  • 打卡总奖励:1802
  • 最近打卡:2026-10-18 23:23:25
发表于 2019-7-14 08:56 | 显示全部楼层
  • 打卡总天数:690
  • 打卡月天数:10
  • 打卡总奖励:2858
  • 最近打卡:2026-11-11 19:51:00
81
发表于 2019-7-14 10:39 | 显示全部楼层
