查看: 14489|回复: 78
[Allegro16.6以下] XC7K325TFBG676_FBG676 +88E1111-BAB1I000+ISL6539IA 做的工业通信板PCB文
1元学习PADS(3期)
发表于 2019-7-17 18:53 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BT1BATTERY_0_BR1225HC_TS518FE FL35TS518FE FL35EBR1225HC
CD1CAP_POL_4_STC7343_220UF220uFSTC7343
CD2CAP_POL_4_STC7343_220UF220uFSTC7343
CD3CAP_POL_4_STC7343_220UF220uFSTC7343
CD4CAP_POL_STC3528_47UF47uFSTC3528
CD5CAP_POL_STC3528_47UF47uFSTC3528
CD11CAP_POL_STC3528_47UF47uFSTC3528
CD12CAP_POL_4_STC7343_220UF220uFSTC7343
CD13CAP_POL_4_STC7343_220UF220uFSTC7343
CD14CAP_POL_4_STC7343_220UF220uFSTC7343
CD15CAP_POL_STC3528_47UF47uFSTC3528
CD16CAP_POL_STC3528_10UF/16V10UF/16VSTC3528
CD17CAP_POL_STC3528_220UF220uFSTC3528
CD18CAP_POL_STC3528_220UF220uFSTC3528
CD19CAP_POL_STC3528_220UF220uFSTC3528
CD20CAP_POL_STC3528_220UF220uFSTC3528
CD21CAP_POL_STC3528_220UF220uFSTC3528
CD22CAP_POL_STC3528_220UF220uFSTC3528
CD23CAP_POL_STC3528_220UF220uFSTC3528
CD24CAP_POL_STC3528_10UF/16V10UF/16VSTC3528
CD25CAP_POL_STC3528_10UF/16V10UF/16VSTC3528
CD26CAP_POL_STC7343_470UF/6V470UF/6VSTC7343
CD27CAP_POL_STC7343_470UF/6V470UF/6VSTC7343
CD28CAP_POL_STC7343_470UF/6V470UF/6VSTC7343
CD29CAP_POL_STC7343_470UF/6V470UF/6VSTC7343
CD30CAP_POL_STC3528_4.7UF/16V4.7UF/16VSTC3528
CD31CAP_POL_STC3528_10UF/16V10UF/16VSTC3528
CD32CAP_POL_STC3528_10UF/16V10UF/16VSTC3528
CD33CAP_POL_STC7343_470UF/6V470UF/6VSTC7343
CD34CAP_POL_STC7343_470UF/6V470UF/6VSTC7343
CD35CAP_POL_STC7343_470UF/6V470UF/6VSTC7343
CD36CAP_POL_STC7343_470UF/6V470UF/6VSTC7343
CD37CAP_POL_STC3528_4.7UF/16V4.7UF/16VSTC3528
CD38CAP_POL_STC7343_220UF220uFSTC7343
CD39CAP_POL_STC7343_220UF220uFSTC7343
CD40CAP_POL_STC7343_220UF220uFSTC7343
CD41CAP_POL_STC7343_220UF220uFSTC7343
CD42CAP_POL_STC7343_220UF220uFSTC7343
CD43CAP_POL_STC7343_220UF220uFSTC7343
CD44CAP_POL_STC7343_220UF220uFSTC7343
CD45CAP_POL_STC7343_220UF220uFSTC7343
CD46CAP_POL_STC7343_220UF220uFSTC7343
CD47CAP_POL_STC7343_220UF220uFSTC7343
CD48CAP_POL_STC7343_220UF220uFSTC7343
CD49CAP_POL_STC7343_220UF220uFSTC7343
CD50CAP_POL_1_STC7343_47UF/25V47UF/25VSTC7343
D2DIODE SCHOTTKY_0_DIODE_SS14SS14DIODE
D4DIODE SCHOTTKY_2_SD1206_MBR0520MBR0520SD1206
D5DIODE SCHOTTKY_3_SD1714_IR_30BQIR_30BQ015SD1714
D6DIODE SCHOTTKY_2_SD1206_MBR0520MBR0520SD1206
D7DIODE SCHOTTKY_3_SD1714_IR_30BQIR_30BQ015SD1714
D8BAT54C_SOT23_SOT23_BAT54CWBAT54CWSOT23
D9BAT54C_SOT23_SOT23_BAT54CWBAT54CWSOT23
D10BAT54C_SOT23_SOT23_BAT54CWBAT54CWSOT23
D11BAT54C_SOT23_SOT23_BAT54CWBAT54CWSOT23
D14DIODE SCHOTTKY_0_DL4148_DL4148DL4148 100VDL4148
D15DIODE SCHOTTKY_0_MM3Z2V7B_MM3Z2MM3Z2V7B 2.7VMM3Z2V7B
F1FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020F1206
F2FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020F1206
F5FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020F1206
F6FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020F1206
J1JTAG_JTAG_JTAGJTAGJTAG
J11FAN3_1_FAN3P_FANFANFAN3P
J12HDR 1X9_HDR1X9_HDR 1X9HDR 1X9HDR1X9
J13HDR 1X9_HDR1X9_HDR 1X9HDR 1X9HDR1X9
JP1HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP2HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP3HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP4HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP5HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP6HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP7HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP8HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP9HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP10HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP11HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP12HEADER_0_DIP2-79-160_1X21X2DIP2-79-160
JP13FAN3_0_2X5P_UARTUART2X5P
JP14FAN3_0_2X5P_UARTUART2X5P
JP15J31X31X3_2
JP16J31X31X3_2
JP17J31X31X3_2
JP18J31X31X3_2
JP19J31X31X3_2
JP20J31X31X3_2
JP21J31X31X3_2
JP22J31X31X3_2
L1INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525
L2INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525
L3INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525
L4INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525
L5INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525
L6INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525
LED1LED_32_LED0805_LED_GREENLED_GreenLED0805
LED2LED_32_LED0805_LED_GREENLED_GreenLED0805
LED3LED_32_LED0805_LED_GREENLED_GreenLED0805
LED4LED_32_LED0805_LED_GREENLED_GreenLED0805
LED5LED_32_LED0805_LED_GREENLED_GreenLED0805
LED6LED_32_LED0805_LED_GREENLED_GreenLED0805
LED7LED_32_LED0805_LED_GREENLED_GreenLED0805
LED8LED_32_LED0805_LED_GREENLED_GreenLED0805
LED9LED_32_LED0805_LED_GREENLED_GreenLED0805
LED10LED_32_LED0805_LED_GREENLED_GreenLED0805
LED11LED_32_LED0805_LED_GREENLED_GreenLED0805
LED12LED_32_LED0805_LED_GREENLED_GreenLED0805
LED13LED_32_LED0805_LED_GREENLED_GreenLED0805
LED14LED_32_LED0805_LED_GREENLED_GreenLED0805
LED17LED_32_LED0805_LED_GREENLED_GreenLED0805
LED18LED_LED0805_LEDLEDLED0805
LED19LED_LED0805_LEDLEDLED0805
LED20LED_LED0805_LEDLEDLED0805
LED21LED_LED0805_LEDLEDLED0805
LED22LED_32_LED0805_LED_GREENLED_GreenLED0805
Q1MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYSOP8-50-244
Q2MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYSOP8-50-244
Q3MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYSOP8-50-244
Q4MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYSOP8-50-244
Q5MOSFET_N_TO252_AOD452AOD452TO252
Q6MOSFET_N_TO252_AOD452AOD452TO252
Q7MOSFET_N_TO252_AOD452AOD452TO252
Q8MOSFET_N_TO252_AOD452AOD452TO252
Q9MOSFET_N_TO252_AOD452AOD452TO252
Q10MOSFET_N_TO252_AOD452AOD452TO252
Q11MOSFET_N_TO252_AOD452AOD452TO252
Q12MOSFET_N_TO252_AOD452AOD452TO252
Q39MOSFET_N_NDS331N_NDS331N 460MWNDS331N 460MWNDS331N
Q402020000600_0_NDT3055L_NDT3055LNDT3055L 1.3WNDT3055L
R262R-0603_1_R2512_0.005,1%0.005,1%R2512
R280R-0603_1_R2512_0.005,1%0.005,1%R2512
SW1FPGA SEL SWITCH_2_SDA05H1SBD_SDSDA05H1SBDSDA05H1SBD
TP1TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
TP2TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
TP3TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
TP4TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
TP5TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
TP6TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
TP7TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
TP8TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
TP9TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68
U1CPCI1_M_PHM0625A-T_CPCI1_MCPCI1_MPHM0625A-T
U2SN74AVC4T245_D_0_D16_VALUEValueD16
U3SN74AVC4T245_D_0_D16_VALUEValueD16
U4SN74AVC4T245_D_0_D16_VALUEValueD16
U5SN74AVC4T245_D_0_D16_VALUEValueD16
U6SN74AVC4T245_D_0_D16_VALUEValueD16
U8SN74AVC32T245_ZKE_0_ZKE96_VALUEValueZKE96
U10CPCI4_M_6_PHM0625A-T_CPCI4_MCPCI4_MPHM0625A-T
U11CPCI5_M_5_PHM0622B-T_CPCI5_MCPCI5_MPHM0622B-T
U1288E1111_TFBGA117_88E1111-BAB1I088E1111-BAB1I000TFBGA117
U13MAX3243_0_SSOP28_MAX3243EAIMAX3243EAISSOP28
U14MAX3243_0_SSOP28_MAX3243EAIMAX3243EAISSOP28
U1574LV14DB_SOP14-26-173_SN74HC14PSN74HC14PWSOP14-26-173
U16MAX485_1_SOP8-50-150_MAX485ESAMAX485ESASOP8-50-150
U17MAX485_1_SOP8-50-150_MAX485ESAMAX485ESASOP8-50-150
U18MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDSOP14-50-150
U19MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDSOP14-50-150
U20MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150
U21MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150
U22MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150
U23MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150
U24LSF0204PWR_0_PW0014A_N_VALUEValuePW0014A_N
U25SN74AVC4T245_D_0_D16_VALUEValueD16
U26SN74AVC4T245_D_0_D16_VALUEValueD16
U27SN74AVC4T245_D_0_D16_VALUEValueD16
U5088E1111_TFBGA117_88E1111-BAB1I088E1111-BAB1I000TFBGA117
U51PC28F00AP30TF_BGA64_8X10MM_BGA6BGA64_8X10MMBGA64_8X10MM
U52N25Q128_SO16_SO16_SPI_FLASHSPI_FLASHSO16
U54SN74LVC1T45_DVB_0_DVB_SN74LVC1TSN74LVC1T45DVB
U55XC7K325TFBG676_FBG676_(S1+S2+S3xc7k325tfbg676FBG676
U56IS62WV20488BLL_0_IS62WV20488BLLIS62WV20488BLLIS62WV20488BLL
U57LTC1736_SOP24-26-208_LTC1736IGLTC1736IGSOP24-26-208
U58ISL80102_0_DFN10-3X3_ISL80103IRISL80103IRAJZDFN10-3X3
U59ISL80102_0_DFN10-3X3_ISL80103IRISL80103IRAJZDFN10-3X3
U60LTC1736_SOP24-26-208_LTC1736IGLTC1736IGSOP24-26-208
U61ISL6539_SSOP28_150_ISL6539IAISL6539IASSOP28_150
U62ISL6539_SSOP28_150_ISL6539IAISL6539IASSOP28_150
U63H5020_0_TFM48-40-300_HX5020NLHX5020NLTFM48-40-300
U64MAX3243_0_SSOP28_MAX3243EAIMAX3243EAISSOP28
U65MAX3243_0_SSOP28_MAX3243EAIMAX3243EAISSOP28
U6674LV14DB_SOP14-26-173_SN74HC14PSN74HC14PWSOP14-26-173
U67MAX485_1_SOP8-50-150_MAX485ESAMAX485ESASOP8-50-150
U68MAX485_1_SOP8-50-150_MAX485ESAMAX485ESASOP8-50-150
U69MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDSOP14-50-150
U70MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDSOP14-50-150
U71MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150
U72MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150
U73MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150
U74MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150
U75PCA82C250_2_SOT96-1_PCA82C250PCA82C250SOT96-1
U76PCA82C250_2_SOT96-1_PCA82C250PCA82C250SOT96-1
U77DIGILENT_USB_JTAG_2_DIGILENT_USDIGILENT_USB_JTAGDIGILENT_USB_JTAG
U78SN74AVC2T245_RSW_1_RSW10_VALUEValueRSW10
U79SN74LVC1T45_DVB_1_DVB_SN74LVC1TSN74LVC1T45DVB
U81ADP123AUJZ_R7_0_UJ_5_VALUEValueUJ_5
U82SN74LVC1G18DBVR_SOT23_6_SOT23_6SOT23_6SOT23_6
U83LSF0108PWR_PW0020A_VALUEValuePW0020A
U84LSF0108PWR_PW0020A_VALUEValuePW0020A
U85LSF0108PWR_PW0020A_VALUEValuePW0020A
U86LSF0108PWR_PW0020A_VALUEValuePW0020A
Y1XTAL_0_X53F_XVHEELNANF-25MHZXVHEELNANF-25MHZX53F
Y2XTAL_0_X53F_XVHEELNANF-25MHZXVHEELNANF-25MHZX53F
Y3SIT9102_0_SIT9102_SIT9102SIT9102SIT9102
Y4OSC_OSC4-XO53_OCJTDLJANF-125MHZOCJTDLJANF-125MHZ NCOSC4-XO53
Y5OSC_OSC4-XO53_OCJTDLJANF-66MHZOCJTDLJANF-66MHZOSC4-XO53
Y7OSC_OSC4-XO53_OVETDLJANF-33MHZOVETDLJANF-33MHZOSC4-XO53
重要提示:PCB作品文件展下载说明
42
1元学习PADS(3期)
 楼主| 发表于 2019-7-17 18:54 | 显示全部楼层
XC7K325TFBG676.7z
1.64 MB, 下载次数: 121, 下载积分:金币 -5 枚
点评
https://bbs.ntpcb.com/static/image/smiley/wangwang/34.gif  详情 回复 发表于 2026-7-21 11:17
  • 打卡总天数:125
  • 打卡总奖励:378
  • 最近打卡:2026-02-25 09:00:15
终身成就奖社区居民特殊贡献奖原创先锋奖
发表于 2019-7-18 06:55 | 显示全部楼层
  • 打卡总天数:566
  • 打卡月天数:9
  • 打卡总奖励:1684
  • 最近打卡:2026-11-13 09:23:17
43
7万
发表于 2019-7-18 07:57 | 显示全部楼层
  • 打卡总天数:1
  • 打卡总奖励:2
  • 最近打卡:2025-09-26 18:52:36
263
发表于 2019-7-18 08:26 | 显示全部楼层
大功率碳化硅逆变器 qq2536791790
  • 打卡总天数:484
  • 打卡总奖励:1657
  • 最近打卡:2025-11-20 23:52:59
发表于 2019-7-18 08:51 | 显示全部楼层
终身成就奖原创先锋奖
发表于 2019-7-18 08:53 | 显示全部楼层
社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
发表于 2019-7-18 08:55 | 显示全部楼层
  • 打卡总天数:888
  • 打卡月天数:15
  • 打卡总奖励:3000
  • 最近打卡:2026-11-15 10:32:22
23
  • 打卡总天数:2
  • 打卡总奖励:11
  • 最近打卡:2025-05-11 09:52:16
发表于 2019-7-18 09:02 | 显示全部楼层
