重要提示:PCB作品文件展下载说明
| Name | Part Type | PCB Decal | Value | | BT1 | BATTERY_ELEM | BAT\CR2032-4-2 | CR2032 | | CON1 | HEADER_2X20_0 | HEADER10X2\BOX | JTAG ICE | | CON2 | POWER_JACK | POWRJACK\3P | DC-PLUG | | CON3 | AXA2R63061_0 | AXA2R63021 | eMMC Card | | CON4 | AXA2R63061_1 | AXA2R63021 | SD Card | | CON5 | CON2 | HEADER_2X1_2.54MM | IIC Mode | | CON6 | CON2 | HEADER_2X1_2.54MM | AUXi | | CON7 | CON2 | HEADER_2X1_2.54MM | NANDMLC | | CON8 | CON2 | HEADER_2X1_2.54MM | Spko | | CON9 | CON2 | HEADER_2X1_2.54MM | AUXo | | CON10 | CON4A | HEADER_2X2_2.54MM | CAN0/1 | | CON11 | PJK-691_0 | PJK-691 | EARPhone | | CON12 | CON12A | HEADER_2X6_2.54MM | PD[0:7] | | CON13 | CON20A | HEADER_2X10_2.54MM | PC[0:14] | | CON14 | CON20A | HEADER_2X10_2.54MM | PB[0:15] | | CON15 | CON24A | HEADER_2X12_2.54MM | CMOS Sensor | | CON16 | CON10A | HEADER_2X5_2.54MM | PJ[0:4] | | CON17 | CON6A_1 | HEADER_2X3_2.54MM | PG[4:5] | | CON18 | RJ45_SHLD_0 | RJ45\8P\JA\LED | RJ-45 8P8C_LED R/A | | CON19 | CON8A | HEADER_2X4_2.54MM | PH[0:3] | | CON20 | CON4 | USB4P_ATYPE | USB | | CON21 | CON20A | HEADER_2X10_2.54MM | PE[0:15] | | CON22 | CON20A | HEADER_2X10_2.54MM | PI[0:15] | | CON23 | CON40A_0 | M_DIN_32X2/2.54A | LCD | | CON24 | USB_TYPE_B_3 | MINI_5P_B_TYPE | USB miniAB RECEP. | | CON25 | CON16A | HEADER_2X8_2.54MM | PH[4:15] | | CON26 | CON40A | HEADER_2X20_2.54MM | EBI | | CON27 | CON16A | HEADER_2X8_2.54MM | PF[0:10] | | CON28 | CON8A_2 | HEADER_2X4_2.54MM | PG[0:3] | | CON29 | CON8A | HEADER_2X4_2.54MM | ADC[0:7] | | CON30 | CON8A | HEADER_2X4_2.54MM | PF[11:14] | | CON31 | HEADER_6_0 | SIM-CARD | SIM CARD SLOT | | CON32 | CON12A | HEADER_2X6_2.54MM | PD[8:15] | | CON33 | CON20A | HEADER_2X10_2.54MM | PA[0:15] | | CON34 | CON10A_1 | HEADER_2X5_2.54MM | PG[10:14] | | CON35 | CON8A_3 | HEADER_2X4_2.54MM | PG[6:9] | | CON36 | CON4A | HEADER_2X2_2.54MM | CON4A | | CON37 | CONNECTOR_DB9_0 | DB9_FMALE | UART1 | | CON38 | CONNECTOR_DB9_0 | DB9_FMALE | UART2 | | CON39 | CONNECTOR_DB9_0 | DB9_FMALE | UART0 | | CON40 | CONNECTOR_DB9_0 | DB9_FMALE | UART3 | | CON41 | CONNECTOR_DB9_0 | DB9_FMALE | UART4 | | CT1 | CAP_NP | C0603 | 10uF | | D2 | ZENAR_0 | SOD-523 | RB521S-30 | | J2 | CON2 | HEADER_2X1_2.54MM | Vin | | K6 | SW-S | STS-B5 | Enter | | L1 | INDUCTOR_IRON | SMTDR43 | 4.7uH | | L2 | INDUCTOR_IRON | SMTDR43 | 4.7uH | | L3 | INDUCTOR | L0603 | 1608-221T | | L4 | INDUCTOR_IRON | SMTDR43 | 4.7uH | | L5 | INDUCTOR | L0603 | 1608-221T | | LED10 | LED | LED_0603 | LED_R | | M1 | MICROPHONE_0 | 9.7D2.54MM | MIC | | M2 | MICROPHONE_0 | 9.7D2.54MM | MIC | | PAD1 | 1PAD | 1PAD_1.25X1.25MM | eMWP | | PAD2 | 1PAD | 1PAD_1.25X1.25MM | SDWP | | PAD3 | 1PAD | 1PAD_1.25X1.25MM | N_Pre | | Q1 | NPN_1 | SOT23-BEC | 2N3904 | | Q2 | NPN_1 | SOT23-BEC | 2N3904 | | Q3 | SI2303CDS_1 | SOT23-GSD | SI2303CDS | | Q4 | NPN_1 | SOT23-BEC | 2N3904 | | Q5 | NPN_1 | SOT23-BEC | 2N3904 | | Q6 | SI2303CDS_1 | SOT23-GSD | SI2303CDS | | Q7 | SI2303CDS_1 | SOT23-GSD | SI2303CDS | | SW2 | SW-S | STS-B5 | RTC Key | | SW3 | SW_DIP-5 | DIPSWX5_2.54MM | NANDD[0:4] | | SW4 | SW-S | STS-B5 | WDTRst | | SW5 | SW-3PAD2 | 3P-1.2MM | PSL | | SW6 | SW_DIP-5 | DIPSWX5_2.54MM | ICE | | SW7 | SW_DIP-5 | DIPSWX5_2.54MM | NANDD[5:7]/Ctrl | | SW8 | SW_DIP-6 | DIPSWX6_2.54MM | SPI | | SW9 | SW2PHS | 2P-1.2MM | VD33 | | SW10 | SW2PHS | 2P-1.2MM | VD18 | | SW11 | SW_DIP-6_1 | DIPSWX6_2.54MM | eMMC | | SW12 | SW2PHS | 2P-1.2MM | VD12 | | SW13 | SW_DIP-5 | DIPSWX5_2.54MM | NANDCtrl | | SW14 | SW_DIP-8 | DIPSWX8_2.54MM | SD | | SW15 | SW_DIP-8 | DIPSWX8_2.54MM | IIS | | SW17 | SW_DIP-4_0 | DIPSWX4_2.54MM | CAN Bus0/1 | | SW18 | SW_DIP-4_0 | DIPSWX4_2.54MM | PWM | | SW19 | SW_DIP-6_1 | DIPSWX6_2.54MM | CAN 0/1 Cfg | | SW20 | SW_DIP-6_1 | DIPSWX6_2.54MM | LCDCtrl | | SW21 | SW_DIP-5_0 | DIPSWX5_2.54MM | Ethernet | | SW22 | SW_DIP-8_0 | DIPSWX8_2.54MM | CMOSD[2:7]/IIC | | SW23 | SW_DIP-8_0 | DIPSWX8_2.54MM | LCDD[16:23] | | SW24 | SW_DIP-8_0 | DIPSWX8_2.54MM | CMOSCtrl/D[0:1] | | SW25 | SW_DIP-8_0 | DIPSWX8_2.54MM | LCDD[8:15] | | SW26 | SW_DIP-5_0 | DIPSWX5_2.54MM | KPI | | SW27 | SW_DIP-4_0 | DIPSWX4_2.54MM | EBIAdd[8:9]/Ctrl | | SW28 | SW_DIP-8_0 | DIPSWX8_2.54MM | EBICtrl | | SW29 | SW_DIP-8_0 | DIPSWX8_2.54MM | LCDD[0:7] | | SW30 | SW_DIP-4 | DIPSWX4_2.54MM | USB P_Ctrl | | SW31 | SW_DIP-5 | DIPSWX5_2.54MM | Cfg[0:4] | | SW32 | SW_DIP-8_0 | DIPSWX8_2.54MM | EBID[0:7] | | SW33 | SW_DIP-8_0 | DIPSWX8_2.54MM | EBIAdd[0:7] | | SW34 | SW_DIP-4 | DIPSWX4_2.54MM | USB P_Ind | | SW35 | SW_DIP-5 | DIPSWX5_2.54MM | Cfg[5:9] | | SW36 | SW_DIP-5_0 | DIPSWX5_2.54MM | LCD Touch | | SW37 | SW_DIP-5 | DIPSWX5_2.54MM | SIM Card | | SW38 | SW_DIP-5_0 | DIPSWX5_2.54MM | Ethernet | | SW39 | SW_DIP-8_0 | DIPSWX8_2.54MM | EBID[8:15] | | SW40 | SW_DIP-4_0 | SDS-8 | UART1 | | SW41 | SW_DIP-4_0 | SDS-8 | UART2 | | SW42 | SW_DIP-4_0 | DIPSWX4_2.54MM | UART0 | | SW43 | SW_DIP-4_0 | SDS-8 | UART3 | | SW44 | SW_DIP-4_0 | SDS-8 | UART4 | | U1 | APL3203A_1 | TDFN2X2-8 | APL3203A | | U3 | ZT7103S_0 | TSOT-25 | ZT7103T | | U4 | ZT7103S_0 | TSOT-25 | ZT7103T | | U6 | W55X10_2 | SOIC8_208 | W55X16 | | U7 | W25Q128BV_4 | SOIC16_300 | W25Q128BV | | U8 | ZT7103S_0 | TSOT-25 | ZT7103T | | U9 | NAND_4-8G_0 | TSOP48-0.5MM | NAND Flash | | U10 | NAU8501 | QFN32L_5X5MM\0.5MM_PITCH | NCU8822L | | U11 | SN65HVD230 | SO-8-1.27X5.4M | SN65HVD230 | | U12 | SN65HVD230 | SO-8-1.27X5.4M | SN65HVD230 | | U13 | PE-68515_1 | ST6200T | TS8121C | | U14 | IP101GA_0 | QFN32 | IP101GR | | U15 | NUC970_1 | LQFP-216 | NUC970 | | U16 | NCT3520W-H10 | MSOP-8 | NCT3520W-H10 | | U17 | NCT3520W-H10 | MSOP-8 | NCT3520W-H10 | | U18 | ADM232_1 | SOP16/150 | TRS3232EC | | U19 | ADM232_1 | SOP16/150 | TRS3232EC | | U20 | ADM232_1 | SOP16/150 | TRS3232EC | | U21 | ADM232_1 | SOP16/150 | TRS3232EC | | U22 | ADM232_1 | SOP16/150 | TRS3232EC | | UX? | TPS61161_0 | SOT23-5 | NCT3705U-A | | X1 | CRYSTAL_SMD_2 | SOT-143 | 25MHz | | X2 | CRYSTAL_SMD_2 | TXC7M-3.2X2.5MM | 12MHz | | X3 | MA306/SM_2 | XTAL_2P/1.5MM | TXC-9H T9 SMD 32.768KHz 30ppm |
重要提示:PCB作品文件展下载说明
