| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| C1 | CP_1_CAPC2-98-248A_220UF | 220UF | CAPC2-98-248A |
| C2 | CP_1_SCAPC2-0808C_220UF | 220UF | SCAPC2-0808C |
| D1 | DZ3_0_SD1710A_DZ3 | DZ3 | SD1710A |
| D2 | D2-3_D_0_SOT23_D2-3_D | D2-3_D | SOT23 |
| D10 | RCLAMP3346P_0_BCC7-080-0301L_RC | RCLAMP3346P | BCC7-080-0301L |
| D15 | LED_0_SD0805-LED_LED | LED | SD0805-LED |
| D17 | LED_0_SD0805-LED_LED | LED | SD0805-LED |
| D22 | DZ3_0_SD1714D_DZ3 | DZ3 | SD1714D |
| D24 | D_A_0_HSOD323A_D_A | D_A | HSOD323A |
| D25 | D_A_0_HSOD323A_D_A | D_A | HSOD323A |
| D44 | DZ_L_0_HSOD882_DZ_L | DZ_L | HSOD882 |
| D45 | DZ_L_0_HSOD882_DZ_L | DZ_L | HSOD882 |
| D49 | DIODEPIN_SD1710A_DIODE PIN | DIODE PIN | SD1710A |
| D54 | LED_0_SD0805-LED_LED | LED | SD0805-LED |
| D55 | LED_0_SD0805-LED_LED | LED | SD0805-LED |
| D56 | LED_0_SD0805-LED_LED | LED | SD0805-LED |
| F1 | FUSE2_0_SF6127_FUSE2 | FUSE2 | SF6127 |
| FB1 | BEAD0805_0805-FB_220R/100MHZ | 220R/100MHz | 0805-FB |
| ID1 | PCB_MARKPOINT | ID-BOARD | ID-BOARD |
| J6 | USB-9S2_A_0_USB9-200-1516_USB-9 | USB-9S2_A | USB9-200-1516 |
| J10 | USB-4S4_2_CON90RS2R50-4TM_USB-4 | USB-4S4 | CON90RS2R50-4TM |
| J11 | MJ8-SL_1_MJ8-SRLFY_MJ8-SL | MJ8-SL | MJ8-SRLFY |
| J12 | PWC3_A_2_PWC0103-M-C_PWC3_A | PWC3_A | PWC0103-M-C |
| J33 | DB19S4_2_MOLEX_47151_DB19S4 | DB19S4 | MOLEX_47151 |
| J34 | DB19S4_3_MOLEX_47151_DB19S4 | DB19S4 | MOLEX_47151 |
| J35 | WBC1X4-M2_3_6PIN-20_6PIN-2.0 | 6PIN-2.0 | 6PIN-20 |
| J36 | WBC1X4-M2_3_6PIN-20_6PIN-2.0 | 6PIN-2.0 | 6PIN-20 |
| J37 | WBC1X4-M2_3_6PIN-20_6PIN-2.0 | 6PIN-2.0 | 6PIN-20 |
| J39 | CON4X1X254MM_4PIN-20_CON4X1X2MM | CON4X1X2MM | 4PIN-20 |
| J40 | CON4X1X254MM_4PIN-20_CON4X1X2MM | CON4X1X2MM | 4PIN-20 |
| J41 | WBC1X4-M2_3_6PIN-20_6PIN-2.0 | 6PIN-2.0 | 6PIN-20 |
| J42 | CON4X1X254MM_4PIN-20_CON4X1X2MM | CON4X1X2MM | 4PIN-20 |
| J43 | CON4X1X254MM_4PIN-20_CON4X1X2MM | CON4X1X2MM | 4PIN-20 |
| J45 | DB19S4_3_MOLEX_47151_DB19S4 | DB19S4 | MOLEX_47151 |
| J46 | DB19S4_3_MOLEX_47151_DB19S4 | DB19S4 | MOLEX_47151 |
| L1 | L_1_SPL0505H_4.7U | 4.7U | SPL0505H |
| L2 | L_1_SPL0505H_4.7U | 4.7U | SPL0505H |
| L3 | L_1_SPL0505H_4.7U | 4.7U | SPL0505H |
| L4 | L_1_SPL0404B_1UH | 1UH | SPL0404B |
| L8 | L_1_HSL1008_2.2UH | 2.2UH | HSL1008 |
| L9 | L_1_SPL0404L_2.2UH | 2.2UH | SPL0404L |
| L18 | L_1_SPL0707G_2.2UH | 2.2UH | SPL0707G |
| L19 | L_252012_2.2UH/1A | 2.2UH/1A | 252012 |
| L20 | L_252012_2.2UH/1A | 2.2UH/1A | 252012 |
| L21 | L_1_SPL0505H_4.7U | 4.7U | SPL0505H |
| OSC1 | 25MHZ_HSX4-0302B_25MHZ | 25MHZ | HSX4-0302B |
| Q4 | MOSFETP_SOT23_2N7002P | 2N7002P | SOT23 |
| RN17 | RND8-4_2_SRN8-0804_22 | 22 | SRN8-0804 |
| RN18 | RND8-4_2_SRN8-0804_22 | 22 | SRN8-0804 |
| S1 | DSW2_0_DSW4-L_DSW2 | DSW2 | DSW4-L |
| S2 | MSW4_2_SSW-PUSH_MSW4 | MSW4 | SSW-PUSH |
| T1 | G2401CE_0_STFM24-40-280_G2401CE | G2401CE | STFM24-40-280 |
| T2 | RCLAMP0524P_DFN2510P10E_AZ1045_ | NC/RCLAMP0524P | DFN2510P10E_AZ1045 |
| T3 | RCLAMP0524P_DFN2510P10E_AZ1045_ | NC/RCLAMP0524P | DFN2510P10E_AZ1045 |
| T4 | RCLAMP0524P_DFN2510P10E_AZ1045_ | NC/RCLAMP0524P | DFN2510P10E_AZ1045 |
| T5 | RCLAMP0524P_DFN2510P10E_AZ1045_ | NC/RCLAMP0524P | DFN2510P10E_AZ1045 |
| TS1 | TEST_0_GND12_TEST | TEST | GND12 |
| U1 | TPS2551DRVR_0_MLF6-065-0202L_TP | TPS2551DRVR | MLF6-065-0202L |
| U2 | TPS2551DRVR_0_MLF6-065-0202L_TP | TPS2551DRVR | MLF6-065-0202L |
| U3 | 24C02_SOP8-50-150_24C02 | 24C02 | SOP8-50-150 |
| U4 | AZ1045-04F_0_DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 |
| U5 | SPI_NAND_FLASH_0_WSON8-MX25L128 | NC | WSON8-MX25L12835ZN |
| U7 | ADM706SAR_1_SOP8-50-150_ADM706S | ADM706SAR | SOP8-50-150 |
| U10 | MP2316_0_QFN14-20-0302-MV_MP231 | MP2316 | QFN14-20-0302-MV |
| U11 | PWR1-2_0_SBAT2-13A_PWR1-2 | PWR1-2 | SBAT2-13A |
| U12 | HI3531D_M2_3_BGA805-32-3333_HI3 | HI3531D_M2 | BGA805-32-3333 |
| U13 | MP1494S_0_TSOT23-8_MP1494S | MP1494S | TSOT23-8 |
| U14 | SII9022_0_QFN-72_SII9022 | SII9022 | QFN-72 |
| U15 | MT41J256M16RE-15E-D_0_BGA96-32- | MT41J256M16RE-15E-D | BGA96-32-1609M |
| U16 | MP1494S_0_TSOT23-8_MP1494S | MP1494S | TSOT23-8 |
| U17 | MP1494S_0_TSOT23-8_MP1494S | MP1494S | TSOT23-8 |
| U18 | AZC199-04S_0_SOT23-6L_AZC199-04 | AZC199-04S | SOT23-6L |
| U19 | AZC199-04S_0_SOT23-6L_AZC199-04 | AZC199-04S | SOT23-6L |
| U21 | MAX3485E_0_SOP8-50-150_MAX3485E | MAX3485E | SOP8-50-150 |
| U22 | MT29F2G08ABAEAWP_0_SOP48-20-720 | MT29F2G08ABAEAWP | SOP48-20-720 |
| U23 | SN74LVC1G125Q-Q1_1_HSOT-SC70-DC | SN74LVC1G125Q-Q1 | HSOT-SC70-DCK |
| U28 | AZ1045-04F_0_DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 |
| U31 | RTL8211EG_0_QFN64-050-0909LH_RT | RTL8211EG_1 | QFN64-050-0909LH |
| U32 | AZ1045-04F_0_DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 |
| U33 | AZ1045-04F_0_DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 |
| U37 | MT41J256M16RE-15E-D_0_BGA96-32- | MT41J256M16RE-15E-D | BGA96-32-1609M |
| U38 | MT41J256M16RE-15E-D_0_BGA96-32- | MT41J256M16RE-15E-D | BGA96-32-1609M |
| U39 | MT41J256M16RE-15E-D_0_BGA96-32- | MT41J256M16RE-15E-D | BGA96-32-1609M |
| U40 | MP2161GJ_0_TSOT23-8_MP2161GJ | MP2161GJ | TSOT23-8 |
| U43 | MP2326_0_QFN14-20-0302-MV_MP232 | MP2326 | QFN14-20-0302-MV |
| U44 | LT8619B_0_IT6801_IT6801 | IT6801 | IT6801 |
| U45 | PST597NR_3_SOT23-5_TD6817 | TD6817 | SOT23-5 |
| U46 | AT24C08_AT24C08_SOIC8_AT24C02/N | AT24C02/NC | AT24C08_SOIC8 |
| U47 | PST597NR_3_SOT23-5_TD6817 | TD6817 | SOT23-5 |
| U48 | PST597NR_0_SOT23-5_TPS2061 | TPS2061 | SOT23-5 |
| U50 | LT8619B_0_IT6801_IT6801 | IT6801 | IT6801 |
| U53 | AT24C08_AT24C08_SOIC8_AT24C02/N | AT24C02/NC | AT24C08_SOIC8 |
| U54 | AZ1045-04F_0_DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 |
| U55 | J18_1_MINI_PCIE_CONNECTOR_MINIS | minisata | MINI_PCIE_CONNECTOR |
| U56 | CS5340_TSSOP16_ES7240 | ES7240 | TSSOP16 |
| U57 | MP1494S_0_TSOT23-8_MP1494S | MP1494S | TSOT23-8 |
| U58 | CS4344_0_CS4344_TSSOP10_CS4344 | CS4344 | CS4344_TSSOP10 |
| U59 | PST597NR_0_SOT23-5_TPS2061 | TPS2061 | SOT23-5 |
| X2 | X_B_0_HSX4-0302_24MEG | 24MEG | HSX4-0302 |
| X3 | X_0_HSX2-0302_32.768KHZ | 32.768KHZ | HSX2-0302 |
| Y1 | CRYSTAL_4PIN_CRY_3225_27MHZ | 27MHz | CRY_3225 |
| Y2 | CRYSTAL_4PIN_CRY_3225_27MHZ | 27MHz | CRY_3225 |
