| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | 82401646_WURTH_MSOP8_82401646 | 82401646 | WURTH_MSOP8 |
| D2 | 82401646_WURTH_MSOP8_82401646 | 82401646 | WURTH_MSOP8 |
| D3 | LED_WURTH_1_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D4 | LED_WURTH_1_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D5 | LED_WURTH_1_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D6 | LED_WURTH_1_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D7 | LED_WURTH_1_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D8 | LED_WURTH_1_LED_0603_GREEN_LED | GREEN_LED | LED_0603 |
| D9 | LED_WURTH_1_LED_0603_YELLOW_LED | YELLOW_LED | LED_0603 |
| D10 | LED_WURTH_1_LED_0603_YELLOW_LED | YELLOW_LED | LED_0603 |
| D11 | LED_WURTH_1_LED_0603_YELLOW_LED | YELLOW_LED | LED_0603 |
| J1 | FCC CONN_1_52559-3652_FFC_CONN_ | FFC_CONN_1x36 | 52559-3652 |
| J2 | FCC CONN_1_52559-3652_FFC_CONN_ | FFC_CONN_1x36 | 52559-3652 |
| J3 | FFC_CONN_0_68711614522_FFC CONN | FFC CONN 1x16 | 68711614522 |
| J4 | HDMI 19-PIN RECEPTACLE_HDMI-19P | 6.85119E+11 | HDMI-19PIN |
| J5 | USB MINI-B_WURTH_USB_MINI-B_USB | USB MINI-B | WURTH_USB_MINI-B |
| J6 | 2X5_HDR2X5_100MIL_SMT_DNI | DNI | HDR2X5_100MIL_SMT |
| J7 | 2X5_HDR2X5_100MIL_SMT_2X5_100MI | 2X5_100mil | HDR2X5_100MIL_SMT |
| J8 | 2X6 PMOD_HDR2X6_100MIL_2X6 PMOD | 2x6 PMOD Connector | HDR2X6_100MIL |
| J9 | 2X6 PMOD_HDR2X6_100MIL_2X6 PMOD | 2x6 PMOD Connector | HDR2X6_100MIL |
| J10 | JACK-DC_JACK-DC_2MM_DC INPUT JA | DC Input Jack 2.0 mm | JACK-DC_2MM |
| J11 | HEADER, 1X3-PIN_CONN_TSW_103_07 | HEADER, 1x3-PIN | CONN_TSW_103_07_L_S |
| J12 | 2X10_10-89-1201_HEADER 2X10 (DN | Header 2x10 (DNI) | 10-89-1201 |
| J13 | 2X10_10-89-1201_HEADER 2X10 (DN | Header 2x10 (DNI) | 10-89-1201 |
| J14 | HEADER_3_10-89-1141_HEADER 2X7 | Header 2x7 (DNI) | 10-89-1141 |
| L1 | IND 10UH 245MA 0.82OHM 0806 SMD | 10uH | 806 |
| L2 | IND 10UH 245MA 0.82OHM 0806 SMD | 10uH | 806 |
| L3 | IND 10UH 245MA 0.82OHM 0806 SMD | 10uH | 806 |
| L4 | IND 10UH 245MA 0.82OHM 0806 SMD | 10uH | 806 |
| L5 | IND FERRITE 0402 300MA/220_0402 | BLM15AG221SN1 | 402 |
| L6 | IND FERRITE 0402 300MA/220_0402 | BLM15AG221SN1 | 402 |
| L7 | INDUCTOR_0805_742792022 | 742792022 | 805 |
| L8 | INDUCTOR_0805_742792022 | 742792022 | 805 |
| L9 | IND FERRITE 0402 300MA/220_0402 | BLM15AG221SN1 | 402 |
| S6 | TS-A02SA-2-S100_PUSHBUTTON_SMT_ | PB Switch | PUSHBUTTON_SMT |
| S7 | TS-A02SA-2-S100_PUSHBUTTON_SMT_ | PB Switch | PUSHBUTTON_SMT |
| SW1 | SPST4_DIPSWITCH_SMT_QUAD_DIPSWI | DIPSWITCH4 | DIPSWITCH_SMT_QUAD |
| SW2 | SPST4_DIPSWITCH_SMT_QUAD_DIPSWI | DIPSWITCH4 | DIPSWITCH_SMT_QUAD |
| SW3 | SW-PUSH_3_SW-PUSH-8X8_POWER SW | POWER SW | SW-PUSH-8X8 |
| U1 | 10M50DAF484_V2.0_4.5_F484_(S1+S | 10M50DAF484 | F484 |
| U2 | LPDDR2_IS43LD16640A-3BL_2_FBGA1 | LPDDR2_IS43LD16640A-3BL | FBGA134 |
| U3 | ADV7513BSWZ_LQFP-64_ADV7513BSWZ | ADV7513BSWZ | LQFP-64 |
| U4 | EPM1270M256_2_M256_(S1+S4),(S2+ | EPM1270_M256FBGA | M256 |
| U5 | MAX811_SOT-143_MAX811 | MAX811 | SOT-143 |
| U6 | TPD2EUSB30_DRT_TPD2EUSB30 | TPD2EUSB30 | DRT |
| U7 | CY7C68013A_56QFN_QFN56_CY7C6801 | CY7C68013A_QFN | QFN56 |
| U8 | 824013_SOT23-6L_824013 | 824013 | SOT23-6L |
| U9 | 824013_SOT23-6L_824013 | 824013 | SOT23-6L |
| U10 | 824013_SOT23-6L_824013 | 824013 | SOT23-6L |
| U11 | 824013_SOT23-6L_824013 | 824013 | SOT23-6L |
| U14 | CLOCK GEN, SI5338A_CUSTOM, A5SK | Si5338C-CUSTOM | QFN24 |
| U15 | SI510-DUALCMOS_SI510_510MCA50M0 | 510MCA50M0000AAGR | SI510 |
| U16 | FDMC8878_VER2_FDMC8878_VER2_FDM | FDMC8878 | FDMC8878_VER2 |
| U17 | EN5329/5339QI_0_EN5339QI_EN5329 | EN5329QI | EN5339QI |
| U18 | LTC4218CGN_16-LEAD_PLASTIC_SSOP | LTC4218CGN | 16-LEAD_PLASTIC_SSOP |
| U19 | EP5348UI_0_EP5348UI_EP5348UI | EP5348UI | EP5348UI |
| U20 | EP5358XUI_UQFN16_EP5358HUI | EP5358HUI | UQFN16 |
| U21 | EN5329/5339QI_0_EN5339QI_EN5339 | EN5339QI | EN5339QI |
| U22 | EP5348UI_0_EP5348UI_EP5348UI | EP5348UI | EP5348UI |
| U23 | N25Q00AA13GSF40F_1_SO16_WIDE_N2 | N25Q512A83GSF40F | SO16_WIDE |
| V1 | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | SENSE |
| V2 | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | SENSE |
| Y1 | CRYSTAL_SM_13_XTAL_FA-128_24.00 | 24.00MHz | XTAL_FA-128 |
| Y2 | XTAL 25MHZ 30PPM 18PF MINI_XTAL | 25.00MHz | XTAL_FA-128 |
