| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CON1 | SD11-S7_SSIM9-98-2734_503500-09 | 503500-0991 | SSIM9-98-2734 |
| CON2 | RJ45_2_MJ1-0204SRL_406549-1 | 406549-1 | MJ1-0204SRL |
| CON3 | DC-005_PWC3-DC-005_DC-005 | DC-005 | PWC3-DC-005 |
| CON4 | PH-3_PH100-3_CI0103P1VK0 | CI0103P1VK0 | PH100-3 |
| D1 | BAS70-06/SOT_SOT23-28X44_BAT54A | BAT54A | SOT23-28X44 |
| D2 | BAS70-06/SOT_SOT23-28X44_BAT54A | BAT54A | SOT23-28X44 |
| D3 | BAV70L_DPAK_STPS640CB | STPS640CB | DPAK |
| D4 | DIODE_SD-DO-214_SMCJ1.5KE16A | SMCJ1.5KE16A | SD-DO-214 |
| D5 | D-AAC_SOT23-3B_BAT54CLT1G | BAT54CLT1G | SOT23-3B |
| DVI1 | DVI-JDR11-241L-A_DVI0308-3RF-B_ | DVI-JDR11-241L | DVI0308-3RF-B |
| DVI2 | DVI-JDR11-241L-A_DVI0308-3RF-B_ | DVI-JDR11-241L | DVI0308-3RF-B |
| F1 | FUSE_SF2-2410_LITTELFUSE/0452 | LITTELFUSE/0452 | SF2-2410 |
| FB1 | FB_SL0805_PBY201209T | PBY201209T | SL0805 |
| FB2 | INDUCTOR_0_SL0805_PBY201209T201 | PBY201209T201Y-N | SL0805 |
| FB3 | FB_SL0603_PZ1608D221 | PZ1608D221 | SL0603 |
| FB13 | FB_SL0805_PBY201209T/NC | PBY201209T/NC | SL0805 |
| FB14 | FB_SL0805_PBY201209T | PBY201209T | SL0805 |
| J1 | CON10_DG141R-5_CON10 | CON10 | DG141R-5 |
| J2 | HEADER4X15_0_CONN2X10-29X110-F | 20 PIN CTI INTERFACE | CONN2X10-29X110-FTR |
| J3 | DIPSOC-4X2_DM-4_DIPSOC-4X2 | DIPSOC-4x2 | DM-4 |
| J4 | USB-ASTACKED2_USB_STACKED2_USB | USB-A connector | USB_STACKED2 |
| J6 | CON40A_IDC40_100_CON40A | CON40A | IDC40_100 |
| J7 | CON40A_IDC40_100_CON40A | CON40A | IDC40_100 |
| J8 | CON2_PC250_PC250 | PC250 | PC250 |
| J9 | CON2_PC250_PC250 | PC250 | PC250 |
| J10 | CON2_XH100-2_CON2 | CON2 | XH100-2 |
| J11 | CON15_XH100-15_CON15 | CON15 | XH100-15 |
| L1 | SCDW_STFM4-60-2012_SDCW2012H | SDCW2012H | STFM4-60-2012 |
| L2 | SCDW_STFM4-60-2012_SDCW2012H | SDCW2012H | STFM4-60-2012 |
| L3 | SCDW_STFM4-60-2012_SDCW2012H | SDCW2012H | STFM4-60-2012 |
| L4 | SCDW_STFM4-60-2012_SDCW2012H | SDCW2012H | STFM4-60-2012 |
| L5 | INDUCTOR_SL0805_BLM21PG221SN1D | BLM21PG221SN1D | SL0805 |
| L6 | INDUCTOR_3_SL0805_BLM21PG221SN1 | BLM21PG221SN1 | SL0805 |
| L7 | INDUCTOR_3_SL0805_BLM21PG221S_1 | BLM21PG221SN1/NC | SL0805 |
| L8 | INDUCTOR_3_SL0805_BLM21PG221SN1 | BLM21PG221SN1 | SL0805 |
| L10 | INDUCTORIRON_NR4018_4.7UH_NR40 | 4.7uH_NR4018T4R7M | NR4018 |
| L11 | INDUCTOR_SL0805_BLM21PG221SN1D | BLM21PG221SN1D | SL0805 |
| L12 | SCDW_STFM4-60-2012_SDCW2012H | SDCW2012H | STFM4-60-2012 |
| L13 | SCDW_STFM4-60-2012_SDCW2012H | SDCW2012H | STFM4-60-2012 |
| L14 | SCDW_STFM4-60-2012_SDCW2012H | SDCW2012H | STFM4-60-2012 |
| L15 | SCDW_STFM4-60-2012_SDCW2012H | SDCW2012H | STFM4-60-2012 |
| L16 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L17 | FERRITEBEAD_0_INDUCTOR_NR10050 | NR10050T3R8N | INDUCTOR |
| L18 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L19 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L20 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L21 | FERRITEBEAD_0_INDUCTOR_NR10050 | NR10050T3R8N | INDUCTOR |
| L22 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L23 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L24 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L25 | FERRITEBEAD_0_IND109X100_1.5UH | 1.5uH-WURTH7443330150 | IND109X100 |
| L26 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L27 | FERRITEBEAD_0_INDUCTOR_NR10050 | NR10050T3R8N | INDUCTOR |
| L28 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L29 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L30 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L31 | FERRITEBEAD_0_INDUCTOR_NR10050 | NR10050T3R8N | INDUCTOR |
| L32 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L33 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L34 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L35 | FERRITEBEAD_0_CHOKE-115X212_1. | 1.8uH-7447715001 | CHOKE-115X212 |
| L36 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| L37 | INDUCTOR_0_1806_BLM41P750SPT | BLM41P750SPT | 1806 |
| LED1 | LED_LED_17-215-SURC-S530-A3-TR8 | 17-215-SURC-S530-A3-TR8_780 | LED |
| LED2 | LED_LED_17-215-SURC-S530-A3-TR8 | 17-215-SURC-S530-A3-TR8_780 | LED |
| Q1 | 2N2222_1_SOT23-28X44_MMBT2222A | MMBT2222A | SOT23-28X44 |
| Q2 | CSD86330Q3D_SON_0_DQZ8_1P8X2P7_ | CSD86330Q3D | DQZ8_1P8X2P7 |
| Q3 | 2N2222_1_SOT23-28X44_MMBT2222A | MMBT2222A | SOT23-28X44 |
| Q4 | 2N2222_1_SOT23-28X44_MMBT2222A | MMBT2222A | SOT23-28X44 |
| Q5 | 2N2222_1_SOT23-28X44_MMBT2222A | MMBT2222A | SOT23-28X44 |
| Q6 | 2N2222_1_SOT23-28X44_MMBT2222A | MMBT2222A | SOT23-28X44 |
| RN14 | R-PAK4_SRN4-0402_RPACK4-47 | RPack4-47 | SRN4-0402 |
| RN15 | R-PAK4_SRN4-0402_RPACK4-47 | RPack4-47 | SRN4-0402 |
| RN16 | R-PAK4_SRN4-0402_RPACK4-47 | RPack4-47 | SRN4-0402 |
| RN17 | RN_SRN4-0402_33R | 33R | SRN4-0402 |
| RN18 | RN_SRN4-0402_33R | 33R | SRN4-0402 |
| RN19 | RN_SRN4-0402_33R | 33R | SRN4-0402 |
| RN20 | RN_SRN4-0402_33R | 33R | SRN4-0402 |
| RN21 | RN_SRN4-0402_33R | 33R | SRN4-0402 |
| RN22 | RN_SRN4-0402_33R | 33R | SRN4-0402 |
| SW1 | PSW4-DTS_STSW4-TG-A_LTL-613SV | LTL-613SV | STSW4-TG-A |
| SW2 | KFC-A06_0_KFC-A06_KFC-A06 | KFC-A06 | KFC-A06 |
| TC1 | TC_STC3216-A_10UF | 10uF | STC3216-A |
| U1 | TMS320DM8168_0_BGA1031-26-3737_ | TMS320DM8168BCYG2 | BGA1031-26-3737 |
| U2 | TPD12S521_SOP38-20-173_TPD12S52 | TPD12S521 | SOP38-20-173 |
| U3 | MT29F2G16ABAEAWP-IT_0_SOP48-20- | MT29F2G16ABAEAWP-IT | SOP48-20-725 |
| U4 | MAX3232_SOP16-26-173_MAX3232EEU | MAX3232EEUE | SOP16-26-173 |
| U5 | DS1621S_SOP8-50-160_DS1621S | ds1621s | SOP8-50-160 |
| U6 | TPS3808G01DBVR_SOT23-6_TPS3808G | TPS3808G01DBVR | SOT23-6 |
| U7 | 1G08_DCK-5_1G08 | 1G08 | DCK-5 |
| U9 | H6096NL_H6096NL_H6096NL | H6096NL | H6096NL |
| U11 | TPS2061_1_SO8-25X75_TPS2065D | TPS2065D | SO8-25X75 |
| U12 | TPDE0001RSE_0_DRL5-12X40_TPD2E0 | TPD2E001DRL | DRL5-12X40 |
| U13 | TPS2061_1_SO8-25X75_TPS2065D | TPS2065D | SO8-25X75 |
| U14 | TPDE0001RSE_0_DRL5-12X40_TPD2E0 | TPD2E001DRL | DRL5-12X40 |
| U15 | MT41J128M16JT-125_0_BGA96-32-16 | MT41J256M16HA-125 | BGA96-32-1609-B |
| U16 | MT41J128M16JT-125_0_BGA96-32-16 | MT41J256M16HA-125 | BGA96-32-1609-B |
| U17 | MT41J128M16JT-125_0_BGA96-32-16 | MT41J256M16HA-125 | BGA96-32-1609-B |
| U18 | MT41J128M16JT-125_0_BGA96-32-16 | MT41J256M16HA-125 | BGA96-32-1609-B |
| U19 | RTL8169S_3_QFN64_RTL8211DG | RTL8211DG | QFN64 |
| U20 | SII9022AQFN_1_QFN72-10X10_SII90 | SiI9022ACNU | QFN72-10X10 |
| U21 | TPS71701DCK_0_DCK-5_TPS71701DCK | TPS71701DCK | DCK-5 |
| U22 | 1G08_DCK-5_1G08 | 1G08 | DCK-5 |
| U23 | TPD12S521_SOP38-20-173_TPD12S52 | TPD12S521 | SOP38-20-173 |
| U24 | MQ7802T120-R_MQ7802-R_MQ7802T12 | MQ7802T120-R | MQ7802-R |
| U25 | TPS54620_RGY14-12X34_TPS54620 | TPS54620 | RGY14-12X34 |
| U26 | TPS54620_RGY14-12X34_TPS54620 | TPS54620 | RGY14-12X34 |
| U27 | TPS40400RHL_QFN24_0_RHL24_TPS40 | TPS40400RHL | RHL24 |
| U28 | TPS54620_RGY14-12X34_TPS54620 | TPS54620 | RGY14-12X34 |
| U29 | TPS54620_RGY14-12X34_TPS54620 | TPS54620 | RGY14-12X34 |
| U30 | TPS54620_RGY14-12X34_TPS54620 | TPS54620 | RGY14-12X34 |
| U31 | TPS71701DCK_DCK-5_TPS71701DCK | TPS71701DCK | DCK-5 |
| U33 | TPS51200DRCR_MLF10-050-0303L_TP | TPS51200DRCR | MLF10-050-0303L |
| VT1 | SI4413DY_0_SOP8-50-160_SI4413AD | Si4413ADY | SOP8-50-160 |
| X1 | XTAL-4P_SX4-3225_27.000MHZ | 27.000MHz | SX4-3225 |
| X2 | XTAL-2P_XTAL2-192_25MHZ | 25MHZ | XTAL2-192 |
