| Name | PCB Decal | Value | Part Type |
| ANT3401 | ELJ-P-JS-29E11-ANT-H1.1 | POGO PIN | ELJ-P-JS-29E11-ANT-H1.1 |
| CN6001 | ELJ_05-0521132-B_USB-CB0.8 | ELJ_05-0521132-B_USB-CB0.8 | ELJ_05-0521132-B_USB-CB0.8 |
| CON3302 | ELJ_RF_MM8030-2610RK0_2X2X1MM | KLJ_RF_818000291_2X2X1 | ELJ_RF_MM8030-2610RK0_2X2X1MM |
| CON3401 | ELJ_RF_MM8030-2610RK0_2X2X1MM | NC KLJ_RF_818000291_2X2X1 | ELJ_RF_MM8030-2610RK0_2X2X1MM |
| CON6001 | ELJ_ST-0279D00-00_AUDIO | ADJ-312-P2.0-3.9X(·´) | ELJ_ST-0279D00-00_AUDIO |
| CON6101 | ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3 | FH26-39S-0.3 | ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3 |
| D2000 | SOD323/SMD/MM3Z2V4T1 | PZ3D4V2H (PRISEMI) | TVS-6V2-PZ3D4V2H-ROHM |
| D6003 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 |
| D6110 | SOD123 | 1N5819 | DIODE_SCHOTTKY_2 |
| D6201 | FLASHLED_SMD_EFF-D8CA-POOT | FLASH LED | FLASHLED_SMD_EFF-D8CA-POOT |
| EMI6001 | FILTER/SMD/TCM0806G | NC | EMIX21A390FNPE_1 |
| H1000 | PTH_HOLE_1.6/2.8MM | DNI | PTH_HOLE_1.6/2.8MM |
| H1001 | PTH_HOLE_1.6/2.8MM | DNI | PTH_HOLE_1.6/2.8MM |
| H1002 | PTH_HOLE_1.6/2.8MM | DNI | PTH_HOLE_1.6/2.8MM |
| J2001 | ELJ_FTS09M-612-01_BTB-6P-H0.9 | ELJ_FTS09M-612-01_BTB-6P-H0.9 | ELJ_FTS09M-612-01_BTB-6P-H0.9 |
| J3401 | MM4829-2702B | MHC-310 | CON-RF-TEST-MM4829-2702B-MURATA |
| J6001 | ELJ_FH26_L_25S_0.3SHW-A | FH26 | ELJ_FH26_L_25S_0.3SHW-A |
| J6003 | REC1206 | NC | REC_1206 |
| J6201 | ELJ_FH26_L_25S_0.3SHW-A | FH26 | ELJ_FH26_L_25S_0.3SHW-A |
| J6202 | ELJ_WP7-S030VA1_BTB-30P-H0.7 | ELJ_WP7-S030VA1_BTB-30P-H0.7 | ELJ_WP7-S030VA1_BTB-30P-H0.7 |
| J6501 | ELJ_FH26_L_25S_0.3SHW-A | FH26 | ELJ_FH26_L_25S_0.3SHW-A |
| J6502 | ELJ_HC503-6R-GF_PJ_0.5_H1.0 | NC | ELJ_HC503-6R-GF_PJ_0.5_H1.0 |
| J6601 | NC-PADX2-1X1.5 | NC | NC-CON-2-0805 |
| J6701 | ELJ_HC503-6R-GF_PJ_0.5_H1.0 | NC | ELJ_HC503-6R-GF_PJ_0.5_H1.0 |
| L2000 | L2520 | 0.33uH_252012 | L2520-22U |
| L2001 | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 | L/IND/SMD/VLS201610E |
| L2002 | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 | L/IND/SMD/VLS201610E |
| L2003 | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 | L/IND/SMD/VLS201610E |
| L6103 | SWPA5012S | SWPA5012S100MT | SWPA5012S |
| L6105 | L_NRH2410 | 10uH | L2520-4U7 |
| LED2001 | ELE_LTST-C19GD2WT-G_RGB-LED_1.6X2.1X0.4 | ELE_LTST-C19GD2WT-G_RGB-LED_1.6X2.1X0.4 | ELE_LTST-C19GD2WT-G_RGB-LED_1.6X2.1X0.4 |
| MARK1000 | MARK_ALL | DNI | MARK_ALL_A |
| MARK1001 | MARK_ALL | DNI | MARK_ALL_A |
| MARK1002 | MARK_ALL | DNI | MARK_ALL_A |
| MARK1003 | MARK_ALL | DNI | MARK_ALL_A |
| MIC6001 | ELJ_(R)SOB-413S42-EM_MIC-SMT | ELJ_(R)SOB-413S42-EM_MIC-SMT | ELJ_(R)SOB-413S42-EM_MIC-SMT |
| NTC2000 | R0402 | NTCG104EF104F | RES0402 |
| NTC3201 | R0402 | NTC / NTCG064EF104F | R0402-0R |
| Q1 | SC-75_SOT-416_DTC114EET1-D | DTC114YET1 | SC-75_SOT-416_DTC114EET1-D |
| Q6101 | SC-75_SOT-416_DTC114EET1-D | NC DTC114YET1 | SC-75_SOT-416_DTC114EET1-D |
| Q6102 | SC-75_SOT-416_DTC114EET1-D | NC DTC114YET1 | SC-75_SOT-416_DTC114EET1-D |
| Q6103 | SOT23_3 | WPM2026 | IRF5210/TO_6 |
| Q6104 | SOT23_3 | MMBT3904 | NPN_BEC |
| SH2100 | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL | KLINK_NO_PAD_0.1MM_LAYER7 |
| SH6503 | NC/MMD/L1/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH6504 | NC/MMD/L1/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SHORT1 | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL | KLINK_NO_PAD_0.1MM_LAYER7 |
| SHORT2 | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL | KLINK_NO_PAD_0.1MM_LAYER7 |
| SHORT3 | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL | KLINK_NO_PAD_0.1MM_LAYER7 |
| SHORT4 | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL | KLINK_NO_PAD_0.1MM_LAYER7 |
| SHORT1001 | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL | KLINK_NO_PAD_0.1MM_LAYER7 |
| SHORT1002 | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL | KLINK_NO_PAD_0.1MM_LAYER7 |
| TP_UTXD1101 | TP_1.0A | | TP1.0MM |
| U1000 | MT6735/VFBGA641/P0.4/B0.25/12.6X12.6 | MT6735M | MT6735/VFBGA641/P0.4/B0.25/12.6X12.6 |
| U2002 | MT6328/VFBGA206/P0.4/B0.25/6.6X6.6 | MT6328V/A | MT6328/VFBGA206/P0.4/B0.25/6.6X6.6 |
| U2003 | WDFN8/SMD/P0.5/NCP6324 | NCP6324CMTAATBG | WDFN8/SMD/P0.5/NCP6324 |
| U2004 | NCP1855 | NCP1855 | NCP1855 |
| U2005 | NTLUS3A18PZ | NTLUS3A18PZ | NTLUS3A18PZ |
| U2305 | CP2155 | CP2155DN10-A1 | CP2155 |
| U3001 | FBGA178/SMD/B0.4/3-IN-1 | LPDDR3 178b | FBGA178/SMD/B0.4/3-IN-1 |
| U3002 | BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA | Samsung KLM2G1HE3F-B001 | BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA |
| U3101 | MT6169/VFBGA175/P0.4/B0.25/6.2X5.4 | U / MT6169 | MT6169/VFBGA175/P0.4/B0.25/6.2X5.4 |
| U3102 | TCXO/SMD/2.5X2.0/KT2520F | VTCXO / 26 / MHz / KT2520F26000DCW28QAK | KT2520F26000DCW28QAK |
| U3203 | SKY77643 | SKY77643/HRSMAC001/RF5410 | SKY77643 |
| U3303 | RF1628 | SPDT / RF1628A | SPDT_/_BGS12SL6_2 |
| U3304 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | DPX / SAYEY806MBA0F0A | SAW-DPX-RX-BAL_2 |
| U3306 | SAW-SAYRF1G73CA0F0A-2016 | DPX / SAYRF1G95CA0B0AR05 | SAYRF1G73CA0F0A-2016 |
| U3307 | SKY77910 | SKY77910/HRTXAB008/RF5210 | SKY77910 |
| U3308 | SAW-SAYRF1G73CA0F0A-2016 | DPX / SAYFH2G53CCOFOA | SAYRF1G73CA0F0A-2016 |
| U3309 | SAW-SAYRF1G73CA0F0A-2016 | SAYFH1G74CA0B0A | SAYRF1G73CA0F0A-2016 |
| U3310 | FILTER/SMD/TFSL06050915-4108B1 | LPF / TFSL06050915-4108B1 / NC | SAW_0_2 |
| U3311 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | DPX / SAYEY710MBA0F0A | SAW-DPX-RX-BAL_2 |
| U3312 | SAW-SAYRF1G73CA0F0A-2016 | SAYRF1G88CA0B0AR05 | SAYRF1G73CA0F0A-2016 |
| U3313 | SAW-SAYRF1G73CA0F0A-2016 | DPX / SAYFH836MCC0F0AR05 | SAYRF1G73CA0F0A-2016 |
| U3314 | SAW-SAYRF1G73CA0F0A-2016 | SAYFH1G74CA0B0A | SAYRF1G73CA0F0A-2016 |
| U3316 | SAW-SAYRF1G73CA0F0A-2016 | DPX / SAYFH897MHC0F0AR05 | SAYRF1G73CA0F0A-2016 |
| U3318 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TFSZ06050775-3338A1 | BAL_/_TFSZ06051897-3317A1_2 |
| U3402 | SKY13414 | SP5T / SKY13416 | IC/SP6T/SKY13416_0 |
| U3403 | SAW/SMD/SAWEN881MCY0F00R14 | SAW / SAWFD881MCG0F0A | SAW_/_EN881MCY0F00R14_1 |
| U3404 | SAW/SMD/SAWEN881MCY0F00R14 | SAW / SAWFD942MCA0F0A | SAW_/_EN881MCY0F00R14_0_2 |
| U3406 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G84FL0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A |
| U3408 | SAWFILTER/SMD/F6QB2G595P2BS | SAW / B9898 | SAWFILTER/SMD/SAFFB1G90FB0F0A |
| U3412 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB710MAA0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A |
| U3413 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB806MAA0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A |
| U3414 | FILTER/SMD/TFSL06050915-4108B1 | LPF / TFSL06050915-4108B1 / NC | SAW_0_2 |
| U3468 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TFSZ06050775-3338A1 | BAL_/_TFSZ06051897-3317A1_1 |
| U3474 | RF1628 | SPDT / RF1628A | SPDT_/_BGS12SL6_2 |
| U5101 | MT6625/SQFN40/SMD/P0.4/5X5 | U / MT6625L / QFN40 | MT6611_SMD_WLCSP-61_0 |
| U5102 | SAFEB1G57KE0F00 | SAFEB1G57KE0F00 | IC-SAW-SAFEB1G57KE0F00-MURATA |
| U5103 | MAX2659 | MAX2659ELT | IC-GPS-LNAP-MAX2659-MAXIM |
| U5104 | KLJ_TPX205950MT-7110A1_1.1X2X0.9 | TRPX / TDK TPX205950MT-7110A1 | KLJ_TPX205950MT-7110A1_1.1X2X0.9 |
| U5105 | SAW-1411 | FBAR / ACPF-7124 | SAFEB1G57KA0F00 |
| U6001 | MSOP8QMYYA | NC TCS7190( LM4890MM) | MSOP8QMY |
| U6002 | MSOP8QMYYA | TCS7190( LM4890MM) | MSOP8QMY |
| U6105 | SOT23_5 | WD1013EA/TCS4150-E | TCS4150-E |
| U6109 | SOT23_6 | EUP2530/CP2123ST-B1 | AP3031_0 |
| U6303 | STK3171 | STK3171 | STK3171 |
| U6401 | M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7 | | M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7 |
| U6403 | OCH177 | OCH177 | OCH177 |
| U6404 | BMA250 | BMA223 | IC-3-A-ACCELEROMETER-BMA250-BOSCH |
| VR6001 | MLV0402 | SFI0402-180E10RPP-LF | VAR_0402 |
| VR6002 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 |
| VR6003 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 |
| VR6006 | R0402 | EZJZ0V500AA | VR0402 |
| VR6512 | R0402 | SFI0402-180E10RPP-LF | VR0402 |
| X2000 | CRYS/SMD/3.2X1.5/9H032000XX/TXC | 32.768KHz¡À20ppm | CRYS/SMD/3.2X1.5/9H032000XX/TXC |
| X5101 | TCXO/SMD/2.5X2.0/IT2205BE | TCXO / 26 / MHz / IT2205AE | TCXO_RAKON_SMD_4P |
