| 1、Allegro 如何设置route keepin,package keepin1)、setup->area->route keepin,package keepin ->画框 |
| 2)、edit ->z-copy->options->package keepin,route keepin->offset->50->点击外框 |
| 2、ALLEGRO 如何生成钻孔文件Manufacture -> NC -> Drill Customization->auto generate symbols |
| Manufacture -> NC -> Drill Legend |
| Manufacture -> NC ->NC parameters->enhanced excellon format->close |
| Manufacture -> NC -> NC Drill->auto tool select->optimize drill head travel |
| 3、Allegro 如何设置间距setup -> constraints->set standard values->default value form |
| 4、在Allegro中,在布线完成之后如何改变叠层设置选Setup-> Cross-section |
| 5、如何在allegro中使specttra保护手工布线route->automatic router->sections-> all but select->选择要保护的net |
| 6、如何在allegro中使specttra用45度布线route->route Autormatic->Setup->enable Diagonal Ruoting |
| 在specttra出错时可以用route->route Checks 检查错误 |
| TOOLS -> REPORTS -> Dangling line Report |
| 7、Allegro 过孔定义,查找多余的cline创建过孔 setup ->vias->auto define bbvia ->create bbvia->input pad name->generate |
Setup-> Constraints-> hysical (lines/vias) rule set->Set Values->Via list property->Name |
Rout->Gloss-> arameters |
| TOOLS->REPORTS->Dangling line Report |
| rote -> gloss-> parameters-> line smoothing -> ok |
| rote -> gloss-> parameters->convert corner to arc-> ok |
| rote -> gloss-> parameters->pad and T connection fillet-> ok |
| rote -> gloss-> windows |
| 9、在Allegro中如何修改线宽在Allegro的Setup->constraints里的set standard values中可定义每一层走线的宽度,比如,可以定义VCC和GND的线宽为10 Mil。在铺铜时注意shape->parameters里一些线宽的定义是否设置成DRC Value。 |
| 10、Fanout by pick 的用途route->fanout by pick |
| 对某个器件进行fanout,通俗的说就是从pin拉出一小段表层或底层线,打个孔 |
| 11、如何allegro在中取消Package to Package Spacing的DRC检测setup -> constraint -> design constraints -> package to package ->off |
| 12、No Placement Grid was found 的处理方法edit -> z-copy -> option->package keepin层 -> offset =40 |
| 或者 Setup -> Area -> Package Keepin |
| ROUTING KEEPIN 一般内移40MIL,PACKAGE KEEPING 一般内移120MIL |
| 13、在Allegro中如何更改字体和大小(丝印,位号等)配置字体: setup->text sizes |
| 改变字体大小:edit->change,然后在右边控制面板find tab里只选text(只改变字体) |
| 然后在右边控制面板options tab里line width添线的宽度和text block里选字体的大小。 |
| 14、在Allegro中怎样移动元件的标识edit-->move,右边find面板只选text~~~ |
| 15、Allegro 查找元件的方法按 F5 然后在 Find 面板,Find by name 下面选 Symbol(or pin) ,接着再下面输入元件名称,按回车后,屏幕就会高亮这个元件 |
| 16、Allegro 如何将元件元件到底层edit---mirror,find栏选SYMBOL和TEXT |
| 17、在 Editor 启动 Specctra的方法点击 菜单 route ->route Editor 启动 |
| 18、ERROR Unable to open property mapping file: devparam.txt. 错误处理解决方法 |
| PSpice->Edit Simulation Profile-> Configuration Files-> |
| Library-> Library path->(<orcad>toolspspicelibrary |
| 19、如何将敷铜隐藏(前提是layout走线要看得见,只是敷铜隐藏)回复:Setup-->User Perferences-->shape-->no_shape_fill 这个选项打勾; |
| 20、layout走线的线经大小查看命令菜单回复:Display-->element-->右边选择“find”里面的clines; |
| 21、layout走线完成以后,错误检查命令菜单回复:Tools--->Quick Reports-->Design Rules Check Reports; |
22、如何在现有layout中添加元器件回复:Place-->Manually-->Adanced Settings-->打勾“library”--> lacement List-->Components by refdes ; |
| 23、如何利用layout元器件,存储到元器件库中回复:File-->Export-->libraries--> 只选择“Package symbols”就行; |
| 24、layout中鼠线的添加与删除回复:一般是在原理图里面添加和删除,然后再导入网络表,如果硬是要删除Edit-->delete, 选择要删除的器件; |
| 25、如何设置坐标原点回复:Setup-->Drawing Size-->Move Origin(X,Y); |
