查看: 1350|回复: 8
[技术文章] 51单片机学习之简易时钟
发表于 2020-10-27 08:54 | 显示全部楼层 |阅读模式
51单片机学习之简易时钟
使用芯片STC89C52RC, 2个锁存器
6个带小数点共阴极数码管显示一个24时制时钟
没有时钟芯片,所以掉电后时间会复位
原理图为TX-1C开发板
暂时显示了半小时,一秒不差,
未验证有无其他bug,代码贴上来,欢迎高手指点
最终显示的<时.分.秒>是 16.31.37  形式
#include <reg52.h>#include "MY51.H"void show();uint8  shi=15;   //初始时间15:45:00  按复位按钮对时uint8  fen=45;uint8  miao=0;void main(){startT0(1000);  //开始定时器while(1){show();}}void show()  //显示时钟{uint8 oneWela,twoWela,threeWela,foreWela,fiveWela,sixWela; //oneWela是最左边的数码管sixWela =miao%10;fiveWela=miao/10;foreWela=fen%10;threeWela=fen/10;twoWela=shi%10;oneWela=shi/10;displaySMG(oneWela,twoWela,threeWela,foreWela,fiveWela,sixWela,0xf5); //0xf5小数点位置}void T0_Work()  //T0定时器调用的工作函数{miao++;if(miao>59){miao=0;fen++;}if(fen>59){fen=0;shi++;}if(shi>23){shi=0;}}
#ifndef _MY51_H_#define _MY51_H_#include <math.h>#include <intrins.h>typedef int                   int16  ;typedef int                   INT16  ;typedef unsigned int    uint16 ;typedef unsigned int    UINT16 ;typedef unsigned short  uint ;typedef unsigned short  UINT ;typedef unsigned short  word ;typedef unsigned short  WORD ;typedef unsigned long   uint32 ;typedef unsigned long   UINT32 ;typedef unsigned long   DWORD ;typedef unsigned long   dword ;typedef signed long       int32     ;typedef signed long       INT32  ;typedef float                    float32     ;typedef double                double64  ;typedef signed char        int8 ;typedef signed char         INT8 ;typedef unsigned char    byte ;typedef unsigned char    BYTE      ;        //WINDOWS的windef.h里面是这么定义的typedef unsigned char    uchar ;typedef unsigned char    UCHAR ;typedef unsigned char    UINT8 ;typedef unsigned char    uint8 ;typedef unsigned char    BOOL     ;        //windows中定义BOOL为inttypedef unsigned char    bool     ;            //bool是c++的内置类型#define TRUE     1#define true     1#define FALSE    0#define false    0#define open     1    //open和close用于 标志打开和关闭状态#define OPEN     1#define close    0#define CLOSE    0#define lock     0#define start    1#define START    1#define stop     0#define STOP     0uint8    dulaIndex=0;         //数码管0~F段编码索引号uint8    welaIndex=0;         //0~5位的数码管位索引号sbit dula =P2^6;  //段选锁存器控制  控制笔段sbit wela =P2^7;  //位选锁存器控制  控制位置#define led P1    //灯总线控制sbit led0=P1^0;   //8个led灯sbit led1=P1^1;sbit led2=P1^2;sbit led3=P1^3;sbit led4=P1^4;sbit led5=P1^5;sbit led6=P1^6;sbit led7=P1^7;sbit keyS2=P3^4; //4个独立按键sbit keyS3=P3^5;sbit keyS4=P3^6;sbit keyS5=P3^7;void displaySMG(uint8 one,uint8 two,uint8 three,uint8 four,uint8 five,uint8 six,uint8 dot);void delayms(uint16 ms);void T0_Work();//void delayms(uint16 ms)  //软延时函数{uint16 i,j;for(i=83;i>0;i--){for(j=ms;j>0;j--){}}}///#define dark    0x11  //也就是索引第17号元素0x00,共阴极数码管正极全部输入低电平uint8 code table[]= {             //0~F外加小数点和空输出的数码管编码0x3f , 0x06 , 0x5b , 0x4f , // 0 1 2 30x66 , 0x6d , 0x7d , 0x07 , // 4 5 6 70x7f , 0x6f , 0x77 , 0x7c , // 8 9 A B0x39 , 0x5e , 0x79 , 0x71 , // C D E F0x80 , 0x00                 // . 空     空时是第0x11号也就是第17号元素};/uint8   TH0Cout=0 ;        //初值uint8   TL0Cout=0 ;uint16  T0IntCout=0;     //中断计数uint16  T0IntCountAll=0; //(N-1)/65536+1;  //总中断次数bool    bT0Delay=false;  //使用延时函数标志,初始未用bool    bT0Over=false;      //中断处理函数执行结果之一void startT0(uint32 ms)  //开启定时器{float32   t=ms/1000.0;                    //定时时间double64    fox =11.0592*(pow(10,6));  //晶振频率uint32    N=(t*fox)/12 ;                  //定时器总计数值TH0Cout =(65536-N%65536)/256;           //装入计时值零头计数初值TL0Cout =(65536-N%65536)%256;T0IntCountAll=(N-1)/65536+1;             //总中断次数TMOD=TMOD | 0x01;                          //设置定时器0的工作方式为1EA =open;   //打开总中断ET0=open;   //打开定时器中断TH0=TH0Cout;  //定时器装入初值TL0=TL0Cout;TR0=start;     //启动定时器}void delayT0(uint32 ms)        //硬延时函数,自己乱写的不好用,求指点{startT0(ms);                //启动定时器bT0Delay=true;            //告诉T0定时器,起用延时模式while(bT0Over==false);    //时间没到的话继续检测bT0Over=false;                //时间到了,让标志复位}void T0_times() interrupt 1 //T0定时器中断函数{T0IntCout++;if(T0IntCout==T0IntCountAll)  //达到总中断次数值{T0IntCout=0;          //中断次数清零,重新计时bT0Over=true;     //时间真的到了if(bT0Delay)             //本次中断是用来延时的吗{TR0=stop;          //如果是由延时函数开启T0的话,关闭T0return;}TH0=TH0Cout;           //循环定时的话要重装初值,每次定时1秒,重装一次TL0=TL0Cout;T0_Work();                //工作函数}}void displaySMG(uint8 oneWela,uint8 twoWela,uint8 threeWela,uint8 fourWela,uint8 fiveWela,uint8 sixWela,uint8 dot){        //控制6位数码管显示函数,不显示的位用参数 darkdula=1;            //小数点P0=table[16];dula=00=0xff;wela=10=dot;wela=0;delayms(1);dula=10=table[oneWela];   //送段数据dula=00=0xff;    //送位数据前关闭所有显示,防止打开位选锁存后段选数据通过位选锁存器wela=10=0xfe;wela=0;delayms(1);dula=10=table[twoWela];dula=00=0xff;wela=10=0xfd;wela=0;delayms(1);dula=10=table[threeWela];dula=00=0xff;wela=1;P0=0xfb;wela=0;delayms(1);dula=1;P0=table[fourWela];dula=0;P0=0xff;wela=1;P0=0xf7;wela=0;delayms(1);dula=1;P0=table[fiveWela];dula=0;P0=0xff;wela=1;P0=0xef;wela=0;delayms(1);dula=1;P0=table[sixWela];dula=0;P0=0xff;wela=1;P0=0xdf;wela=0;delayms(1);}#endif
  • 打卡总天数:122
  • 打卡总奖励:433
  • 最近打卡:2026-04-21 11:15:52
发表于 2020-10-27 09:21 | 显示全部楼层
发表于 2020-10-27 11:50 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:17
  • 打卡总奖励:61
  • 最近打卡:2025-01-13 19:11:02
发表于 2020-10-27 16:20 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:69
  • 打卡总奖励:208
  • 最近打卡:2026-09-11 13:37:01
发表于 2020-10-28 09:01 | 显示全部楼层
  • 打卡总天数:5
  • 打卡总奖励:17
  • 最近打卡:2025-03-31 14:59:05
163
PADS-241024高级班
发表于 2020-11-5 21:26 | 显示全部楼层
  • 打卡总天数:14
  • 打卡总奖励:38
  • 最近打卡:2026-06-02 19:55:44
26
发表于 2020-11-10 08:51 | 显示全部楼层
  • 打卡总天数:9
  • 打卡总奖励:29
  • 最近打卡:2026-03-27 16:43:34
发表于 2021-3-27 08:52 | 显示全部楼层
  • 打卡总天数:7
  • 打卡总奖励:26
  • 最近打卡:2025-11-10 15:56:06
29
发表于 2023-2-11 11:58 | 显示全部楼层
