| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CON1 | FX10A-144P-SV2_1_FX10A_144P_SV2 | FX10A-144P-SV | FX10A_144P_SV2 |
| D1 | LED_D0603_LED | LED | D0603 |
| D2 | LED_0_D0603_LED | LED | D0603 |
| D3 | LED_0_D0603_LED | LED | D0603 |
| D4 | LED_0_D0603_LED | LED | D0603 |
| D5 | LED_0_D0603_LED | LED | D0603 |
| D6 | BYT3400B/DD_0_DO-214AC_B340A | B340A | DO-214AC |
| D7 | LED_D0603_LED | LED | D0603 |
| D8 | DIODETVS_0_DO-214AC_SMAJ12A | SMAJ12A | DO-214AC |
| D9 | LED_D0603_LED | LED | D0603 |
| D25 | DIODE-2A_TVS1006_RCLAMP0521PATC | RCLAMP0521PATCT | TVS1006 |
| D26 | DIODE_0_SOD-123_1N4148W | 1N4148W | SOD-123 |
| D27 | DIODE_0_SOD-123_1N4148W | 1N4148W | SOD-123 |
| D28 | DIODE_0_SOD-123_1N4148W | 1N4148W | SOD-123 |
| D29 | DIODE_0_SOD-123_1N4148W | 1N4148W | SOD-123 |
| F1 | FUSE_1_F2920_SMD2920P300TF/15 | SMD2920P300TF/15 | F2920 |
| F2 | FUSE_F0603_SMD0603P050TF | SMD0603P050TF | F0603 |
| F3 | FUSE_F0603_SMD0603P050TF | SMD0603P050TF | F0603 |
| FB1 | MAGNETICBEAD_FB0603_BLM18PG121 | BLM18PG121SN1D | FB0603 |
| J1 | HEADER5X2_1_HDR2X7-2R54-VM-TH_ | 510-90-14GB00 | HDR2X7-2R54-VM-TH |
| J2 | CONNJACK PWR_POWER-JACK-DC005_ | DC005 | POWER-JACK-DC005 |
| J3 | CON6_0_CON4-533980471_53398-047 | 53398-0471 | CON4-533980471 |
| J4 | HDMICONNECTOR_HDMI_HDMI CON | HDMICON | HDMI |
| J5 | BNC_0_CON3-U-FL_RECE-20279-001E | RECE-20279-001E-01 | CON3-U-FL |
| J6 | BNC_0_CON3-U-FL_RECE-20279-001E | RECE-20279-001E-01 | CON3-U-FL |
| J7 | BNC_0_CON3-U-FL_RECE-20279-001E | RECE-20279-001E-01 | CON3-U-FL |
| J8 | MICROSD_2_CON-SD-DM3AT_DM3AT_S | DM3AT_SF_PEJM5 | CON-SD-DM3AT |
| J9 | A74307-003 | HR911130A | RJ45-HR911130C |
| J10 | USB-UEA3119C_2_USB3R0-VM-TH_U23 | U231-091N-4BLCC14-F-5 | USB3R0-VM-TH |
| J11 | CON9_HDR9-2R54-VM-TH_CON9 | CON9 | HDR9-2R54-VM-TH |
| J13 | VPX_P0_0_VPX-P0-1410189-3_VPX-P | VPX-P0-1410189-3 | VPX-P0-1410189-3 |
| J14 | VPX_P1_1_VPX-P1-1410187-3_VPX_P | VPX_P1_1410187-3 | VPX-P1-1410187-3 |
| J16 | MINI_USB_MINI_USB_MINI_USB_U-M | MINI_USB_U-M-M5SS-W-2 | MINI_USB |
| L1 | L_L1210_1277AS-H-R68M | 1277AS-H-R68M | L1210 |
| L2 | L_L0402_6.2NH | 6.2nH | L0402 |
| L3 | L_L0402_4.7NH | 4.7nH | L0402 |
| L4 | L_L0402_4.7NH | 4.7nH | L0402 |
| L5 | L_L0402_5.6NH | 5.6nH | L0402 |
| L6 | L_L0402_4.7NH | 4.7nH | L0402 |
| L7 | L_L0402_4.7NH | 4.7nH | L0402 |
| L8 | L_L0402_5.6NH | 5.6nH | L0402 |
| L9 | CHOKE-4I_T-DLW21HN-H1_4_DLW21HN | DLW21HN900HQ2L | T-DLW21HN-H1_4 |
| L10 | CHOKE-4I_T-DLW21HN-H1_4_DLW21HN | DLW21HN900HQ2L | T-DLW21HN-H1_4 |
| L11 | CHOKE-4I_T-DLW21HN-H1_4_DLW21HN | DLW21HN900HQ2L | T-DLW21HN-H1_4 |
| MAKR1 | TPOINT_MARKC_TEST POINT_453000 | TESTPOINT | MARKC |
| MAKR2 | TPOINT_MARKC_TEST POINT_453000 | TESTPOINT | MARKC |
| MAKR3 | TPOINT_MARKC_TEST POINT_453000 | TESTPOINT | MARKC |
| MAKR4 | TPOINT_MARKC_TEST POINT_453000 | TESTPOINT | MARKC |
| MAKR5 | TPOINT_MARKC_TEST POINT_453000 | TESTPOINT | MARKC |
| MAKR6 | TPOINT_MARKC_TEST POINT_453000 | TESTPOINT | MARKC |
| MAKR7 | TPOINT_MARKC_TEST POINT_453000 | TESTPOINT | MARKC |
| MAKR8 | TPOINT_MARKC_TEST POINT_453000 | TESTPOINT | MARKC |
| P1 | MTG280_700_PADC2R7_MTG280_700 | MTG280_700 | PADC2R7 |
| P2 | MTG280_700_PADC2R7_MTG280_700 | MTG280_700 | PADC2R7 |
| P3 | MTG280_700_PADC2R7_MTG280_700 | MTG280_700 | PADC2R7 |
| P4 | MTG280_700_PADC2R7_MTG280_700 | MTG280_700 | PADC2R7 |
| Q1 | MMBT3904/SOT_1_SOT23_MMBT3904 | MMBT3904 | SOT23 |
| Q2 | MMBT3904/SOT_1_SOT23_MMBT3904 | MMBT3904 | SOT23 |
| Q4 | MMBT3904/SOT_1_SOT23_MMBT3904 | MMBT3904 | SOT23 |
| Q5 | MMBT3904/SOT_1_SOT23_MMBT3904 | MMBT3904 | SOT23 |
| U1 | XC7A100T-2FGG484I_BGA484-1R0-22 | XC7A100T-2FGG484I | BGA484-1R0-22X22-23X23 |
| U2 | W25Q128FVSI_1_SOIC8-1R27-5R2_N2 | N25Q128A13ESE40/Micron | SOIC8-1R27-5R2 |
| U3 | JZA77-1CC3-50MHZ_1_OSC6-5X3R2_ | SIT9121AI-2C1-33E200.00000MHZ | OSC6-5X3R2 |
| U4 | JZA77-1CC3-50MHZ_1_OSC6-5X3R_1 | SIT9121AI-2C1-33E100.00000MHZ | OSC6-5X3R2 |
| U5 | LT4644_BGA77-LTM4644_LTM4644IY# | LTM4644IY#PBF | BGA77-LTM4644 |
| U6 | TPS82140_QFN8P1-0R65-2R8X3-SIL0 | TPS82130SILT | QFN8P1-0R65-2R8X3-SIL0008C |
| U7 | TPS7A9201DSKT_0_WSON10_TPS7A92_ | TPS7A9201DSKT | WSON10_TPS7A92 |
| U8 | TPS82140_QFN8P1-0R65-2R8X3-SIL0 | TPS82130SILT | QFN8P1-0R65-2R8X3-SIL0008C |
| U9 | TPS7A9201DSKT_0_WSON10_TPS7A92_ | TPS7A9201DSKT | WSON10_TPS7A92 |
| U10 | TPS82140_QFN8P1-0R65-2R8X3-SIL0 | TPS82130SILT | QFN8P1-0R65-2R8X3-SIL0008C |
| U11 | TPS82140_QFN8P1-0R65-2R8X3-SIL0 | TPS82130SILT | QFN8P1-0R65-2R8X3-SIL0008C |
| U12 | TPS82140_QFN8P1-0R65-2R8X3-SIL0 | TPS82130SILT | QFN8P1-0R65-2R8X3-SIL0008C |
| U13 | TPS7A9201DSKT_0_WSON10_TPS7A92_ | TPS7A9201DSKT | WSON10_TPS7A92 |
| U14 | MT41J256M16_BGA96-0R8-10X14_MT4 | MT41K256M16TW-125IT | BGA96-0R8-10X14 |
| U15 | MT41J256M16_0_BGA96-0R8-10X14_M | MT41K256M16TW-125IT | BGA96-0R8-10X14 |
| U16 | TPS51200DRCR_QFN10P1-0R5-3X3_TP | TPS51200DRCR | QFN10P1-0R5-3X3 |
| U17 | SII9134CTU_0_TQFP100-0R5-14_SII | SiI9134CTU | TQFP100-0R5-14 |
| U18 | RCLAMP0524P_0_ESD-RCLAMP0524P_R | RClamp0524P | ESD-RCLAMP0524P |
| U19 | RCLAMP0524P_0_ESD-RCLAMP0524P_R | RClamp0524P | ESD-RCLAMP0524P |
| U20 | GS2971AIBE3_1_BGA100-1R0-11_GS2 | GS2971AIBE3 | BGA100-1R0-11 |
| U21 | XO32YAGRC8MHZ_0_OSC4-3R2X2R5_XO | XO32YAGRC27MHz | OSC4-3R2X2R5 |
| U22 | GS2972-IBE3_9_BGA100-1R0-11_GS2 | GS2972-IBE3 | BGA100-1R0-11 |
| U23 | H26M41204HPR_BGA153-0R5-EMMC_(S | H26M41204HPR | BGA153-0R5-EMMC |
| U25 | MA124/TO_SOT23-6_SRV05-4TCT | SRV05-4TCT | SOT23-6 |
| U26 | MA124/TO_SOT23-6_SRV05-4TCT | SRV05-4TCT | SOT23-6 |
| U27 | KSZ9031RN_QFN48P1-0R5-7-KSZ9031 | KSZ9031RNXIA | QFN48P1-0R5-7-KSZ9031 |
| U28 | XO32YAGRC8MHZ_0_OSC4-3R2X2R5__1 | XO32YAGRC25MHz | OSC4-3R2X2R5 |
| U29 | TXS0104EPWR_TSSOP14-0R65-4R4_TX | TXS0104EPWR | TSSOP14-0R65-4R4 |
| U30 | TXS0104EPWR_TSSOP14-0R65-4R4_TX | TXS0104EPWR | TSSOP14-0R65-4R4 |
| U31 | TP485E-VR_3_SOIC8-1R27-3R8_MAX3 | MAX3490ESA | SOIC8-1R27-3R8 |
| U32 | TP485E-VR_3_SOIC8-1R27-3R8_MAX3 | MAX3490ESA | SOIC8-1R27-3R8 |
| U33 | VPX-P2-1410190-3_0_VPX-P2-14101 | VPX_P2_1410190-3 | VPX-P2-1410190-3 |
| U34 | CP2102N-A01-GQFN20_2_QFN28-0_5- | CP2102N-A01-GQFN28 | QFN28-0_5-5_0X5_0 |
| U35 | TXS0104EPWR_TSSOP14-0R65-4R4_TX | TXS0104EPWR | TSSOP14-0R65-4R4 |
| U37 | CDCV304PW_TSSOP-8_CDCV304PW | CDCV304PW | TSSOP-8 |
