查看: 1264|回复: 2
[问题求助] 想学一下genesis2000脚本!那位高手能帮我看一下这是什么意
发表于 2021-1-23 16:50 | 显示全部楼层 |阅读模式
DO_INFO -t matrix -e $JOB/matrix -d ROWset matrix_counter = 0set L_NUM = 0set OUTER_LAYERS = ( )set INN_LAYERS = ( )set SM_LAYERS = ( )set SS_LAYERS = ( )set DRL_LAYERS = ( )set layers_no = ( )set SIGNAL_LAYERS = ( )set NEGATIVE_LAYERS = ( )set TOP_LAYERS = ( )set BOT_LAYERS = ( )set outer_top = ( )set outer_bot = ( )set posi_top = ( )set posi_bot = ( )set nega_top = ( )set nega_bot = ( )........
发表于 2021-3-19 15:36 | 显示全部楼层
我也想学,哪里有教程啊
发表于 2021-9-3 11:16 | 显示全部楼层
DO_INFO -t matrix -e $JOB/matrix -d ROW          这里是获取层数
