| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | LED_LEDSC95P220X135X40-2N_FPGA_ | FPGA_DONE | LEDSC95P220X135X40-2N |
| D2 | DIODE_DIOM6032X280N_DIODE | DIODE | DIOM6032X280N |
| DP1 | CON20A_SHDR0S254P10X2_3300X900X | CON20A | SHDR0S254P10X2_3300X900X500 |
| DP2 | CON12A_SHDR0S254P6X2_2284X900X5 | CON12A | SHDR0S254P6X2_2284X900X500 |
| DP3 | CON20A_SHDR0S254P10X2_3300X900X | CON20A | SHDR0S254P10X2_3300X900X500 |
| DP4 | CON20A_SHDR0S254P10X2_3300X900X | CON20A | SHDR0S254P10X2_3300X900X500 |
| DP5 | CON20A_SHDR0S254P10X2_3300X900X | CON20A | SHDR0S254P10X2_3300X900X500 |
| DP6 | CON12A_SHDR0S254P6X2_2284X900X5 | CON12A | SHDR0S254P6X2_2284X900X500 |
| F1 | FUSE_SMC0805_500MA_MFU00003 | 500mA | SMC0805 |
| HDMI | HDMICONNECTOR_MINI_HDMI_HDMI C | HDMIConnector | MINI_HDMI |
| IIC1 | CON4_SHDR0S254P4X1_1000X300X500 | CON4 | SHDR0S254P4X1_1000X300X500 |
| J2 | GE_RJ45_GE_RJ45_GE_RJ45 | GE_RJ45 | GE_RJ45 |
| J5 | CON4_SHDR0S254P4X1_1000X300X500 | CON4 | SHDR0S254P4X1_1000X300X500 |
| J6 | MICROSD_2_MICRO_SD_MICRO SD_2 | MicroSD_2 | MICRO_SD |
| J7 | 2-JUMPER_JUMPER2_2-JUMPER | 2-Jumper | JUMPER2 |
| J8 | USB_TYPEA_USB_TYPEA_USB_TYPEA | USB_TYPEA | USB_TYPEA |
| J10 | CON40_FFC_0P5_40PIN_CON40 | CON40 | FFC_0P5_40PIN |
| J13 | CON3_CN1_DCJACK_CON3 | CON3 | CN1_DCJACK |
| J15 | CON8A_SHDR0S254P4X2_1200X600X50 | CON8A | SHDR0S254P4X2_1200X600X500 |
| J16 | 2-JUMPER_SMC0805_2-JUMPER | 2-Jumper | SMC0805 |
| J17 | 2-JUMPER_SMC0805_2-JUMPER | 2-Jumper | SMC0805 |
| JTAG | HEADER14_SHDR0S254P7X2_2538X90 | JTAG | SHDR0S254P7X2_2538X900X500 |
| L1 | INDUCTOR_C0603_INDUCTOR | INDUCTOR | C0603 |
| L2 | INDUCTOR_C0805_120OHM@100MHZ | 120OHM@100MHz | C0805 |
| L3 | INDUCTOR_INDP4232X280N_2.2UH | 2.2uH | INDP4232X280N |
| L4 | INDUCTOR_INDP7070X280N_2.2UH50 | 2.2uH5000mA | INDP7070X280N |
| L5 | INDUCTOR_INDP7070X280N_2.2UH50 | 2.2uH5000mA | INDP7070X280N |
| L6 | INDUCTOR_INDP7070X280N_2.2UH50 | 2.2uH5000mA | INDP7070X280N |
| L7 | INDUCTOR_INDP7070X280N_2.2UH50 | 2.2uH5000mA | INDP7070X280N |
| L8 | INDUCTOR_C0805_INDUCTOR | INDUCTOR | C0805 |
| L9 | INDUCTOR_INDP7070X280N_2.2UH50 | 2.2uH5000mA | INDP7070X280N |
| OPV_SW | CON3_SHDR0S254P3X1_1000X570X500 | POWER | SHDR0S254P3X1_1000X570X500 |
| RN21 | RESAR_IS_4/SM_CAPCAF80P160X320X | RESAR_IS_4/SM | CAPCAF80P160X320X100-8N |
| SW1 | BUTTON_KEY735SO_BUTTON | Button | KEY735SO |
| SW2 | SWKEY-DPDT_KEY_DPDT_SW KEY-DPD | SWKEY-DPDT | KEY_DPDT |
| U1 | ZYNQ7010/7020_CLG400_ZYNQ7010/7 | Zynq7010/7020 | CLG400 |
| U2 | RTL8211E_RTL8211_QFN48_8169SB | 8169SB | RTL8211_QFN48 |
| U3 | MT41J256M16_FBGA_96_MT41J256M16 | MT41J256M16 | FBGA_96 |
| U5 | TCM811TERCTR_TCM811TERCTR_TCM81 | TCM811TERCTR | TCM811TERCTR |
| U6 | CRYSTAL4_OSCCC290X385X150-4N_33 | 33.33333.MHz | OSCCC290X385X150-4N |
| U7 | CRYSTAL4_OSCCC290X385X150-4N_50 | 50MHz | OSCCC290X385X150-4N |
| U8 | W25Q256FV_MLP8_W25Q256FV | W25Q256FV | MLP8 |
| U9 | USB3320C-EZK_6_USB3320C_USB3320 | USB3320C-EZK_6 | USB3320C |
| U10 | TPS2051BDBV_TPS2051BDBV_TPS2051 | TPS2051BDBV | TPS2051BDBV |
| U11 | TLV62130RGT_5_TLV62130RGT_TLV62 | TLV62130RGT | TLV62130RGT |
| U12 | TLV62130RGT_5_TLV62130RGT_TLV62 | TLV62130RGT | TLV62130RGT |
| U13 | TLV62130RGT_5_TLV62130RGT_TLV62 | TLV62130RGT | TLV62130RGT |
| U14 | TLV62130RGT_5_TLV62130RGT_TLV62 | TLV62130RGT | TLV62130RGT |
| U15 | ADG3308_SOIC65P640X140-20N_ADG3 | ADG3308 | SOIC65P640X140-20N |
| U16 | ADG3308_SOIC65P640X140-20N_ADG3 | ADG3308 | SOIC65P640X140-20N |
| U17 | TLV62130RGT_5_TLV62130RGT_TLV62 | TLV62130RGT | TLV62130RGT |
| U18 | AMS1117-3.3_SOT230P700X180-4N_A | AMS1117-3.3 | SOT230P700X180-4N |
| U19 | IF_NC7WZ07_NC7WZ07_NC7WZ07P6X_I | NC7WZ07P6X | NC7WZ07 |
| U20 | IF_NC7SZ125_NC7SZ125_NC7SZ125_I | NC7SZ125 | NC7SZ125 |
| U21 | IF_GTL2002D_GTL2002D_GTL2002D_I | GTL2002D | GTL2002D |
| U22 | PW_TPS2051BDBV_TPS2051BDBV_TPS2 | TPS2051BDBV | TPS2051BDBV |
| UART0 | CON4_SHDR0S254P4X1_1000X300X500 | CON4 | SHDR0S254P4X1_1000X300X500 |
| UART1 | CON4_SHDR0S254P4X1_1000X300X500 | CON4 | SHDR0S254P4X1_1000X300X500 |
| Y2 | CRYSTAL_OSCSC254P460X320X170-2N | 24MHz | OSCSC254P460X320X170-2N |
| Y3 | CRYSTAL_OSCSC254P460X320X170-_1 | 25MHz | OSCSC254P460X320X170-2N |
