| Name | PCB Decal | Part Type | Value |
| ANT3301 | ELJ_DZ_F2 | ELJ_DZ_F2 | POGO PIN |
| ANT5102 | ELJ_ANTPTH_LTPG-PT0H43-CB01 | ELJ_ANTPTH_LTPG-PT0H43-CB01 | POGO PIN |
| B6000 | L0603 | B0603-2500R | BLM18BD252SN1 |
| BEAD2001 | L0402 | BEAD-0402 | BLM15BD102SN1D |
| BEAD5001 | B0402 | FB_/_BLM15AG121SN1 | FB / BLM15AG601SN1 |
| BEAD6010 | L0402 | BEAD-0402 | BLM15BD102SN1D |
| BEAD6200 | R0402 | BEAD-0402 | 0R |
| C1 | C0201 | C0201 | L / 6.8 / nH / 0201 |
| CN6001 | ELJ_CMUS-06505-097-03 | ELJ_CMUS-06505-097-03 | KM0004U5P-03-06 |
| CON1 | ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3 | ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3 | FH26-39S-0.3 |
| CON3302 | ELJ_RF_MM8030-2610RK0_2X2X1MM | ELJ_RF_MM8030-2610RK0_2X2X1MM | KLJ_RF_818000291_2X2X1 |
| CON3401 | ELJ_RF_MM8030-2610RK0_2X2X1MM | ELJ_RF_MM8030-2610RK0_2X2X1MM | NC KLJ_RF_818000291_2X2X1 |
| CON6002 | ELJ_ADJ-312-P2.0-3.9X_H4.2 | ELJ_ADJ-312-P2.0-3.9X_H4.2 | ADJ-312-P2.0-3.9X(反) |
| D2000 | SOD323/SMD/MM3Z2V4T1 | TVS-6V2-PZ3D4V2H-ROHM | PZ3D4V2H (PRISEMI) |
| D6003 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 |
| D6101 | SOD123 | DIODE_SCHOTTKY_2 | MM1Z5V |
| D6102 | SOT23_3 | BAT54S | BAT54S |
| D6103 | SOD123 | DIODE_SCHOTTKY_2 | MM1Z20V |
| D6108 | SOT23_3 | BAT54S | BAT54S |
| D6109 | SOD123 | DIODE_SCHOTTKY_2 | 1N5819 |
| D6110 | SOD123 | DIODE_SCHOTTKY_2 | 1N5819 |
| EMI6001 | FILTER/SMD/TCM0806G | EMIX21A390FNPE_1 | NC |
| H1000 | PTH_HOLE_1.6/2.8MM | PTH_HOLE_1.6/2.8MM | DNI |
| H1001 | PTH_HOLE_1.6/2.8MM | PTH_HOLE_1.6/2.8MM | DNI |
| J1 | ELJ-KS270013 | ELJ-KS270013 | |
| J25 | ELJ_HXQKTS-088_2_4 | ELJ_HXQKTS-088_2_4 | HX-088 2*4 |
| J26 | V30SIM(H3.0MM) | DUALSIM | ALP-SIMD618-01 |
| J31 | ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5 | ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5 | ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5 |
| J32 | ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9 | ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9 | NC |
| J6001 | C0805 | NC-CON-2-0805 | NC |
| J6003 | REC_DYS-1506T2332-W01 | REC_DYS-1506T2332-W01 | NC |
| J6006 | C0805 | NC-CON-2-0805 | NC |
| J6101 | ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5 | ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5 | ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5 |
| J6102 | ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3 | ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3 | FPC51P-0.3MM |
| J6502 | SOCKET-SIM-LK-SIM437-0615R | SOCKET-SIM-LK-SIM437-0615R | S0DD-180006-01G |
| J6503 | ELJ_YHTKP-1915-W_PHS_H1.9 | ELJ_YHTKP-1915-W_PHS_H1.9 | YHTKP-1915-C |
| J6601 | NC-PADX2-1X1.5 | NC-CON-2-0805 | NC |
| J6602 | NC-PADX2-1X1.5 | NC-CON-2-0805 | NC |
| L1302 | L0402 | L0402-1N0 | 1.0nH_0.3nH |
| L2000 | IND2520 | L2520-22U | 0.33uH_252012 |
| L2001 | L/IND/SMD/VLS201610E | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 |
| L2002 | L/IND/SMD/VLS201610E | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 |
| L2003 | L/IND/SMD/VLS201610E | L/IND/SMD/VLS201610E | PL / 0.47 / uH / 2016 |
| L2004 | IND2016 | L2520-22U | 2.2uH_201610 |
| L2005 | IND252010 | L2520-ELLYFJ100M | 1uH_252010/NC |
| L2020 | L/IND/SMD/2520 | L/IND/SMD/2520 | 1uH |
| L6003 | L0402 | L0402-1N0 | 1.0nH_0.3nH |
| L6101 | MPH252012 | MPH252012 | NRH2410T4R7MN |
| L6103 | CD43 | IND-CD43 | 10uH |
| L6105 | MPH252012 | MPH252012 | NRH2410T4R7MN |
| LED6201 | FLASHLED_SMD_EFF-D8CA-POOT | FLASHLED_SMD_EFF-D8CA-POOT | FLASH LED |
| MARK1000 | MARK_ALL | MARK_ALL_A | DNI |
| MARK1001 | MARK_ALL | MARK_ALL_A | DNI |
| MARK1002 | MARK_ALL | MARK_ALL_A | DNI |
| MARK1003 | MARK_ALL | MARK_ALL_A | DNI |
| NTC2000 | R0402 | RES0402 | NTCG104EF104F |
| NTC3201 | R0402 | R0402-0R | NTC / NTCG064EF104F |
| Q6101 | SC-75_SOT-416_DTC114EET1-D | SC-75_SOT-416_DTC114EET1-D | NC DTC114YET1 |
| Q6102 | SC-75_SOT-416_DTC114EET1-D | SC-75_SOT-416_DTC114EET1-D | NC DTC114YET1 |
| Q6103 | SOT23_3 | IRF5210/TO_6 | WPM2026 |
| Q6104 | SOT23_3 | NPN_BEC | MMBT3904 |
| SH2100 | KLINK_NO_PAD_0.1MM_TOP | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL |
| SH6100 | NC_SHORT_0402 | NC_SHORT_0402 | |
| SHORT1002 | KLINK_NO_PAD_0.1MM_TOP | KLINK_NO_PAD_0.1MM_LAYER7 | SHORT / NC-MMD-L9-4MIL |
| TP_SYSRST_B | TP/SMD/0.5MM | TP_0.5 | |
| TP_URXD1101 | TP_1.0 | TP1.0MM | |
| TP_UTXD1101 | TP_1.0 | TP1.0MM | |
| U11 | ELI-MXC400XXC_6P_17X11.8_H0.9MM | ELI-MXC400XXC_6P_17X11.8_H0.9MM |
| U1000 | MT6735/VFBGA641/P0.4/B0.25/12.6X12.6 | MT6735/VFBGA641/P0.4/B0.25/12.6X12.6 | MT6735M |
| U2001 | FAN54015 | FAN54015 | |
| U2002 | MT6328/VFBGA205/P0.4/B0.25/6.6X6.6 | MT6328/VFBGA205/P0.4/B0.25/6.6X6.6 | MT6328V/A |
| U2003 | WDFN8/SMD/P0.5/NCP6324 | WDFN8/SMD/P0.5/NCP6324 | NCP6324CMTAATBG |
| U2305 | CP2155 | CP2155 | CP2155DN10-A1 |
| U3001 | FBGA178/SMD/B0.4/3-IN-1 | FBGA178/SMD/B0.4/3-IN-1 | LPDDR3 178b |
| U3002 | BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA | BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA | Samsung KLM2G1HE3F-B001 |
| U3101 | MT6169/VFBGA175/P0.4/B0.25/6.2X5.4 | MT6169/VFBGA175/P0.4/B0.25/6.2X5.4 | U / MT6169 |
| U3102 | 26M_VTCXO_2520_2016_T_V | 26M_VTCXO_2520_2016_T_V | VTCXO / 26 / MHz / KT2520F26000DCW28QAK |
| U3203 | SKY77643 | SKY77643 | SKY77643/HRSMAC001/RF5410 |
| U3215 | BALUN/SMD/HHM22112A2 | BALUN/SMD/HHM22112A2 | LPF / LF1608-B2R5KCB |
| U3303 | RF1628 | SPDT_/_BGS12SL6_2 | SPDT / RF1628A |
| U3304 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | SAW-DPX-RX-BAL_2 | DPX / SAYEY806MBA0F0A |
| U3306 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAW-SAYRF1G73CA0F0A-2016-1814 | DPX / SAYRF1G95CA0B0AR05 |
| U3307 | SKY77910 | SKY77910 | SKY77910/HRTXAB008/RF5210 |
| U3308 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAW-SAYRF1G73CA0F0A-2016-1814 | DPX / SAYFH2G53CCOFOA |
| U3309 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAYFH1G74CA0B0A |
| U3310 | FILTER/SMD/TFSL06050915-4108B1 | SAW_0_2 | LPF / TFSL06050915-4108B1 / NC |
| U3311 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | SAW-DPX-RX-BAL_2 | DPX / SAYEY710MBA0F0A |
| U3312 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | SAW-DPX-RX-BAL_2 | SAYEY1G88BA0B0A |
| U3313 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAYFH836MCC0F0A/SAYEY836MCA0F0A |
| U3314 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAYFH1G74CA0B0A |
| U3316 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAW-SAYRF1G73CA0F0A-2016-1814 | SAYEY897MCA0B0A |
| U3318 | BALUN/SMD/TFSZ06052460-3310A2 | BAL_/_TFSZ06051897-3317A1_2 | BAL / TFSZ06050775-3338A1 |
| U3329 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G84FL0F0A |
| U3338 | BALUN/SMD/TFSZ06052460-3310A2 | BALUN/SMD/TFSZ06052460-3310A2 | TFSZ06051897-3317A1 |
| U3401 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G84FL0F0A |
| U3402 | SKY13414 | IC/SP6T/SKY13416_0 | SP5T / SKY13416 |
| U3404 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G84FL0F0A |
| U3405 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G84FL0F0A |
| U3406 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G84FL0F0A |
| U3407 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G84FL0F0A |
| U3408 | SAWFILTER/SMD/F6QB2G595P2BS | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / B9898 |
| U3412 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB710MAA0F0A |
| U3413 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB806MAA0F0A |
| U3414 | FILTER/SMD/TFSL06050915-4108B1 | SAW_0_2 | LPF / TFSL06050915-4108B1 / NC |
| U3468 | BALUN/SMD/TFSZ06052460-3310A2 | BAL_/_TFSZ06051897-3317A1_1 | BAL / TFSZ06050775-3338A1 |
| U3474 | RF1628 | SPDT_/_BGS12SL6_2 | SPDT / RF1628A |
| U5101 | MT6625/SQFN40/SMD/P0.4/5X5 | MT6611_SMD_WLCSP-61_0 | U / MT6625L / QFN40 |
| U5102 | SAFEB1G57KE0F00 | IC-SAW-SAFEB1G57KE0F00-MURATA | SAFEB1G57KE0F00 |
| U5103 | MAX2659 | IC-GPS-LNAP-MAX2659-MAXIM | MAX2659ELT |
| U5104 | KLJ_TPX205950MT-7110A1_1.1X2X0.9 | KLJ_TPX205950MT-7110A1_1.1X2X0.9 | TRPX / TDK TPX205950MT-7110A1 |
| U5105 | SAW-1411 | SAFEB1G57KA0F00 | FBAR / ACPF-7124 |
| U6103 | SOT23_6 | AP3031_0 | CP2121ST-B2/TCS23352 |
| U6105 | SOT23_5 | TCS4150-E | WD1013EA/TCS4150-E |
| U6109 | SOT23_6 | AP3031_0 | EUP2530/CP2123ST-B1 |
| U6305 | CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MM | CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MM |
| U6401 | G-SENSOR-MMC3516XPJ_1.6X1.6_H0.7 | M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7 |
| U6402 | STK3171 | STK3171 | STK3171 |
| U6403 | | TLE4917 | OCH167TWAD |
| U6404 | BMA250 | IC-3-A-ACCELEROMETER-BMA250-BOSCH | BMA223 |
| U6705 | GSL915 | GSL915 | |
| VR2001 | R0402 | VR0402 | SFI0402-180E10RPP-LF |
| VR2002 | R0402 | VR0402 | SFI0402-180E10RPP-LF |
| VR2003 | SOD-323 | PTVSHC3D4V5B | NC PTVSHC3D4V5B |
| VR6000 | MLV0402 | VAR_0402 | SFI0402-180E10RPP-LF |
| VR6001 | MLV0402 | VAR_0402 | SFI0402-180E10RPP-LF |
| VR6002 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 |
| VR6003 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 | ELJ_TVSESD9X5VL-2_SOD-923_H0.45 |
| VR6004 | R0402 | VR0402 | SFI0402-180E10RPP-LF |
| VR6005 | R0402 | VR0402 | SFI0402-180E10RPP-LF |
| VR6006 | R0402 | VR0402 | EZJZ0V500AA |
| VR6007 | R0402 | VR0402 | EZJZ0V500AA |
| VR6008 | MLV0402 | VAR_0402 | SFI0402-180E10RPP-LF |
| VR6009 | MLV0402 | VAR_0402 | SFI0402-180E10RPP-LF |
| VR6010 | MLV0402 | VAR_0402 | SFI0402-180E10RPP-LF |
| VR6011 | R0402 | VR0402 | NC |
| VR6012 | R0402 | VR0402 | NC |
| VR6015 | R0402 | VR0402 | SFI0402-180E10RPP-LF |
| VR6026 | ESD5641D07 | ESD5641D07 | NC ESD5641D07 |
| VR6501 | R0402 | VR0402 | EZJZ0V500AA |
| VR6502 | R0402 | VR0402 | EZJZ0V500AA |
| VR6503 | R0402 | VR0402 | EZJZ0V500AA |
| VR6504 | R0402 | VR0402 | 0_5% |
| VR6512 | R0402 | VR0402 | SFI0402-180E10RPP-LF |
| VR6515 | R0402 | VR0402 | EZJZ0V500AA |
| VR6516 | R0402 | VR0402 | EZJZ0V500AA |
| X2000 | CRYS/SMD/3.2X1.5/9H032000XX/TXC | CRYS/SMD/3.2X1.5/9H032000XX/TXC | NC 32.768KHz±20ppm |
| X5101 | 26M_TCXO_2520TC7L26002015_2016L26421 | 26M_TCXO_2520TC7L26002015_2016L26421 | NC TCXO / 26 / MHz / IT2205AE |
