查看: 7330|回复: 59
[ALLEGRO格式] RK3566开发板封装
  • 打卡总天数:6
  • 打卡总奖励:16
  • 最近打卡:2026-01-17 21:27:14
36
发表于 2021-7-15 16:33 | 显示全部楼层 |阅读模式
3566.7z
398 KB, 下载次数: 59, 下载积分:金币 -1 枚
Rockchip RK3566 Datasheet V1.0-20201210.pdf
5.66 MB, 下载次数: 10, 下载积分:金币 -1 枚
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_TOL
COMP_CLASS
QUANTITY
REFDES
AK09918
U / AK09918C_AK09918_DNP/AK0991
DNP/AK09918C
IC
U9001
BAT3_2R54
BATT3_BAT3_2R54_BAT3_2R54
BAT3_2R54
IC
BT2100
BGA153_13R00X11R50X0R90_2L
INAND_EMMC_153_2L_BGA153_13R00X
EMMC_B153_2L
IC
U4000
BGA200_15R00X10R00X0R90
LPDDR4_200P_0_BGA200_15R00X10R0
LPDDR4_200p
IC
U3900
BGA565_15R5X14R4X0R90
SOC_RK3566_BGA565_15R5X14R4X0R9
RK3566
IC
U1000
C0201
CAP NP_C0201_100NF
100nF
IC
40
C1005;C1012;C1017;C1021;C1022;C1100;C1101;C1102;C1103;C1105;C1200;C1203;C1205;C1207;C1209;C1210;C1212;C1300;C1301;C1400;C1401;C1402;C1403;C1508;C1510;C1517;C1600;C1601;C1604;C1700;C1701;C1716;C1721;C1722;C1800;C1900;C7028;C7029;C7032;C7035
C0201
CAP NP_C0201_18PF
18pF
IC
C1201;C1202
C0201
CAP NP_C0201_DNP
DNP
IC
9
C1404;C1405;C1406;C1407;C1408;C1704;C1705;C1717;C1718
C0201
CAP NP_C0201_100PF
100pF
IC
C2159
C0201
CAP NP_C0201_DNP/100NF
DNP/100nF
IC
C4703;C4704
C0201
CAP NP_C0201_1UF
1uF
IC
C7033;C9102
C0402
CAP NP_C0402_4.7UF
4.7uF
IC
13
C1000;C1002;C1006;C1007;C1008;C1013;C1723;C1724;C2102;C3947;C5210;C5213;C6109
C0402
CAP NP_C0402_1UF
1uF
IC
43
C1204;C1206;C1208;C1211;C1602;C1603;C1702;C1703;C2100;C2101;C2105;C2106;C2109;C2110;C2114;C2116;C2117;C2118;C2121;C2138;C2141;C2142;C2151;C2152;C2300;C3904;C3927;C3931;C4100;C4103;C5000;C5001;C5002;C5218;C5219;C5304;C6107;C6113;C7002;C9006;C9007;C9008;C9009
C0402
CAP NP_C0402_1NF
1nF
IC
C1500;C3900;C9757
C0402
CAP NP_C0402_100NF
100nF
IC
101
C2001;C2060;C2144;C2145;C2146;C2147;C2153;C2157;C2158;C2238;C2239;C2509;C3905;C3906;C3907;C3908;C3909;C3910;C3911;C3912;C3913;C3914;C3915;C3916;C3917;C3918;C3919;C3924;C3925;C3926;C3932;C3933;C3934;C3935;C3936;C3937;C3938;C3939;C3940;C3941;C3942;C3943;C3944;C3949;C3950;C3951;C3954;C3955;C3956;C3957;C3958;C3959;C4000;C4001;C4002;C4003;C4004;C4006;C4007;C4101;C4102;C4104;C4201;C4202;C4700;C4702;C4706;C4707;C4709;C4710;C4711;C4713;C4716;C4717;C4718;C5204;C5206;C5207;C5209;C5212;C5214;C5217;C5220;C5221;C5222;C5223;C5300;C5302;C5303;C5305;C6104;C6108;C6112;C6114;C7001;C9001;C9002;C9003;C9004;C9005;C9103
C0402
CAP NP_C0402_2.2UF
2.2uF
IC
C2133;C2139;C4009
C0402
CAP NP_C0402_22PF
22pF
IC
C2137;C2140;C5215;C6105;C6106
C0402
CAP NP_C0402_27PF
27pF
IC
C2148;C2149
C0402
CAP NP_C0402_DNP
DNP
IC
C2302;C2303;C3952;C3953;C6110
C0402
CAP NP_C0402_220PF
220pF
IC
C7008;C7038
C0402
CAP NP_C0402_680PF
680pF
IC
C7030;C7031;C7036;C7037
C0603
CAP NP_C0603_22UF
22uF
IC
C1001;C1003;C1004;C1009;C1011;C1016;C1018;C1020;C2103;C2111;C2112;C2122;C2123;C2125;C2204;C2205;C2209;C3901;C3928
C0603
CAP NP_C0603_10UF
10uF
IC
34
C1010;C1015;C1019;C1104;C2104;C2107;C2108;C2113;C2115;C2119;C2120;C2124;C2126;C2136;C2150;C2154;C2500;C2510;C3902;C3903;C3923;C3929;C3930;C3948;C4200;C4705;C4708;C4712;C5203;C5205;C6103;C6111;C7000;C7034
C0603
CAP NP_C0603_4.7UF
4.7uF
IC
9
C2301;C4005;C4008;C4701;C4714;C4715;C5200;C5301;C9101
C0603
CAP NP_C0603_2.2UF
2.2uF
IC
C5201
C0603
CAP NP_C0603_1UF
1uF
IC
C5208;C5211
C0805
CAP NP_C0805_22UF
22uF
IC
C2134;C2155;C2156;C2202;C2240
C0805
CAP NP_C0805_10UF
10uF
IC
C5216
CON2_0R8
TOUCH-4PIN_7.25MM_CON2_0R8_2PIN
2PIN_0.5mm
IC
J7001
CON2_0R8
TOUCH-4PIN_5.25MM_CON2_0R8_2PIN
2pin_0.5
IC
J7002;J7003
CON30-0R5-H1R2A
BL509-06G31-TAH1_1_CON30-0R5-H1
CON0.5/30P
IC
J5301
CON30PIN-0R5MM
CLAP070LF02CW_1_CON30PIN-0R5MM_
30PIN-DOWN
IC
J5200
CON39-06-1329-105
FH26-25S-0_0.3SHW-05_CON39-06-1
FH26-25S-0.3SHW(05)
IC
J4700
CON51_ZF0R6A
33PIN_1_CON51_ZF0R6A_CON0.6/51P
CON0.6/51P
IC
J5300
CRY2_6R90X1R40X1R30
CRYSTAL_2P_1G_CRY2_6R90X1R40X1R
32.768KHz
IC
Y2100
CRY4_3R20X2R50X0R80
CRYSTAL_4P_CRY4_3R20X2R50X0R80_
24MHz
IC
Y1200
CRY4_3R20X2R50X0R80
CRYSTAL_4P_CRY4_3R20X2R50X0R8_1
37.4MHz
IC
Y6100
CSP20_1R96X1R56X0R66
DCDC_SY827_CSP20_1R96X1R56X0R66
TCS4525
IC
U2200
E0402N
DIODE BI_DIR TRIG_E0402N_ST0561
ST0561D4
IC
ED5300;ED5301;ED5302;ED5303;ED5304;ED7007;ED7008;ED9101;ED9102;ED9103;ED9104;ED9105;ED9106;ED9107;ED9108
E0603
DIODE BI_DIR TRIG_E0603_PSUR161
PSUR1610DNV07/RSD8535MA/BTRD06B800A
IC
D2515
ESD0402
DIODE BI_DIR TRIG_ESD0402_ESD53
ESD5341N
IC
17
D2500;D2504;D2513;D2514;D4200;D4201;D4202;D4203;D4204;D4205;D4206;D9100;D9101;ED5000;ED5001;ED5002;ED5003
ESD0402
DIODE BI_DIR TRIG_ESD0402_ESD54
ESD5451N
IC
D9200;D9201;D9202;ED7000;ED7001;ED7002;ED7004;ED7005;ED7006;ED7009
ESD0402
DIODE_TVS_BIDIR_ESD0402__B72590
B72590D0050H160
IC
TVS2501
FLASH-LED
FH26-25S-0_1.3SHW-05_FLASH-LED_
SPEAK1
IC
J4701
GSL3675
GT800_1_GSL3675_GSL3676
GSL3676
IC
U5300
HDMI-MINI-19PIN-COR
HDMI_C_HDMI-MINI-19PIN-COR_HDMI
HDMI_C
IC
J5000
IND_252010
INDUCTORS OF FERRITE_IND_252010
470nH
IC
L2100;L2101;L2102;L2103;L2104
IND_252012
INDUCTORS OF FERRITE_IND_252012
0.24uH
IC
L2200
IND_303012
INDUCTORS OF FERRITE_IND_303012
4.7uH
IC
L6103
IND_303015
INDUCTORS OF FERRITE_IND_303015
2.2uH
IC
L5201
IND_404030
INDUCTORS OF FERRITE_IND_404030
10uH
IC
L5200
L0402
INDUCTOR_L0402_DNP
DNP
IC
L6101;L6102
L0402
INDUCTOR_L0402_600R-100M
600R-100M
IC
L7003;L7004
L0603
BEAD_L0603_120R-100MHZ
120R-100MHz
IC
FB2100
L0603
BEAD_L0603_180R-100M
180R-100M
IC
FB7001;FB7002;L4700;L7002
LGA14-2R5X3
U / ITG-1010_0_LGA14-2R5X3_DNP/
DNP/ICM-20600
IC
U9002
MARK
MARK_MARK_MARK
MARK
IC
M9900;M9901;M9902;M9903;M9904;M9905
MC3433
MC3413-P-HF_0_MC3433_SC7A20
SC7A20
IC
U9003
MD44_AP6XXX
MODULE_AP6XXX_MD44_AP6XXX_AP625
AP6255
IC
U6100
MM4829-2702B
ANT_0_MM4829-2702B_ANT_JACK
ANT_JACK
IC
ANT6101
MSOP8
AMPLIFIER_PT1505_MSOP8_TT8642
TT8642
IC
U7005
PJ18-05AB03-XX
LS_JAF00-05382-0304
PJ301-6
IC
JP7001
QFN5X5-40PINA
GT800_0_QFN5X5-40PINA_CST21680S
CST21680SE
IC
U5301
QFN24_2R50X3R40X0R90
BCT642_QFN24_2R50X3R40X0R90_BCT
BCT642
DISCRETE
U4700;U4702
QFN68_7R00X7R00X0R80_T
PMIC_RK817_5_QFN68_7R00X7R00X0R
PMIC_RK817_5
IC
U2100
R0201
RESISTOR_R0201_120R
120R
IC
R1100
R0201
RESISTOR_R0201_22R
22R
DISCRETE
R1200;R1310;R1313;R2130;R2257;R2530;R2537;R4200;R4201;R4202;R4203;R4204;R4205;R4705;R4706;R6103;R6108;R9100;R9101
R0201
RESISTOR_R0201_1M
1M
IC
R1202;R5200;R6127
R0201
RESISTOR_R0201_2.2K
2.2K
IC
R1205;R1206;R1615;R1616;R1621;R1622;R1820;R1821
R0201
RESISTOR_R0201_10K
10K
IC
16
R1500;R2301;R2500;R4003;R4004;R4005;R5000;R5002;R5208;R5228;R5229;R6129;R7025;R7026;R7028;R9006
R0201
RESISTOR_R0201_0R
0R
DISCRETE
R1510;R2534;R4000;R4001;R4002;R4100;R4101;R4103;R4104;R4105;R4106;R4700;R4721;R5203;R6102;R7021;R7022;R7023;R7024;R7027
R0201
RESISTOR_R0201_2.2R
2.2R
DISCRETE
R1704;R1705;R1706;R1707;R1708;R1709;R1710;R1711
R0201
RESISTOR_R0201_1.62K
1.62K
IC
R1713
R0201
RESISTOR_R0201_4.7K
4.7K
IC
R2303;R4102;R4107;R4108
R0201
RESISTOR_R0201_15K
15K
IC
R2501
R0201
RESISTOR_R0201_DNP
DNP
IC
13
R2531;R2532;R2533;R2535;R2536;R5204;R5232;R5234;R5236;R7020;R9005;R9008;R9009
R0201
RESISTOR_R0201_47K
47K
IC
R4006
R0201
RESISTOR_R0201_DNP/0R
DNP/0R
IC
R4701;R4702;R4703;R4704
R0201
RESISTOR_R0201_1.8K
1.8K
IC
R5001;R5003
R0201
RESISTOR_R0201_1K
1K
IC
R5004
R0201
RESISTOR_R0201_27K
27K
IC
R5005;R5006
R0201
RESISTOR_R0201_100K
100K
IC
R5007;R5201;R5205;R6126
R0201
RESISTOR_R0201_51K
51K
IC
R5209
R0201
RESISTOR_R0201_DNP/10K
DNP/10K
IC
R5230;R5231;R5233;R5235;R5238;R5239
R0402
RESISTOR_R0402_0R
0R
DISCRETE
30
R1201;R1209;R1404;R1715;R1716;R2119;R2121;R2126;R2128;R2132;R2136;R2137;R4711;R5008;R5014;R5220;R5222;R5237;R5301;R5303;R6105;R6130;R7003;R7012;R7013;R7015;R9003;R9004;R9011;R9115
R0402
RESISTOR_R0402_1R
1R
IC
R1400;R1402;R1613;R1618;R1700;R1702
R0402
RESISTOR_R0402_100R
100R
IC
R2105;R2115;R2203;R7001;R7017;R9200
R0402
RESISTOR_R0402_47K
47K
IC
R2117;R4207;R4720
R0402
RESISTOR_R0402_120K
120K
IC
R2120
R0402
RESISTOR_R0402_DNP/10K
DNP/10K
IC
R2124;R4208;R4724;R5212
R0402
RESISTOR_R0402_10K
10K
IC
13
R2125;R2129;R2304;R3902;R4715;R4716;R4719;R4722;R4723;R5013;R5218;R6107;R7014
R0402
RESISTOR_R0402_DNP
DNP
IC
R2134;R4718
R0402
RESISTOR_R0402_51K
51K
IC
R2202
R0402
RESISTOR_R0402_DNP/1M
DNP/1M
IC
R2219
R0402
RESISTOR_R0402_2.2R
2.2R
DISCRETE
R2502;R2503;R2523;R2526
R0402
RESISTOR_R0402_240R
240R
IC
R3900;R3901
R0402
RESISTOR_R0402_1M
1M
IC
R4206
R0402
RESISTOR_R0402_DNP/0R
DNP/0R
IC
R4712;R4713;R5214;R5215;R5219;R5223;R5227;R5302
R0402
RESISTOR_R0402_100K
100K
IC
R4714;R5012;R7018;R7019
R0402
RESISTOR_R0402_75K
75K
IC
R5202
R0402
RESISTOR_R0402_2K
2K
IC
R5210
R0402
RESISTOR_R0402_39K
39K
IC
R5211;R5217
R0402
RESISTOR_R0402_1K
1K
IC
R5216
R0402
RESISTOR_R0402_5.1K
5.1K
IC
R5221
R0402
RESISTOR_R0402_15K
15K
IC
R5224
R0402
RESISTOR_R0402_3.9K
3.9K
IC
R5225
R0402
RESISTOR_R0402_2.2K
2.2K
IC
R5226;R7002;R7016
R0402
RESISTOR_R0402_15R
15R
IC
R9010
R0402
RESISTOR_R0402_3K
3K
IC
R9201
R0603
RESISTOR_R0603_0.05R
0.05R
IC
R2100;R2101;R2102;R2103;R2104;R2106;R2110;R2111;R2112;R2300;R2302;R2305
R0603
RESISTOR_R0603_0R
0R
IC
R2524;R3903;R5011;R6128
R0603
RESISTOR_R0603_DNP/4.7R
DNP/4.7R
IC
R4710
R0805
RESISTOR_R0805_0.02R
0.02R
IC
R2107;R2108;R2113;R2131
R0805
RESISTOR_R0805_0.01R
0.01R
IC
R2123;R2201
R0805
RESISTOR_R0805_DNP
DNP
IC
R2133;R2135;R5207
R0805
RESISTOR_R0805_4.7R
4.7R
IC
R4717
R0805
RESISTOR_R0805_1.65R
1.65R
IC
R5206
RP2_0405
INDUCTOR COM_RP2_0405_NC/MCZ121
NC/MCZ1210DH900L2TA0G
IC
L1700
RP2_0405
INDUCTOR COM_RP2_0405_DNP
DNP
IC
L2500;L2502
SOD_123
DIODE_SOD_123_B5819W
B5819W
IC
D5002;D5200;D5205
SOD_123
DIODE ZENER1_SOD_123_BZT52B6V8
BZT52B6V8
IC
D5201
SOD_123
DIODE ZENER1_SOD_123_BZT52B18
BZT52B18
IC
D5203
SOD_323
DIODE_SOD_323_B5819WS
B5819WS
IC
D5000;D5001
SON10_2R50X1R00X0R50
ESD_ESD5304D_SON10_2R50X1R00X0R
ESD5304D
IC
U5000;U5001
SOT23
MOSFET P_SOT23_TCS1401-C
TCS1401-C
IC
Q4700
SOT23
MOSFET P_SOT23_DNP/WPM2026
DNP/WPM2026
IC
Q6102
SOT26
DCDC_MP1488_SOT26_TCS5226
TCS5226
IC
U5200
SOT26
RT9271_0_SOT26_TCS3256
TCS3256
IC
U5201
SOT_23
DIODE DOUBLE F_SOT_23_BAT54S
BAT54S
IC
D5202;D5204
SOT_23
MOSFET P_SOT_23_DNP/WPM2341-3/T
DNP/WPM2341-3/TR
IC
Q2204
SOT_23
MOSFET P_SOT_23_WPM3407-3/TR
WPM3407-3/TR
IC
Q4203;Q5200
SOT_23
NPN_SOT_23_S8050
S8050
IC
Q5201;Q5202
SOT_23_5
LDO_PT5108_SOT_23_5_RT9193-18GB
RT9193-18GB
IC
U2300
SOT_23_5
LDO_PT5108_SOT_23_5_DNP/PT5108E
DNP/PT5108E23E-18
IC
U3901
SOT_23_5
LDO_PT5108_SOT_23_5_PT5108E23E-
PT5108E23E-12
IC
U4701
SOT_23_5
SWITCH_SY6280_SOT_23_5_SY6280AA
SY6280AAC
IC
U5002
SOT_23_5
LDO_PT5108_SOT_23_5_PT5108E23_1
PT5108E23E-18
IC
U5202
SOT_323
MOSFET N_SOT_323_2SK3018
2SK3018
IC
Q5000;Q5001;Q5002
STK3171-018
CON / 10 / AXE510127_3_STK3171-
DNP/STK3311-A
IC
CON9000
T-1
TESTLOOP_T-1__TP30
tp30
IC
TP2501
TDWC06P-05
CON / 10 / AXE510127_11_TDWC06P
NC/6pin_0.5
IC
CON2405
TDWC06P-05
CON / 10 / AXE510127_3_TDWC06P-
DNP/6pin_0.5
IC
CON5300
TDWC06P-05
CON / 10 / AXE510127_4_TDWC06P-
6pin_0.5
IC
CON9001
TDWC06P-05
CON / 10 / AXE510127_0_TDWC06P-
6pin_0.5
IC
CON9200
TDWC06P-05-L
CON / 10 / AXE510127_2_TDWC06P-
6pin_0.5
IC
CON7001
TDWC010P-05-L
CON / 10 / AXE510127_12_TDWC010
DNP/6pin_0.5
IC
CON9101
TF9_TFP09-2-12B
TFCARD_SOCKET_TF9_TFP09-2-12B_T
TFP09-2-12B
IC
J4200
TP_0R70
TP_TP_0R70_GND
GND
IC
TP1301
TP_0R70
TP_TP_0R70_EMMC_D0/FLASH_D0
eMMC_D0/FLASH_D0
IC
TP1302
TP_0R70
TP_TP_0R70_TP_0.7
TP_0.7
IC
48
TP2201;TP4700;TP4701;TP4702;TP4703;TP4704;TP4705;TP4706;TP4707;TP4708;TP4709;TP4710;TP4711;TP4712;TP4713;TP4714;TP4715;TP4716;TP4717;TP4718;TP4719;TP4720;TP4721;TP4722;TP4723;TP4724;TP4725;TP4726;TP4727;TP4728;TP4729;TP4730;TP4731;TP4732;TP7001;TP7002;TP7003;TP7004;TP7005;TP9101;TP9102;TP9103;TP9104;TP9105;TP9106;TP9107;TP9108;TP9109
TP_1R00
TP_TP_1R00_TP_1.0
TP_1.0
IC
TP9110;TP9111;TP9112;TP9200;TP9201;TP9202;TP9203;TP9204
TSOP48_18R40X12R10X1R20
NANDFLASH_TSOP48_TSOP48_18R40X1
NAND_FLASH
IC
U4100
T_1
TP_T_1_TP_0.7
TP_0.7
IC
88
P53005301530253035304530553065307530853095310;P5311;P5312;P5313;P5314;P5315;P5316;P5317;P5318;P5319;P5320;P5321;P5322;P5323;P5324;P5325;P5326;P5327;P5328;P5329;P5330;P5331;P5332;P5333;P5334;P5335;P5336;P5337;P5338;P5339;P5340;P5341;P5342;P5343;P5344;P5345;P5346;P5347;P5348;P5349;P5350;P5351;P5352;TP5200;TP5201;TP5202;TP5203;TP5204;TP5205;TP5206;TP5207;TP5208;TP5209;TP5210;TP5211;TP5212;TP5213;TP5214;TP5215;TP5216;TP5217;TP5218;TP5219;TP5220;TP5221;TP5222;TP5300;TP5301;TP5302;TP5303;TP5304;TP5305;TP9000;TP9001;TP9002;TP9003;TP9004;TP9005
USB16-3190016-CF059-RA
USB31_TYPE_C_1_USB16-3190016-CF
USB_TYPEC_115H0
IC
J2501
WIFIANTA
ANT_1P1G_WIFIANTA_ANT4411DR
ANT4411DR
IC
ANT6100
YZT24
CON5_0_YZT24_CON5
CON5
IC
SHIELD1;SHIELD2;SHIELD3;SHIELD4;SHIELD5;SHIELD6;SHIELD7;SHIELD10
  • 打卡总天数:688
  • 打卡月天数:8
  • 打卡总奖励:2855
  • 最近打卡:2026-11-09 20:10:27
81
发表于 2021-7-15 16:45 | 显示全部楼层
发表于 2021-7-15 16:52 | 显示全部楼层
  • 打卡总天数:3
  • 打卡总奖励:10
  • 最近打卡:2026-09-30 11:52:54
61
终身成就奖特殊贡献奖优秀斑竹奖
发表于 2021-7-16 08:38 | 显示全部楼层
  • 打卡总天数:6
  • 打卡总奖励:16
36
 楼主| 发表于 2021-7-16 09:47 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:69
  • 打卡总奖励:208
  • 最近打卡:2026-09-11 13:37:01
发表于 2021-7-16 09:51 | 显示全部楼层
  • 打卡总天数:4
  • 打卡总奖励:13
  • 最近打卡:2026-06-01 16:36:28
9
发表于 2021-8-6 10:04 | 显示全部楼层
发表于 2021-8-25 23:30 | 显示全部楼层
  • 打卡总天数:871
  • 打卡月天数:10
  • 打卡总奖励:3242
  • 最近打卡:2026-11-10 13:49:51
37
PADS-180606高级班
发表于 2021-8-31 15:52 | 显示全部楼层
  • 打卡总天数:4
  • 打卡总奖励:13
9
发表于 2021-9-2 10:19 | 显示全部楼层
