查看: 7838|回复: 80
[Pads_VX.2x] MT8392+MT6166 MT6322 MT6333 MT6625 2个DDR3X16 通话平板电脑PCB 和原
    11万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2021-7-16 15:23:13 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NamePCB DecalPart TypeValue
    ANT701PAD_3PINCAR_KIT_/_MM8430-2610B_1ECT818000117
    ANT1201ANT/1P/SMD/818000378/ECTANTENNAECT 818000378
    ANT1202ANT/1P/SMD/818000378/ECTANTENNAECT 818000378
    BEAD401L0603BEADBLM18BD252SN1
    CON401J301T05GAGZL2CXJC-PJ2_1PJ-S3142
    CON600MM8130-2602CAR_KIT_/_MM8130-2600_2MM8130-2602
    CON803BBL1MM0.23MMW0.4MMPH30PIN-ZOV7645FB_13_2MAIN CAMERA CONNECTOR
    CON804BBL1MM0.23MMW0.4MMPH24PINSUB_CAMSUB CAMERA CONNECTOR
    CON807H3/SMD/P1.25/1.25A-WTT-3P/ZHENGHEOV7645FB_131.25A-WTT-3P(JD1)H1.85
    CON903LCD_40_0.5P_2.8H_HJ080NA-04FIPEX-20455-040E_440P-0.5PITCH, BOTTOM
    CON1102ZIF_H51/SMD/P0.3-Z33PIN_2AXT340124
    CON1204BBL1MM0.23MMW0.4MMPH10PINOV7645FB_3Wisky camera connector
    CON1211CAF11-08173-1514/9PIN/1.7HTF_CARD_8PINTF_CARD_8PIN
    CON1212S01-4B08F19ATF_CARD_0SIM
    CON2001CON20X2/SMD/M/AXT440124HEADER_1AXT440124
    D6SOT23BAT54SBAT54S
    D8SOT23BAT54SBAT54S
    D105819DIODE_SCHOTTKY_2B5819W
    D302DIODE/SMD/MMSZ5221BDIODE/ZENERMMSZ5231BT1G
    D401VR0402PG05BSESC_0ESD9L5.0ST5G
    D805RB551V-30(UMD2)DIODE_SCHOTTKY_6RB551V-30
    D901RCLAMP0524P/10P/SMDRCLAMP0524PRClamp0524P
    D902RCLAMP0524P/10P/SMDRCLAMP0524PRClamp0524P
    D903VR0402DIODE_DIACESD0603/SMD/NC
    D904VR0402DIODE_DIACESD0603/SMD/NC
    D905VR0402DIODE_DIACESD0603/SMD/NC
    D1201D/SMD/UMD2DIODE_SCHOTTKY_0UDZV 12B
    D1401RB551V-30(UMD2)DIODE_SCHOTTKY_6BAT54WS
    D1611DIODE/SMD/RB521CS-30D_/_RB521CS-30RB521CS-30
    EMI801FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FR
    EMI802FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FR
    EMI803FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FR
    EMI804FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FR
    F201DIPLEXER/6P/SMD/DP1608BL1608-05K2450_0DIPLEXER/6P/SMD/DP1608
    H1301DH1_6MMNSCREW_HOLE_3_0.5MMTOOLING_HOLE/4MM/NC
    H1302DH1_6MMNSCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NC
    H1303DH1_6MMNSCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NC
    H1304DH1_6MMNSCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NC
    H1305DH1_6MMNSCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NC
    J902LK-A151902PORT_HDMI_TYPE-AHDMI-TYPE-MINI
    L6L/IND/SMD/IHLP-2020AB-01INDUCTORVishay IHLP2020ABER2R2M01 (2.2uH)
    L306L/IND/SMD/2520INDUCTORMPH252010S2R2MT/2.2uH
    L307L/IND/SMD/2520INDUCTOR0.47uH
    L402L0603BEADBLM18BD252SN1
    L731L0402IND0
    L802L/IND/SMD/LVS-S3016INDUCTOR_1LQH44PN4R7MPOL(4.7uH)
    L803L/IND/SMD/LVS252010-2R2INDUCTORVLS252010T-4R7M (4.7uH)
    L1004L0402L_/_39_/_NH_/_0402L / NC / nH / 0402
    L1006L0402L_/_27_/_NH_/_020182nH
    L1008L0402L_/_8.2_/_NH_/_04025.6nH
    L1009L0402INDUCTOR_3L / NC / nH / 0402
    L1201L/IND/SMD/0603FERRITE_BEAD_SMD_0402560nH/MLF1608DR56J
    L1202L/IND/SMD/0603FERRITE_BEAD_SMD_0402560nH/MLF1608DR56J
    L1203L/IND/SMD/LVS252010-2R2INDUCTOR_1LQH2HPN4R7MG0L
    LED301LED/4P/SMD/19-237ADIODE_10SMLP36RGB1W
    MIC+1PIN-1.2X2TEST_POINT_DIP0_4.6TEST POINT
    NTC301R0402NTC_/_NCP15WF104F03RC_/_0402_NC
    NTC302R0402NTC_/_NCP15WF104F03RC_/_0402_NTC / NTCG103JF103F / 0402
    PL1L/IND/SMD/2520L_/_MDMK2020TR68MM_/_SMD2520PMSB25201T-R47MS
    Q801SOT2340852_43904
    Q802SOT23P_DGS_1SI2305
    Q803SOT2340852_43904/NC
    REC12PIN-2.5-1.5-1.2AUDIO_JACK_0EAO-4015-PFA
    REC2_NANT-1.5-2.5TEST_POINT_DIP0_4.6TEST POINT
    REC2_PANT-1.5-2.5TEST_POINT_DIP0_4.6TEST POINT
    SPK+1PIN-1.2X2TEST_POINT_DIP0_4.6TEST POINT
    SPK-1PIN-1.2X2TEST_POINT_DIP0_4.6TEST POINT
    SW1201KEY_RESETKEY_1POWER
    SW1301DSWDKEY_0POWER
    SW1304DSWDKEY_0POWER
    SW1305DSWDKEY_0POWER
    TP1367TP/SMD/0.5MMTEST_POINT_DIP0.6TEST POINT
    TP1378TP/SMD/0.5MMTEST_POINT_DIP0.6TEST POINT
    U1BGA64/SMD/P0.5/B0.27/SN65DSI83/SSN75LVDS83A_1SN65DSI83
    U2SC70/5P/SMD/P0.65/TLV70012DCKR1172X_5TLV70018DCK
    U3SC70/5P/SMD/P0.65/TLV70012DCKR1172X_5TLV70033DCK
    U5FBGA96/SMD/P0.8/3-IN-1IC_DDR3_X16_FBGA-96IC DDR3 x16 FBGA-96
    U6FBGA96/SMD/P0.8/3-IN-1IC_DDR3_X16_FBGA-96IC DDR3 x16 FBGA-96
    U12TSOT-23-6/SMD/P0.95/AT1316/SAPL5151_1TPS61165DBVT
    U13SOT23-6/SMDSY7208_2SY7208
    U201MT8392/VFBGA494/P0.4/B0.25/11.4X11.4MT8392_DDR3L_X16MT8392
    U301MT6323/VFBGA145/P0.4/B0.25/5.8X5.8MT6323_E1_1MT6322
    U302WLCSP20/P0.4/B0.25/2-IN-1NCP6335_1NCP6335 / FAN53555
    U503BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA169_BALL_EMMCSamsung KLM2G1HE3F-B001
    U605SKY77186SKY77701_0RF7241
    U608SKY77186SKY77701_1RF7242
    U609SKY77186SKY77701_2RF7248
    U610SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYRF1G88CA0B0A
    U611SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYRF1G95HQ0F0A
    U612SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYFH897MHA0F00
    U614SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYFH836MCA0F00
    U615XM0860SH-DL0601XM0860SH-DL0601XM0860SH-DL0672
    U616SKY77590PA_/_SKY77590_0PA / SKY77590
    U707SKY77186SKY77701_3RF7245
    U811MT6166/VFBGA104/P0.4/B0.25/4.6X4.6MT6166_3MT6166
    U901FILTER_EXC24CE_1FILTER_EXC24CE_2Filter_EXC24CE
    U903SOT23-6/SMDTEA1206T_0Onsemi CAT3200TDI-T3
    U906FILTER_EXC24CE_1FILTER_EXC24CE_3Filter_EXC24CE
    U907FILTER_EXC24CE_1FILTER_EXC24CE_4Filter_EXC24CE
    U909FILTER_EXC24CE_1FILTER_EXC24CE_5Filter_EXC24CE
    U910FILTER_EXC24CE_1FILTER_EXC24CE_6Filter_EXC24CE
    U1001MT6627-NS/MQFN40/SMD/P0.4/5X5MT6611_SMD_WLCSP-61_0MT6625_IPD_QFN40
    U1005TCXO/SMD/2.5X2.0/IT2205BETCXO_RAKON_SMD_4PMT6627 QVL TCXO
    U1006SAW/SMD/1.05X1.35SAFEB1G57KA0F00SAFEB1G57KE0F00
    U1010TSLP6/SMD/P0.4/BGA725L6/SNJG1107HB3_0BGA725L6
    U1101QFN52/SMD/P0.4/GT911/SGT800_0GT911
    U1201MT6605/MQFN32/SMD/P0.4/4X4/SMT3301-140_SMD_PBGA-140_0MT6605 QFN (32 Pins, 0.4mm pitch)
    U1208HALL_IC_AH1883HALL_IC_AH1883BU52011HFV/NC
    U1301MMA8452QADXL345_7KXCJK-1013
    U1302QFN30/SMD/MPU-300074ALVC74PW_1MPU-3050
    U1303WLCSP14/SMD/P0.4/B0.23/AK8963ADXL345_2AK8963C
    U1304ALS_APDS9930CM3623_2ADPS-9930
    U1401QFN72/SMD/P0.5/SII9022A/SAD9389BBCPZ-165_0SiI9024ACNU
    U1802MT6333/WLCSP30/P0.4/B0.25/2.1259X2.638YDA145_6MT6333
    U1904VQFN24/SMD/P0.5/BQ24196BQ24196_0bq24196
    U1905SOT23-5LED_DRIVER_SY8006SY8006AAC
    U9307CSP16/SMD/P0.4/B0.25/TPS6128X/SIC/BUCK/TPS6128TPS61280A
    VIB_GND1ANT-1.5-2.5TEST_POINT_DIP0_4.6TEST POINT
    VIB_POWER1ANT-1.5-2.5TEST_POINT_DIP0_4.6TEST POINT
    VR301VR0402VR0402EZJZ0V500AA
    VR1310VR0402VR0402_1EZJZ0V500AA
    WIFI_BT_GPS_ANTPAD_3PINCAR_KIT_/_MM8430-2610B_0PAD_3PIN
    X301CRYS/SMD/MS3V-T1RCRYSTAL_132K (MS3V-T1R)
    X600CRYS/SMD/D2.5X2.0/CT2520DB/KYOCERATCVCXO_2X / 26MHz / X1E000021043400
    X1201CRYS/SMD/FA-128QUARTZ_IQX0_1QUARTZ 27.12 Mhz /NC
    Z600BALUN/10P/SMD/BD2012SAW_1Balun / RFBLN2012090BM5T25
    重要提示:PCB作品文件展下载说明
    11万
    管理员
     楼主| 发表于 2021-7-16 15:25:17 | 显示全部楼层
    8层 1介盲埋孔 PCB设计。 PCB 是PADS VX2 版本。原理图ORCAD格式 。里面有两份参考原理图。原理图和PCB 有一点点差异。但是总体参考没问题。
    一起打包。回复可见下载。 独家发布。请不要转载网上。
    游客,如果您要查看本帖隐藏内容请回复
  • 签到天数: 325 天
    社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2021-7-16 15:43:31 | 显示全部楼层
    发表于 2021-7-16 15:44:48 | 显示全部楼层
    前天 08:29
  • 签到天数: 256 天
    4万
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模最爱沙发社区明星优秀斑竹奖宣传大使奖
    发表于 2021-7-16 16:03:47 | 显示全部楼层
    5 天前
  • 签到天数: 141 天
    1元学习Allegro(2期)旁听
    发表于 2021-7-16 16:19:17 | 显示全部楼层
    Allegro240812初级
    发表于 2021-7-16 21:49:34 | 显示全部楼层
    PADS20210616高级班
    发表于 2021-7-16 21:55:06 | 显示全部楼层
    昨天 21:33
  • 签到天数: 235 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2021-7-16 22:53:42 | 显示全部楼层
    发表于 2021-7-17 07:01:00 | 显示全部楼层
