各位大牛,我在win10(64bits)上安装了pads vx 2.2,都是按论坛上教程安装的。但是打开logic,layout都是出现以下窗口,然后进入演示模式。请问有人遇到过吗?如何解决?
No License was found for feature padslogic: You have specified the following license locations:
Using MGLS_LICENSE_FILE environment variable = C:\MentorGraphics\License.dat;
Using FlexNet default locations for license files.
The following FlexNet errors were found:
Server C:\MentorGraphics\License.dat: SIGN= keyword required but missing from the license certificate.
This is probably because the license is older than the application
You need to obtain a SIGN= version of this license from your vendor.
Feature: mgc_s
Missing: SIGN2=
License path: C:\MentorGraphics\License.dat;
FlexNet Licensing error:-114,582
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
Feature: mentorall_s
Missing: SIGN2=
Feature: xdesigner051_c
Missing: SIGN2=
available at "www.flexerasoftware.com". |
