查看: 16444|回复: 225
[Allegro17.4以下] 18层经典PCB XILINX XCVC1902-2MSEVSVA2197-ES9780+XCZU4 PCB原理图
  • 打卡总天数:2
  • 打卡总奖励:5
  • 最近打卡:2025-11-25 19:43:06
1257
人人为我,我为人人。
社区居民最爱沙发宣传大使奖终身成就奖社区明星忠实会员优秀斑竹奖
发表于 2021-11-28 23:01 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
B1BATTERY_BAT_TS518_TS621_DUAL_TSTS621E-FL11EBAT_TS518_TS621_DUAL
J5HDR_2X4_HDR_2X4_HDR_2X4HDR_2X4HDR_2X4
J8TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J10TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J11HDR_2X6_HDR_2X6_HDR_2X6HDR_2X6HDR_2X6
J12HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J1612V_RT_ANGLE_MINI_FIT_JACK_CON_39-30-1060CON_MOL_5569_6P
J17TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J26HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J29TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J34HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J36HDR_2X7_87832_1420_87832-142087832-142087832_1420
J37HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J45DDR4_1V2_288P_SMT_SKT_0_SOC_FCI10124677-0001001LFSOC_FCI_DDR4_288_DIMM
J51ASP_184329_01_ASP_184329_01_ASPASP_184329_01ASP_184329_01
J53ASP_184329_01_ASP_184329_01_ASPASP_184329_01ASP_184329_01
J60HDR_2X3_HDR_2X3_HDR_2X3HDR_2X3HDR_2X3
J63TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J64TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J72TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J77TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J112TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J117TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J202HDR_2X7_87832_1420_87832-142087832-142087832_1420
J203HDR_1X2_HDR_1X2_HDR_1X2HDR_1X2HDR_1X2
J204HFJ11_1G01E_L12RL_CON_ETH_HFJ11RJ45CON_ETH_HFJ111G01E_L12RL
J205HDR_2X4_HDR_2X4_HDR_2X4HDR_2X4HDR_2X4
J2065025700893_CON_MOL_10P_50257008CON_MOL_10P_5025700893CON_MOL_10P_5025700893
J207CONN_USB_C_CON_AMP_12401598E4_212401598E4#2ACON_AMP_12401598E4_2A
J209TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J212SEAF-30-05P0-L-08-1-A-K_SAMTEC_SAMTEC_SEAF_08X30SAMTEC_SEAF_30X8
J233FANHDR4_HDR_1X4_LOCK_MOLEX_0470470533000HDR_1X4_LOCK_MOLEX
J234HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J249TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J275TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J288FS1-Z38-20Z6-10_CON_TE_1551920_1551920-2CON_TE_1551920_2
J290TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J291TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J295TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J296TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J297TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J300HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J301HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J3025025700893_CON_MOL_10P_50257008CON_MOL_10P_5025700893CON_MOL_10P_5025700893
J306HDR_1X2_HDR_1X2_HDR_1X2HDR_1X2HDR_1X2
J3072301997-7_RJ45_28P_1O27MM_PTH_RRJ45RJ45_28P_1O27MM_PTH_RA_H27O24_TYCO
J308629104190121_WURTH_6291041901216.29104E+11WURTH_629104190121
J309CONN_JACK_RCA_CUI_RCJ_021_RCAJRCAJACKCUI_RCJ_021
J310HDR_2X9_HDR_MOLEX_87832_1820_08878321820HDR_MOLEX_87832_1820
J313HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J324TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J325HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J326HDR_2X4_HDR_2X4_HDR_2X4HDR_2X4HDR_2X4
J328SMA-5PIN_CONN_CARLISE_TM14_0084TM14-0084-00CONN_CARLISE_TM14_0084_00
J329SMA-5PIN_CONN_CARLISE_TM14_0084TM14-0084-00CONN_CARLISE_TM14_0084_00
J330SMA-5PIN_CONN_CARLISE_TM14_0084TM14-0084-00CONN_CARLISE_TM14_0084_00
J331SMA-5PIN_CONN_CARLISE_TM14_0084TM14-0084-00CONN_CARLISE_TM14_0084_00
J332QSFP_PLUS_CAGE_TYCO_1551892_1_11551892_1TYCO_1551892_1
J366DDR4_RDIMM_FENCE_DDR4_RDIMM_FENSL-13621FDDR4_RDIMM_FENCE
J367MECH_ZSFP_PLUS_1X2_CAGE_CAGE_192227728-1CAGE_19P_PTH_RA_1X2_ZSFP_2227728_TE
J368ZSFP_PLUS_CONNECTOR_NO_CAGE_CON2170088-2CON20_08MM_SMT_ZSFP_RA_2170088-2_TE
J369ZSFP_PLUS_CONNECTOR_NO_CAGE_CON2170088-2CON20_08MM_SMT_ZSFP_RA_2170088-2_TE
JP1PCIE_PWR_2X4_ASTRON_6652208-T006652208-T0003T-HASTRON_6652208-T0003T-H_A
L1IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L2IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L3IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L4IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L5IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L6IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L7IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L8IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L18IND_BEADC100X50X55L25N_FERRITE-FERRITE-120BEADC100X50X55L25N
L19IND_BEADC100X50X55L25N_FERRITE-FERRITE-120BEADC100X50X55L25N
L20IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L21IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L22IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L23IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L24IND_IND_COIL_SCL7649_36NH36NHIND_COIL_SCL7649
L31IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L32IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L39IND_IND_WURTH_744355047_470NH470NHIND_WURTH_744355047
L41IND_IND_BOURNS_SRN2512_0.68UH0.68UHIND_BOURNS_SRN2512
L54IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L55IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L56IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L57IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L58IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65
L60IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L61IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L62IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L65IND_IND_MUR_2520_470NH470NHIND_MUR_2520
L66IND_IND_MUR_2520_470NH470NHIND_MUR_2520
L67IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520
L68IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520
L69IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520
L71IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L72IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L73IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L74IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L75IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L76IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L77IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L78IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L79IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L81IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L82IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L83IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L84IND_IND_SRP4020TA_2.2UH2.2UHIND_SRP4020TA
L87IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L88IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L89IND_IND_SRP4020TA_2.2UH2.2UHIND_SRP4020TA
L90IND_IND_SRP4020TA_2.2UH2.2UHIND_SRP4020TA
L93IND_IND_SRP7050TA_680NH680NHIND_SRP7050TA
L94IND_IND_SRP7050TA_680NH680NHIND_SRP7050TA
L95IND_IND_SRP7050TA_680NH680NHIND_SRP7050TA
L96IND_INDC1050X1020X470_720NH720nHINDC1050X1020X470
L97IND_IND_IHLP2020BZ_ER_4.7UH4.7UHIND_IHLP2020BZ_ER
L98IND_IND_IHLP2020BZ_ER_4.7UH4.7UHIND_IHLP2020BZ_ER
L99IND_IND_IHLP2020BZ_ER_4.7UH4.7UHIND_IHLP2020BZ_ER
L100IND_IND_IHLP2020BZ_ER_4.7UH4.7UHIND_IHLP2020BZ_ER
L101IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L102IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L103IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L108IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L109IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L112IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L113IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L114IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L115IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L118IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L127IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L128IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L132IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L133IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L134IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L135IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L136IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L137IND_IND_COIL_1008AF_5.8UH5.8UHIND_COIL_1008AF
L138IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L139IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AF
L140IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AF
L141IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AF
MH11HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
MH12HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
MH14HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
MH23HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
MH26HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
P2HDMI_DUAL_STACKED_CON_TE_1888811888811-1CON_TE_1888811_1
P3CON_PCI_EXPRESS_X8_PCIE_8LANE_EPCIE_8LANE_EDGEGen4PCIE_8LANE_EDGE_GEN4
Q1FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q2FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q3FET-3PIN_SOT_23_2N7002_2152N7002_215SOT_23
Q4FET-3PIN_SOT_23_2N7002_2152N7002_215SOT_23
Q5FET-3PIN_SOT_23_2N7002_2152N7002_215SOT_23
Q8FET-3PIN_SOT_23_SI2300DSSI2300DSSOT_23
Q13FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q33FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q34FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q35FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q36FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q37FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q38FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q39SI7157DP_PWR_56_V02_SI7157DPSI7157DPPWR_56_V02
Q40SI7157DP_PWR_56_V02_SI7157DPSI7157DPPWR_56_V02
Q41RUM001L02T2CL_SOT_723_RUM001L02RUM001L02T2CLSOT_723
Q42NDS336P_SOT_23_FDN336PFDN336PSOT_23
Q43FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
SHIELD1FF-VCK190-1588-SHIELD_FF-VCK190FF-VCK190-1588-SHIELDFF-VCK190-1588-SHIELD
SW1SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8P
SW2PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW3SW_DIP_2_SW_SDA_4P_SDA02H1SBDSDA02H1SBDSW_SDA_4P
SW4PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW5PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW6SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8P
SW7PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW11SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8P
SW12PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW13SW_SLIDE_SPDT_SW_102_1261_EV_111101M2S3AQE2SW_102_1261_EV
SW14PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW15PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW16PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
U1XCVC1902VSVA2197_C_SOC_2197_092XCVC1902-2MSEVSVA2197-ES9780SOC_2197_092MM_IRON_IDI_HEAD
U2SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U3SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U4SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U5SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U6REF3012_SOT23_3_ISL60002DIH310ZISL60002DIH310Z-TKSOT23_3
U7SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14
U8LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U10TPS3890_WSON_6_155X155X80_TPS38TPS389001DSERWSON_6_155X155X80
U14SN74CB3Q3253_TSSOP065P620X120_1SN74CB3Q3253PWRTSSOP065P620X120_16
U15SN74CB3Q3253_TSSOP065P620X120_1SN74CB3Q3253PWRTSSOP065P620X120_16
U16SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U17TL1963A_33DCYR_DCY_R_DPSO_G4_TLTL1963A_33DCYRDCY_R_DPSO_G4
U18SN74AVC2T245_QFN40P140X180X55-1SN74AVC2T245QFN40P140X180X55-10
U20FT4232HL_LQFP_64_FT4232HL_LQFP6FT4232HL_LQFP64LQFP_64
U21SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U2293LC56B_SOIC8P127W390_93LC56B93LC56BSOIC8P127W390
U23SN74AVC2T245_QFN40P140X180X55-1SN74AVC2T245QFN40P140X180X55-10
U24MAX9100_SOP095P280X145_5_MAX910MAX9100SOP095P280X145_5
U25K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U26K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U27SBSMC_FILTER_SYFER_SBSM_2220_0.0.33UFFILTER_SYFER_SBSM_2220
U32SI570_SINGLE_SI570_10MHZ-160MHZ10MHZ-160MHZSI570
U33TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24
U34M24128-BR_TSSOP65P640X120_8_M24M24128-BRTSSOP65P640X120_8
U35TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24
U40TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U41TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U42TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U43SN65DP159RGZ_VQFN05P700X700X100SN65DP159RGZVQFN05P700X700X100_48_408EP
U44TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U45TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U46TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U47TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U48TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U49TPD12S016_UQFN04P210X410X55_24PTPD12S016RKTRUQFN04P210X410X55_24P
U50M24C64_TSSOP65P640X120_8_M24C64M24C64-WTSSOP65P640X120_8
U51TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U52TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U53TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U54TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U55TMDS181IRGZT_VQFN05P700X700X100TMDS181VQFN05P700X700X100_48_408EP
U56TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U57TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U58TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U59TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U60TCA9406DCUR_SOIC50P320X90X8_TCATCA9406DCURSOIC50P320X90X8
U61TPD4E05U06DQAR_DQA_R_PSON_N10_TTPD4E05U06DQARDQA_R_PSON_N10
U628T49N241_VFQFPN05P6X6X10_40_4658T49N241VFQFPN05P6X6X10_40_465EP
U63SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U64MAX6643_QSOP16_MAX_E16_1_MAX664MAX6643QSOP16_MAX_E16_1
U65INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U80IR3897_PWR_QFN_IR3897_17_IR3897IR3897PWR_QFN_IR3897_17
U99USB3320_QFN32_QFN05P500X500X100USB3320QFN05P500X500X100_32P_330EP
U100MIC2544A_1YM_SOIC_8_MIC2544A-1YMIC2544A-1YMSOIC_8
U101TPD2EUSB30_DRT_R_PDSO_N3_TPD2EUTPD2EUSB30DRTRDRT_R_PDSO_N3
U103SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6
U104X-SDM-01_IP4856CX25_SHIFTER_ADAX-SDM-01IP4856CX25_SHIFTER_ADAPTER
U105SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6
U107SN74AVC2T244_SON35P145X105X40_SSN74AVC2T244SON35P145X105X40
U109SN74AVC2T244_SON35P145X105X40_SSN74AVC2T244SON35P145X105X40
U110TJA1057_SOIC_8_TJA1057GT/3JTJA1057GT/3JSOIC_8
U122SN74AVC8T245_TSSOP_24_SN74AVC8TSN74AVC8T245TSSOP_24
U123SN74AVC8T245_TSSOP_24_SN74AVC8TSN74AVC8T245TSSOP_24
U124SN74AVC8T245_TSSOP_24_SN74AVC8TSN74AVC8T245TSSOP_24
U125XCZU4EGSFVC784_BGA784C08P28X8_2XCZU4-SFVC784BGA784C08P28X8_230X230X312
U128SN74AVC1T45_SC70_6_SN74AVC1T45SN74AVC1T45SC70_6
U129TPS3890_WSON_6_155X155X80_TPS38TPS389001DSERWSON_6_155X155X80
U130AND_GATE_SINGLE_SC70_5_SN74LVC1SN74LVC1G08SC70_5
U13188E1512_QFN56_QFN05P800X800X100M88E1512QFN05P800X800X100_56_437EP
U132K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U134DP83867ISRGZ_VQFN05P700X700X100DP83867ISRGZVQFN05P700X700X100_48_408EP
U135TPD4E05U06DQAR_DQA_R_PSON_N10_TTPD4E05U06DQARDQA_R_PSON_N10
U142SI5332F_PQFN05P500X500X100_32P_Si5332FD10259-GM1PQFN05P500X500X100_32P_220EP
U143TPS62480_VQFN05P260X310X100_16_TPS62480RNCRVQFN05P260X310X100_16
U144TPS62097_VQFN05P210X210X100_11_TPS62097RWKRVQFN05P210X210X100_11
U145TPS7A83A_PVQFN05P365X365X100_20TPS7A8300ARGRRPVQFN05P365X365X100_20_200EP
U146TPS62097_VQFN05P210X210X100_11_TPS62097RWKRVQFN05P210X210X100_11
U147TPS62097_VQFN05P210X210X100_11_TPS62097RWKRVQFN05P210X210X100_11
U150K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U151K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U152IR35215_QFN04P500X500X85_40_370IR35215QFN04P500X500X85_40_370
U153TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U154TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U155TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U156TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U157TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U158TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U159TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U160IRPS5401_IRPS5401MTRPBF_IRPS540IRPS5401IRPS5401MTRPBF
U161INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U162INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U163INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U164INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U165INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U166INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U167IRPS5401_IRPS5401MTRPBF_IRPS540IRPS5401IRPS5401MTRPBF
U168INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U172INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U173INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U174INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U175IRPS5401_IRPS5401MTRPBF_IRPS540IRPS5401IRPS5401MTRPBF
U176INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U177INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U184INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U185IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26
U186INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U187IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26
U188INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U189IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26
U190IR3889_QFN_IR3889_36_IR3889IR3889QFN_IR3889_36
U191IR3889_QFN_IR3889_36_IR3889IR3889QFN_IR3889_36
U192SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U198DP83867ISRGZ_VQFN05P700X700X100DP83867ISRGZVQFN05P700X700X100_48_408EP
U199SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6
U200SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U201MAX8869EUE18_TSSOP_16_EP_MAX886MAX8869EUE18+TSSOP_16_EP
U203SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6
U204SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U205SI570_SI570_10_TO_810MHZ10_TO_810MHZSI570
U206SI53340_QFN16_SI_3X3MM_SI53340-SI53340-B-GMQFN16_SI_3X3MM
U210PCA9306DCTR_DCT_R_PDSO_G8_PCA93PCA9306DCTRDCT_R_PDSO_G8
U211PCA9306DCTR_DCT_R_PDSO_G8_PCA93PCA9306DCTRDCT_R_PDSO_G8
U212PCA9306DCTR_DCT_R_PDSO_G8_PCA93PCA9306DCTRDCT_R_PDSO_G8
U213PCA9306DCTR_DCT_R_PDSO_G8_PCA93PCA9306DCTRDCT_R_PDSO_G8
U214TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24
U216SN74AVC1T45_SC70_6_SN74AVC1T45SN74AVC1T45SC70_6
U217U7836LF_OSC_RAKON_U7836LF_38.4M38.4MHZOSC_RAKON_U7836LF
U218TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20
U2198A34001_CABGA_144P80_(S1+S2+S3)8A34001CABGA_144P80
U220TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20
U221AND_GATE_SINGLE_SC70_5_SN74LVC1SN74LVC1G08SC70_5
U22224LC64_SOIC127P600X175_8_24FC1024FC1025T-I/SNSOIC127P600X175_8
U223LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U225LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U226LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U227LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U228LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U229LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U230LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U231LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U232LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U233TCA6416A_TSSOP_24_TCA6416ATCA6416ATSSOP_24
U234INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U235SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14
U236LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U238SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U239SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U240NC7SZ66_SC70_5_SC70_5_NC7SZ66P5NC7SZ66P5XSC70_5
U241NC7SZ66_SC70_5_SC70_5_NC7SZ66P5NC7SZ66P5XSC70_5
U242SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U243LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U244SIT5358AN-FR-33E0_OSC_SIT5358_554.000000MHzOSC_SIT5358_500X320X095
U245ICS85411AMLF_SOIC_8_ICS85411AMLICS85411AMLFSOIC_8
X1FC-13A_XTAL_XTAL_FC13A_32.768KH32.768KHZXTAL_FC13A
X2TPD4S012_DRY_6_SON_TPD4S012TPD4S012DRY_6_SON
X3FA238_XTAL_EPSON_FA238_12.00MHZ12.00MHZXTAL_EPSON_FA238
X5XTAL_40MHZ_XTAL4P_320X250X60_4040.00MHZXTAL4P_320X250X60
X7MA506_XTAL_MA506_25.00MHZ25.00MHZXTAL_MA506
X8CRYS_2_XTAL_HCM49_24.000MHZ24.000MHZXTAL_HCM49
X9ABM8_XTAL_XTAL_ABM8_25.00MHZ25.00MHZXTAL_ABM8
X10ABM8_XTAL_XTAL_ABM8_25.00MHZ25.00MHZXTAL_ABM8
重要提示:PCB作品文件展下载说明
人人为我,我为人人。希望大家下载资料的同时能回帖支持,你们的支持,是我最大的共享动力。不回帖以后不共享了。哈哈
  • 打卡总天数:2
  • 打卡总奖励:5
1257
人人为我,我为人人。
 楼主| 发表于 2021-11-28 23:06 | 显示全部楼层
文件解压出来差不多 80M 。 回复可见
游客,如果您要查看本帖隐藏内容请回复
点评
  • 打卡等级:以坛为家I
  • 打卡总天数:73
  • 打卡总奖励:231
  • 最近打卡:2026-09-20 11:08:12
752
PADS20220105初级班
发表于 2021-11-28 23:43 | 显示全部楼层
点评
打广告苏打  详情 回复 发表于 2026-9-22 08:02
  • 打卡总天数:533
  • 打卡总奖励:1802
  • 最近打卡:2026-10-18 23:23:25
发表于 2021-11-29 02:02 | 显示全部楼层
  • 打卡总天数:566
  • 打卡月天数:9
  • 打卡总奖励:1684
  • 最近打卡:2026-11-13 09:23:17
43
7万
发表于 2021-11-29 06:04 | 显示全部楼层
发表于 2021-11-29 06:50 | 显示全部楼层
  • 打卡总天数:262
  • 打卡总奖励:1113
  • 最近打卡:2026-10-29 09:12:35
114
发表于 2021-11-29 07:02 | 显示全部楼层
发表于 2021-11-29 08:01 | 显示全部楼层
  • 打卡总天数:379
  • 打卡总奖励:1331
  • 最近打卡:2025-07-12 21:21:35
743
终身成就奖特殊贡献奖原创先锋奖金点子奖优秀斑竹奖
发表于 2021-11-29 08:42 | 显示全部楼层
  • 打卡总天数:634
  • 打卡月天数:14
  • 打卡总奖励:2315
  • 最近打卡:2026-11-14 09:22:06
14
1元学习Pads(221219)旁听
发表于 2021-11-29 08:45 | 显示全部楼层
