| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CL1 | C/ 1 / UF / 0201_SMC0201_0.1_2 | 0.1uF/10V | SMC0201 |
| CON1 | CAR_KIT/ MM8130-2600_1_ECT8180 | ECT818000291 | ECT818000291 |
| CON2 | CONRF I-PEX MHF-20279_0_CON_AN | SLE-100010077 | CON_ANT_4 |
| CON3 | CAR_KIT/ MM8130-2600_1_ECT8180 | ECT818000291 | ECT818000291 |
| CON5 | CONFPC 10PIN 0_2.5MM PITCH_FPC | FPC10_0_5MM_XG | FPC_10PIN_0_5MM_XG |
| CON6 | CONFPC 10PIN 0_0.5MM PITCH_WTB | 1.25T-4-5AW | WTB6T12-5P |
| CON7 | CON/ 5 / EJ-36952-10-GP_ER-J94 | ER-J941-R05GA-WZL2-C | ER-J941-R05GA-WZL2-C |
| CV10 | TEST_POINT_TP_0_5MM_TEST_POINT | TEST_POINT | TP_0_5MM |
| CV11 | TEST_POINT_TP_0_5MM_TEST_POINT | TEST_POINT | TP_0_5MM |
| CV12 | TEST_POINT_TP_0_5MM_TEST_POINT | TEST_POINT | TP_0_5MM |
| D1 | DBAV99 200MA 70V SOT-23_SOT_23 | BAV99 | SOT_23 |
| D2 | DIODE_SOD-123_SS1040L | SS1040L | SOD-123 |
| D3 | DBAV99 200MA 70V SOT-23_SOT_23 | BAV99 | SOT_23 |
| D4 | DIODE_SOD-123_B5819W | B5819W | SOD-123 |
| D5 | DIODE_SOD-123_B5819W | B5819W | SOD-123 |
| D8 | BAT54S/SOT_2_DFN2_0X_20-3L_ESD5 | ESD5641DXX | DFN2_0X_20-3L |
| FB1 | BEAD0603_0_FB0603-T_0R/5%_EL4. | 0R/5% | FB0603-T |
| FB2 | FB/ BLM18BD252SN1 / 0603_0_L04 | SZ1005K182CTF | L0402-T |
| FB5 | FB/ BLM18BD252SN1 / 0603_0_L04 | SZ1005K182CTF | L0402-T |
| FB6 | FB/ BLM18BD252SN1 / 0603_0_L04 | SZ1005K182CTF | L0402-T |
| FW1 | BL1608-05K2450_1_FILTER_SMD_LFD | TP2012-A1255DA | FILTER_SMD_LFD211G57ME3 |
| GND1 | TEST_POINT_TP_1_0MM_TEST_POINT | TEST_POINT | TP_1_0MM |
| J1 | IRM-6638TS45_0_FPC_06PIN_0_5MM_ | 6P-0.5mmH1.5 | FPC_06PIN_0_5MM_XG_V2 |
| J2 | BANGDING-PIN-50S_0_FPC51_0_3MM_ | COTEX-FPC0310-51B2-G1R | FPC51_0_3MM_XG_1 |
| J3 | CON40_1_FPC30_0_5MM_XG_1_5_705_ | FPC-0_3 | FPC30_0_5MM_XG_1_5_705 |
| J4 | EJ080NA-04B_0_FPC45_0_3MM_XG_CO | COTEX-FPC0310-45B2-G1R | FPC45_0_3MM_XG |
| J5 | IRM-6638TS45_2_FPC06-0_5MM-09MM | COTEX-FPC0509-06B3-G1R-B | FPC06-0_5MM-09MM-XG |
| J6 | ST30L_8_FPC39_0_3MM_XG_1_COTEX- | COTEX-FPC0310-39B2-G1R | FPC39_0_3MM_XG_1 |
| J7 | CON2_0_SPKPAD_TP1X3MM_FLASH | FLASH | SPKPAD_TP1X3MM |
| J8 | IRM-6638TS45_1_FPC_06PIN_0_5MM_ | COTEX-FPC0509-06B3-G1R-B | FPC_06PIN_0_5MM_XG_V2 |
| J9 | IRM-6638TS45_1_FPC_06PIN_0_5MM_ | COTEX-FPC0509-06B3-G1R-B | FPC_06PIN_0_5MM_XG_V2 |
| J10 | CON2_1_CON2_0_8MM_0.8T-WT-2A | 0.8T-WT-2A | CON2_0_8MM |
| J11 | USB_TYPE_C_RECEPTACLE_1_TYPE_C_ | USB_C_FTYPE | TYPE_C_XNTCU20-16CB080-KB |
| J12 | TFCARD TF-5010-03_2_TF_PUSH_CS | CSTT-102010909 | TF_PUSH_CSTT_102010909 |
| J13 | CON2_1_CON2_0_8MM_0.8T-WT-2A | 0.8T-WT-2A | CON2_0_8MM |
| J14 | C14-0_2.5K/FPC_FPC_06PIN_0_5MM_ | COTEX-FPC0509-06B3-G1R-B | FPC_06PIN_0_5MM_XG_V2 |
| J15 | CON2_1_CON2_0_8MM_0.8T-WT-2A | 0.8T-WT-2A | CON2_0_8MM |
| J16 | CON2_1_CON2_0_8MM_0.8T-WT-2A | 0.8T-WT-2A | CON2_0_8MM |
| J18 | CON2_1_CON2_0_8MM_0.8T-WT-2A | 0.8T-WT-2A | CON2_0_8MM |
| J33 | FPC_21PIN_0_0_FPC21_0_3MM_XG_1_ | FPC_21PIN_0_3 | FPC21_0_3MM_XG_1 |
| L1 | L/IND/SMD/2520_1_CDH2520_CCHB-2 | CCHB-252012-R33-M | CDH2520 |
| L2 | L/IND/SMD/2520_1_CDH2520_CCHB-2 | CCHB-252012-R33-M | CDH2520 |
| L3 | L/IND/SMD/2520_1_CDH2520_CCHB-2 | CCHB-252012-R33-M | CDH2520 |
| L4 | L/ 2.2 / NH / 0201_L0201-T_1NH | 1nH | L0201-T |
| L5 | C/ 1 / NF / 0402_SMC0201_1NF/5 | 1nF/50V | SMC0201 |
| L6 | L/ LQM18NN82NM00_L0402-T_VHF10 | VHF100505HQ82NJT | L0402-T |
| L7 | INDUCTOR_0_CDH28B16_WLPQHD3015F | WLPQHD3015F100ME | CDH28B16 |
| L8 | INDUCTOR_CDH3B16_WLPQHD3015F100 | WLPQHD3015F100ME | CDH3B16 |
| L9 | INDUCTOR_1_CDH3B16_WLPQHD4015F2 | WLPQHD4015F2R2ME | CDH3B16 |
| L10 | INDUCTOR_CDH3B16_PSPNAF4015-1R0 | PSPNAF4015-1R0N | CDH3B16 |
| L11 | L0201_L0201_0R | 0R | L0201 |
| M2801 | ANT_1_SMD_1R2X2R7_ANT/PCA2442A- | ANT/PCA2442A-12 | SMD_1R2X2R7 |
| M2802 | ANT_1_SMD_1R2X2R7_ANT/PCA2442A- | ANT/PCA2442A-12 | SMD_1R2X2R7 |
| M2803 | ANT_1_SMD_1R2X2R7_ANT/PCA2442A- | ANT/PCA2442A-12 | SMD_1R2X2R7 |
| M2804 | ANT_1_SMD_1R2X2R7_ANT/PCA2442A- | ANT/PCA2442A-12 | SMD_1R2X2R7 |
| MARK1 | TEST_POINT_ID-BOARD_TEST_POINT | TEST_POINT | ID-BOARD |
| MARK2 | TEST_POINT_ID-BOARD_TEST_POINT | TEST_POINT | ID-BOARD |
| MARK3 | TEST_POINT_ID-BOARD_TEST_POINT | TEST_POINT | ID-BOARD |
| MARK4 | TEST_POINT_ID-BOARD_TEST_POINT | TEST_POINT | ID-BOARD |
| MARK5 | TEST_POINT_ID-BOARD_TEST_POINT | TEST_POINT | ID-BOARD |
| MARK6 | TEST_POINT_ID-BOARD_TEST_POINT | TEST_POINT | ID-BOARD |
| NTC1 | NTC/ NCP03WF104F05RL / 0201_R0 | NTC/47K/1% | R0402-T |
| NTC2 | NTC/ NCP03WF104F05RL / 0201_R0 | NTC/47K/1% | R0402-T |
| NTC3 | TEST_POINT_TP_2X1MM_TEST_POINT | TEST_POINT | TP_2X1MM |
| NTC4 | NTC/ NCP03WF104F05RL / 0201_R0 | NTC/47K/1% | R0402-T |
| NTC10 | TEST_POINT_TP_1_0MM_TEST_POINT | TEST_POINT | TP_1_0MM |
| PL1 | PL/ 1 / UH / 2016_L_IND_SMD_ME | CRH201610S-1R0MT | L_IND_SMD_MEKK2016 |
| PL2 | PL/ 1 / UH / 2016_L_IND_SMD__1 | CRH201610S-2R2MT | L_IND_SMD_MEKK2016 |
| PL3 | PL/ 1 / UH / 2016_L_IND_SMD__1 | CRH201610S-2R2MT | L_IND_SMD_MEKK2016 |
| PL4 | PL/ 1 / UH / 2016_L_IND_SMD_ME | CRH201610S-1R0MT | L_IND_SMD_MEKK2016 |
| Q1 | QPFET 30V 4.2A AO3401A_SOT_23_ | CJ3401 | SOT_23 |
| Q2 | QKTC9014S NPN 50V 150MA SOT23_ | MMBT3904 | SOT_23 |
| Q3 | FDG6303_6_SOT-89-3L_V1_WPT2E33- | WPT2E33-3/TR | SOT-89-3L_V1 |
| Q4 | FDG6303_6_SOT-89-3L_V1_WPT2E33- | WPT2E33-3/TR | SOT-89-3L_V1 |
| Q5 | FDG6303_6_SOT-89-3L_V1_WPT2E33- | WPT2E33-3/TR | SOT-89-3L_V1 |
| Q6 | QPFET 30V 4.2A AO3401A_SOT23_A | AO3401 | SOT23 |
| Q7 | QKTC9014S NPN 50V 150MA SOT23_ | MMBT3904 | SOT_23 |
| RX1 | TEST_POINT_TP_1_0MM_TEST_POINT | TEST_POINT | TP_1_0MM |
| SH2 | SHORT/ 10MIL_NC_MMD_L1_20MIL_S | SHORT/ 10MIL | NC_MMD_L1_20MIL |
| SH4 | SHORT/ 10MIL_NC_MMD_L1_20MIL_S | SHORT/ 10MIL | NC_MMD_L1_20MIL |
| SIM1 | SA-1505-001_REV_X5_2_SIM_PUSH_C | csts_102322294 | SIM_PUSH_CSTS_102322294 |
| T1 | HOLEC335D185_0_HOLE_C3_5D1_8MM_ | THERM_HOLE | HOLE_C3_5D1_8MM |
| U1 | ASIC-SC2721G-166-0_0.4_BGA_166_ | ASIC-SC2721G-166-0.4 | BGA_166_P040 |
| U2 | FAN53555UC04X_BGA_20_P040_200X1 | FAN53555UC04X | BGA_20_P040_200X160_H063_B026 |
| U3 | 169BALL EMMC_0_BGA169-20-1414_ | QVLMemory | BGA169-20-1414 |
| U4 | LPDDR4_FBGA200_B0_34_2_IN_1_MIC | H9HCNNNBKUMLHR-NME | FBGA200_B0_34_2_IN_1_MICRON |
| U5 | SY8859QWC_0_QFN_7_P045_150X150_ | SY8859QWC | QFN_7_P045_150X150_H090_SY8859 |
| U6 | PA/ QM56022_0_SKY77643_RPM6743 | RPM6743-12 | SKY77643 |
| U7 | SR3595D_0_BGAS_123_P035_450X450 | SR3595D | BGAS_123_P035_450X450_H085_SR3595D |
| U8 | TXM/ RF5216_0_SKY77910_RTM7916 | RTM7916-31 | SKY77910 |
| U9 | IC/SP6T/SKY13416_1_SKY13414_XMS | XMSS2Q3G0PA-068 | SKY13414 |
| U11 | BB_SC9863A_BGA_774_P040_3_BGA_7 | BB_SC9863A_BGA_774_P040 | BGA_774_P040 |
| U12 | SGM2037-ADJXUDX6G/TR_SON_6_P040 | SGM2037-ADJXUDX6G/TR | SON_6_P040 |
| U13 | GSL1688_0_QFN40-0_4MM-5X5_V1_GS | GSL1680E | QFN40-0_4MM-5X5_V1 |
| U14 | MP1540DJ_SOT_25_SY7208CABC | SY7208CABC | SOT_25 |
| U15 | SSC9284_0_SOT_26_SY7200AABC | SY7200AABC | SOT_26 |
| U16 | GT9006_QFN40_0_QFN56-7X7-P0_4_G | GSL3676 | QFN56-7X7-P0_4 |
| U17 | KTD265_1_DFN3030-10L_WD3610DA | WD3610DA | DFN3030-10L |
| U18 | SOT-23/5P/SMD/P0.9395/RT9078/S_ | AF6212-28C | SOT_25 |
| U19 | MMA8452Q_0_LGA12_0_5_2X2MM_STK8 | STK8BA50-R | LGA12_0_5_2X2MM |
| U20 | APX9132ATI_TRL_SOT_23_APX9132HA | APX9132HAI-TRG | SOT_23 |
| U21 | U/ AK09918C_MMC5603NJL_4P_0_4M | MMC5603NJL/AK09918C | MMC5603NJL_4P_0_4MM |
| U22 | UMMA7660FC DFN-10_0_LGA14_0_5M | LSM6DSL | LGA14_0_5MM_3X2_5_0_86 |
| U23 | UMMA7660FC DFN-10_3_SMT-STK331 | STK3310_REV | SMT-STK3310-8P-V1 |
| U24 | MOSFETN_2_SOT523_PNM723T703E0- | PNM723T703E0-2 | SOT523 |
| U25 | LCOMMON CHOKE MCM1220B900G_0_C | MCM1220B900G | CCH-8565_0201 |
| U26 | LCOMMON CHOKE MCM1220B900G_0_C | MCM1220B900G | CCH-8565_0201 |
| U27 | RT9266PE_0_SOT_26_ETA1038S2G | ETA1038S2G | SOT_26 |
| U28 | U_RT9701_2_SOT_25_SY6280AAAC | SY6280AAAC | SOT_25 |
| U29 | U_RT9701_2_SOT_25_SY6280AAAC | SY6280AAAC | SOT_25 |
| U30 | AOZ6184_DPDT_0_LCC10_P4MM_1P8X1 | SGM7227YUWQ10G/TR | LCC10_P4MM_1P8X1P4 |
| U31 | LM4990_MSOP-8_NS4150B | NS4150B | MSOP-8 |
| U32 | LM4990_MSOP-8_NS4150B | NS4150B | MSOP-8 |
| U33 | SON8/SMD/P0_0.4/NCP186_DFN8-0_4 | NCP186AMX330TAG | DFN8-0_4MM-1_6X1_2 |
| U34 | SAWFD1G84AA0F0A_SAWFILTER_10P_S | SAWFD1G84AA0F0A | SAWFILTER_10P_SMD |
| U35 | SGM41511_2_QFN24_0_5MM_4X4_V2_S | SGM41511/BQ25611D/HL7019 | QFN24_0_5MM_4X4_V2 |
| U38 | SAFEA2G35MF0FA_FILTER_5_135X105 | SAFEA2G35MF0FA | FILTER_5_135X105_H050 |
| U39 | SAFEA2G35MF0FA_FILTER_5_135X105 | SAFEA2G35MF0FA | FILTER_5_135X105_H050 |
| U40 | SAFFB2G35AA0F0A_SFLT5-0101-005A | SAFFB2G35AA0F0A | SFLT5-0101-005A |
| U41 | SAFFB2G35AA0F0A_0_SFLT5-0101-00 | SAFFB2G35AA0F0A | SFLT5-0101-005A |
| U43 | U/ BGA824N6_TSLP6_SMD_P0_4_BGA | U/ BGA824N6 | TSLP6_SMD_P0_4_BGA725L6_S |
| U44 | SAFEB1G57KA0F00_0_CSP-5BT_EPCOS | EPCOS-B9444 | CSP-5BT |
| U45 | SOT-23/5P/SMD/P0.9395/RT9078/_1 | AF6212-33C | SOT_25 |
| U50 | WCN_UMW2651_BGA_204_P040 | WCN_UMW2651_BGA_204_P040 | BGA_204_P040 |
| U1805 | BPF/ ACPF-7124_0_SFLT5-0101-00 | BF1411-L2R4NCAT/LF | SFLT5-0101-005A |
| UB1 | DPX/ D5DA942M5K2S2_0_SFLT8-010 | D5DA942M5K2S2 | SFLT8-0102-006 |
| UB3 | DPX/ D6DA2G140K2A4_0_SFLT8-010 | D6DA2G140K2A4 | SFLT8-0102-006 |
| UB4 | DPX/ D6DA1G960K2B2_0_SFLT8-010 | D6DA1G960K2B2 | SFLT8-0102-006 |
| UB5 | DPX/ D6DA1G842K2C4_0_SFLT8-010 | D6DA1G842K2C4 | SFLT8-0102-006 |
| UB7 | DPX/ D6HQ2G655DP02_0_SFLT8-010 | D6HQ2G655DP02 | SFLT8-0102-006 |
| UB8 | DPX/ D5DA881M5K2E4_0_SFLT8-010 | D5DA881M5K2E4 | SFLT8-0102-006 |
| UB9 | DPX/ D5DA942M5K2S2_0_SFLT8-010 | D5DA942M5K2S2 | SFLT8-0102-006 |
| UB10 | DPX/ D6DA2G132K2D4_0_SFLT8-010 | D6DA2G132K2D4 | SFLT8-0102-006 |
| UD02 | SAW/ F6QA1G960M2AP_0_SFLT5-010 | SAFFB1G96AB0F0A | SFLT5-0101-005A |
| UD2 | SAW/ F6QA1G960M2AP_0_SFLT5-0_1 | SAFFB881MAN0F0A | SFLT5-0101-005A |
| UD3 | SAW/ F6QA1G842M2AN_0_SFLT5-010 | SAFFB2G65AA0F0A | SFLT5-0101-005A |
| UD4 | SAW/ F5QA881M5M2AU_0_SFLT5-010 | SAFFB806MAA0F0AR1X | SFLT5-0101-005A |
| UD6 | SAW/ F5QA942M5M2AW_0_SFLT5-010 | SAFFB942MAN0F0AR1X | SFLT5-0101-005A |
| UD7 | SAW/ F6QA2G350M2QA_0_SFLT5-010 | SAFFB2G35AA0F0A | SFLT5-0101-005A |
| UD9 | SAW/ F6FC2G600H4PA_0_SFLT5-010 | SAFEA2G60MA0F0AR15 | SFLT5-0101-005A |
| V37 | 1_0.5KE100A_TVS0402_TEVB3R0V05B | TEVB3R0V05B1X | TVS0402 |
| VBAT+1 | TEST_POINT_TP_1_0MM_TEST_POINT | TEST_POINT | TP_1_0MM |
| VBAT+2 | TEST_POINT_TP_5X2_5MM_TEST_POIN | TEST_POINT | TP_5X2_5MM |
| VBAT-1 | TEST_POINT_TP_5X2_5MM_TEST_POIN | TEST_POINT | TP_5X2_5MM |
| VBAT-2 | TEST_POINT_TP_1_0MM_TEST_POINT | TEST_POINT | TP_1_0MM |
| X1 | CRYSTAL_7_CRYSTAL2P2_5_32.768K | 32.768K(SSP-T7-F) | CRYSTAL2P2_5 |
| X2 | TMS/ OZ26030001_TCXO_2520_26_0 | 26_000MHzOZ26000004 | TCXO_2520 |
| YW1 | SMD_CRYSTAL_0_TCXO_2520_26_000M | 26_000MHz | TCXO_2520 |
