查看: 4939|回复: 33
[Pads_VX.2x] HI3751V350 +AD52050B做的微型投影仪 MINI投影机PCB和原理图
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2022-1-11 17:20:24 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NamePCB DecalPart TypeValue
    1C70C0805C080510uF_25V
    1C71C0805C080510uF_25V
    1C72C0805C080510uF_25V
    1C73C0805C080510uF_25V
    1Q7SOT-23Q_2BC847
    1Q8SOT-23Q_2MMBT3904
    1Q9SOT-23Q_2BC847
    1Q11SOT-23P-MOSFETWPM3401
    1Q12SOT-23P-MOSFETWPM3401
    1Q13SOT-23P-MOSFETWPM3401
    2Y1Y-SMD4P3225CRYSTAL-4P24MHz_CL12pF_20ppm
    3L2L3030L-POWER10uH_600A_DCR<=80mR
    5L1L0603INDUCTOR50 OHM/100MHZ
    7D5ESD0402TVS_DIODEPESDR0521P1
    10FB3L0805L0805600Rohm_100mhz_2.5A
    10FB4L0805L0805600Rohm_100mhz_2.5A
    10R40R0402R0603_32.2K_1%
    10R41R0402R0603_32.2K_1%
    11C4C0402CAPNP100nF
    11D2ESD0402TVS_DIODEPESDR0521P1
    11R1R0402R0603_24.7K
    11R12R0402R06031K
    11R15R0402R06034.7K
    CN1USB-2A-03USB-2A-03USB-2A-03
    CON4CN_52_S_0P50_HCONN_SMD-50_1RCONN SMD-50-0P50
    CU1SC0402C_0100NF
    CU2SC0805C_022UF/6.3V
    CU4SC0402C_0100NF
    CZ1SC0402C_0NC/100PF*
    CZ2SC0402C_0100PF
    CZ3SOT23-6SY81XXSY8120B1ABC
    CZ6SC0402C_030PF
    CZ7SC0402C_030PF
    CZ9C0402C_0100PF
    D2SOT-23BAS70-04/SOTBAT54S
    D7SOD-123DIODE_SCHOTTKY5.6V
    D8DIO-SOD323AADIODE_SCHTKY_0RB050L-60
    D9SOD-123DIODE_SCHOTTKY5.6V
    D10SOD-123DIODE_SCHOTTKY6.8V
    D11SOT-23BAS70-04/SOTBAT54S
    D12SOT-23BAS70-04/SOTBAT54S
    DH18ESD0402AZ5215-01F_1NC*
    DH19HSOD123AD_A_0D_A
    FU1SR1206FUSE_1FUSE
    J2PJ-327FPJ-327FSW-T1.5
    J3PJ-327FPJ-327FSW-T1.5
    J4CON6_0.5MMCON6_1.0MMCON6_0.5mm
    J10J-MS-156ANT-WIFII-PEX_RF-CON
    J58ZYA1250-FRS03CON3_0.5MMCON3_1.25mm
    J62CON4-1.25MMCON-4PIN-LED_0CON4-1.25MM
    J63CON7_1.25MM_SMDCON6_0.0MMCON7_1.25mm
    J70ZYA1250-FRS02CONN_2_SMDCON2_1.25
    J71ZYA1250-FRS02CONN_2_SMDCON2_1.25
    JH2HDMI-A-19NSMDWBC1X19S4M2_2WBC1X19S4M2
    JH3HDMI-A-19NSMDWBC1X19S4M2_2WBC1X19S4M2
    JZ2CON5_1.25MM_SMDCONN_5_SMDCONN 5 SMD/1P25
    JZ4CON4-1.25MMCONN_4_SMDCONN 4 SMD/1P25
    JZ13HEAD0101-T-BSIP1_0NC*
    JZ15HEAD0101-T-BSIP1_0NC*
    LA1L0805LBLB
    LA2L0805LBLB
    LA3L0805LBLB
    LA4L0805LBLB
    LBS1R_2_S_1L00_0W50LB_0LB
    LBS2SR0402R_00
    LBS3SR0402R_00
    LBS4R_2_S_1L00_0W50LB_0LB
    LP1SL2828L_04.7UH
    LP2SPL0404LL_03.9UH
    LP3SPL0404LL_02.2UH
    LP5SPL0404LL_02.2UH
    MZ2TEST-4.5MMHOLE-8STAR_0*
    MZ3TEST-4.5MMHOLE-8STAR_0*
    MZ5TEST-4.5MMHOLE-8STAR_0*
    MZ6TEST-4.5MMHOLE-8STAR_0*
    Q2SOT-23NPN(BEC)_13904
    Q3SOT-23Q_2BC847
    TP28TP_S_1D00TEST_POINT_DIP1_0.0TEST POINT DIP1_0.0
    U106223E-UUD6223E-UUD6223E-UUD
    U17SOT23-6ALPU-MPALPU-MP
    U66SOT-23-5MP1540MP1540
    U67SOP-8SI7898DP_0AO4401
    UA1HTSSOP28-26-173-H3R04X2R34TPA3110D2_2TPA3110D2
    UH4DFN10-050-2R5X1R0-DPTAZ1143-04F_2AZ1143-04F
    UH5DFN10-050-2R5X1R0-DPTAZ1143-04F_2AZ1143-04F
    UH6DFN10-050-2R5X1R0-DPTAZ1143-04F_2AZ1143-04F
    UH7DFN10-050-2R5X1R0-DPTAZ1143-04F_2AZ1143-04F
    UM1BGA153-20-1414AEMMC5_0_NC_4EMMC5_0_NC
    UP1SOT-23-5WL2003ESGM2019-3.3YN5G
    UP2SOT23-6SY81XXSY8120B1ABC
    UP3SOT563-0R50-1R6X1R2MP1652_3MP1652
    UP5SOT23-6SY81XXSY8120B1ABC
    UP9SOT-23-5WL2003ESGM2019-1.8YN5G
    US1BGA278-32-1921HI3751V350B_AV_9HI3751V350B_AV
    UU6SOT23-6AZC299-02S_2NC*
    UU7SOT23-6AZC299-02S_2NC*
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2022-1-11 17:21:40 | 显示全部楼层
    PCB原理图。赚10RMB。需要的下载。
    HI3751V350_PCB_DSN.7z (821 KB, 下载次数: 26)
    发表于 2022-1-11 17:32:42 | 显示全部楼层
    PADS20200601高级班
    发表于 2022-1-11 18:37:49 | 显示全部楼层
    3 小时前
  • 签到天数: 210 天
    你必须非常努力才能显
    发表于 2022-1-12 08:45:09 | 显示全部楼层
  • 签到天数: 5 天
    发表于 2022-1-12 08:55:17 | 显示全部楼层
    发表于 2022-1-12 08:58:45 | 显示全部楼层
    发表于 2022-1-12 09:56:08 | 显示全部楼层
    2 小时前
  • 签到天数: 157 天
    发表于 2022-1-13 08:51:13 | 显示全部楼层
    昨天 09:11
  • 签到天数: 65 天
    发表于 2022-1-13 08:58:12 | 显示全部楼层
