| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | TB8S_0_BRIDGE_SMD_B__TB8S | TB8S | BRIDGE_SMD_B |
| D2 | TB8S_0_BRIDGE_SMD_B__TB8S | TB8S | BRIDGE_SMD_B |
| D4 | ZD_0_DO-214AA_SMCJ58CA | SMCJ58CA | DO-214AA |
| D5 | ZD_DO-214AA_SS310 | SS310 | DO-214AA |
| D6 | 1_7.5KE100A_DO-214AB__SK810/100 | SK810/100V/NC | DO-214AB |
| D7 | 1_7.5KE100A_DO-214AB__SK810/1_1 | SK810/100V | DO-214AB |
| DS1 | LED-ANODE1_0_0603LED_GREEN | GREEN | 0603LED |
| DS2 | LED-ANODE1_0_0603LED_GREEN | GREEN | 0603LED |
| DS3 | LED-ANODE1_0_0603LED_GREEN | GREEN | 0603LED |
| DS4 | LED-ANODE1_0_0603LED_GREEN | GREEN | 0603LED |
| DS5 | LED-ANODE1_0_0603LED_GREEN | GREEN | 0603LED |
| DS6 | LED-ANODE1_0_0603LED_GREEN | GREEN | 0603LED |
| E1 | EC_EC3D5-8_33UF/100V | 33uF/100V | EC3D5-8 |
| E2 | IND_MAG_HIND_MAG2PIN_V1_2P040_2 | 120OHM@100MHZ | 2P0402R |
| E3 | L_2_2P0402R_120R/100MHZ/1.3A | 120R/100MHz/1.3A | 2P0402R |
| E4 | L_2_2P0402R_120R/100MHZ/1.3A | 120R/100MHz/1.3A | 2P0402R |
| E5 | L_2_2P0402R_120R/100MHZ/1.3A | 120R/100MHz/1.3A | 2P0402R |
| E6 | L_2_2P0402R_120R/100MHZ/1.3A | 120R/100MHz/1.3A | 2P0402R |
| E7 | L_2_2P0402R_BEAD/120R_100MHZ/1. | bead/120R_100MHz/1.3A/0402 | 2P0402R |
| E8 | L_2_2P0402R_120R/100MHZ/1.3A | 120R/100MHz/1.3A | 2P0402R |
| E9 | L_2_2P0402R_120R/100MHZ/1.3A | 120R/100MHz/1.3A | 2P0402R |
| E10 | IND_MAG_HIND_MAG2PIN_V1_2P0402R | 120OHM@100MHZ | 2P0402R_SD |
| E11 | IND_MAG_HIND_MAG2PIN_V1_2P040_1 | 120OHM@100MHZ | 2P0402ROFS |
| E12 | IND_MAG_HIND_MAG2PIN_V1_2P040_2 | 120OHM@100MHZ | 2P0402R |
| E13 | IND_MAG_HIND_MAG2PIN_V1_2P0805R | 60R/100MHz/3.0A/0805 | 2P0805R |
| EE1 | L_4_2P0402R_1000R/100MHZ | 1000R/100MHz | 2P0402R |
| EE2 | L_4_2P0402R_1000R/100MHZ | 1000R/100MHz | 2P0402R |
| EE3 | L_4_2P0201R_RF_75R/100MHZ/300MA | 75R/100MHz/300mA | 2P0201R_RF |
| EE4 | L_4_2P0201R_RF_75R/100MHZ/300MA | 75R/100MHz/300mA | 2P0201R_RF |
| EE5 | L_4_2P0402R_120R/100MHZ/1300MA | 120R/100MHz/1300mA | 2P0402R |
| EE6 | L_4_2P0201R_RF_600R/100MHZ/280M | 600R/100MHz/280mA | 2P0201R_RF |
| EE7 | L_4_2P0402R_120R/100MHZ/1300MA | 120R/100MHz/1300mA | 2P0402R |
| EE8 | L_4_2P0402R_120R/100MHZ/1300MA | 120R/100MHz/1300mA | 2P0402R |
| EE9 | L_4_2P0201R_RF_75R/100MHZ/300MA | 75R/100MHz/300mA | 2P0201R_RF |
| EE10 | L_4_2P0201R_RF_33R/100MHZ/750MA | 33R/100MHz/750mA | 2P0201R_RF |
| EE11 | L_4_2P0201R_RF_33R/100MHZ/750MA | 33R/100MHz/750mA | 2P0201R_RF |
| EE12 | L_4_2P0402R_120R_100MHZ/1300MA | 120R_100MHz/1300mA | 2P0402R |
| EE13 | L_4_2P0402R_120R/100MHZ/1300MA | 120R/100MHz/1300mA | 2P0402R |
| EE14 | L_4_2P0201R_RF_600R/100MHZ/280M | 600R/100MHz/280mA | 2P0201R_RF |
| EE15 | L_4_2P0201R_RF_600R/100MHZ/280M | 600R/100MHz/280mA | 2P0201R_RF |
| EE16 | L_4_2P0402R_120R/100MHZ/NC | 120R/100MHz/NC | 2P0402R |
| FB1 | RES_R0805_3A | 3A | R0805 |
| FB2 | RES_R0805_3A | 3A | R0805 |
| FFL1 | BPF-BF2012-L5R5DAB_0_3PSM67X35N | RFBPF1608060K88Q1C/NC | 3PSM67X35NV1 |
| FFL2 | BPF-BF2012-L5R5DAB_0_3PSM67X35N | RFBPF1608060K88Q1C/NC | 3PSM67X35NV1 |
| FFL3 | BPF-BF2012-L5R5DAB_0_3PSM67X35N | RFBPF1608060K88Q1C/NC | 3PSM67X35NV1 |
| FFL4 | BPF-BF2012-L5R5DAB_0_3PSM67X35N | RFBPF1608060K88Q1C/NC | 3PSM67X35NV1 |
| H1 | SMTSO-M3-3-ET_1PCY161X161P_NT1R | NT1R3000 | 1PCY161X161P |
| H2 | SMTSO-M3-3-ET_M2D2-4D2_SMTSO-M3 | SMTSO-M3-3-ET | M2D2-4D2 |
| H14 | SMTSO-M3-3-ET_1PCY161X161P_NT1R | NT1R3000 | 1PCY161X161P |
| J1 | IPEX_1_JACK-COAXIAL-4P-PINDOWN_ | IPEX | JACK-COAXIAL-4P-PINDOWN |
| J2 | SMA/UFLR_3SCOXSV4_I-PEX/20279-0 | I-PEX/20279-001E-01 | 3SCOXSV4 |
| J3 | SMA/UFLR_3SCOXSV4_I-PEX/20279-0 | I-PEX/20279-001E-01 | 3SCOXSV4 |
| J4 | SMA/UFLR_3SCOXSV4_I-PEX/20279-0 | I-PEX/20279-001E-01 | 3SCOXSV4 |
| J5 | SMA/UFLR_3SCOXSV4_I-PEX/20279-0 | I-PEX/20279-001E-01 | 3SCOXSV4 |
| J6 | SMA/UFLR_3SCOXSV4_I-PEX/20279-0 | I-PEX/20279-001E-01 | 3SCOXSV4 |
| J7 | PJ-A1-BDBH-FD0NN-1_0_RJ45-1XLED | PJ-A1-BDBH-FD0NN-1 | RJ45-1XLED |
| J8 | PJ-A1-BDBH-FD0NN-1_0_RJ45-1XLED | PJ-A1-BDBH-FD0NN-1 | RJ45-1XLED |
| J9 | CONPOWERJACK_POWER-JACK_PJ-102 | PJ-102AH | POWER-JACK |
| J10 | IPEX_1_JACK-COAXIAL-4P-PINDOWN_ | IPEX | JACK-COAXIAL-4P-PINDOWN |
| J11 | 78119-1209_4_FPC8-0_5MM_78119-1 | 78119-1209 | FPC8-0_5MM |
| J12 | CONN_4_CONN_S_1_J4X1_CONN_4_CON | CONN_4_CONN_S_4PIN | J4X1 |
| JX1 | IPEX_0_RF-CON-SMA-S-2_8_SMA | SMA | RF-CON-SMA-S-2_8 |
| JX2 | IPEX_0_RF-CON-SMA-S-2_8_SMA | SMA | RF-CON-SMA-S-2_8 |
| JX3 | IPEX_0_RF-CON-SMA-S-2_8_SMA | SMA | RF-CON-SMA-S-2_8 |
| JX4 | IPEX_0_RF-CON-SMA-S-2_8_SMA | SMA | RF-CON-SMA-S-2_8 |
| JX5 | IPEX_0_RF-CON-SMA-S-2_8_SMA | SMA | RF-CON-SMA-S-2_8 |
| JX6 | IPEX_0_RF-CON-SMA-S-2_8_SMA | SMA | RF-CON-SMA-S-2_8 |
| L1 | L_4_2P0201R_RF_18NH3%/NC | 18NH3%/NC | 2P0201R_RF |
| L2 | IND_MAG_HIND_MAG2PIN_2PSM169X16 | 3.3uH/2.9A/4.0/4.0/1.8mm | 2PSM169X169NV3 |
| L3 | L_4_2P0201R_RF_18NH3%/NC | 18NH3%/NC | 2P0201R_RF |
| L4 | L_4_2P0201R_RF_18NH3%/NC | 18NH3%/NC | 2P0201R_RF |
| L5 | L_4_2P0201R_RF_18NH3%/NC | 18NH3%/NC | 2P0201R_RF |
| L6 | L_4_2P0201R_RF_18NH3%/NC | 18NH3%/NC | 2P0201R_RF |
| L7 | L_4_2PSM205X205NV6_3.3UH/4.6A_1 | 3.3uH/4.6A/5.0*5.0*4.0mm | 2PSM205X205NV6 |
| L8 | L_4_2PSM205X205NV6_4.7UH/3.9A/5 | 4.7uH/3.9A/5.0/5.0/4.0mm | 2PSM205X205NV6 |
| L9 | IND_MAG_HIND_MAG2PIN_2PSM169X_1 | 2.2uH/3.2A/4.0/4.0/1.8mm | 2PSM169X169NV3 |
| L10 | L_4_2PSM169X169NV3_2.2UH/3.2A/4 | 2.2uH/3.2A/4.0/4.0/1.8mm | 2PSM169X169NV3 |
| L11 | L_4_2PSM205X205NV6_3.3UH/4.6A/5 | 3.3uH/4.6A/5.0/5.0/4.0mm | 2PSM205X205NV6 |
| L12 | L_0_2P0201R_RF_18NH/NC | 18NH/NC | 2P0201R_RF |
| L21 | L_4_2PSM169X169NV3_2.2UH/3.2A/4 | 2.2uH/3.2A/4.0/4.0/1.8mm | 2PSM169X169NV3 |
| L22 | FB_RV2-5MM-05K820_FNR-05K820/40 | FNR-05K820/400A | RV2-5MM-05K820 |
| L23 | L_4_2PSM169X169NV3_3.3UH/2.9A/4 | 3.3uH/2.9A/4.0/4.0/1.8mm | 2PSM169X169NV3 |
| L24 | INDUCTOR_0_SMD_L4-6X7MM-BOK6E_B | BOK6E-5A50T/NC | SMD_L4-6X7MM-BOK6E |
| L25 | IND_4_SPA63-150M_10UH/3A | 10uH/3A | SPA63-150M |
| L26 | L_4_2P0201R_RF_18NH3%/NC | 18NH3%/NC | 2P0201R_RF |
| LL1 | L/0402_0_2P0201R_RF_18NH/NC | 18nH/NC | 2P0201R_RF |
| LL9 | IND_MAG_HIND_MAG_2PIN_2PSM87X71 | 1.0UH/20%/4.4A/HTQH20160H-1R0MSR-39 | 2PSM87X71R |
| LL10 | IND_MAG_PRI_HIND_MAG_PRI_2PIN_2 | 1.0UH | 2PSM87X71NV4 |
| LL11 | IND_MAG_PRI_HIND_MAG_PRI_2PIN_2 | 1.0UH | 2PSM87X71NV4 |
| Q1 | NFET_DIODE_G1S2D3_3PSOT118X55G_ | BSS138LT1G/SOT23-3 | 3PSOT118X55G |
| Q2 | NFET_DIODE_G1S2D3_3PSOT118X55G_ | BSS138LT1G/SOT23-3 | 3PSOT118X55G |
| Q3 | 2N6766_0_3PSOT118X55G_BSS138TA/ | BSS138TA/NC | 3PSOT118X55G |
| Q4 | 2N6766_0_3PSOT118X55G_BSS138TA | BSS138TA | 3PSOT118X55G |
| Q5 | 2N6766_0_3PSOT118X55G_BSS138TA | BSS138TA | 3PSOT118X55G |
| Q6 | 9013_3PSOT118X55G_MMBT3904LT1G | MMBT3904LT1G | 3PSOT118X55G |
| Q7 | 9013_3PSOT118X55G_MMBT3904LT1G | MMBT3904LT1G | 3PSOT118X55G |
| Q8 | 9013_3PSOT118X55G_MMBT3904LT1G | MMBT3904LT1G | 3PSOT118X55G |
| Q9 | 9013_3PSOT118X55G_MMBT3904LT1G | MMBT3904LT1G | 3PSOT118X55G |
| Q10 | 2N6766_0_3PSOT118X55G_BSS138TA | BSS138TA | 3PSOT118X55G |
| Q11 | 9013_3PSOT118X55G_MMBT3904LT1G | MMBT3904LT1G | 3PSOT118X55G |
| QQ1 | NFET_DIODE_G1S2D3_3PSM43X28N_DM | DMN3730UFB-7 | 3PSM43X28N |
| QQ2 | 2N6766_0_3PSOT118X55G_BSS138TA/ | BSS138TA/NC | 3PSOT118X55G |
| QQ3 | 2N6766_0_3PSOT118X55G_BSS138TA/ | BSS138TA/NC | 3PSOT118X55G |
| RV5 | VARISTOR_RV2-6MM_05D681K | 05D681K | RV2-6MM |
| S1 | TACT_SW_P2P_TACT | TACT | SW_P2P |
| S2 | RTC7608U_6PSM43X43N138V1_RTC760 | RTC7608U | 6PSM43X43N138V1 |
| S3 | RTC7608U_6PSM43X43N138V1_RTC760 | RTC7608U | 6PSM43X43N138V1 |
| T1 | XFMR-FM-1178-1LLF_1_SMD_TRAN24- | LP82440NL | SMD_TRAN24-1_27MM-TF5433 |
| T2 | XFMR-FM-1178-1LLF_1_SMD_TRAN24- | LP82440NL | SMD_TRAN24-1_27MM-TF5433 |
| U1 | TEXT2_MB101B_TEXT2 | text2 | MB101B |
| U2 | FP9854SP_9PSO197X157G50V5_FR985 | FR9854SP/SO-8 | 9PSO197X157G50V5 |
| U3 | FP9854SP_9PSO197X157G50V5_FR985 | FR9854SP/SO-8 | 9PSO197X157G50V5 |
| U4 | RT6252BHGJ6F_0_6PSM67X51F197V5_ | MP1653H(ES) | 6PSM67X51F197V5 |
| U5 | RT6252BHGJ6F_0_6PSM67X51F197V4_ | MP1653H(ES) | 6PSM67X51F197V4 |
| U6 | QPF4288SB_ES_0_25PSM201X122N197 | QPF4288SB(ES) | 25PSM201X122N197V1 |
| U7 | QPF4288SB_ES_0_25PSM201X122N197 | QPF4288SB(ES) | 25PSM201X122N197V1 |
| U8 | FP9852PSD_6PSM67X51F197V5_FR985 | FR9853PSD/SOT-563-6 | 6PSM67X51F197V5 |
| U9 | FP6396S5_5PSO120X69G374V1_FP639 | FP6396S5/SOT23-5 | 5PSO120X69G374V1 |
| U10 | IPQ-5018_233PSM555X555N217_IPQ- | IPQ-5018-0-MRQFN232-MT-00-0 | 233PSM555X555N217 |
| U11 | QCA8081_PROTO_1_57PSM280X280N15 | QCA8081_PROTO | 57PSM280X280N157V4 |
| U12 | FP6396S5_5PSO120X69G374V1_FP639 | FP6396S5/SOT23-5 | 5PSO120X69G374V1 |
| U13 | MT41K256M16TW-107_96PGA557X321B | MT41K256M16TW-107 /BGA-96 | 96PGA557X321B315 |
| U14 | FP6396S5_5PSO120X69G374V1_FP639 | FP6396S5/SOT23-5 | 5PSO120X69G374V1 |
| U15 | LMR16030_SPQ8_1M27_6M2X5_LMR160 | LMR16030 | SPQ8_1M27_6M2X5 |
| U16 | PD-TPS2378_SOP8_XS2100S | XS2100S | SOP8 |
| U17 | TEXT2_MB101B_TEXT2 | text2 | MB101B |
| U18 | TEXT2_MB101B_TEXT2 | text2 | MB101B |
| U19 | GD25LQ32DSIG_SOP8-208MILS_8PSO2 | GD25LQ32DSIG_SOP8-208MILS/NC | 8PSO210X212G50 |
| U20 | GD25LQ32DWIG_WSON-8_9PSM240X319 | GD25LQ32DWIG/SMD6.0*5.0*0.75mm | 9PSM240X319N50V2 |
| U21 | GD5F1GQ4RE9IH-SPI-NAND_9PSM240X | GD5F1GQ4RE9IH/LGA-8 | 9PSM240X319N50V2 |
| UU1 | QPF4288SB_25PSM201X122N197V1_QP | QPF4588SB | 25PSM201X122N197V1 |
| UU2 | QPF4288SB_25PSM201X122N197V1_QP | QPF4588SB | 25PSM201X122N197V1 |
| UU3 | QCN9074_234PGA476X440B256_QCN90 | QCN9074(000-0) | 234PGA476X440B256 |
| UU4 | QPF4288SB_25PSM201X122N197V1_QP | QPF4588SB | 25PSM201X122N197V1 |
| UU5 | RT6252BHGJ6F_1_5PSO120X70G_FP61 | FP6186(ES) | 5PSO120X70G |
| UU6 | MP1614CGTL_8PSM87X51F197_MP1614 | MP1614CGTL | 8PSM87X51F197 |
| UU7 | RT6252BHGJ6F_1_5PSO120X70G_FP61 | FP6186(ES) | 5PSO120X70G |
| UU8 | RT6252BHGJ6F_1_5PSO120X70G_FP61 | FP6186(ES) | 5PSO120X70G |
| UU9 | QPF4288SB_25PSM201X122N197V1_QP | QPF4588SB | 25PSM201X122N197V1 |
| UU10 | MP1601GTF_6PSM67X51F197V5_MP160 | MP1601GTF | 6PSM67X51F197V5 |
| UU11 | MP1601GTF_6PSM67X51F197V5_MP160 | MP1601GTF | 6PSM67X51F197V5 |
| Y1 | TXAL_4PSM83X67NV4_X2C048000L71H | X2C048000L71HH-CEHZ | 4PSM83X67NV4 |
| Y2 | 7M50070029_4PSM130X102N_7M50070 | 7M50070029 | 4PSM130X102N |
| YY1 | TXAL_4PSM83X67NV4_48MHZ/10PPM/9 | 48MHz/10ppm/9pF/1ZZXAE96000BB0A | 4PSM83X67NV4 |
