查看: 604|回复: 4
12864点阵屏驱动程序(XJCG12864)源码
终身成就奖特殊贡献奖金点子奖原创先锋奖
发表于 2022-4-6 09:15 | 显示全部楼层 |阅读模式
/*                     CONTROL IC:ST7565R                          */
/*                     MODEL TYPE:128*64                           */
/*                     MPU INTERFACE:4-SPI                         */
/*                       20141013 . v1.0                           */
/*                    深圳市鹏芯集成电路有限公司                   */
/*                     网址:www.pengchip.com                       */
/*                     鲁工 15338865299                            */
#include <stdio.h>
//#include <ctype.h>
#include <reg52.h>
#include "math.h"
#include "ctype.h"
#include "string.h"
#include "stdlib.h"
#include "absacc.h"
#include "intrins.h"
#include "stdarg.h"
#include "setjmp.h"
#define Uchar unsigned char
#define Uint  unsigned int
sbit CS1=P3^5;    //3.2
sbit RES=P3^3;    //3.0
sbit RS=P3^4;          //3.1
sbit SCLK=P1^6;        //d6
sbit SDI=P1^7;        //d7
sbit    key_up    = P2^2;
sbit    key_down  = P2^1;
sbit    key  = P3^6;  //3.5
Uchar   EV=0x18    ;
sbit KEY1=P3^2;
sbit KEY2=P3^3;
sfr  CHPENR=0xF6;    //定义W78E516B的特殊功能寄存器
sfr  CHPCON=0xBF;    //用来打开片上的256Byte的RAM
Uchar code snow[]={0xaa,0x55,0xaa,0x55,0xaa,0x55,0xaa,0x55};
Uchar code clear[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
Uchar code black[]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
Uchar code map1[];
Uchar code map2[];
Uchar code map3[];
Uchar code map4[];
Uchar code IC[]={0xe2,   //command reset
                   0xaf,
                 0xa0, // 从左往后,还是从右往左扫描(0xa1)
                 0xc8, // 从上往下,还是从下往上扫描(0xc0)
                 0xa2,
                 0x40,  // start line
                 0x25,   //V0 voltage regulator internal resistor ratio set   //对比度调节 V0的电阻率调节 范围:0x21-0x27 ,值越大,显示效果越浓(底影越浓)
                 0x81,   // electronic volume mode set
                     0x15,   // V0电压调节(可微调对比度)    //电压调整寄存器低位 范围:0x1e-0x32    值越大,显示效果越浓(底影越浓)//0x13 kehu
                 0x2f,   //power controller set
                 //0xac,
                 //0xa6,
                 0xaf    //display on
void Delay(Uint times)
   while(times)
    times--;
void M_Delay(Uint NOs)
   while(NOs)
    Delay(300);
    NOs--;
void WriteData(Uchar data1, bit di)
   Uint i,temp;
   CS1=0;
   RS=di;
   //temp=data1;
   for(i=0;i<8;i++)
       {          //SCLK=0;
            temp=data1;
            SDI=temp&0x80;
            SCLK=0;
            Delay(3);
            SCLK=1;
            data1<<=1;
            //data1=temp;
   RS=~di;
    CS1=1;
** 函数名称: key_scan
** 功能描述: 按键扫描调节对比度和切屏
** 输 入: 无
** 输 出 : 无
** 全局变量:无
** 调用模块: Busy,
/*void key_scan(void)                        //按键处理
    //Uchar    i;
    while(1)
        key_down= 1;
        if(key_down == 0)
            key_hold1:
                M_Delay(30);
                if(key_down == 0)
                    goto key_hold1;
                else
                    M_Delay(30);
                    if(key_down == 0)
                        goto key_hold1;
                    else
                        if(EV==0)
                            M_Delay(1);
                        else
                            WriteData(0x81,0);//write_command(0x81);
                            WriteData(--EV,0);//32    0x45
        key_up= 1;
        if(key_up == 0)
            key_hold:
                M_Delay(30);
                if(key_up == 0)
                    goto key_hold;
                else
                    M_Delay(30);
                    if(key_up == 0)
                        goto key_hold;
                    else
                        if(EV==63)
                            M_Delay(1);
                        else
                            WriteData(++EV,0);//32    0x45
        KEY2= 1;
        if(KEY2 == 0)
            key_hold2:
                M_Delay(30);
                if(KEY2 == 0)
                    goto key_hold2;
                else
                    M_Delay(30);
                    if(KEY2 == 0)
                        goto key_hold2;
                    else
                        return;
** 函数名称: key_scan
** 功能描述: 按键扫描
** 输 入: 无
** 输 出 : 无
** 全局变量:无
** 调用模块: Busy,
    void key_scan()                     //按键处理
        //uchar i;
        key = 1;
    key_in:
        Delay(30);
        //i=key;                    //P3.5为按键输入
        if(key == 1)
            goto key_in;
        else
            Delay(30);
            if(key == 1)
                goto key_in;
    key_hold:
        Delay(30);
        //i=P3;
        //i=i&0x20;
        if(key == 0)
            goto key_hold;
        else
            Delay(30);
            if(key == 0)
                goto key_hold;
        return;
void INT0_ROUTING() interrupt 0
    EA    = 0; // 关掉所有中断 防止出错
    //while(KEY2 == 1);
    //M_Delay(10);
   // while(KEY2 == 1);
   key_scan();
    EA    = 1; // 打开所有中断
/*void INIT_INT0()
    IP = 0x01;
    IE = 0x81;
    TCON=0;
void InitInterrupt()
{  INIT_INT0();
void Init_lcd(void)
   int i;
   RES=0;
   M_Delay(200);
   RES=1;
   M_Delay(300);
   for(i=0;i<10;i++)
    WriteData(IC,0);
void Displine(Uchar array[])
   Uint i,j,k;
   for(i=0;i<8;i++)
    WriteData(0x40,0);
    WriteData(0xb0|i,0);
    WriteData(0x10,0);
    WriteData(0x00,0);
    for(j=0;j<16;j++)
    for(k=0;k<8;k++)
     WriteData(array[k],1);
void DispPane()
   Uint i,j;
   WriteData(0x40,0);
   for(i=0;i<8;i++)
    WriteData(0x10,0);
    WriteData(0x00,0);
    WriteData(0xff,1);
   for(i=0;i<8;i++)
    WriteData(0x18,0);
    WriteData(0x03,0);
    WriteData(0xff,1);
   WriteData(0xb0,0);
   WriteData(0x10,0);
   WriteData(0x05,0);
   for(j=0;j<126;j++)
    WriteData(0x01,1);
   WriteData(0xb7,0);
   WriteData(0x10,0);
   WriteData(0x05,0);
   for(j=0;j<126;j++)
    WriteData(0x80,1);
void Dispgraphic(Uchar array[])
   Uint i,k;
   for(i=0;i<8;i++)
        WriteData(0x40,0);
        WriteData(0x10,0);
        WriteData(0x00,0);
        for(k=0;k<128;k++)
             WriteData(array[i*128+k],1);
void main(void)
    ///InitInterrupt();
    Init_lcd();
//    EA = 1;
  ///  EX0 = 1;
   while(1)
      Dispgraphic(map1);
   M_Delay(300);
    //key_scan() ;
    //WriteData(0xa7,0);
     ///M_Delay(300);
    //key_scan() ;
    //WriteData(0xa6,0);
    Dispgraphic(map2);
    M_Delay(300);
      //key_scan() ;
    Displine(snow);
    M_Delay(300);
      //key_scan() ;
    Displine(black);
     M_Delay(300);
    //key_scan() ;
    Displine(clear);
     M_Delay(300);
    //key_scan() ;
      Dispgraphic(map3);
     M_Delay(300);
    //key_scan() ;
    Dispgraphic(map4);
     M_Delay(300);
Uchar code map1[] = {
/*-- 图片内容 《深圳市鑫晶科技 袁小姐 15914134963 网址:www.lcdxj.com》--*/
/*--           字体:华文宋体           --*/
/*--       尺寸 :     128x64           --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x90,0x20,0x00,0xC0,0x40,
0xA0,0xE0,0x20,0x60,0xA0,0x70,0x00,0x00,0x00,0x00,0xF0,0x00,0x80,0xF0,0x10,0xE0,
0x00,0xF0,0x00,0x00,0x40,0x40,0x40,0xC0,0x40,0x40,0xF0,0x40,0x40,0x40,0xC0,0x60,
0x40,0x00,0x80,0x80,0xC0,0xE0,0xD0,0xD0,0xE0,0xC0,0xC0,0x40,0x40,0x40,0x00,0x00,
0x00,0x00,0xE0,0xA0,0xA0,0xA0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0xE0,0x20,
0x00,0x00,0x40,0x40,0xF0,0x00,0x00,0x00,0x00,0x40,0x40,0xF0,0xC0,0xC0,0x80,0xF0,
0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0xF9,0x47,0x22,0x13,
0x0E,0xFF,0x0E,0x12,0x23,0x22,0x00,0x00,0x41,0x21,0xBF,0x61,0x21,0x1F,0x00,0x3F,
0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x7F,0x01,0x01,0xFF,0x01,0x01,0x41,0x3F,0x00,
0x00,0x00,0x9A,0x5E,0x7A,0x5B,0xB6,0x9B,0xDE,0xFB,0xDE,0xBA,0xDA,0x08,0x00,0x00,
0xFC,0x54,0x57,0xFD,0x01,0xFF,0x55,0x54,0x54,0xFC,0x00,0x20,0x19,0x05,0xFF,0x15,
0x0D,0x11,0x0E,0x08,0xFF,0x08,0x04,0x00,0x00,0x08,0x84,0xFF,0x82,0x47,0x5A,0x23,
0x52,0x4F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x40,0x50,0xD0,0xD0,0xD0,
0xFC,0xD4,0xD0,0xD0,0x50,0x70,0x40,0x00,0x00,0x00,0xC0,0x00,0x00,0xFC,0x00,0x00,
0x40,0x80,0x00,0x00,0x20,0xA0,0x7C,0x20,0xF0,0x00,0xF8,0x48,0x48,0x48,0xF8,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x09,0x3D,0x23,
0x13,0x1D,0x15,0x15,0x22,0x00,0x00,0x00,0x04,0x03,0x00,0x00,0x20,0x3F,0x00,0x00,
0x00,0x00,0x03,0x00,0x20,0x27,0x18,0x06,0x39,0x20,0x3F,0x22,0x22,0x22,0x3F,0x30,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x04,0xFC,0x00,0x00,
0x00,0x00,0x3C,0x24,0x24,0x64,0x80,0x3C,0x42,0xC2,0x7C,0x00,0x00,0x08,0x04,0xFC,
0x00,0x00,0x00,0xC0,0xB0,0x88,0xFC,0x80,0x00,0x08,0x04,0xFC,0x00,0x00,0x00,0x08,
0x44,0x24,0x58,0x80,0x00,0xC0,0xB0,0x88,0xFC,0x80,0x00,0x3C,0x42,0xC2,0x7C,0x00,
0x00,0xE0,0x18,0x24,0x24,0xC0,0x00,0x08,0x44,0x24,0x58,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x83,0x80,0x80,
0x80,0x82,0x82,0x82,0x82,0x03,0x00,0x02,0x02,0xC1,0x00,0x00,0x00,0x00,0x00,0xC3,
0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x04,
0x04,0x04,0x02,0x01,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x02,0x02,0x01,0x00,0x00,
0x00,0x03,0x04,0x04,0x04,0x03,0x80,0x04,0x04,0x04,0x02,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x24,0x1C,0x33,
0x42,0x34,0x1F,0x62,0xFF,0x00,0x00,0x04,0x84,0xFF,0x84,0x46,0x00,0xFE,0x00,0xFF,
0x08,0x08,0x0C,0x00,0x00,0x88,0x00,0x08,0x38,0xC0,0x88,0x78,0xC8,0xC8,0x38,0x08,
0x08,0x38,0xC0,0x88,0x78,0xC8,0xC8,0x38,0x08,0x08,0x38,0xC0,0x88,0x78,0xC8,0xC8,
0x38,0x08,0x00,0x80,0x00,0x00,0xFF,0x00,0x00,0x70,0x88,0x88,0x88,0x00,0x70,0x88,
0x88,0x88,0xFF,0x80,0x08,0x98,0x68,0x68,0x98,0x08,0x08,0xF9,0x00,0x00,0x80,0x00,
0x00,0x70,0x88,0x88,0x88,0x20,0xD8,0x88,0x88,0x88,0x70,0x00,0x00,0xF8,0x10,0x08,
0x08,0xF0,0x08,0x08,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,
0x00,0x00,0x00,0x02,0x03,0x00,0x00,0x01,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,
0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x00,
0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x04,0x03,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,
0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
Uchar code map2[]={
/*-- 图片内容 《深圳市鑫晶科技有限公司 袁小姐 15914134963 网址:www.lcdxj.com》--*/
/*--           字体:汉仪旗黑-55           --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x80,0x00,0x00,0x00,0x80,0x00,0x00,0x00,
0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x80,
0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x80,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF4,0x8F,0x52,0x35,0x13,
0xFD,0x33,0x4D,0x00,0x00,0x44,0xBF,0x64,0x3F,0x00,0x7F,0x00,0xFF,0x00,0x00,0x00,
0x7E,0x02,0x7E,0x02,0x02,0x7E,0x01,0x00,0x02,0xD2,0xE9,0x75,0xA6,0xD5,0xEF,0xB5,
0xD6,0x10,0x00,0xF8,0x93,0x72,0x02,0x72,0x92,0x97,0xF8,0x00,0x20,0x14,0x7F,0x1C,
0x25,0x29,0x20,0xEF,0x10,0x00,0x00,0x12,0xFF,0x8A,0x8A,0x7A,0x67,0x9A,0x80,0x00,
0x00,0x09,0x7D,0x13,0x15,0x15,0x95,0xFD,0x01,0x00,0x00,0xFF,0x27,0x18,0x7F,0x59,
0x29,0x5F,0x80,0x00,0x00,0x08,0x46,0xB1,0x88,0x81,0xA2,0xC4,0x08,0x00,0x00,0x02,
0x3B,0x2B,0x2B,0x3B,0x03,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0xC0,0x60,0x70,0x60,
0x60,0xE0,0x40,0x00,0x00,0x00,0x80,0x00,0xE0,0x10,0x00,0x80,0x00,0x00,0x00,0xC0,
0x30,0xC0,0xE0,0xA0,0xA0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x0B,0x0E,0x12,0x0A,
0x06,0x0B,0x10,0x00,0x00,0x02,0x01,0x00,0x1F,0x00,0x00,0x00,0x03,0x00,0x12,0x0D,
0x04,0x07,0x0F,0x14,0x14,0x0F,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0xFE,0x00,0x00,0x4E,
0x8A,0x8A,0x72,0x00,0x4C,0x92,0x92,0x7C,0x00,0x00,0x04,0xFE,0x00,0x00,0x30,0x28,
0x24,0xFE,0x20,0x00,0x04,0xFE,0x00,0x00,0x44,0x82,0x92,0x6C,0x00,0x30,0x28,0x24,
0xFE,0x20,0x4C,0x92,0x92,0x7C,0x00,0x7C,0x92,0x92,0x64,0x00,0x44,0x82,0x92,0x6C,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x80,
0x80,0x80,0xC0,0x00,0x00,0x80,0x40,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x09,0x07,0x19,0x0A,
0x07,0x48,0x3F,0x00,0x00,0x3F,0x22,0x52,0x3F,0x40,0x3F,0x44,0x42,0x00,0x00,0x11,
0x00,0x07,0x18,0x04,0x03,0x04,0x18,0x07,0x00,0x07,0x18,0x04,0x03,0x04,0x18,0x07,
0x00,0x07,0x18,0x04,0x03,0x04,0x18,0x07,0x00,0x00,0x10,0x00,0x1F,0x00,0x0E,0x11,
0x11,0x0A,0x00,0x0E,0x11,0x11,0x1F,0x00,0x1B,0x04,0x04,0x1B,0x40,0x3F,0x00,0x00,
0x10,0x00,0x0E,0x11,0x11,0x0A,0x00,0x0E,0x11,0x11,0x0E,0x00,0x1F,0x01,0x01,0x1F,
0x01,0x01,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Uchar code map3[]={
/*-- 图片内容 《1234567890 abcdefghijklmnopqrstuvwxyz》--*/
/*--           字体:Arial Black           --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,
0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,
0x80,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x80,
0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x0C,0x06,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x83,
0xC3,0xE3,0xF1,0xBF,0x9F,0x8E,0x00,0x00,0xC3,0xC3,0xC3,0x99,0xFF,0xFF,0x66,0x00,
0x70,0x78,0x7C,0x66,0x63,0xFF,0xFF,0xFF,0x60,0x00,0xCC,0xDF,0xCF,0x8D,0xFD,0xFD,
0x79,0x00,0x00,0x7E,0xFF,0xFF,0x91,0xFB,0xFB,0xF3,0x00,0x00,0x01,0xC1,0xF1,0xFD,
0x3F,0x07,0x01,0x00,0x00,0xE7,0xFF,0xFF,0x99,0xFF,0xFF,0xE7,0x00,0x00,0xCF,0xDF,
0xDF,0x89,0xFF,0xFF,0x7E,0x00,0x00,0x7E,0xFF,0xFF,0x81,0xFF,0xFF,0x7E,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x00,
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x01,0x01,0x01,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x01,
0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x60,0x70,0x70,0xB0,0xB0,0xF0,0xF0,0xE0,0x00,0xFE,0xFE,
0xFE,0x20,0x30,0xF0,0xF0,0xE0,0x00,0xC0,0xE0,0xF0,0x30,0x30,0x70,0x60,0x40,0x00,
0xE0,0xF0,0xF0,0x30,0x20,0xFE,0xFE,0xFE,0x00,0xC0,0xE0,0xF0,0xB0,0xB0,0xF0,0xE0,
0xC0,0x30,0xFC,0xFE,0xFE,0x32,0x02,0xE0,0xF0,0xF0,0x30,0x20,0xF0,0xF0,0xF0,0x00,
0xFE,0xFE,0xFE,0x20,0x30,0xF0,0xF0,0xE0,0x00,0xF6,0xF6,0xF6,0x00,0xF6,0xF6,0xF6,
0x00,0xFE,0xFE,0xFE,0xC0,0xE0,0xF0,0xB0,0x10,0x00,0xFE,0xFE,0xFE,0x00,0x00,0xF0,
0xF0,0xF0,0x20,0xF0,0xF0,0xE0,0x30,0xF0,0xF0,0xE0,0x00,0xF0,0xF0,0xF0,0x20,0x30,
0xF0,0xF0,0xE0,0x00,0xC0,0xE0,0xF0,0x30,0x30,0xF0,0xE0,0xC0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x03,0x07,0x07,0x06,0x02,0x07,0x07,0x07,0x00,0x07,0x07,
0x07,0x02,0x06,0x07,0x07,0x03,0x00,0x01,0x03,0x07,0x06,0x06,0x07,0x03,0x01,0x00,
0x03,0x07,0x07,0x06,0x02,0x07,0x07,0x07,0x00,0x01,0x03,0x07,0x06,0x06,0x06,0x06,
0x02,0x00,0x07,0x07,0x07,0x00,0x00,0x13,0x37,0x37,0x36,0x32,0x3F,0x3F,0x1F,0x00,
0x07,0x07,0x07,0x00,0x00,0x07,0x07,0x07,0x00,0x07,0x07,0x37,0x30,0x3F,0x3F,0x1F,
0x00,0x07,0x07,0x07,0x01,0x01,0x03,0x07,0x06,0x04,0x07,0x07,0x07,0x00,0x00,0x07,
0x07,0x07,0x00,0x07,0x07,0x07,0x00,0x07,0x07,0x07,0x00,0x07,0x07,0x07,0x00,0x00,
0x07,0x07,0x07,0x00,0x01,0x03,0x07,0x06,0x06,0x07,0x03,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0x80,0xC0,0xC0,0xC0,0x80,0x00,0x80,0xC0,
0xC0,0xC0,0x80,0xC0,0xC0,0xC0,0x00,0xC0,0xC0,0xC0,0x80,0xC0,0x40,0x80,0xC0,0xC0,
0x40,0x40,0xC0,0x80,0x00,0xC0,0xF0,0xF0,0xF8,0xC0,0x00,0xC0,0xC0,0xC0,0x00,0x00,
0xC0,0xC0,0xC0,0x40,0xC0,0xC0,0x80,0x00,0x80,0xC0,0xC0,0x40,0xC0,0xC0,0x00,0x00,
0xC0,0xC0,0xC0,0x00,0x00,0xC0,0xC0,0x40,0x40,0xC0,0xC0,0x80,0x00,0x80,0xC0,0xC0,
0x40,0xC0,0xC0,0x00,0x00,0x00,0xC0,0xC0,0x40,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x08,0x18,0x1F,0x1F,0x0F,0x00,0x0F,0x1F,
0x1F,0x18,0x08,0xFF,0xFF,0xFF,0x00,0x1F,0x1F,0x1F,0x00,0x00,0x00,0x09,0x1B,0x13,
0x17,0x1E,0x1E,0x0C,0x00,0x00,0x0F,0x1F,0x1F,0x18,0x18,0x0F,0x1F,0x1F,0x18,0x08,
0x1F,0x1F,0x1F,0x00,0x01,0x07,0x1F,0x1C,0x1F,0x07,0x01,0x00,0x03,0x1F,0x1F,0x1C,
0x07,0x01,0x07,0x1C,0x1F,0x1F,0x03,0x00,0x10,0x18,0x1F,0x0F,0x07,0x0F,0x1F,0x18,
0x10,0xC3,0xCF,0xFF,0xF8,0x7F,0x0F,0x03,0x00,0x18,0x1C,0x1E,0x1B,0x19,0x18,0x00,
Uchar code map4[]={
/*-- 图片内容 《ABCDEFGHIJKLMNOPQRSTUVWXYZ》--*/
0x00,0x00,0x00,0x80,0xE0,0x60,0xE0,0x80,0x00,0x00,0x00,0xE0,0xE0,0x60,0x60,0x60,
0xE0,0xC0,0x00,0x00,0x80,0xC0,0x60,0x60,0x60,0xE0,0xC0,0x00,0x00,0xE0,0xE0,0x60,
0x60,0x60,0xC0,0x80,0x00,0x00,0xE0,0xE0,0x60,0x60,0x60,0x60,0x00,0x00,0xE0,0xE0,
0x60,0x60,0x60,0x00,0x00,0x80,0xC0,0x60,0x60,0x60,0xE0,0xC0,0x00,0x00,0x00,0x00,
0x00,0x10,0x1E,0x0F,0x0D,0x0C,0x0D,0x0F,0x1E,0x10,0x00,0x1F,0x1F,0x1B,0x1B,0x1B,
0x1F,0x0E,0x00,0x00,0x07,0x0F,0x18,0x18,0x18,0x1C,0x0C,0x00,0x00,0x1F,0x1F,0x18,
0x18,0x18,0x0F,0x07,0x00,0x00,0x1F,0x1F,0x1B,0x1B,0x1B,0x1B,0x00,0x00,0x1F,0x1F,
0x03,0x03,0x00,0x00,0x00,0x07,0x0F,0x18,0x18,0x1A,0x1E,0x0E,0x00,0x00,0x00,0x00,
0x00,0x00,0xF0,0xF0,0x80,0x80,0x80,0xF0,0xF0,0x00,0x00,0xF0,0xF0,0x00,0x00,0x00,
0x00,0x00,0xF0,0xF0,0x00,0x00,0xF0,0xF0,0x80,0xC0,0xE0,0x30,0x10,0x00,0x00,0xF0,
0xF0,0x00,0x00,0x00,0x00,0x00,0xF0,0xF0,0xE0,0x00,0x00,0xE0,0xF0,0xF0,0x00,0x00,
0xF0,0xF0,0xE0,0x80,0x00,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x0F,0x0F,0x01,0x01,0x01,0x0F,0x0F,0x00,0x00,0x0F,0x0F,0x00,0x06,0x0E,
0x0C,0x0C,0x0F,0x07,0x00,0x00,0x0F,0x0F,0x00,0x00,0x03,0x07,0x0C,0x08,0x00,0x0F,
0x0F,0x0C,0x0C,0x0C,0x00,0x00,0x0F,0x0F,0x01,0x0F,0x0F,0x01,0x0F,0x0F,0x00,0x00,
0x0F,0x0F,0x00,0x01,0x07,0x0F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0xE0,0xF0,0x18,0x18,0x18,0xF0,0xE0,0x00,0x00,0xF8,0xF8,0x98,0x98,0xF8,
0xF0,0x00,0x00,0xE0,0xF0,0x18,0x18,0x18,0xF0,0xE0,0x00,0x00,0xF8,0xF8,0xD8,0xD8,
0xD8,0xF8,0x70,0x00,0x00,0x70,0x78,0xD8,0xD8,0xD8,0x90,0x00,0x00,0x18,0x18,0xF8,
0xF8,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x03,0x06,0x06,0x06,0x03,0x01,0x00,0x00,0x07,0x07,0x01,0x01,0x01,
0x00,0x00,0x00,0x01,0x03,0x06,0x07,0x07,0x07,0x0D,0x00,0x00,0x07,0x07,0x00,0x00,
0x01,0x03,0x06,0x04,0x00,0x02,0x06,0x06,0x06,0x07,0x03,0x00,0x00,0x00,0x00,0x07,
0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0xFC,0xFC,0x00,0x00,0x00,0xFC,0xFC,0x00,0x04,0x3C,0xF8,0xE0,0x00,0xE0,
0xF8,0x3C,0x04,0x0C,0x7C,0xE0,0xC0,0xFC,0x1C,0xFC,0xC0,0xE0,0x7C,0x0C,0x04,0x0C,
0xD8,0xF0,0x60,0xF0,0xD8,0x0C,0x04,0x04,0x0C,0x38,0xF0,0xF0,0x38,0x0C,0x04,0x00,
0x00,0x0C,0x8C,0xEC,0x7C,0x1C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x03,0x03,0x03,0x03,0x03,0x01,0x00,0x00,0x00,0x00,0x03,0x03,0x03,
0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x00,0x00,0x00,0x03,0x03,0x00,0x00,0x02,0x03,
0x01,0x00,0x00,0x00,0x01,0x03,0x02,0x00,0x00,0x00,0x03,0x03,0x00,0x00,0x00,0x00,
0x00,0x03,0x03,0x03,0x03,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
购买主题 本主题需向作者支付 1 枚金币 才能浏览
  • 打卡总天数:193
  • 打卡月天数:1
  • 打卡总奖励:613
  • 最近打卡:2026-11-11 12:59:27
9571
7万
发表于 2022-4-6 09:18 | 显示全部楼层
发表于 2022-4-6 09:20 | 显示全部楼层
发表于 2022-4-6 09:25 | 显示全部楼层
  • 打卡总天数:2
  • 打卡总奖励:5
  • 最近打卡:2024-09-13 19:04:14
PADS20220406高级特惠班
发表于 2022-4-6 09:35 | 显示全部楼层
