| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D2 | LED_DUAL_SEP2_RG_2_LED4_2P54_8P | LEDR/G | LED4_2P54_8P13X4P5MM |
| D3 | PRTR5V0U2AX_SOT143B_IC_1.1MM_48 | PESD2ETH-AX | SOT143B |
| D4 | PRTR5V0U2AX_SOT143B_IC_1.1MM_48 | PESD2ETH-AX | SOT143B |
| D5 | DUALDIODE_CC_SOT23_SOT23_A_IC_1 | BAT54CLT1 | SOT23_A |
| D6 | DUALDIODE_CC_SOT23_SOT23_A_IC_1 | BAT54CLT1 | SOT23_A |
| D7 | LED_DUAL_SEP2_RG_0_LED_DUAL_2X1 | APHBM2012SURKCGKC | LED_DUAL_2X1P25MM_SM |
| D8 | LED_DUAL_SEP2_RG_0_LED_DUAL_2X1 | APHBM2012SURKCGKC | LED_DUAL_2X1P25MM_SM |
| D9 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
| D10 | LED_LED_0603_IC_1.1MM_370-76427 | LEDRed | LED_0603 |
| D11 | DIODE_SCH_A1A2C3_SOT1289_IC_0.8 | PMEG45A10EPD | SOT1289 |
| D12 | ZDIODE_SOD123_048X028_IC_1.45MM | BZT52C3V3 | SOD123_048X028 |
| D13 | ZDIODE_SOD123_048X028_IC_1.45MM | BZT52C3V3 | SOD123_048X028 |
| D14 | ZDIODE_SOD123_048X028_IC_1.45MM | BZT52C3V3 | SOD123_048X028 |
| D15 | ZDIODE_SOD123_048X028_IC_1.45MM | BZT52C3V3 | SOD123_048X028 |
| D16 | ZDIODE_SOD123_048X028_IC_1.45MM | BZT52C3V3 | SOD123_048X028 |
| D17 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D18 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D19 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D20 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D21 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D22 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D23 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D24 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D25 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D28 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D33 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
| D34 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D35 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D36 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
| D43 | ESD_DIODE_2LINE_SOT23_A_IC_1._1 | PESD2ETH1G-T | SOT23_A |
| D44 | ESD_DIODE_2LINE_SOT23_A_IC_1._1 | PESD2ETH1G-T | SOT23_A |
| D45 | ESD_DIODE_2LINE_SOT23_A_IC_1._1 | PESD2ETH1G-T | SOT23_A |
| D46 | ESD_DIODE_2LINE_SOT23_A_IC_1._1 | PESD2ETH1G-T | SOT23_A |
| D47 | ESD_DIODE_2LINE_SOT23_A_IC_1._1 | PESD2ETH1G-T | SOT23_A |
| D48 | ESD_DIODE_2LINE_SOT23_A_IC_1._1 | PESD2ETH1G-T | SOT23_A |
| D49 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D50 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D51 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D52 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D53 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D54 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D55 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D56 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D60 | DIODE_TVS_BIDIR_DO-214AC_BIDIR_ | SMAJ33CA | DO-214AC_BIDIR |
| D61 | ZDIODE_SOD123_IC_1.35MM_480-800 | MMSZ4700T1G | SOD123 |
| D62 | DIODE_SCHTKY_SOD_523_IC_0.7MM_4 | RB521S30T1G | SOD_523 |
| D63 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D64 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D65 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D66 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D67 | ESD_DIODE_2LINE_SOT23_A_IC_1.1M | PESD2IVN24-T | SOT23_A |
| D68 | DIODE_TVS_SOD-882_IC_0.5MM_480- | PESD5V0S1UL | SOD-882 |
| D69 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D70 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D71 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D72 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D73 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D76 | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | SOD123LF |
| D77 | DIODE_TVS_SOD-882_IC_0.5MM_480- | PESD5V0S1UL | SOD-882 |
| D78 | DIODE_TVS_SOD-882_IC_0.5MM_480- | PESD5V0S1UL | SOD-882 |
| D79 | DIODE_SCHTKY_SOD_523_IC_0.7MM_4 | RB521S30T1G | SOD_523 |
| D80 | DIODE_SCHTKY_SOD_523_IC_0.7MM_4 | RB521S30T1G | SOD_523 |
| F1 | FUSE_FUSE_3P4X1P8_DISCRETE_0.86 | 7A | FUSE_3P4X1P8 |
| FL1 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL2 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL3 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL4 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL5 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL6 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL7 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL8 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL9 | FILTER_4P_IND_ACT1210_SM_DISCRE | 200uH@ 100KHz | IND_ACT1210_SM |
| FL10 | FILTER_4P_IND_ACT1210_SM_DISCRE | 200uH@ 100KHz | IND_ACT1210_SM |
| FL15 | FILTER_4P_IND_ACT1210_SM_DISCRE | 200uH@ 100KHz | IND_ACT1210_SM |
| FL16 | FILTER_4P_IND_ACT1210_SM_DISCRE | 200uH@ 100KHz | IND_ACT1210_SM |
| FL17 | FILTER_4P_IND_ACT1210_SM_DISCRE | 200uH@ 100KHz | IND_ACT1210_SM |
| FL18 | FILTER_4P_IND_ACT1210_SM_DISCRE | 200uH@ 100KHz | IND_ACT1210_SM |
| FL19 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL20 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL21 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL22 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL23 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL24 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL25 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL26 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL501 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| FL502 | FILTER_4P_IND4_4P7X3P4_SMT_DISC | ACT45B-101-2P-TL003 | IND4_4P7X3P4_SMT |
| J1 | MICRO_USB_CONN_9PIN_CON9_MICROA | 6.29105E+11 | CON9_MICROAB_USB_SHELL_TH |
| J2 | MICRO_USB_CONN_9PIN_CON9_MICROA | 6.29105E+11 | CON9_MICROAB_USB_SHELL_TH |
| J3 | CONN_MICRO_SD_CARD_REVERSED_CON | ConnMicroSD | CON_SDCARD_8F_SM_RA |
| J4 | MICRO_USB_CONN_9PIN_CON9_MICROA | 6.29105E+11 | CON9_MICROAB_USB_SHELL_TH |
| J5 | CONN_HDR_13X2_CON2X13_2MM_RA_TH | con2x13 | CON2X13_2MM_RA_TH |
| J6 | CONN_RCPT_2X20_CON2X20_2MM_RA_T | con2x20 | CON2X20_2MM_RA_TH |
| J16 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J37 | CONN_HDR_3X1_HDR103_A_IO_8.74MM | HDR1X3 | HDR103_A |
| J44 | CONN_HDR_5X2_HDR205_10M_50_SM_K | FTSH-105-01-L-DV-K | HDR205_10M_50_SM_K |
| J47 | CON_67_FEMALE_RA_KEY_M_CON_75_0 | CON_MINI_PCIe_RA | CON_75_0P5_22X9_RA_KEY_M |
| J48 | HDR_2X10_HDR_20M_100_TH_IO_9.98 | HDR_2X10 | HDR_20M_100_TH |
| J50 | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR1X3 | HDR1X3_TH |
| J53 | CONN_HDR_24X1_CON24_2MM_34826_T | CON24 | CON24_2MM_34826_TH_DI |
| J56 | CON_67_FEMALE_RA_A_CON_67_0P5_2 | M.2SKT KEY-E | CON_67_0P5_22X6P73_RA |
| J57 | CONN_2X20_2G_CON2X20_0P8_23P5X5 | ASP-130367-01 | CON2X20_0P8_23P5X5P6_SM |
| J172 | CONN_HDR_3X1_HDR1X3_100_294X250 | HDR_1X3_W/LOCK | HDR1X3_100_294X250_TH |
| J176 | DCPOWER JACK_PJ-202B_IO_11MM_2 | CON_1_PWR | PJ-202B |
| J177 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J178 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J180 | CONN_HDR_2X2_HDR2X2_50MIL_IO_4. | HDR_2X2 | HDR2X2_50MIL |
| J181 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J182 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J183 | CONN_HDR_3X1_HDR103_A_IO_8.74MM | HDR1X3 | HDR103_A |
| J184 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J185 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J186 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J187 | CONN_HDR_3X1_CON_1X3_1P27_TH_IO | HDR_1X3 | CON_1X3_1P27_TH |
| J188 | CONN_HDR_3X1_HDR103_A_IO_8.74MM | HDR1X3 | HDR103_A |
| L1 | BEAD_0_0603_CC_DISCRETE_0.95MM_ | 120OHM | 0603_CC |
| L2 | BEAD_0_0603_CC_DISCRETE_0.95MM_ | 120OHM | 0603_CC |
| L3 | DLW43_IND4_CHOKE_0805_DISCRETE_ | 90OHM | IND4_CHOKE_0805 |
| L5 | EMIFILTER_NFM21P_CC_FIL_1206_DI | NFM31KC153R1H3 | CC_FIL_1206 |
| L6 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L7 | DLW43_IND_DLW43_DISCRETE_2.8MM_ | DLW43SH | IND_DLW43 |
| L8 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L26 | IND_FERRITE_IND_0603_DISCRETE_0 | 330OHM | IND_0603 |
| L27 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L28 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L30 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L31 | IND_FERRITE_IND_0603_DISCRETE_0 | 330OHM | IND_0603 |
| L32 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L33 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L34 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L35 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L37 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L38 | IND_FERRITE_IND_0603_DISCRETE_0 | 330OHM | IND_0603 |
| L39 | IND_IND_2P2X2_DISCRETE_1.4MM_18 | 4.7UH | IND_2P2X2 |
| L40 | IND_IND_2P2X2_DISCRETE_1.4MM_18 | 4.7UH | IND_2P2X2 |
| L41 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L43 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L44 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L45 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L46 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L47 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L48 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L49 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L50 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L51 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L53 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L54 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L55 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L56 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L57 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L58 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L59 | IND_FERRITE_IND_0603_DISCRETE_0 | 330OHM | IND_0603 |
| L515 | BEAD_IND_0805_DISCRETE_1.05MM_1 | MPZ2012S101A | IND_0805 |
| L519 | IND_3P_IND3_2P5_SQ5P2MM_DISCRET | 100nH | IND3_2P5_SQ5P2MM |
| L520 | INDUCTOR_IND2_7P5X7_DISCRETE_5. | 4.7UH | IND2_7P5X7 |
| L521 | INDUCTOR_IND_IHLP_DISCRETE_3.0M | 6.8uH | IND_IHLP |
| L522 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L523 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L524 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L528 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| L529 | BEAD_IND_0805_DISCRETE_1.05MM_2 | MPZ2012S101A | IND_0805 |
| L530 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L531 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L532 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L533 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600OHM | IND_1608 |
| LBK1 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| LBK2 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| LBK3 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| LBO1 | INDUCTOR_IND2520_DISCRETE_1.2_1 | 4.7uH | IND2520 |
| LPI1 | INDP_IND2_7P4X6P9_SM_DISCRETE_4 | 1uH | IND2_7P4X6P9_SM |
| LPRE1 | INDUCTOR_IND2_XAL1010_DISCRETE_ | 4.7uH | IND2_XAL1010 |
| P1 | PCIEXPRESS X1_CON_PCI_36_79TH_ | CONPCIE 36 | CON_PCI_36_79TH |
| P2 | RJ45_MAG_2X1_LED_CON_RJ45_2X1_M | RJ4513X2PORTS | CON_RJ45_2X1_MAG_LED |
| P3 | RJ45_MAG_2X1_LED_CON_RJ45_2X1_M | RJ4513X2PORTS | CON_RJ45_2X1_MAG_LED |
| P4 | RJ45_7499011121A_CON_RJ45_16F_2 | RJ45 | CON_RJ45_16F_2P54_TH_RA |
| P5 | CON_RJ45_19P_CON19_RJ-45_LED_80 | RJ45-19 | CON19_RJ-45_LED_80MIL_TH_RA |
| Q1 | NMOS_NX3008NBK_DFN10106B_IC_0.4 | PMZB550UNE | DFN10106B |
| Q3 | NMOS_DUAL_8P_LFPAK56_1P27_4P7X5 | BUK9K18-40E | LFPAK56_1P27_4P7X5P3 |
| Q5 | PNP_SC70_3_IC_1.1MM_480-79396_P | PMST2907A | SC70_3 |
| Q7 | NPN_SOT23_A_IC_1.1MM_480-78958_ | PMBT3904 | SOT23_A |
| Q8 | NPN_SOT23_A_IC_1.1MM_480-78958_ | PMBT3904 | SOT23_A |
| Q9 | PNP_SC70_3_IC_1.1MM_480-79396_P | PMST2907A | SC70_3 |
| Q10 | MOSFET_P_5P_SO8_U8FL_0P65_3P3SQ | NVTFS5116PLTAG | U8FL_0P65_3P3SQ |
| Q11 | MOSFET_P_DIODE_SOT23_A_IC_1.1MM | PMV27UPEA | SOT23_A |
| Q12 | PNP_SC70_3_IC_1.1MM_480-79396_P | PMST2907A | SC70_3 |
| Q13 | NPN_SOT23_A_IC_1.1MM_480-78958_ | PMBT3904 | SOT23_A |
| QZ1 | CRYSTAL_XTAL2-3P2X1P5-SM_IC_0.9 | 32.768KHZ | XTAL2-3P2X1P5-SM |
| RN3 | NETW_B8_10P_RCA_8_10_DISCRETE_0 | 10K | RCA_8_10 |
| RN4 | NETW_B8_10P_RCA_8_10_DISCRETE_0 | 10K | RCA_8_10 |
| RSNS1 | RES_4PIN_RC2512_4P_6P6X3P4_DISC | 0.01 | RC2512_4P_6P6X3P4 |
| SW1 | SW_TACT-SPST-2_SM1_SW2_TL1105M_ | TL1105MF160Q | SW2_TL1105M |
| SW2 | SW_TACT-SPST-2_SM1_SW2_TL1105M_ | TL1105MF160Q | SW2_TL1105M |
| SW3 | SW-SPST_SW2_DIP_1P27_2P51X5P7_I | SWDIP 1 POS | SW2_DIP_1P27_2P51X5P7 |
| SW4 | SW_DIP-8_SM_SW16_DIP_1P27_11P4X | SW_DIP-8/SM | SW16_DIP_1P27_11P4X5P7 |
| SW5 | SW_DIP-8_SM_SW16_DIP_1P27_11P4X | SW_DIP-8/SM | SW16_DIP_1P27_11P4X5P7 |
| SW6 | SW_DIP-8_SM_SW16_DIP_1P27_11P4X | SW_DIP-8/SM | SW16_DIP_1P27_11P4X5P7 |
| SW7 | SW_DIP-8_SM_SW16_DIP_1P27_11P4X | SW_DIP-8/SM | SW16_DIP_1P27_11P4X5P7 |
| SW8 | SW-SPST_SW2_DIP_1P27_2P51X5P7_I | SWDIP 1 POS | SW2_DIP_1P27_2P51X5P7 |
| SW9 | SW_DIP-2_SW2_DIP_1P27_4X5P8_IC_ | SWDIP 2 POS | SW2_DIP_1P27_4X5P8 |
| SW10 | SW_DIP-2_SW2_DIP_1P27_4X5P8_IC_ | SWDIP 2 POS | SW2_DIP_1P27_4X5P8 |
| SW11 | SW-SPST_SW2_DIP_1P27_2P51X5P7_I | SWDIP 1 POS | SW2_DIP_1P27_2P51X5P7 |
| SW12 | SW_DIP-2_SW2_DIP_1P27_4X5P8_IC_ | SWDIP 2 POS | SW2_DIP_1P27_4X5P8 |
| SW15 | SW3_SPDT_SW3_SLIDE_260X500_TH_I | SPDT_SLIDE_SWITCH | SW3_SLIDE_260X500_TH |
| SW16 | SW2P_SW2_SPST_3P5X6P0_5P0_IC_5. | EVQ-PE105K | SW2_SPST_3P5X6P0_5P0 |
| SW17 | SW-SPST_SW2_DIP_1P27_2P51X5P7_I | SWDIP 1 POS | SW2_DIP_1P27_2P51X5P7 |
| U1 | 1G17_SC70-5_IC_1.1MM_312-81468_ | 74LVC1G17GW | SC70-5 |
| U2 | FT232RQ_QFN32_MC1320X_IC_1.05MM | FT232RQ | QFN32_MC1320X |
| U3 | FT232RQ_QFN32_MC1320X_IC_1.05MM | FT232RQ | QFN32_MC1320X |
| U5 | 74AUP1G11GW_SOT-363_0P65_SMT_IC | 74AUP1G11GW | SOT-363_0P65_SMT |
| U6 | 1G17_SC70-5_IC_1.1MM_312-81468_ | 74LVC1G17GW | SC70-5 |
| U7 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U8 | USB83340_QFN32_QFN32_IC_0.9MM_ | USB83340 | QFN32 |
| U9 | TJA1024HG_24P_QFN24_0P5_5P6X3P6 | TJA1024HG | QFN24_0P5_5P6X3P6_EP |
| U11 | OPAMP_DUAL_8P_D_SO8_1P27_4X5_IC | MCP6022-E/SN | SO8_1P27_4X5 |
| U12 | OPAMP_DUAL_8P_D_SO8_1P27_4X5_IC | MCP6022-E/SN | SO8_1P27_4X5 |
| U13 | OPAMP_DUAL_8P_D_SO8_1P27_4X5_IC | MCP6022-E/SN | SO8_1P27_4X5 |
| U15 | TJA1043TK_14P_HVSON14_0P65_4P6X | TJA1043TKY | HVSON14_0P65_4P6X3P1_EP |
| U16 | TJA1043TK_14P_HVSON14_0P65_4P6X | TJA1043TKY | HVSON14_0P65_4P6X3P1_EP |
| U17 | TJA1043TK_14P_HVSON14_0P65_4P6X | TJA1043TKY | HVSON14_0P65_4P6X3P1_EP |
| U18 | TJA1043TK_14P_HVSON14_0P65_4P6X | TJA1043TKY | HVSON14_0P65_4P6X3P1_EP |
| U19 | TJA1153ATK_HVSON14_HVSON14_0P65 | TJA1153 | HVSON14_0P65_4P6X3P1_EP |
| U20 | TJA1153ATK_HVSON14_HVSON14_0P65 | TJA1153 | HVSON14_0P65_4P6X3P1_EP |
| U21 | TJA1043ATK_14P_EP_HVSON14_0P65_ | TJA1463ATK | HVSON14_0P65_4P6X3P1_EP |
| U22 | TJA1043ATK_14P_EP_HVSON14_0P65_ | TJA1463ATK | HVSON14_0P65_4P6X3P1_EP |
| U23 | TJA1081_SSOP_16P_SSOP16_6P5X5P6 | TJA1081GTS | SSOP16_6P5X5P6MM |
| U24 | PCAL6524HE_QFN_32P_UQFN32_0P5_5 | PCAL6524HEAZ | UQFN32_0P5_5X5_EP3X3 |
| U25 | MAX4886E_42P_EP_QFN42_0P5_9X3P5 | MAX4886ETO+ | QFN42_0P5_9X3P5_EP2P1X7P5 |
| U26 | MAX4886E_42P_EP_QFN42_0P5_9X3P5 | MAX4886ETO+ | QFN42_0P5_9X3P5_EP2P1X7P5 |
| U28 | MTFC16GAKAE_VFBGA_153P_FBGA153_ | MTFC32GAPALBH-AAT | FBGA153_0P5_11P5X13 |
| U31 | MAX4886E_42P_EP_QFN42_0P5_9X3P5 | MAX4886ETO+ | QFN42_0P5_9X3P5_EP2P1X7P5 |
| U33 | 1G125_SC70-5_IC_1.1MM_315-80956 | 74AUP1G125GW | SC70-5 |
| U34 | MAX4886E_42P_EP_QFN42_0P5_9X3P5 | MAX4886ETO+ | QFN42_0P5_9X3P5_EP2P1X7P5 |
| U37 | MX25UW51245GXDR00_BGA24_PBGA24_ | MX25UW51245GXDR00 | PBGA24_1_6X8MM |
| U38 | MAX4886E_42P_EP_QFN42_0P5_9X3P5 | MAX4886ETO+ | QFN42_0P5_9X3P5_EP2P1X7P5 |
| U39 | 74LVC1G32GF_6P_UDFN6_1X1P5MM_IC | 74AUP1G09GM | UDFN6_1X1P5MM |
| U40 | 74LVC1G32GF_6P_UDFN6_1X1P5MM_IC | 74AUP1G09GM | UDFN6_1X1P5MM |
| U41 | VR5510_QFN56P_EP_QFN56_0P5_8X8_ | PVR5510AMDAHES | QFN56_0P5_8X8_EP217X199 |
| U42 | MT53B768M32D4NQ_200P_BGA200_0P6 | MT53D1024M32D4DT-046AUT | BGA200_0P65X0P8_10P1X14P6 |
| U43 | S32G275_BGA525_A_BGA525_0P8_19X | S32G274A | BGA525_0P8_19X19MM |
| U44 | MAX4886E_42P_EP_QFN42_0P5_9X3P5 | MAX4886ETO+ | QFN42_0P5_9X3P5_EP2P1X7P5 |
| U46 | SJA1110_BGA256_B_BGA256_0P8_14X | SJA1110(RHINE) | BGA256_0P8_14X14MM |
| U47 | DIODEZ_SOT23_SOT23_A_IC_1.1MM_4 | BZX84-A7V5 | SOT23_A |
| U48 | CBTL02043ABQ_20P_DHVQFN20_0P5_2 | CBTL02043A | DHVQFN20_0P5_2P6X4P6 |
| U49 | NC7SZ14_SC70-5_IC_1.1MM_312-819 | 74LVC1G04GW-Q100 | SC70-5 |
| U50 | 25WP_8P_SO8_1P27_4X5_IC_1.75MM_ | IS25LP080D-JNLE | SO8_1P27_4X5 |
| U51 | CBTL02043ABQ_20P_DHVQFN20_0P5_2 | CBTL02043A | DHVQFN20_0P5_2P6X4P6 |
| U53 | 74CBTLV3253DS_QSOP16-16X70_IC_1 | 74CBTLV3253DS | QSOP16-16X70 |
| U54 | 74LVC1G32GF_6P_UDFN6_1X1P5MM__1 | 74AUP1G08GM | UDFN6_1X1P5MM |
| U56 | AR8035_QFN40_A_QFN40_0P4_5P1X5P | AR8035 | QFN40_0P4_5P1X5P1 |
| U57 | AR8035_QFN40_A_QFN40_0P4_5P1X5P | AR8035 | QFN40_0P4_5P1X5P1 |
| U58 | KSZ9031RNXUA_48P_EP_WQFN48_0P5_ | KSZ9031RNXVB-VAO | WQFN48_0P5_7X7_EP5P05 |
| U59 | SI5332-GM1_QFN32_S142EP_IC_0.9M | Si5332DD12454-AM1 | QFN32_S142EP |
| U62 | 74CBTLV3253DS_QSOP16-16X70_IC_1 | 74CBTLV3253DS | QSOP16-16X70 |
| U67 | TJA1043ATK_14P_EP_HVSON14_0P65_ | TJA1463ATK | HVSON14_0P65_4P6X3P1_EP |
| U68 | TJA1043ATK_14P_EP_HVSON14_0P65_ | TJA1463ATK | HVSON14_0P65_4P6X3P1_EP |
| U69 | TJA1153ATK_HVSON14_HVSON14_0P65 | TJA1153 | HVSON14_0P65_4P6X3P1_EP |
| U70 | TJA1153ATK_HVSON14_HVSON14_0P65 | TJA1153 | HVSON14_0P65_4P6X3P1_EP |
| U71 | TJA1043TK_14P_HVSON14_0P65_4P6X | TJA1043TKY | HVSON14_0P65_4P6X3P1_EP |
| U72 | TJA1043TK_14P_HVSON14_0P65_4P6X | TJA1043TKY | HVSON14_0P65_4P6X3P1_EP |
| U73 | TJA1043TK_14P_HVSON14_0P65_4P6X | TJA1043TKY | HVSON14_0P65_4P6X3P1_EP |
| U74 | TJA1043TK_14P_HVSON14_0P65_4P6X | TJA1043TKY | HVSON14_0P65_4P6X3P1_EP |
| U75 | CBTL02043ABQ_20P_DHVQFN20_0P5_2 | CBTL02043A | DHVQFN20_0P5_2P6X4P6 |
| U76 | CBTL02043ABQ_20P_DHVQFN20_0P5_2 | CBTL02043A | DHVQFN20_0P5_2P6X4P6 |
| U78 | 74LVC1G32GF_6P_UDFN6_1X1P5MM__1 | 74AUP1G08GM | UDFN6_1X1P5MM |
| U80 | FPF1321_6P_WLCSP6_0P5_0P98X1P48 | FPF1321UCX | WLCSP6_0P5_0P98X1P48 |
| U82 | NX3DV3899GU_XQFN_16P_PQFN16_0P4 | NX3DV3899GU | PQFN16_0P4_2P65X1P85 |
| U83 | PCA8565TS_TSSOP8_TSSOP8_A_IC_1. | PCA85073A | TSSOP8_A |
| U84 | KSZ9031RNXUA_48P_EP_WQFN48_0P5_ | KSZ9031RNXVB-VAO | WQFN48_0P5_7X7_EP5P05 |
| U85 | 74LVC1G32GF_6P_UDFN6_1X1P5MM__1 | 74AUP1G08GM | UDFN6_1X1P5MM |
| U86 | AQR113C-BGA64_BGA64_0P8_7P1X7P1 | AQR113C-B0-C | BGA64_0P8_7P1X7P1 |
| U87 | NTS0102_XSON8_0P5_3P1X2P1_IC_0. | NTS0102 | XSON8_0P5_3P1X2P1 |
| U89 | AT45DB041D-SU_SO8_1P27_4X5_IC_1 | AT45DB041E-SSHN2B-B | SO8_1P27_4X5 |
| U90 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U92 | IC_PMIC_QFN_PQFN24_0P5_3P5X4P5M | BUCK_CONVERTER | PQFN24_0P5_3P5X4P5MM |
| U93 | MOSFET_DUAL_NMOS_6P_A_LFPAK56_1 | BUK9K18-40E | LFPAK56_1P27_4P7X5P3 |
| U94 | FS5600_QFN32_HPQFN32_0P5_5X5_EP | MFS5600AMMA7ES | HPQFN32_0P5_5X5_EP3P6 |
| U96 | PF5020_QFN40_QFN40_0P5_6X6_4P_1 | PPF5020AMBACES | QFN40_0P5_6X6_4P1EP |
| U98 | TJA1043ATK_14P_EP_HVSON14_0P65_ | TJA1463ATK | HVSON14_0P65_4P6X3P1_EP |
| U99 | TJA1043ATK_14P_EP_HVSON14_0P65_ | TJA1463ATK | HVSON14_0P65_4P6X3P1_EP |
| U100 | TJA1021T_SO8_1P27_4X5_IC_1.75MM | TJA1021T/20/C | SO8_1P27_4X5 |
| U101 | NX5P3290_16P_BGA16_0P5_2P23X2P2 | NX5P3363UKZ | BGA16_0P5_2P23X2P23 |
| U103 | CBTL02043ABQ_20P_DHVQFN20_0P5_2 | CBTL02043A | DHVQFN20_0P5_2P6X4P6 |
| U104 | CBTL02043ABQ_20P_DHVQFN20_0P5_2 | CBTL02043A | DHVQFN20_0P5_2P6X4P6 |
| U105 | CBTL02043ABQ_20P_DHVQFN20_0P5_2 | CBTL02043A | DHVQFN20_0P5_2P6X4P6 |
| U106 | CBTL02043ABQ_20P_DHVQFN20_0P5_2 | CBTL02043A | DHVQFN20_0P5_2P6X4P6 |
| U107 | NC7SZ14_SC70-5_IC_1.1MM_312-819 | 74LVC1G04GW-Q100 | SC70-5 |
| U108 | PF5020_QFN40_QFN40_0P5_6X6_4P1E | PPF5020AMBADES | QFN40_0P5_6X6_4P1EP |
| U109 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U110 | NX30P0121UKZ_WLCSP_12P_WLCSP12_ | NX30P0121UK | WLCSP12_0P4_1P38X1P68MM_SMDP |
| U111 | NTS0102_XSON8_0P5_3P1X2P1_IC_0. | NTS0102 | XSON8_0P5_3P1X2P1 |
| U112 | NC7SZ14_SC70-5_IC_1.1MM_312-819 | 74LVC1G04GW-Q100 | SC70-5 |
| U113 | 74LVC1G32GF_6P_UDFN6_1X1P5MM_IC | 74AUP1G09GM | UDFN6_1X1P5MM |
| U115 | 74LVC1G32GF_6P_UDFN6_1X1P5MM_IC | 74AUP1G09GM | UDFN6_1X1P5MM |
| U116 | 74AUP1G11GW_SOT-363_0P65_SMT_IC | 74AUP1G11GW | SOT-363_0P65_SMT |
| U119 | AND_TRIPLE_EP_DHVQFN14_3X2P5MM_ | 74LVC11BQ | DHVQFN14_3X2P5MM |
| U124 | NX30P0121UKZ_WLCSP_12P_WLCSP12_ | NX30P0121UK | WLCSP12_0P4_1P38X1P68MM_SMDP |
| U125 | 1G125_SC70-5_IC_1.1MM_315-80956 | 74AUP1G125GW | SC70-5 |
| U126 | 1G125_SC70-5_IC_1.1MM_315-80956 | 74AUP1G125GW | SC70-5 |
| U127 | NX3P1108_4P_WLCSP4_0P5_0P99X0P9 | NX3P1108 | WLCSP4_0P5_0P99X0P99 |
| U128 | LED_RGB_6P_LED6_0P85_3P25X2P85_ | 150352M173300 | LED6_0P85_3P25X2P85_SM |
| U129 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U131 | SN74AVC2T45_TSSOP8_A_IC_1.3MM_ | SN74AVC2T45DCTR | TSSOP8_A |
| U132 | SN74AVC2T45_TSSOP8_A_IC_1.3MM_ | SN74AVC2T45DCTR | TSSOP8_A |
| U133 | 1G17_SC70-5_IC_1.1MM_312-81468_ | 74LVC1G17GW | SC70-5 |
| U134 | 1G17_SC70-5_IC_1.1MM_312-81468_ | 74LVC1G17GW | SC70-5 |
| U135 | NX3P1108_4P_WLCSP4_0P5_0P99X0P9 | NX3P1108 | WLCSP4_0P5_0P99X0P99 |
| U136 | INA231_CSP_12P_CSP12_0P4_1P675X | INA231 | CSP12_0P4_1P675X1P418_SMDP |
| U137 | PCT2075_SON8_EP_HWSON8_0P5_3P1 | PCT2075 | HWSON8_0P5_3P1X2P1 |
| Y1 | XTAL_13_XTLOSC4_3P2X2P5MM_SM_IC | 26MHZ | XTLOSC4_3P2X2P5MM_SM |
| Y2 | XTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I | 40MHz | XTLOSC4_3P2X2P5MM_SM |
| Y3 | XTAL_13_XTLOSC4_3P2X2P5MM_SM__1 | 25MHz | XTLOSC4_3P2X2P5MM_SM |
| Y4 | XTAL_13_XTAL4_3P3X2P6_SM_FL_IC_ | 50Mhz | XTAL4_3P3X2P6_SM_FL |
| Y6 | XTAL_13_XTLOSC4_3P2X2P5MM_SM__1 | 25MHz | XTLOSC4_3P2X2P5MM_SM |
| Y7 | XTAL_13_XTLOSC4_3P2X2P5MM_SM__1 | 25MHz | XTLOSC4_3P2X2P5MM_SM |
| Y10 | XTAL_13_XTLOSC4_3P2X2P5MM_SM__1 | 25MHz | XTLOSC4_3P2X2P5MM_SM |
