楼主: qczzhi
[问题求助] capture17.4导出原理图后字体显示不连续
 楼主| 发表于 2022-9-1 09:31 | 显示全部楼层
回 aseyer22 的帖子
aseyer22:go to your design properties-> fonts then change the Text from Arial to Courier New.
 (2022-09-01 09:02)
thanks,and did you try this and it's normal?    I changed the Text from Courier New to Arial a few days ago.
发表于 2022-9-1 10:16 | 显示全部楼层
回 qczzhi 的帖子
Capture1.PNG qczzhi :
Yes i did export pdf and here's the outcome
 楼主| 发表于 2022-9-1 16:29 | 显示全部楼层
回 aseyer22 的帖子
aseyer22:Yes i did export pdf and here's the outcome (2022-09-01 10:16)
Was it normal before it was changed? I changed  the Text from Arial to Courier New but it didn't improve.I'm not sure if it's because of win10...
发表于 2022-9-1 17:20 | 显示全部楼层
发表于 2022-9-1 18:08 | 显示全部楼层
回 qczzhi 的帖子
qczzhi:Was it normal before it was changed? I changed  the Text from Arial to Courier New but it didn't improve.I'm not sure if it's because of win10... (2022-09-01 16:29)
before i change the font i generated pdf like you have then after i changed it improves.
i also using a win10 PC. are you using the ghostscript to generate pdf?
 楼主| 发表于 2022-9-2 09:26 | 显示全部楼层
回 aseyer22 的帖子
aseyer22:
Yes, I have uesd ghostscript and acrobat but the result is the same.
发表于 2022-9-2 13:15 | 显示全部楼层
回 qczzhi 的帖子
it seems problem is not on your software, try to use other PC to export pdf.
you compare the parameters of your PC to another PC.
  • 打卡总天数:793
  • 打卡月天数:17
  • 打卡总奖励:2621
  • 最近打卡:2026-11-18 15:37:49
发表于 2022-9-4 08:35 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:67
  • 打卡月天数:7
  • 打卡总奖励:182
  • 最近打卡:2026-11-17 22:25:10
Allegro261021初级班
发表于 2022-9-4 11:03 | 显示全部楼层
  • 打卡总天数:1
  • 打卡总奖励:1
  • 最近打卡:2026-07-17 22:45:39
发表于 2022-9-10 16:44 | 显示全部楼层
