| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | DIODE1N4004_D604_0_D0603_1N414 | 1N4148 | D0603 |
| D2 | DIODE1N4004_D604_0_D0603_1N414 | 1N4148 | D0603 |
| D3 | DIODE1N4004_D604_0_D0603_1N414 | 1N4148 | D0603 |
| D4 | DIODE1N4004_D604_0_D0603_1N414 | 1N4148 | D0603 |
| D5 | DIODE1N4004_D604_0_D0603_1N414 | 1N4148 | D0603 |
| D6 | DIODE1N4004_D604_0_D0603_1N414 | 1N4148 | D0603 |
| D7 | DIODE1N4004_D604_0_SOD323_NC | NC | SOD323 |
| D8 | DIODE1N4004_D604_0_SMA_SS34 | SS34 | SMA |
| D9 | DIODE1N4004_D604_0_SMC_SL42 | SL42 | SMC |
| D10 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D11 | DIODE1N4004_D604_0_SMA_SS34 | SS34 | SMA |
| D12 | DIODE1N4004_D604_0_SMA_SS12 | SS12 | SMA |
| D14 | DIODE_D0603_IN4148 | IN4148 | D0603 |
| D15 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D16 | DIODE_D0603_IN4148 | IN4148 | D0603 |
| D17 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D18 | DIODE_D0603_IN4148 | IN4148 | D0603 |
| D19 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D20 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D21 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D22 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D23 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D24 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D25 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D26 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D27 | DIODEBI_DIR TRIG_SOD323_SPD911 | SPD9112W | SOD323 |
| D28 | DIODEBI_DIR TRIG_SOD323_SPD911 | SPD9112W | SOD323 |
| D29 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D30 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D31 | DIODEBI_DIR TRIG_R0402_ESD5451 | ESD5451N | R0402 |
| D32 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D33 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D34 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D35 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D36 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D37 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D38 | DIODE_D0603_NC | NC | D0603 |
| D39 | DIODE_D0603_NC | NC | D0603 |
| D40 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D41 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D42 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D43 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D44 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D45 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D46 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D47 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D48 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D49 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D50 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D51 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D52 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D53 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D54 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D55 | DIODE_D0603_1N4148 | 1N4148 | D0603 |
| D56 | DIODE_SOD323_IN4148 | IN4148 | SOD323 |
| J1 | JAMP_FB0_2_JAMP_5MM | JAMP_5mm | FB0_2 |
| J2 | JAMP_FB0_2_JAMP_5MM | JAMP_5mm | FB0_2 |
| J3 | JAMP_FB0_2_JAMP_5MM | JAMP_5mm | FB0_2 |
| J4 | HEADER4_CON1X4_3R96_H10_VM_VH- | VH-4P | CON1X4_3R96_H10_VM |
| J5 | HEADER4_CON1X4_3R96_H10_VM_VH- | VH-4P | CON1X4_3R96_H10_VM |
| J6 | HEADER12_GY_B01M_A_12PIN_R1_A_ | GY-B01M-A-12PIN-R1 | GY_B01M_A_12PIN_R1_A |
| J9 | HEADER6_GY_B01M_A_6P_R1_GY-B01 | GY-B01M-A-6P-R1 | GY_B01M_A_6P_R1 |
| J10 | HEADER7_1_CON1X7_2_H6_VM_SH-7P | SH-7P | CON1X7_2_H6_VM |
| J13 | CON7_3_CON1X5_2_H6_VM_PH-5P | PH-5P | CON1X5_2_H6_VM |
| J14 | CON7_4_PH-1_0_5P_WT_CON7 | CON7 | PH-1_0_5P_WT |
| J15 | HEADER15_CON1X15_2_H6_VM_PH-15 | PH-15P | CON1X15_2_H6_VM |
| L1 | INDUCTOR_L_13R8X12R8_H7R3_SM_CS | CSBL1275-150M | L_13R8X12R8_H7R3_SM |
| L2 | INDUCTOR_L_13R8X12R8_H7R3_SM__1 | CSBL1275-560M | L_13R8X12R8_H7R3_SM |
| L3 | INDUCTORSOF FERRITE_0_L_3X3_H1 | SWPA3015S220MT | L_3X3_H1R5_SM |
| L4 | INDUCTOR_R0805_BLM21PG2218N1 | BLM21PG2218N1 | R0805 |
| L5 | INDUCTOR_R0805_BLM21PG2218N1 | BLM21PG2218N1 | R0805 |
| L6 | INDUCTOR_L0805_BLM21PG2218N1 | BLM21PG2218N1 | L0805 |
| L7 | INDUCTOR_L0805_BLM21PG2218N1 | BLM21PG2218N1 | L0805 |
| L8 | INDUCTOR_L0805_BLM21PG2218N1 | BLM21PG2218N1 | L0805 |
| LED1 | LED_0_LED0603_RED | RED | LED0603 |
| LED2 | LED_0_LED0603_RED | RED | LED0603 |
| Q1 | EMB09N03V_1_DFN8_1R27_6X5_H1R1_ | D120N10ES | DFN8_1R27_6X5_H1R1_MOS |
| Q2 | EMB09N03V_1_DFN8_1R27_6X5_H1R1_ | D120N10ES | DFN8_1R27_6X5_H1R1_MOS |
| Q3 | EMB09N03V_1_DFN8_1R27_6X5_H1R1_ | D120N10ES | DFN8_1R27_6X5_H1R1_MOS |
| Q4 | EMB09N03V_1_DFN8_1R27_6X5_H1R1_ | D120N10ES | DFN8_1R27_6X5_H1R1_MOS |
| Q5 | 2N3904_Q601_0_SOT23_9014 | 9014 | SOT23 |
| Q6 | 2N3904_Q601_0_SOT23_9014 | 9014 | SOT23 |
| Q7 | PDGS_1_SOT23_SI2301 | SI2301 | SOT23 |
| Q8 | NPN_0_SOT23_9014 | 9014 | SOT23 |
| Q9 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q10 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q11 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q12 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q13 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q14 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q15 | MOSFETN_SOT23_2SK3018 | 2SK3018 | SOT23 |
| Q16 | MOSFETN_SOT23_2SK3018 | 2SK3018 | SOT23 |
| Q17 | MOSFETN_SOT23_2SK3018 | 2SK3018 | SOT23 |
| Q18 | MOSFETN_SOT23_2SK3018 | 2SK3018 | SOT23 |
| Q19 | MOSFETN_SOT23_2SK3018 | 2SK3018 | SOT23 |
| Q20 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q21 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q22 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q23 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q24 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q25 | FDS4435A_SOP8_YJS4407A | YJS4407A | SOP8 |
| Q26 | PNP_SOT23_9015 | 9015 | SOT23 |
| Q27 | PNP_SOT23_9015 | 9015 | SOT23 |
| Q28 | MOSFETN_SOT23_2SK3018 | 2SK3018 | SOT23 |
| Q29 | MOSFETN_SOT23_2SK3018 | 2SK3018 | SOT23 |
| Q30 | MOSFETN_SOT23_2SK3018 | 2SK3018 | SOT23 |
| Q31 | 2N6788_0_SOT23_AO3400 | AO3400 | SOT23 |
| Q32 | 2N6788_0_SOT23_AO3400 | AO3400 | SOT23 |
| Q33 | NPN_SOT23_9014 | 9014 | SOT23 |
| Q34 | 2N6788_0_SOT23_AO3400 | AO3400 | SOT23 |
| Q35 | NPN_SOT23_9014 | 9014 | SOT23 |
| Q36 | NPN_SOT23_9014 | 9014 | SOT23 |
| TP9 | TPOINT R_TP_1R3_0R9_3.3V | 3.3V | TP_1R3_0R9 |
| TP10 | TPOINT R_TP_TOPLAYER_5V | 5V | TP_TOPLAYER |
| TP11 | TP_TP_1R3_0R9_IR | IR | TP_1R3_0R9 |
| U1 | SC8701_1_QFN32_0R4_4X4_H0R8_SC8 | SC8701 | QFN32_0R4_4X4_H0R8 |
| U2 | RT8289_SOP8_PAD_RT8279 | RT8279 | SOP8_PAD |
| U3 | DCDC_SY8113_SOT_23_6_TMI3253SH | TMI3253SH | SOT_23_6 |
| U4 | REG1117A-1.8_U606_TI-DCY4_L_LM1 | LM1117S-3.3 | TI-DCY4_L |
| U5 | REG1117A-1.8_U606_TI-DCY4_L_L_1 | LM1117S-5 | TI-DCY4_L |
| U6 | SI8621BC-B-IS_U301_SOP8_1R27_3R | NSI8122S | SOP8_1R27_3R9_H1R8 |
| U7 | MAX232ECD_U308_SOP16_1R27_3R9_M | MAX3232ExPW | SOP16_1R27_3R9 |
| U8 | ISO1541_U805_0_SOP8_NSI8100N | NSi8100N | SOP8 |
| U9 | STM32F103_48P_QFP48_0R5_7X7_H1R | CH32V303CBT6 | QFP48_0R5_7X7_H1R6 |
| Y1 | CRYSTAL_OSC2_5R0X3R2_H1R3_SM_8M | 8M | OSC2_5R0X3R2_H1R3_SM |
