industrial wireless AP router/indoor based on QSDK IPQ6010/IPQ4019/IPQ4029 Support openwrt QCA9880 QCN9074
The industrial wireless router adopts high performance industrial 32-bit communication processor and industrial wireless module, with embedded real-time operating system
Software support platform, at the same time provides 1 RS232, 4 Ethernet LAN, 1 Ethernet WAN and 1 WIFI interface, can be connected to serial devices, Ethernet devices and WIFI devices at the same time, to achieve transparent data transmission and routing functions.
The industrial wireless router is a durable device designed to connect two or more networks and transmit signals only to the required ports. The gateway can convert standard Ethernet and industrial Ethernet protocols, wireless and wired interfaces, or Ethernet and fieldbus communication protocols. Processor performance ranges from 200 to over 1500 MIPS, and on-chip memory capacity is usually greater than 256 KB of second-level cache. This factory automation equipment is rugged and suitable for harsh industrial environments without fan cooling.
The WCDMA/HSDPA/HSUPA Router adopts high-performance 32-bit industrial ARM9 communication processor and embedded real-time operating system as the software support platform. The system integrates a whole series of communication protocols from the logical link layer to the application layer. Supports static and dynamic routing, PPP server and PPP client, VPN (including PPTP and IPSEC),DHCP server and DHCP client, DDNS, firewall, NAT, and DMZ host. To provide users with a secure, high-speed, stable and reliable wireless routing network, routing and forwarding of various protocols. Products have been widely used in finance, water conservancy, environmental protection, electric power, postal, meteorological and other industries.
wallys has many industrial wireless routers. wallys is a professional ODM manufacturer of wireless equipment, and its strength is beyond doubt.
Here are some popular indoor aps. Outdoor AP there are, of course, if you are interested, please see the wallys's website: https://www.wallystech.com/Industrial_Wireless_AP.html
Iindustrial wifi5 router /DR-AP40X9-A
IPQ4019/IPQ4029 OpenWrt 2.4/5G dual bands 802.11ac
Indoor Aluminium alloy material .
Description
DR-AP40X9-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);
1 x Enclosure.
Dipole antenna
■ 2 x 2.4G&5G Antenna
■ 5dBi 2.4GHz/5Ghz
■ SMA Plug interface
■ Plastic rod of black
■ RoHS compliance
Enclosure
■ Dimension: 132x 119 x 34 mm
■ Aluminum alloy material
■ Support WallysDR40X9
Iindustrial wifi6 router /DR-AP6018-A
IPQ6018 OpenWrt 2.4/5G dual bands 802.11ax
Indoor Aluminium alloy material.
Description
DR-AP6018-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR6018(IPQ6010) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);
1 x Enclosure.
Dipole antenna
■ 5dBi 2.4GHz/5Ghz
■ RoHS compliance
Enclosure
■ Dimension: 192x 123 x 44 mm
■ Two Version :
DR-AP6018-AB : Color Black
DR-AP6018-AO: Color Orange
■ Support Wallys DR6018
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective router boards , wireless network cards,antenna ,enclosure and etc., Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
Skype/EMAIL/Teams:sales@wallystech.com |
