查看: 5275|回复: 79
[Allegro17.4以下] 1500W 电池管理板PCB文件
  • 打卡等级:常住青年
  • 打卡总天数:15
  • 打卡总奖励:36
  • 最近打卡:2026-07-16 23:13:38
3636
4万
终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖原创先锋奖灌水天才奖新人进步奖社区明星最爱沙发
发表于 2023-1-10 11:25 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
CON3XT30_P_XT30U-M_XT30_PXT30_PXT30U-M
CON5DIP_1_DIP-4-2_54MM_12V+12V+DIP-4-2_54MM
D1DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D2DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D3DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D4DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D38BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMA
D39BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMA
D40BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMA
D42DIO_5_SMA_SS54SS54SMA
D48BZX84C16/SOT_5_SMA_TVS_30VTVS_30VSMA
D57BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMA
D58BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMA
D61TLP3023_0_LEDC1608X60N_GLED/NCGLED/NCLEDC1608X60N
D62TLP3023_0_LEDC1608X60N_GLED/NCGLED/NCLEDC1608X60N
D63DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D64DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D65DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D66DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D74PMOS_3PIN_SOT-23_AO3401AO3401SOT-23
D108DI-XI-S_0_SOD-323_IC_3.6V/NC3.6V/NCSOD-323
D354BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23
D359DIO_6_PS-277B_ST2045ST2045PS-277B
D360DIO_6_PS-277B_ST2045ST2045PS-277B
D361DIO_6_PS-277B_ST2045ST2045PS-277B
D362BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23
D364BZX84C16/SOT_15_SMA_DO-214AC_SMAJ25CASMAJ25CASMA_DO-214AC
D365BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D366BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D367BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D368BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D369BZX84C16/SOT_14_SMA_DO-214AC_SMAJ25CASMAJ25CASMA_DO-214AC
D370BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D371BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D372BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D373BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D374DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D375DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D376DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D377DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D378DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D379DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D380DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D381DIO_4_SOD-323_1N4148WS1N4148WSSOD-323
D383DIO_5_SMA_SS34SS34SMA
D384DIO_5_SMA_SS34SS34SMA
D386PMOS_3PIN_SOT-23_AO3401AO3401SOT-23
D387DIO_5_SMA_SS34SS34SMA
D389DIO_5_SMA_SS34SS34SMA
D390BZX84C16/SOT_12_SMB_SMBJ33CASMBJ33CASMB
D391DI-XI-S_0_SOD-323_IC_3.6V3.6VSOD-323
D392BZX84C16/SOT_12_SMA_SMAJ33CASMAJ33CASMA
D397DIO_6_PS-277B_ST2045ST2045PS-277B
D398DIO_6_PS-277B_ST2045ST2045PS-277B
D399BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323
D402BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23
D403BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23
D404BZX84C16/SOT_12_SMA_SMAJ13CASMAJ13CASMA
D408DIO_4_SOD-323_1N58191N5819SOD-323
D409DIO_5_SOD-323_IN4148WSIN4148WSSOD-323
D410DIO_5_SOD-323_IN4148WSIN4148WSSOD-323
D411DIO_5_SOD-323_IN4148WSIN4148WSSOD-323
D413DIO_5_SOD-323_IN4148WSIN4148WSSOD-323
D414DIO_5_SOD-323_IN5819IN5819SOD-323
D415BZX84C16/SOT_5_SMA_SMAJ25CASMAJ25CASMA
D416BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23
D417BZX84C16/SOT_5_SMA_TVS_30VTVS_30VSMA
D418BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323
D419BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323
D420BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323
D421BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323
D422BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323
D423BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323
DC+1TP_0_TEST_MINI_NCNCTEST_MINI
EC1C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MM
EC2C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MM
EC3C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MM
EC4C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MM
EC5C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MM
EC6C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MM
F3FUSE-SMD_R1206_15A15AR1206
F4FUSE-SMD_R1206_15A15AR1206
F5FUSE-SMD_R1206_15A15AR1206
F6FUSE-SMD_R1206_15A15AR1206
F7FUSE-SMD_R1206_2A2AR1206
F8FUSE-SMD_R1206_0R0RR1206
F9FUSE-SMD_R1206_15A15AR1206
F10FUSE-SMD_R1206_12A12AR1206
FB1RESISTOR_R0603_600R@100M600R@100MR0603
J1CON_4_SMD-GH-6P-125MM-L_CON_6PIN_1R27MMCON_6PIN_1R27mmSMD-GH-6P-125MM-L
J7RT9167A-28CB,SOT23_40_SMD-3-2MM-L_WPC_CON_2.0MMWpc_con_2.0mmSMD-3-2MM-L
J16J-HDR-5_DIP-5-2MM_HDR2R0MA-1X5HDR2R0MA-1X5DIP-5-2MM
J17RT9167A-28CB,SOT23_73_TYPEC16_SMD_LM_TYPE-CTYPE-CTYPEC16_SMD_LM
J19RT9167A-28CB,SOT23_0_USB2_DIP_4PLM_USBAUSBAUSB2_DIP_4PLM
J20RT9167A-28CB,SOT23_0_USB2_DIP_4PLM_USBAUSBAUSB2_DIP_4PLM
J21RT9167A-28CB,SOT23_0_USB2_DIP_4PLM_USBAUSBAUSB2_DIP_4PLM
J25RT9167A-28CB,SOT23_74_TYPEC16_SMD_LM_TYPE-CTYPE-CTYPEC16_SMD_LM
J40RT9167A-28CB,SOT23_67_DIP-3-2_54MM_VIN+VIN+DIP-3-2_54MM
J41RT9167A-28CB,SOT23_67_DIP-3-2_54MM_VIN-VIN-DIP-3-2_54MM
J46CON_1X5PIN_SMD-5-2MM-W_CON_1X5PINCON_1X5PINSMD-5-2MM-W
J50CON_1X5PIN_SMD-5P-2_54MM-L_CON_1X5PIN_2R54CON_1X5PIN_2R54SMD-5P-2_54MM-L
J51CON_4_SMD-6-2_0MM_L_CON_6PIN_2R0MMCON_6PIN_2R0mmSMD-6-2_0MM_L
J52RT9167A-28CB,SOT23_67_DIP-3-2_54MM_12V-12V-DIP-3-2_54MM
J53CON_1X5PIN_SMD-5-2MM-W_CON_1X5PIN_2R0CON_1X5PIN_2R0SMD-5-2MM-W
J55RT9167A-28CB,SOT23_67_DIP-3-2_54MM_24V+24V+DIP-3-2_54MM
J56RT9167A-28CB,SOT23_67_DIP-3-2_54MM_24V-24V-DIP-3-2_54MM
J57RT9167A-28CB,SOT23_40_SMD-3-2MM-L_CON_3PIN_2R54CON_3PIN_2R54SMD-3-2MM-L
L1INDUCTOR_INCD_20MMDL_4.7UH4.7uHINCD_20MMDL
L5L_0_INCD_20MML_22UH22uHINCD_20MML
L8L_0_INDP8X8X4_5.6UH5.6uHINDP8X8X4
L9L_0_INDP8X8X4_5.6UH5.6uHINDP8X8X4
L10L_0_INDP8X8X4_5.6UH5.6uHINDP8X8X4
L12L_0_INDP8X8X4_PRS8040-6R8MTPRS8040-6R8MTINDP8X8X4
L15L_0_INCD_20MMDL_4.7UH4.7uHINCD_20MMDL
L17L_0_INCD_20MML_22UH22uHINCD_20MML
L34L_0_INDP8X8X4_5.6UH5.6uHINDP8X8X4
L36L_0_INCD_20MML_4.7UH4.7uHINCD_20MML
LB12LB_R1210_30R/100MHZ30R/100MHzR1210
LB13LB_R1210_30R/100MHZ30R/100MHzR1210
LB14LB_R1210_30R/100MHZ30R/100MHzR1210
LB15LB_R1206_30R/100MHZ30R/100MHzR1206
LB16LB_R1210_30R/100MHZ30R/100MHzR1210
LED2TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60N
LED3TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60N
LED5TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60N
LED6TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60N
LED7TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60N
NTC1R_9_R0603_100K/3950B100K/3950BR0603
NTC2R_9_R0603_100K/3950B100K/3950BR0603
Q0PMOS_3PIN_SOT-23_AO3401AO3401SOT-23
Q1RT9167A-28CB,SOT23_70_DFN5X6_BSC032N04BSC032N04DFN5X6
Q2RT9167A-28CB,SOT23_70_DFN5X6_BSC059N04BSC059N04DFN5X6
Q3NMOS_4_DFN5X6_AON7752AON7752DFN5X6
Q4NMOS_4_DFN5X6_AON7752AON7752DFN5X6
Q5NMOS_4_DFN5X6_AON7752AON7752DFN5X6
Q6RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6
Q13MMBT2907A/SOT_1_SOT-23_MMBT5401MMBT5401SOT-23
Q34RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6
Q35RT9167A-28CB,SOT23_71_DFN5X6_PMOSPMOSDFN5X6
Q36NPN-BECNPNSOT-23
Q43RT9167A-28CB,SOT23_55_SOT23-6_NMOS-8205NMOS-8205SOT23-6
Q44RT9167A-28CB,SOT23_56_SOT23-6_FS112FS112SOT23-6
Q45RT9167A-28CB,SOT23_55_SOT23-6_NMOS-8205NMOS-8205SOT23-6
Q46RT9167A-28CB,SOT23_56_SOT23-6_FS112FS112SOT23-6
Q47RT9167A-28CB,SOT23_55_SOT23-6_NMOS-8205NMOS-8205SOT23-6
Q48RT9167A-28CB,SOT23_56_SOT23-6_FS112FS112SOT23-6
Q50RT9167A-28CB,SOT23_60_SOT23-6_INA181A2IDBVTINA181A2IDBVTSOT23-6
Q53PMOS_3PIN_SOT-23_MMBT5401MMBT5401SOT-23
Q59RT9167A-28CB,SOT23_70_DFN5X6_TDM3436TDM3436DFN5X6
Q60RT9167A-28CB,SOT23_70_DFN5X6_TDM3436TDM3436DFN5X6
Q69RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6
Q70RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6
Q73RT9167A-28CB,SOT23_70_DFN5X6_TDM3436TDM3436DFN5X6
Q74RT9167A-28CB,SOT23_70_DFN5X6_TDM3436TDM3436DFN5X6
Q75NPN-BEC_0_SOT-23_80508050SOT-23
Q84NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23
Q85NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23
Q86NPN-BEC_0_SOT-23_2N7002K2N7002KSOT-23
Q89NMOS_2_SOT-23_S8050S8050SOT-23
Q90RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6
Q91RT9167A-28CB,SOT23_71_DFN5X6_PMOSPMOSDFN5X6
Q92NMOS_4_DFN5X6_AON7752AON7752DFN5X6
Q932N7002/SOT_3_DFN5X6_TDM3307TDM3307DFN5X6
Q94NMOS_4_DFN5X6_AON7752AON7752DFN5X6
Q95NMOS_4_DFN5X6_AON7752AON7752DFN5X6
Q96NMOS_4_DFN5X6_AON7752AON7752DFN5X6
Q97NMOS_4_DFN5X6_AON7752AON7752DFN5X6
Q98NMOS_2_SOT-23_S8050S8050SOT-23
Q99NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23
Q100NMOS_2_SOT-23_S8050S8050SOT-23
Q1012N7002/SOT_1_SOIC-8N_44074407SOIC-8N
Q102NMOS_2_SOT-23_S8050S8050SOT-23
Q103NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23
Q1052N7002/SOT_3_DFN5X6_TDM3307TDM3307DFN5X6
Q106NPN-BEC_0_SOT-23_80508050SOT-23
Q109NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23
Q110RT9167A-28CB,SOT23_71_DFN5X6_PMOSPMOSDFN5X6
Q111NMOS_2_SOT-23_S8050S8050SOT-23
Q112NMOS_2_SOT-23_S8050S8050SOT-23
Q113NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23
SW6ST-1187_0_KEY_TS1102S_ST-1187ST-1187KEY_TS1102S
U0SC8915_0_QFN32-4X4_SC8815SC8815QFN32-4X4
U1SQ33065_3_QFN20_3D5X4D5_MP9928MP9928QFN20_3D5X4D5
U5RT9167A-28CB,SOT23_53_LQFP64_GD32F303RGT6GD32F303RGT6LQFP64
U10FD6288Q_0_QFN28-4X4_SW3516HSW3516HQFN28-4X4
U31MT3608_4_SOP8-EP_SCT2450SCT2450SOP8-EP
U32MT3608_3_SOP8-EP_SCT2450SCT2450SOP8-EP
U33MT3608_1_SOP8-EP_SCT2450SCT2450SOP8-EP
U34PT4115_0_SOT23-6B_PT4121E23FPT4121E23FSOT23-6B
U54RT9167A-28CB,SOT23_66_QFN20-4X4_TD8655TD8655QFN20-4X4
U56FD6288Q_0_QFN28-4X4_SW3516HSW3516HQFN28-4X4
U58LDO_1_SOT-89_ME6203A33PG/SOT89ME6203A33PG/SOT89SOT-89
U60TMB12A03_0_BUZZER_12_2-2P_TMB12A03TMB12A03BUZZER_12_2-2P
U61LDO_SOT-23_HX6206P182MRHX6206P182MRSOT-23
U62MX25L12835EMPQ4430QFN16-3X4
U63BT3L_MZ_BLUE_BT3L_BT3LBT3LMZ_BLUE_BT3L
U65LDO_1_SOT-89_ME6203A50PG/SOT89ME6203A50PG/SOT89SOT-89
Y127MHZ_SMD3225_4P_XTAL_3225_24MHZ24MHzXTAL_3225
Z45BZX84C16/SOT_8_SOD323_32V32VSOD323
Z46BZX84C16/SOT_8_SOD323_15V15VSOD323
重要提示:PCB作品文件展下载说明
  • 打卡等级:常住青年
  • 打卡总天数:15
  • 打卡总奖励:36
3636
4万
 楼主| 发表于 2023-1-10 11:26 | 显示全部楼层
PCB文件来了
游客,如果您要查看本帖隐藏内容请回复
  • 打卡总天数:3
  • 打卡总奖励:8
  • 最近打卡:2024-12-03 19:33:49
16
发表于 2023-1-10 11:28 | 显示全部楼层
  • 打卡总天数:464
  • 打卡总奖励:1642
  • 最近打卡:2026-08-03 14:27:30
社区居民终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
发表于 2023-1-10 12:39 | 显示全部楼层
  • 打卡总天数:450
  • 打卡总奖励:1627
  • 最近打卡:2025-11-18 11:40:58
18
终身成就奖社区居民特殊贡献奖原创先锋奖优秀斑竹奖
发表于 2023-1-10 13:04 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:30
  • 打卡总奖励:110
  • 最近打卡:2025-06-17 09:09:16
发表于 2023-1-10 14:38 | 显示全部楼层
  • 打卡总天数:691
  • 打卡月天数:11
  • 打卡总奖励:2860
  • 最近打卡:2026-11-13 12:03:10
81
发表于 2023-1-10 15:12 | 显示全部楼层
  • 打卡总天数:559
  • 打卡月天数:1
  • 打卡总奖励:2345
  • 最近打卡:2026-11-10 09:00:00
18
终身成就奖社区居民特殊贡献奖原创先锋奖
发表于 2023-1-10 16:21 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:69
  • 打卡总奖励:122
  • 最近打卡:2026-10-13 19:50:11
发表于 2023-1-10 16:55 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:33
  • 打卡总奖励:127
  • 最近打卡:2025-05-13 10:30:19
发表于 2023-1-10 17:03 | 显示全部楼层
