查看: 1672|回复: 22
Wallys\\5g industrial router/IPQ6010 IPQ6018 openwrt QCN9074 QCN9024
头像被屏蔽
50
禁止发言
wifi6
发表于 2023-2-15 14:37 | 显示全部楼层 |阅读模式
https://www.wallystech.com/Routerboard/DR6018-S-V02-wifi6-Qualcomm-IPQ6010-2T2R-2-GE-port-supporting-QCN9074-wifi-card-802.11AX-MU-MIMO-OFDMA.html
Wallys  has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
DR6018-S V02
IPQ6010/IPQ6018/IPQ6000
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48V(DC Jack)
    V
    Operating Temperature Range
    -40 to +70
    oC
    Storage Temperature Range
    -45 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm-Atheros IPQ6010
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
    SD Card Slot
    1x SD Card Slot(Option)
    USB /header
    1x USB 3.0 Port(Option)
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V~48V power supply
    LED header
    2.0 pitch pin header
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Nor Flash
    8MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    125mm x 105mm x 20mm
    Boot Config Switch
    Boot_Config Switch1(S7)
    Boot_Config
    Boot up InterfaceSelect
    S7A
    S7B
    S7C
    SPI NOR. (Default)
    eMMC
    QPIC, Parallel NAND
    USB3.0
    SPI-NOR-GPT
    S7D
    Boot from code ram.(Default)
    Boot from ROM
    Boot_Config Switch2(S9)
    Boot_Config
    No auth.(Default)
    Auth is required
    Interface MAP
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective router boards , wireless network cards,antenna ,enclosure and etc., Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
Skype/EMAIL/Teams:sales@wallystech.com
签名被屏蔽
  • 打卡总天数:889
  • 打卡月天数:16
  • 打卡总奖励:3001
  • 最近打卡:2026-11-16 15:54:49
23
发表于 2023-2-15 15:39 | 显示全部楼层
  • 打卡总天数:400
  • 打卡总奖励:1334
  • 最近打卡:2025-11-20 23:18:22
69
社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
发表于 2023-2-16 03:22 | 显示全部楼层
  • 打卡总天数:410
  • 打卡总奖励:1435
  • 最近打卡:2025-11-21 08:28:49
发表于 2023-2-16 08:02 | 显示全部楼层
发表于 2023-2-16 08:05 | 显示全部楼层
  • 打卡总天数:791
  • 打卡月天数:15
  • 打卡总奖励:2618
  • 最近打卡:2026-11-16 15:26:15
发表于 2023-2-16 08:11 | 显示全部楼层
发表于 2023-2-16 08:28 | 显示全部楼层
发表于 2023-2-16 08:40 | 显示全部楼层
发表于 2023-2-16 08:47 | 显示全部楼层
  • 打卡总天数:311
  • 打卡总奖励:1087
  • 最近打卡:2025-09-01 17:45:30
发表于 2023-2-16 08:55 | 显示全部楼层
