查看: 1119|回复: 11
Wallys Adapter Card support 4 x mini pcie QCA9880/QCA9882,4 x M.2 Card
头像被屏蔽
50
禁止发言
wifi6
发表于 2023-4-14 13:19 | 显示全部楼层 |阅读模式
Today I will introduce a Wallys Adapter Card to you. It can use 4 mini pcie cards DR900VX/DR600VX (QCA9880/QCA9882 chipset), 4 Quectel cards.
What is the function of Adapter Card in wireless
The role of Adapter Card in wireless is to connect computer or other devices to wireless network. Adapter cards are often used in laptops or desktops so that they can connect wirelessly to the Internet or a local area network.
Adapter cards usually include a radio transmitter and a receiver that interface with the computer's USB or PCI slots. Adapter cards can connect to networks using different wireless technologies, including Wi-Fi, Bluetooth, infrared, and radio frequency tags.
In wireless networking, the role of the adapter card is to convert the wireless signal into a digital signal, which is then sent to the computer's processor, enabling it to read and process the network data. At the same time, the adapter card can also convert the computer's digital signal into a wireless signal and send it to the wireless network.
Overall, an adapter card is one of the key components that connects a computer to a wireless network, allowing the computer to wirelessly connect to the network and communicate with other devices.
If it is used with the wifi card of Qualcomm chip QCA9880
If the Adapter Card is used together with the Qualcomm chip QCA9880 WiFi Card, usually faster wireless network connection speed and longer transmission distance can be achieved.
QCA9880 is a Qualcomm wireless chip that supports the 802.11ac wireless network standard and can provide wireless data transmission rates up to 1.3 Gbps. The Adapter Card works with the QCA9880's WiFi Card to provide a more stable and faster wireless network connection, especially in high-speed data transmission and long-distance communication.
The combination of adapter card and QCA9880 WiFi Card can also provide more powerful wireless security and management functions. For example, they can protect networks from hackers and other security threats by supporting the 802.11i/WPA2 encryption standard to encrypt and authenticate wireless data.
In general, the use of Adapter Card and QCA9880 WiFi Card can provide faster, more stable and safer wireless network connection, and can meet the needs of high-speed data transmission and long-distance communication.
If you use 4 WiFi Cards like QCA9880, you can achieve higher wireless network transmission speed and wider coverage.
When using multiple WiFi Cards, you can use a wireless bridge or Mesh Network to connect multiple wireless networks. Wireless bridges allow multiple wireless networks to be connected, providing higher bandwidth and greater coverage. A Mesh network is a self-organizing network structure that achieves greater coverage and higher reliability through the interconnection of multiple devices.
Using multiple WiFi Cards can also provide better load balancing and fault tolerance. By connecting different devices to different WiFi Cards, network traffic can be balanced, thereby reducing network congestion and improving network throughput. At the same time, when a WiFi Card fails, other WiFi Cards can take over its functions to ensure the reliability and stability of the network.
It should be noted that when using multiple WiFi Cards, the distance between devices and mutual interference need to be considered. Too many devices can cause interference and network congestion, reducing network performance and stability. Therefore, adequate planning and optimization of equipment layout and configuration is required.
Wallys has a strong software and hardware team, and also supports customized products.
mail:sales@wallystech.com
web:https://www.wallystech.com/product.
签名被屏蔽
  • 打卡等级:常住青年
  • 打卡总天数:52
  • 打卡月天数:5
  • 打卡总奖励:113
  • 最近打卡:2026-11-09 09:27:55
发表于 2023-4-14 15:58 | 显示全部楼层
发表于 2023-4-15 00:07 | 显示全部楼层
发表于 2023-4-15 00:10 | 显示全部楼层
  • 打卡总天数:620
  • 打卡月天数:11
  • 打卡总奖励:2319
  • 最近打卡:2026-11-13 09:04:26
发表于 2023-4-15 10:05 | 显示全部楼层
  • 打卡总天数:93
  • 打卡总奖励:341
  • 最近打卡:2025-11-19 11:08:23
发表于 2023-4-17 08:02 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:20
  • 打卡总奖励:68
  • 最近打卡:2026-04-14 09:02:00
发表于 2023-4-17 11:45 | 显示全部楼层
  • 打卡总天数:1
  • 打卡总奖励:2
  • 最近打卡:2024-06-25 11:30:47
发表于 2023-4-17 12:26 | 显示全部楼层
  • 打卡总天数:510
  • 打卡月天数:14
  • 打卡总奖励:1548
  • 最近打卡:2026-11-15 13:46:59
41
你必须非常努力才能显
发表于 2023-4-17 14:01 | 显示全部楼层
  • 打卡总天数:450
  • 打卡总奖励:1627
  • 最近打卡:2025-11-18 11:40:58
18
终身成就奖社区居民特殊贡献奖原创先锋奖优秀斑竹奖
发表于 2023-4-18 09:03 | 显示全部楼层
