查看: 1837|回复: 25
Wallys/QSDK/IPQ4019 and IPQ4029 chipsets support 20 km remote transmission
头像被屏蔽
29
禁止发言
发表于 2023-4-27 14:23 | 显示全部楼层 |阅读模式
The IPQ4019 and IPQ4029 chipsets from Qualcomm are designed for high-performance Wi-Fi networks, providing advanced features such as MU-MIMO, beamforming, and enhanced spectral efficiency. These chipsets are suitable for a wide range of applications, including enterprise, industrial, and residential wireless networks.
When combined with the Wallys WiFi5 Industrial Wireless AP DR-AP40X9-A, these chipsets can provide exceptional long-range connectivity. The DR-AP40X9-A is designed for outdoor use and is equipped with high-power radios and antennas, allowing it to cover a large area with a strong Wi-Fi signal. With the IPQ4019 or IPQ4029 chipset, the DR-AP40X9-A can deliver reliable and high-speed wireless connectivity over long distances, making it an ideal solution for industrial applications, remote locations, and outdoor environments.
Description
DR-AP4029(Outdoor) is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;1 x Onmi Antenna; 1 x POE Adapter(24V^1A~48V^0.6A);1 x Enclosure.
Panel Antenna
■  2 x 5G Antenna
■  5G: 17dbi
DRA25 Antenna
ElectricalProperties :
Frequency Range:2.4~2.5&5.15~5.85GHz
Impedance:50Ω
VSWR:2.0 Max (≤2.0)
Gain(peak):6±0.5dBi
Polarization:Linear; Vertical
Physical Properties :
Cable:RG-141 Cable
Connector:N-type PLUG
Antenna CAP:ABS
OperatingTemp:-40℃~+65℃
Storage Temp:-40℃~+75℃
CableTemp:<+250℃
Enclosure
■  Dimension: 275x140x48mm
■  UV Protected and Durable ABS Radome
■  IP67 Waterproof Level
■  Support Wallys  DR4029
DR-AP4029(Outdoor) is a high-power radio AP router that operates on both 2.4GHz and 5GHz frequencies. It comes with a DR40X9 board, an Omni antenna, a POE adapter, and an enclosure. The panel antenna of DR-AP4029 includes 2x 5G antennas with a gain of 17dbi. Additionally, the DRA25 antenna has a frequency range of 2.42.5&5.155.85GHz, a peak gain of 6±0.5dBi, and a linear vertical polarization. The antenna is connected using RG-141 cable and N-type plug connectors. It can operate within a temperature range of -40℃~+65℃ and can withstand cable temperatures of less than +250℃.
The enclosure of DR-AP4029 has dimensions of 275x140x48mm and is made of UV-protected and durable ABS Radome material. It has an IP67 waterproof level and supports Wallys DR4029.
发表于 2023-4-28 00:00 | 显示全部楼层
发表于 2023-4-28 00:04 | 显示全部楼层
发表于 2023-4-28 00:09 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:61
  • 打卡总奖励:196
  • 最近打卡:2024-10-06 16:56:11
发表于 2023-4-28 07:48 | 显示全部楼层
  • 打卡总天数:247
  • 打卡总奖励:888
  • 最近打卡:2025-11-10 08:34:33
114
1元学习Allegro(1期)
终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
发表于 2023-4-28 08:31 | 显示全部楼层
  • 打卡总天数:306
  • 打卡总奖励:1099
  • 最近打卡:2026-09-10 17:29:20
75
社区居民忠实会员社区劳模终身成就奖社区明星宣传大使奖优秀斑竹奖特殊贡献奖原创先锋奖
发表于 2023-4-28 08:33 | 显示全部楼层
  • 打卡总天数:193
  • 打卡月天数:1
  • 打卡总奖励:613
  • 最近打卡:2026-11-11 12:59:27
9571
7万
发表于 2023-4-28 08:54 | 显示全部楼层
  • 打卡总天数:159
  • 打卡总奖励:516
  • 最近打卡:2026-09-24 11:05:31
1元学习Allegro(2期)旁听
发表于 2023-4-28 08:56 | 显示全部楼层
发表于 2023-4-28 08:58 | 显示全部楼层
