查看: 3585|回复: 57
[ALLEGRO格式] ALLEGRO17.4 PCB封装库(BCM53202+BCM5482S+sfpx1-sh)
  • 打卡等级:常住青年
  • 打卡总天数:15
  • 打卡总奖励:36
  • 最近打卡:2026-07-16 23:13:38
3636
4万
终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖原创先锋奖灌水天才奖新人进步奖社区明星最爱沙发
发表于 2023-4-27 15:02 | 显示全部楼层 |阅读模式
BCM53202.zip
1.05 MB, 下载次数: 31, 下载积分:金币 -1 枚
D1DIODE_3_SMB_S1GS1GSMB
D2LED_3_TVS7650_B3D090LB3D090LTVS7650
D3LED_3_TVS7650_B3D090LB3D090LTVS7650
D4LED_3_TVS7650_B3D090LB3D090LTVS7650
D5LED_3_TVS7650_B3D090LB3D090LTVS7650
D6LED_3_TVS7650_B3D090LB3D090LTVS7650
D7LED_3_TVS7650_B3D090LB3D090LTVS7650
D8LED_3_TVS7650_B3D090LB3D090LTVS7650
D9LED_2_TVS7650_B3D090LB3D090LTVS7650
D10LED3X1_2_LED_A694B_2G_LED2X1(DLED2X1(DIP)LED_A694B_2G
D14DIODEDIAC_SOD-323_BV03CBV03CSOD-323
D27DIODEDIAC_SOD-323_BV03CBV03CSOD-323
D28LED3X1_2_LED_A694B-2G_LED2X1(DLED2X1(DIP)LED_A694B-2G
D29LED3X1_2_LED_A694B-2G_LED2X1(DLED2X1(DIP)LED_A694B-2G
D30DIODEDIAC_SOD-323_BV03CBV03CSOD-323
D32CAP_SOD-323_TVSTVSSOD-323
D33LED3X1_2_LED_A694B_2G_LED2X1(DLED2X1(DIP)LED_A694B_2G
D34DIODEDIAC_SOD-323_BV03CBV03CSOD-323
D53LED_LED0603-RF_LEDLEDLED0603-RF
D54LED_LED0603-RF_LEDLEDLED0603-RF
D55LED_LED0603-RF_LEDLEDLED0603-RF
D56LED_LED0603-RF_LEDLEDLED0603-RF
D62DIODEPIN_1_SMC_S3Gs3gSMC
D63DIODEPIN_1_SMC_S3Gs3gSMC
D64DIODEPIN_1_SMC_S3Gs3gSMC
D65DIODETVS BI-DIR_SMCJ_SMCJ TVSSMCJTVSSMCJ
D66DIODEPIN_1_SMC_S3Gs3gSMC
D67DIODEPIN_1_SMC_S3Gs3gSMC
D68DIODEPIN_1_SMC_S3Gs3gSMC
D69DIODETVS BI-DIR_SMCJ_SMCJ TVSSMCJTVSSMCJ
D70DIODEDIAC_SOD-323_BV03CBV03CSOD-323
D91DIODEDIAC_SOD-323_BV03CBV03CSOD-323
D92DIODETVS BI-DIR_BS2600N_BS2600BS2600NBS2600N
D93DIODETVS BI-DIR_BS2600N_BS2600BS2600NBS2600N
F1R_0_FUSE_3216FF-1A3216FF-1AFUSE
F2R_0_FUSE_3216FF-1A3216FF-1AFUSE
FB7FB_L0603_A600@100MHZA600@100MHzL0603
FB8FB_L0603_A600@100MHZA600@100MHzL0603
FB9FB_L0603_A600@100MHZA600@100MHzL0603
FB10FB_L0603_A600@100MHZA600@100MHzL0603
FB15FB_L0603_600600L0603
FB16FB_L0805_600OHM600OHML0805
FB17FB_L0603_600600L0603
FB18FB_L0603_600600L0603
FB19FB_L0603_220OHM220OHML0603
FB21FB_L0603_600600L0603
FB22FB_L0805_600OHM600OHML0805
FB30FB_L0603_220OHM220OHML0603
FB31FB_L0603_600600L0603
H1CON20_1_CON-1X2P-200_CON2_DELAYCON2_delayCON-1X2P-200
J1RJ45_21_RJ45_1X1_NOLED_RJ45_1X1RJ45_1X1RJ45_1X1_NOLED
J2HEADER10X2_2_SFPX1-SH_HEADER 1HEADER10X2SFPX1-SH
J3HEADER10X2_2_SFPX1-SH_HEADER 1HEADER10X2SFPX1-SH
J4HEADER4_0_PWR-SIP-4P_HEADER1X4HEADER1x4x200PWR-SIP-4P
J5HEADER4_0_CON-1X4P-200_HEADER1HEADER1x4x200CON-1X4P-200
J6HFBR5803_0_SC-ST1X9_HFBR5803HFBR5803SC-ST1X9
J7RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011
J8HFBR5803_0_SC-ST1X9_HFBR5803HFBR5803SC-ST1X9
J9RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011
J10CONNEDGE 36X2_2_HD_20X2_SMD_COCON_20x2_PIN_femaleHD_20X2_SMD
J11RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011
J12HFBR5803_0_SC-ST1X9_HFBR5803HFBR5803SC-ST1X9
J13RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011
J14RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011
J15HEADER4_1_CON318-4_HEADER1X4HEADER1x4CON318-4
J16HFBR5803_0_SC-ST1X9_HFBR5803HFBR5803SC-ST1X9
J17RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011
J18RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011
J25RJ45_15_RJ45_1X1_NOLED_RJ45_1X1RJ45_1X1RJ45_1X1_NOLED
J26RJ45_15_RJ45_1X1_NOLED_RJ45_1X1RJ45_1X1RJ45_1X1_NOLED
L2FB_LC0603_120OHMS@100MHZ/NC120OHMs@100MHz/NCLC0603
L3FB_LC0603_120OHMS@100MHZ120OHMs@100MHzLC0603
L4FB_LC0603_120OHMS@100MHZ/NC120OHMs@100MHz/NCLC0603
L5FB_LC0603_120OHMS@100MHZ120OHMs@100MHzLC0603
L6FB_LC1206_1R01R0LC1206
L7INDUCTOR_LC0805_600R0805600R0805LC0805
L8FB_LC0603_120OHMS@100MHZ120OHMs@100MHzLC0603
L9FB_LC0603_120OHMS@100MHZ/NC120OHMs@100MHz/NCLC0603
L10FB_LC1206_1R01R0LC1206
L11INDUCTOR_LC0805_600R0805600R0805LC0805
L12INDUCTOR_LC0805_600R0805600R0805LC0805
L13FB_LC1206_1R01R0LC1206
L16INDUCTOR_CDRH8D43_8.2UH,20MOHM8.2uH,20mOHMCDRH8D43
L17INDUCTOR_0_LC0603_600R300MA600R300mALC0603
L18INDUCTOR_0_LC0805_1R01R0LC0805
L19INDUCTOR_CC0805_150MA150mACC0805
L20INDUCTOR_CC0805_150MA150mACC0805
L21INDUCTOR_0_LC0805_1R01R0LC0805
L22INDUCTOR_0_LC0603_600R300MA600R300mALC0603
L23INDUCTOR_0_LC0805_1R01R0LC0805
L24INDUCTOR_0_LC0603_600R300MA600R300mALC0603
L25INDUCTOR_CC0805_150MA150mACC0805
L26INDUCTOR_0_LC0805_1R01R0LC0805
L27INDUCTOR_0_LC0603_600R300MA600R300mALC0603
L28INDUCTOR_0_LC0603_600R300MA600R300mALC0603
L29INDUCTOR_0_LC0805_1R01R0LC0805
L30INDUCTOR_CC0805_150MA150mACC0805
L31INDUCTOR_0_LC0805_1R01R0LC0805
L32INDUCTOR_0_LC0805_600R300MA600R300mALC0805
L33INDUCTOR_0_LC0603_600R300MA600R300mALC0603
L34INDUCTOR_0_LC0805_1R01R0LC0805
L35INDUCTOR_0_LC0603_600R300MA600R300mALC0603
L36INDUCTOR_CC0805_150MA150mACC0805
L37INDUCTOR_0_LC0805_1R01R0LC0805
L38INDUCTOR_0_LC0603_600R300MA600R300mALC0603
L39INDUCTOR_CDRH8D43_8.2UH,20MOHM8.2uH,20mOHMCDRH8D43
L40INDUCTOR_CDRH8D43_8.2UH,20MOHM8.2uH,20mOHMCDRH8D43
L41INDUCTOR_CC0805_150MA150mACC0805
L42INDUCTOR_CC0805_150MA150mACC0805
L43INDUCTOR_CC0805_150MA150mACC0805
MH1MH-8VIA_MT8-3_5-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-3_5-6_5MM
MH2MH-8VIA_MT8-3_5-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-3_5-6_5MM
MH3MH-8VIA_MT8-3_5-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-3_5-6_5MM
MH4MH-8VIA_MT8-3_5-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-3_5-6_5MM
Q1PNPBEC_SOT23M2_85508550SOT23M2
RLY1RELAYDPDT_5_DIP12-1_TX2-3VTX2-3VDIP12-1
T1PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
T2PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
T3PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
T4PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
T5PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
T6PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
T7PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
T8PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
T9PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LAN
TP1TP_TP30_REDREDTP30
TP2TP_TP30_REDREDTP30
TP3TP_TP30_REDREDTP30
U1MAX3223_3_SSOP28_SP3243ECASP3243ECASSOP28
U2PE68515_9_232_NET_USR-TCP232-SUSR-TCP232-S232_NET
U5USB_19_3X7_0_SOT23-8_MP1497MP1497SOT23-8
U7PE68515_13_SO-16_MAX3232MAX3232SO-16
U14BCM53242M_BGA400-1_27MM_BCM5320BCM53202BGA400-1_27MM
U22BCM5482SKPB_BGA121-1MM_BCM5482SBCM5482SBGABGA121-1MM
U23XFMR-H5007-NS_XFMR_SO24_H5007H5007XFMR_SO24
U24XFMR-H5007-NS_XFMR_SO24_H5007H5007XFMR_SO24
U25USB_19_3X7_0_SOT23-8_MP1497MP1497SOT23-8
U26USB_19_3X7_0_SOT23-8_MP1497MP1497SOT23-8
U422504_5_DFN10-TH-2504_RCLPAM3304Rclpam3304DFN10-TH-2504
U432504_4_DFN10-TH-2504_RCLPAM3304Rclpam3304DFN10-TH-2504
U442504_4_DFN10-TH-2504_RCLPAM3304Rclpam3304DFN10-TH-2504
U452504_4_DFN10-TH-2504_RCLPAM3304Rclpam3304DFN10-TH-2504
U46TVS_SOD323_BV03CBV03CSOD323
U47TVS_SOD323_BV03CBV03CSOD323
U48TVS_SOD323_BV03CBV03CSOD323
U49TVS_SOD323_BV03CBV03CSOD323
U50TVS_SOD323_BV03CBV03CSOD323
U51TVS_SOD323_BV03CBV03CSOD323
U52TVS_SOD323_BV03CBV03CSOD323
U53TVS_SOD323_BV03CBV03CSOD323
U54TVS_ANT3216_BS201N/NCBS201N/NCANT3216
U55TVS_ANT3216_BS201N/NCBS201N/NCANT3216
U5674HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U5774HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U5874HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U5974HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U6074HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U6174HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U6274HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U6374HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U6474HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U6574HC164_0_TSSOP14_74HC164D74HC164DTSSOP14
U6674LS244/SO_0_TSSOP20_74LS244/SO74LS244/SOTSSOP20
U67AT93C46_1_SO8M1_AT93C46/NCAT93C46/NCSO8M1
U68RESET_0_SOT23_MAX809MAX809SOT23
Y3XTAL_DY49US-11_05X4_65H3_5_25.025.000625MHzDY49US-11_05X4_65H3_5
Y4XTAL_DY49US-11_05X4_65H3_5_25_125.000MHzDY49US-11_05X4_65H3_5
  • 打卡总天数:104
  • 打卡总奖励:301
  • 最近打卡:2026-07-31 10:16:02
153
PADS20210616高级班(留级)
发表于 2023-4-27 15:40 | 显示全部楼层
  • 打卡总天数:884
  • 打卡月天数:11
  • 打卡总奖励:2992
  • 最近打卡:2026-11-11 13:14:14
23
发表于 2023-4-27 19:50 | 显示全部楼层
  • 打卡总天数:506
  • 打卡月天数:10
  • 打卡总奖励:1534
  • 最近打卡:2026-11-11 09:34:02
41
你必须非常努力才能显
发表于 2023-4-27 20:09 | 显示全部楼层
发表于 2023-4-28 00:08 | 显示全部楼层
  • 打卡总天数:262
  • 打卡总奖励:1113
  • 最近打卡:2026-10-29 09:12:35
114
发表于 2023-4-28 06:33 | 显示全部楼层
  • 打卡总天数:247
  • 打卡总奖励:888
  • 最近打卡:2025-11-10 08:34:33
114
1元学习Allegro(1期)
终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
发表于 2023-4-28 08:36 | 显示全部楼层
  • 打卡总天数:1
  • 打卡总奖励:2
  • 最近打卡:2024-07-11 09:52:25
33
1元学习Allegro(2期)
发表于 2023-4-28 08:37 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:37
  • 打卡总奖励:97
  • 最近打卡:2026-07-02 11:12:02
35
1元学习Allegro(1期)
发表于 2023-4-28 08:44 | 显示全部楼层
  • 打卡总天数:311
  • 打卡总奖励:1087
  • 最近打卡:2025-09-01 17:45:30
发表于 2023-4-28 08:49 | 显示全部楼层
