| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CIN1 | CAP_NP_C0603_0.1UF | 0.1uF | C0603 |
| CIN2 | CAP_NP_C0805_4.7UF | 4.7uF | C0805 |
| CN1 | POWERJACK_0_POWERJACK_3P_DC_JAC | DC_JACK | POWERJACK_3P |
| COUT1 | CAP_NP_C1206_NI_4.7UF_X5R | NI_4.7uf_X5R | C1206 |
| COUT2 | CAP_NP_C0603_NI_0.1UF_X5R | NI_0.1uF_X5R | C0603 |
| D1 | DIODE_12_MLL41_1N5819 | 1N5819 | MLL41 |
| D2 | DIODE_12_MLL34_NI_IN4001 | NI_IN4001 | MLL34 |
| D3 | DIODE_12_MLL34_IN4001@500MA | IN4001@500mA | MLL34 |
| D4 | DIODE_12_MLL34_1N4148/SMD | 1N4148/SMD | MLL34 |
| D5 | LED_1_LED1X1_LED | LED | LED1X1 |
| D6 | LED_1_LED1X1_LED | LED | LED1X1 |
| D7 | DIODE_12_MLL34_NI-IN4148 | NI-IN4148 | MLL34 |
| D8 | LED_1_LED1X1_NI_LED | NI_LED | LED1X1 |
| D14 | LED_1_LED1X1_LED | LED | LED1X1 |
| J1 | BUTTON_SW415_TW_NI_BUTTON | NI_BUTTON | SW415_TW |
| L1 | L_100UH_100UH_3A | 100uH_3A | 100UH |
| L2 | BEAD_L0805_BEAD_0805 | Bead_0805 | L0805 |
| L3 | BEAD_L0805_BEAD_0805 | Bead_0805 | L0805 |
| L4 | L_L4R5X4R0_NI_2.2UH | NI_2.2uh | L4R5X4R0 |
| L5 | BEAD_L0805_BEAD_100OHM@100MHZ | Bead_100ohm@100MHZ | L0805 |
| L6 | BEAD_L0805_NI_BEAD_0805 | NI_Bead_0805 | L0805 |
| L7 | BEAD_L0805_BEAD_100OHM@100MHZ | Bead_100ohm@100MHZ | L0805 |
| LS1 | BUZZER_BUZZER_NI_BUZZER | NI_BUZZER | BUZZER |
| Q1 | 2N3904_SOT-23_NI_2N3904 | NI_2N3904 | SOT-23 |
| T6 | BUT_LOCK_LD_BUT_LOCK_LD_NI_BUT_ | NI_but_lock_ld | BUT_LOCK_LD |
| T7 | 1X1PIN_JP1X1_NI_1X1PIN | NI_1X1PIN | JP1X1 |
| T8 | 1X1PIN_JP1X1_NI_1X1PIN | NI_1X1PIN | JP1X1 |
| T9 | TRNSFMR_GAP_LD4R061X071X086-5D0 | NI_comm_choke | LD4R061X071X086-5D08 |
| U1 | AP34063_8_SOP8_AP34063 | AP34063 | SOP8 |
| U2 | RTL8309N_64PIN_QFN64-EPAD-9X9_R | RTL8309_64PIN | QFN64-EPAD-9X9 |
| U3 | MAX809S_SOT-23_NI_MAX809S | NI_MAX809S | SOT-23 |
| U4 | 24C02_SERIALEEPROM_DIP8_NI_24C | NI_24C02 | DIP8 |
| U5 | 24C02_SERIALEEPROM_SOP8_NI_24C | NI_24C02 | SOP8 |
| U6 | 20PT1021SX_20PT1021SX_20PT1021S | 20PT1021SX | 20PT1021SX |
| U7 | PHJ8-1ROW_RJ45-PHJ8-1ROW_PHJ1X8 | PHJ1X8(DIP) | RJ45-PHJ8-1ROW |
| U8 | 20PT1021SX_20PT1021SX_20PT1021S | 20PT1021SX | 20PT1021SX |
| U9 | 20PT1021SX_20PT1021SX_20PT1021S | 20PT1021SX | 20PT1021SX |
| U10 | 20PT1021SX_20PT1021SX_20PT1021S | 20PT1021SX | 20PT1021SX |
| Y1 | CRYSTAL_XTAL_49US_CRYSTAL | CRYSTAL | XTAL_49US |
