| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT1 | T_POINT_R_0_WIFI-ANT-SD73412-01 | ANT | WIFI-ANT-SD73412-011H1_3A |
| BAT1 | BAT_6_BAT-XH414HG-C4_8H1_85A_XH | XH414HG-IV01E | BAT-XH414HG-C4_8H1_85A |
| BATT1 | FPC10-PT05A_1_CON3-PT2_3PIN | 3PIN | CON3-PT2 |
| CN1 | FPC10-PT05A_2_CON4-PT1_25-3_2X6 | 4pin | CON4-PT1_25-3_2X6_85H4_8A-UP |
| CN2 | FPC10-PT05A_2_CON4-PT1_25-3_2X6 | 4pin | CON4-PT1_25-3_2X6_85H4_8A-UP |
| CN3 | FPC10-PT05A_24_CON2-PT1_25-3_2X | 2PIN | CON2-PT1_25-3_2X4_35H4_8B-UP |
| CN4 | FPC10-PT05A_24_CON2-PT1_25-3_2X | 2PIN | CON2-PT1_25-3_2X4_35H4_8B-UP |
| CON1 | FPC23_0_CON25-PT0_6-3_6X9H1B_LC | LCD2 | CON25-PT0_6-3_6X9H1B |
| CON2 | LCD-TD043MGEB1_1_CON40_PT1-2X25 | CON40 | CON40_PT1-2X25_6H3A |
| CON3 | FPC10-PT05A_21_FPC6-PT05-H2_0B_ | FPC06-PT0.5 | FPC6-PT05-H2_0B |
| CON4 | TD030673_7_CON40_PT1-2X25_6H3A_ | OV4689 | CON40_PT1-2X25_6H3A |
| D1 | DIODE_SCHOTTKY_0_SOD123H14A_NC/ | NC/IN5819 | SOD123H14A |
| D2 | D_0_SOD-523H0_7A_1N5819 | 1N5819 | SOD-523H0_7A |
| D3 | DIODE_SOD123H14A_1N5819 | 1N5819 | SOD123H14A |
| D5 | D_0_SOD-523H0_7A_1N5819 | 1N5819 | SOD-523H0_7A |
| D6 | DIODESCHOTTKY_D0402_RB521C30_R | RB521C30 | D0402 |
| D7 | D_0_SOD-523H0_7A_1N5819 | 1N5819 | SOD-523H0_7A |
| D8 | DIODESCHOTTKY_0_D0402_RB521C30 | RB521C30 | D0402 |
| D9 | DIODESCHOTTKY_D0402_RB521C30_R | RB521C30 | D0402 |
| D10 | DIODE_SCHOTTKY_0_SOD123H14A_IN5 | IN5819 | SOD123H14A |
| DL1 | DIO-SS16F_0_SOD123H14A_1N5819 | 1N5819 | SOD123H14A |
| DP1 | LED-0603-G_LED0603_LED-0603-R | LED-0603-R | LED0603 |
| DP2 | LED-0805_LED0603_BLUE | BLUE | LED0603 |
| DP3 | LED-0603-G_LED0603_LED-0603-G | LED-0603-G | LED0603 |
| EC1 | CAPACITOR_POL_SCAP2-PT3_5-8X25H | NC/5F/2.7V | SCAP2-PT3_5-8X25H8A |
| EC2 | CAPACITOR_POL_SCAP2-PT3_5-8X25H | NC/5F/2.7V | SCAP2-PT3_5-8X25H8A |
| FB1 | INDUCTOR_0_L0603_NC/600R-100M | NC/600R-100M | L0603 |
| FB6 | INDUCTOR_0_L0603_0R | 0R | L0603 |
| FB10 | INDUCTOR_L0603_600R/100M | 600R/100M | L0603 |
| HOLE1 | T_POINT_R_PAD5D3_3_B5 | B5 | PAD5D3_3 |
| HOLE2 | T_POINT_R_PAD5D3_3_B5 | B5 | PAD5D3_3 |
| HOLE3 | T_POINT_R_PAD5D3_3_B5 | B5 | PAD5D3_3 |
| HOLE4 | T_POINT_R_PAD5D3_3_B5 | B5 | PAD5D3_3 |
| HP1 | PHONOJACK_5_PJ_242-5_1X12H3_2A_ | HXQKPJ-242A | PJ_242-5_1X12H3_2A |
| HP2 | PHONOJACK_3_PJ-320C-6_1X14H5A_H | HXQKPJ-242A | PJ-320C-6_1X14H5A |
| J1 | FPC10-PT05A_1_H2X2-PT2_54H2A_4P | 4PIN | H2X2-PT2_54H2A |
| J2 | DC-33_0_DC-HXQKDC-051H10_8A_HXQ | HXQKDC-051 | DC-HXQKDC-051H10_8A |
| J3 | 2X16P_H16X2-PT2_2X16P | 2x16p | H16X2-PT2 |
| J7 | FPC10-PT05A_1_H2X2-PT2_54H2A_4P | 4PIN | H2X2-PT2_54H2A |
| J8 | FPC10-PT05A_0_CON2X7-PT2-5_5X21 | 14PIN | CON2X7-PT2-5_5X21_45H5_6A |
| J9 | FPC10-PT05A_15_H2X5-PT2_54H2A_1 | 10PIN | H2X5-PT2_54H2A |
| K1 | SW_PUSH_8_SW4-HXQKTS-045-4_5X4_ | VOL+ | SW4-HXQKTS-045-4_5X4_5H3_8A |
| K2 | SW_PUSH_8_SW4-HXQKTS-045-4_5X_1 | VOL- | SW4-HXQKTS-045-4_5X4_5H3_8A |
| K3 | SW_PUSH_8_SW4-HXQKTS-045-4_5X_2 | MENU | SW4-HXQKTS-045-4_5X4_5H3_8A |
| K4 | SW_PUSH_8_SW4-HXQKTS-045-4_5X_3 | ENTER | SW4-HXQKTS-045-4_5X4_5H3_8A |
| K5 | SW_PUSH_8_SW4-HXQKTS-045-4_5X_4 | HOME | SW4-HXQKTS-045-4_5X4_5H3_8A |
| K6 | SW_PUSH_8_SW4-HXQKTS-045-4_5X_5 | UBOOT | SW4-HXQKTS-045-4_5X4_5H3_8A |
| K7 | SW_PUSH_8_SW4-HXQKTS-045-4_5X_6 | PWRON | SW4-HXQKTS-045-4_5X4_5H3_8A |
| K8 | SW_PUSH_8_SW4-HXQKTS-045-4_5X_7 | RESET | SW4-HXQKTS-045-4_5X4_5H3_8A |
| L1 | INDUCTORX_0_L0805X2_ICMF212P900 | ICMF212P900MFR | L0805X2 |
| L2 | INDUCTOR_0_L0805_0R | 0R | L0805 |
| L3 | INDUCTOR_1_L3518_4.7UH@1.1ADCR | 4.7uH@1.1ADCR<0.1R | L3518 |
| L4 | INDUCTOR_L3X3H1_7A_NC/4.7UH@0.7 | NC/4.7uH@0.7ADCR<0.1R | L3X3H1_7A |
| LCD_ID1 | T_POINT_R_TP40_SMD_NC | NC | TP40_SMD |
| LL1 | L-L2520_L4018_4.7UH-DCR<0.1R-1. | 4.7uH-DCR<0.1R-1.7A | L4018 |
| LP1 | L-L3225_L3X3H1_7A_1UH-2A | 1uH-2A | L3X3H1_7A |
| LP2 | L-L3225_L3X3H1_7A_1UH-2A | 1uH-2A | L3X3H1_7A |
| LP3 | L-L3225_L3X3H1_7A_NC-1UH-2A | NC-1uH-2A | L3X3H1_7A |
| LP4 | L-L3225_L3X3H1_7A_1UH-2A | 1uH-2A | L3X3H1_7A |
| LP5 | L-L3225_L3X3H1_7A_1UH-2A | 1uH-2A | L3X3H1_7A |
| LS1 | L-L8080_L2D6X6H2A_6.8UH-3A-DCR< | 6.8uH-3A-DCR<0.031R | L2D6X6H2A |
| MIC1 | MICPHONE_1_MIC-EAO-4013-MBAH1_4 | LSY4013S423-GP | MIC-EAO-4013-MBAH1_4A |
| MIC5 | MICPHONE_1_MIC-EAO-4013-MBAH1_4 | LSY4013S423-GP | MIC-EAO-4013-MBAH1_4A |
| Q1 | NPN_SOT-23_MMBT3904 | MMBT3904 | SOT-23 |
| Q2 | PMOS_SOT-23_WPM2087 | WPM2087 | SOT-23 |
| Q3 | NMOS_SOT-23_NC/WNM6001 | NC/WNM6001 | SOT-23 |
| Q4 | NMOS_SOT-23_NC/WNM6001 | NC/WNM6001 | SOT-23 |
| Q5 | NMOS_SOT-23_NC/WNM6001 | NC/WNM6001 | SOT-23 |
| QC1 | PMOS-STS2301_SOT-23_NC-STS2301 | NC-STS2301 | SOT-23 |
| TF1 | SDMMCSLOT_0_TF_CARDH1_7A_MICRO | MICROSD/TF_SLOT | TF_CARDH1_7A |
| U1 | MCP-BGA169_5_BGA169-PT0_5-12X16 | EMMC | BGA169-PT0_5-12X16H1A |
| U2 | DS8008_0_SOT23-5_WL2801E28-5/TR | WL2801E28-5/TR | SOT23-5 |
| U3 | RT9266PE_0_SOT23_5H14A_LPW5210 | LPW5210 | SOT23_5H14A |
| U4 | MMA7660_1_SOP10-PT05-MMA7660FC- | DA380B | SOP10-PT05-MMA7660FC-H1A |
| U5 | MMA7660_3_QFN12-BMA250E-0_5-2X2 | NC/SC7A20 | QFN12-BMA250E-0_5-2X2H1A |
| U8 | IP101GR_0_QFN33-4X4PT0_4H1A_IP1 | IP101GR | QFN33-4X4PT0_4H1A |
| U9 | SY8088_0_SOT23-5_LP3220SAB5F | LP3220SAB5F | SOT23-5 |
| U10 | DS8008_0_SOT23-5_NC/WL2801E28-5 | NC/WL2801E28-5/TR | SOT23-5 |
| U11 | LY8006_0_MSOP-8_CS8302 | CS8302 | MSOP-8 |
| UD1 | DDR3-FBGA96_FBGA96C80P10X13_DDR | DDR3-FBGA96 | FBGA96C80P10X13 |
| UL1 | SY7200A_SOT23-6_STI9287C | STI9287C | SOT23-6 |
| UM2 | SPI-NOR-SOP8_SOP8-PT1_27-4_45X5 | NC/MX25L25645G | SOP8-PT1_27-4_45X5H1_75A |
| UM3 | SPI-NOR-SOP16_SOIC16-PT1_27-10_ | NC/S25FL128S | SOIC16-PT1_27-10_3X10_3H2_65 |
| UP1 | AXP2101_0_QFN40-PT0_4-5X5H0_8A_ | AXP2101 | QFN40-PT0_4-5X5H0_8A |
| US1 | SY8105_SOT23-6_SY8105 | SY8105 | SOT23-6 |
| USB1 | USB_MINI_SOCKET_1_USB-C-8_65X8_ | HXQK-TYPE-C-3.1 | USB-C-8_65X8_94H3_1A |
| UU1 | V853_0621_BGA318-V853-PT0_5-12X | V853 | BGA318-V853-PT0_5-12X12H1_2A |
| UW1 | AP6XXX_1_QFN44-AP6476-12X12H1_6 | XR829 | QFN44-AP6476-12X12H1_6A |
| X1 | CRY-32.768KHZ-3215-SMD_CRYSTAL- | 32.768K-12.5pF | CRYSTAL-2P-3215-H0_85A |
| Y1 | CRY-24MHZ-3225-SMD_CRYSTAL-4P-3 | 24M-16pF-10ppm | CRYSTAL-4P-3225-H1A |
| YW1 | CRY-37.4MHZ-3225-SMD_CRYSTAL-4P | NC/40M-15pF-10PPM | CRYSTAL-4P-3225-H1A |
