查看: 1830|回复: 15
[供应] Wallys miniPCIe wlan modules/  QCA9880 /2.4G&5G
头像被屏蔽
29
禁止发言
发表于 2023-6-6 11:00 | 显示全部楼层 |阅读模式
Mini PCIe (Peripheral Component Interconnect Express) is a small form factor expansion card interface that offers several advantages over other interfaces:
Small size: Mini PCIe is designed to be compact, which makes it suitable for devices with limited space, such as laptops and small form factor desktops.
High speed: Mini PCIe supports high-speed data transfer rates, which makes it ideal for use with devices that require fast data transfer, such as wireless networking cards, solid-state drives (SSDs), and graphics cards.
Power efficiency: Mini PCIe is designed to be power-efficient, which makes it ideal for use in portable devices that rely on battery power.
Standardization: Mini PCIe is a standardized interface, which means that it is widely available and compatible with a range of devices.
Flexibility: Mini PCIe supports a range of different peripherals, including Wi-Fi cards, Bluetooth cards, SSDs, GPS modules, and more. This makes it a versatile interface that can be used in a variety of different applications.
Antenna connectors: These modules come with antenna connectors, usually in the form of small coaxial connectors. The antennas are used to transmit and receive wireless signals, ensuring proper reception and transmission of data.
Compatibility: MiniPCIe WLAN modules are compatible with devices that have MiniPCIe slots. These slots are commonly found on laptops, small form factor desktop computers, and embedded systems. However, it's important to note that MiniPCIe slots are not as prevalent in modern laptops as they used to be, as newer laptops tend to use smaller M.2 slots for wireless modules.
Upgradeability: One of the advantages of MiniPCIe WLAN modules is their ability to be upgraded or replaced. If a device's wireless capabilities become outdated or require improvement, the MiniPCIe WLAN module can be swapped out for a more advanced module without replacing the entire device.
Best recommend
DR900VX
https://www.wallystech.com/Network_Card/DR900VX-Qualcomm-Atheros-QCA9880-3T3R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-Dual-Band-2-4GHz-5GHz.html
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
  • 打卡总天数:1
  • 打卡总奖励:4
  • 最近打卡:2024-07-30 10:34:04
发表于 2023-6-6 11:23 | 显示全部楼层
  • 打卡总天数:1
  • 打卡总奖励:4
发表于 2023-6-6 11:25 | 显示全部楼层
很牛的无线网卡!!!
发表于 2023-6-6 12:07 | 显示全部楼层
  • 打卡总天数:337
  • 打卡月天数:8
  • 打卡总奖励:981
  • 最近打卡:2026-11-10 12:15:27
发表于 2023-6-6 14:01 | 显示全部楼层
  • 打卡总天数:618
  • 打卡月天数:9
  • 打卡总奖励:2311
  • 最近打卡:2026-11-11 09:00:01
发表于 2023-6-7 08:31 | 显示全部楼层
  • 打卡总天数:1
  • 打卡总奖励:2
  • 最近打卡:2024-12-05 18:05:06
32
发表于 2023-6-7 09:03 | 显示全部楼层
  • 打卡总天数:884
  • 打卡月天数:11
  • 打卡总奖励:2992
  • 最近打卡:2026-11-11 13:14:14
23
发表于 2023-6-7 19:54 | 显示全部楼层
  • 打卡等级:常住青年
  • 打卡总天数:32
  • 打卡月天数:2
  • 打卡总奖励:59
  • 最近打卡:2026-11-08 20:15:29
发表于 2023-6-8 21:43 | 显示全部楼层
  • 打卡总天数:373
  • 打卡月天数:8
  • 打卡总奖励:1108
  • 最近打卡:2026-11-11 09:00:16
14
社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
发表于 2023-6-9 08:59 | 显示全部楼层
