查看: 19391|回复: 436
[Allegro17.4以下] 万兆10G 交换机PCB文件 RTL9311BR+DDR4+RTL8218E+RTL8231+RTL8363SC
  • 打卡总天数:12
  • 打卡总奖励:35
  • 最近打卡:2026-06-25 21:09:40
7087
11万
管理员
原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖社区居民新人进步奖忠实会员原创先锋奖灌水天才奖
发表于 2023-7-18 16:16 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
CON1MINIPCIE GOLD FINGER_MINI_PCIEMINIPCIE Gold fingerMINI_PCIE_GOLDFINGER7_11
D1DIODE_SCHOTTKY_SMC_B320-13-FB320-13-FSMC
D2DIODE_12_MLL34_LL4148LL4148MLL34
D3LED1X1_LED_SMD_0602_LED_1X1_GREled_1x1_greenLED_SMD_0602
D4DIODE_ZENER_SOD-523_NI_BZT52C9VNI_BZT52C9V1TSOD-523
D5LED1X1_LED-3MM_LED_1X1_Yled_1x1_YLED-3MM
D9LED1X1_LED0603_LED_1X1_Rled_1x1_RLED0603
D10LED1X1_LED0603_LED_1X1_Rled_1x1_RLED0603
D11LED1X1_LED_SMD_0602_LED_1X1_GREled_1x1_greenLED_SMD_0602
D37LED1X1_LED_SMD_0602_LED_1X1_GREled_1x1_greenLED_SMD_0602
D38LED1X1_LED_SMD_0602_LED_1X1_GREled_1x1_greenLED_SMD_0602
D39ONE-LINE_BI_TVS_SOD-323_NC-TVS_NC-TVS_SPD9103WSOD-323
D40ONE-LINE_BI_TVS_SOD-323_NC-TVS_NC-TVS_SPD9103WSOD-323
D41ONE-LINE_BI_TVS_SOD-323_NC-TVS_NC-TVS_SPD9103WSOD-323
D42ONE-LINE_BI_TVS_SOD-323_NC-TVS_NC-TVS_SPD9103WSOD-323
EC1CAP_P_E_EC8X12R5-3R5_470UF/25V470uf/25vEC8X12R5-3R5
EC2CAP_P_E_EC8X10P5_SMD_220UF/25V220uf/25vEC8X10P5_SMD
EC3CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5
EC4CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5
EC5CAP_P_E_EC8X10P5_SMD_220UF/25V220uf/25vEC8X10P5_SMD
EC6CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5
EC7CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5
EC8CAP_P_E_EC8X10P5_SMD_220UF/25V220uf/25vEC8X10P5_SMD
EC9CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5
EC10CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5
EC11CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2C
EC12CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2C
EC13CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2C
EC14CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2C
EC15CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2C
EC16CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2C
FB1L_L0402_120OHM@100MHZ/1.2A120ohm@100MHz/1.2AL0402
H1MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PAD
H2MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PAD
H3MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PAD
H4MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PAD
H5MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PAD
H6MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PAD
H7MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PAD
H8MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PAD
H16MOUNTHOLE_1PIN_5_7MMHOLD_5.7MM5.7mmhole5_7MMHOLD
H17MOUNTHOLE_1PIN_5_7MMHOLD_5.7MM5.7mmhole5_7MMHOLD
H18MOUNTHOLE_1PIN_5_7MMHOLD_5.7MM5.7mmhole5_7MMHOLD
HS1HEAT_SINK_HS_35X35X28MM_HS_35X3HS_35X35X28mmHS_35X35X28MM
HS2HEAT_SINK_HS_35X35X28MM_HS_35X3HS_35X35X28mmHS_35X35X28MM
HS3HEAT_SINK_HS_35X35X28MM_HS_35X3HS_35X35X28mmHS_35X35X28MM
HS5HEAT_SINK_HS_60X60X30-70MM_HS_6HS_60X60X30mmHS_60X60X30-70MM
HS6HEAT_SINK_HS_35X35X28MM_HS_35X3HS_35X35X28mmHS_35X35X28MM
J1HEADER_4X1_XH2P5_4X1_XH-4AW_2.5XH-4AW_2.5mmXH2P5_4X1
J2POWERJACK_3P_ROUND_POWERJACK_3PDCJACK_3P_ROUNDPOWERJACK_3P
J3CONN_8P_PWR_PW8P_396MM_CONN_8P_CONN_8P_PWR_3.96MMPW8P_396MM
J4BUTTON_RESET_BUT_DTS-62K-VDTS-62K-VRESET_BUT
J5JTAG_10X2_1.27MM_JS10X2-50MIL_JJTAG2x10PIN 1.27mmJS10X2-50MIL
J6PHJ8-2ROW_RJ45-PHJ8-2ROW_2X4POR2X4PORT_RJ45RJ45-PHJ8-2ROW
J7PHJ8-2ROW_RJ45-PHJ8-2ROW_2X4POR2X4PORT_RJ45RJ45-PHJ8-2ROW
J8PHJ8-2ROW_RJ45-PHJ8-2ROW_2X4POR2X4PORT_RJ45RJ45-PHJ8-2ROW
L1CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L2CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603
L3CHOKE_L2220_550OHM@100MHZ_4A550ohm@100Mhz_4AL2220
L4CHOKE_POWER_L6R0X6R0X4R5_4.7UH/4.7uh/3.37AL6R0X6R0X4R5
L5CHOKE_L2220_550OHM@100MHZ_4A550ohm@100Mhz_4AL2220
L6CHOKE_POWER_WE744311_1.0UH/15A1.0uH/15AWE744311
L7CHOKE_POWER_L10X10X5_0.72UH/22A0.72uH/22AL10X10X5
L8CHOKE_POWER_L4R5X4R0_2.2UH/3A2.2uH/3AL4R5X4R0
L9CHOKE_POWER_L10R5X10R2X5R0_3.3U3.3uH/12AL10R5X10R2X5R0
L10CHOKE_POWER_L10X10X5_0.72UH/22A0.72uH/22AL10X10X5
L11CHOKE_L0402_120OHM100MHZ L0402120ohm100MHZ L0402L0402
L12CM_CHOKE_4PIN_L1220_4PIN_NI_RFCNI_RFCMF1220100M4TL1220_4PIN
L13CHOKE_L1206_120OHM100MHZ L1206120ohm100MHZ L1206L1206
L14CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L15CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603
L16CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603
L19CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603
L20CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603
L21CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603
L22CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603
L23CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603
L24CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603
L25CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603
L26CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603
L27CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603
L29CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L30CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L31CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L32CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L33CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L34CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L35CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
L36CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805
LED1GS2011AR-G_SMD10-1E44-7R20X10R0GS2011AR-GSMD10-1E44-7R20X10R0
P1USB20A_LIE90_USB20A_LIE90_F_USBUSB20AX1_RECEPTACLEUSB20A_LIE90_F
PIC1CAP_NP_C0402_0.1UF/25V-Y5V0.1uF/25V-Y5VC0402
PIC2CAP_NP_C0603_1UF/6.3V-X5R1uF/6.3V-X5RC0603
PIC3CAP_NP_C0805_10UF/6.3V-X5R10uF/6.3V-X5RC0805
PIC4CAP_NP_C0402_0.01UF/25V-X7R0.01uF/25V-X7RC0402
PIC5CAP_NP_C0805_10UF/6.3V-X5R10uF/6.3V-X5RC0805
PIC6CAP_NP_C0402_0.1UF/25V-Y5V0.1uF/25V-Y5VC0402
PIL1INDUCTOR_LVS505040_2.2UH/2.5A2.2uH/2.5ALVS505040
PJ1PHJ1-1ROW_RJ45-PHJ1-1ROW_1X1POR1X1PORT_RJ45RJ45-PHJ1-1ROW
PJ3PHJ1-1ROW_RJ45-PHJ1-1ROW_1X1POR1X1PORT_RJ45RJ45-PHJ1-1ROW
Q1MOS_N-CHANNEL_SOT-23_2N7002K-72N7002K-7SOT-23
Q2MOS_N-CHANNEL_SOT-23_2N7002K-72N7002K-7SOT-23
RV1RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5
RV2RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5
RV3RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5
RV4RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5
RV5RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5
RV6RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5
SW1DIP_SW-4_0_SWDIP_4_NDSR-4-VNDSR-4-VSWDIP_4
T11X1PIN_JP1X1_NI_1X1PIN2.54MMNI_1X1PIN2.54mmJP1X1
T2TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
T3TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
T4TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
T5TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
T6TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
T7TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
T8TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
T9TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
T102X6PIN_JP6X2_2X6PIN2.54MM2X6PIN2.54mmJP6X2
T112X6PIN_JP6X2_2X6PIN2.54MM2X6PIN2.54mmJP6X2
T122X5PIN_JP5X2_2X5PIN2.54MM2X5PIN2.54mmJP5X2
T131X7PIN_JP7X1_1X7PIN2.54MM1X7PIN2.54mmJP7X1
T141X6PIN_JP6X1_1X6PIN2.54MM1X6PIN2.54mmJP6X1
T161X4PIN_JP4X1_1X4PIN2.54MM1X4PIN2.54mmJP4X1
T18TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1
U16_TOP1DDR4X16_4_FBGA96_0R8_DDR4DDR4FBGA96_0R8
U18_TOP1DDR4X16_3_FBGA96_0R8_DDR4DDR4FBGA96_0R8
U1RT7294C_SOT-23-6_RT7294CGJ6FRT7294CGJ6FSOT-23-6
U2MP1653_SOT23-6_0_5_MP1653MP1653SOT23-6_0_5
U3TPS5331X_LSON-CLIP_22_TPS53319DTPS53319DQPLSON-CLIP_22
U4MP20073DH_0_SOP8_4_9_0_65_EP_MPMP20073DH_5SOP8_4_9_0_65_EP
U5MP1653_SOT23-6_0_5_MP1653MP1653SOT23-6_0_5
U6TPS54821_VQFN14_3R5X3R5_0R5_TPSTPS54821VQFN14_3R5X3R5_0R5
U7TPS5331X_LSON-CLIP_22_TPS53319DTPS53319DQPLSON-CLIP_22
U10MAX706_SOP8_MAX706RESAMAX706RESASOP8
U1174LV08_SOP14_74LV08PW74LV08PWSOP14
U1274LV08_SOP14_74LV08PW74LV08PWSOP14
U14SPI_NAND_SOP16_SOP16-SPIF-SKT_FFLASH_16PIN_SKTSOP16-SPIF-SKT
U15SPI_FLASH_SOP16_SOP16-SPIF-SKT_FLASH_16PIN_SKTSOP16-SPIF-SKT
U18TVS_4LINE_SOT-23-6_TVS_AZ1013-0TVS_AZ1013-04SSOT-23-6
U19SPI_FLASH_SOP8_SOP8-SPIF-SKT_MXMX25L12835FMI-10GSOP8-SPIF-SKT
U20SPI_FLASH_SOP8_SOP8-SPIF-SKT_MXMX25L12835FMI-10GSOP8-SPIF-SKT
U2174HC125D_SOP14_74HC125D74HC125DSOP14
U23MAX3232_TSSOP16_MAX3232CPWRMAX3232CPWRTSSOP16
U2474HC125D_SOP14_74HC125D74HC125DSOP14
U25RTL8218E_LQFP128_LQFP128_20X14_RTL8218ELQFP128_20X14_EPAD_0R5
U26RTL8218E_LQFP128_LQFP128_20X14_RTL8218ELQFP128_20X14_EPAD_0R5
U27RTL8218E_LQFP128_LQFP128_20X14_RTL8218ELQFP128_20X14_EPAD_0R5
U30SFP1X1_SFP-CAGE-1X1_SFP_CAGE_1XSFP_CAGE_1x1SFP-CAGE-1X1
U31SFP1X1_SFP-CAGE-1X1_SFP_CAGE_1XSFP_CAGE_1x1SFP-CAGE-1X1
U32SFP1X1_SFP-CAGE-1X1_SFP_CAGE_1XSFP_CAGE_1x1SFP-CAGE-1X1
U33SFP1X1_SFP-CAGE-1X1_SFP_CAGE_1XSFP_CAGE_1x1SFP-CAGE-1X1
U34RTL8231_GPIO_LQFP48_RTL8231RTL8231LQFP48
U35RTL8231_SHIFT_LQFP48_RTL8231RTL8231LQFP48
U36PARALLEL_NAND_TSOP48_TSOP48_PARW29N08GVSIADTSOP48_PARALLELFLASH
U37RTL9311BR_DDR4_DEMO_BGA841C50P2RTL9311BRBGA841C50P29X29_1500X1500X250
U38G2404DG_G2404DG_G2404DGG2404DGG2404DG
U40VRTL8363SC_QFN56_1_QFN56_7X7_0_RTL8363SC-VB_MQFNT56QFN56_7X7_0_4MM
X1QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X18QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X20QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X22QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X23QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X24QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X25QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X26QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X27QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X28QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X29QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
X30QP2093Q_QP2093Q_QP2093QQP2093QQP2093Q
Y1CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49US
Y2CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49US
Y3CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49US
Y4CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49US
Y6CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49US
重要提示:PCB作品文件展下载说明
  • 打卡总天数:12
  • 打卡总奖励:35
7087
11万
管理员
 楼主| 发表于 2023-7-18 16:17 | 显示全部楼层
PCB文件。回复可见下载。
游客,如果您要查看本帖隐藏内容请回复
  • 打卡总天数:2
  • 打卡总奖励:8
  • 最近打卡:2025-01-22 22:55:12
37
1元学习Allegro(1期)
发表于 2023-7-18 16:27 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:64
  • 打卡月天数:4
  • 打卡总奖励:177
  • 最近打卡:2026-11-13 09:25:41
Allegro261021初级班
发表于 2023-7-18 16:29 | 显示全部楼层
感谢老吴的无私分享。。谢谢
芸香馆工 该用户已被删除
发表于 2023-7-18 16:30 | 显示全部楼层
发表于 2023-7-18 16:32 | 显示全部楼层
发表于 2023-7-18 16:33 | 显示全部楼层
  • 打卡总天数:2
  • 打卡总奖励:10
  • 最近打卡:2025-03-28 11:46:30
27
1元学习Allegro(1期)
  • 打卡总天数:2
  • 打卡总奖励:10
27
1元学习Allegro(1期)
