| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| CN4 | DEBUGPORT_0_HEADER1X4_DEBUG PO | debugPort | HEADER1X4 |
| CN5 | RJ-45X4P-NO-SH_4_RJ451X4_58D43X | 5324-MINI-8P8C | RJ451X4_58D43X15D2_THR |
| D1 | LED/0603_0_LED0603_BLUELED | BlueLED | LED0603 |
| D2 | DIODE_1_SOD-123_RB751G-40 | RB751G-40 | SOD-123 |
| D9 | LED/0603_LED0603_BLUELED | BlueLED | LED0603 |
| D11 | LED/0603_LED0603_BLUELED | BlueLED | LED0603 |
| D12 | LED/0603_0_LED0603_BLUELED | BlueLED | LED0603 |
| D14 | TVS_DFN1006_NC | NC | DFN1006 |
| D15 | TVS_DFN1006_NC | NC | DFN1006 |
| D16 | TVS_SMD54X35_TSS-BS0640N-C- | TSS-BS0640N-C- | SMD54X35 |
| HB1 | SMA/UFLR_4_ANT_2MM_5G_ANT_2MM_5 | ANT_2MM_5G | ANT_2MM_5G |
| HB2 | SMA/UFLR_4_ANT_2MM_5G_ANT_2MM_5 | ANT_2MM_5G | ANT_2MM_5G |
| J1 | PHONEJACKMO_2_POWERJACK_THR_PO | POWERJACK_THR | POWERJACK_THR |
| KEY1 | SW-PB-4_0_SW2P_THR_KEY_4PIN | KEY_4PIN | SW2P_THR |
| L1 | INDUCTOR_0_L0201_NC/12NH | NC/12nH | L0201 |
| L2 | INDUCTOR_0_L0201_NC/12NH | NC/12nH | L0201 |
| L3 | INDUCTOR_0_L0201_2.4NH-C-0201 | 2.4nH-C-0201 | L0201 |
| L4 | INDUCTOR_0_L0201_2.4NH-C-0201 | 2.4nH-C-0201 | L0201 |
| L5 | INDUCTOR_0_L0402_4.7NH-S-0402 | 4.7nH-S-0402 | L0402 |
| L6 | INDUCTOR_0_L0402_4.7NH-S-0402 | 4.7nH-S-0402 | L0402 |
| L7 | INDUCTOR_L_6X6_MPIT6045-4R7M-LF | MPIT6045-4R7M-LF/3.8A | L_6X6 |
| L11 | INDUCTOR_L4018_2.2UH/2.15A | 2.2uH/2.15A | L4018 |
| L12 | INDUCTOR_L4018_2.2UH/2A | 2.2uH/2A | L4018 |
| L14 | INDUCTOR_L_6X6_MPIT6045-4R7M-LF | MPIT6045-4R7M-LF/3.8A | L_6X6 |
| L32 | INDUCTOR_0_L0402_4.7NH-S-0402 | 4.7nH-S-0402 | L0402 |
| L33 | INDUCTOR_0_L0402_4.7NH-S-0402 | 4.7nH-S-0402 | L0402 |
| L36 | INDUCTOR_L4018_2.2UH/1.6A | 2.2uH/1.6A | L4018 |
| L37 | INDUCTOR_0_L0201_2PF-B-0201-C0G | 2PF-B-0201-C0G-50V | L0201 |
| L40 | INDUCTOR_0_L0201_2PF-B-0201-C0G | 2PF-B-0201-C0G-50V | L0201 |
| L43 | INDUCTOR_0_L0201_1NH-C-0201/NC | 1nH-C-0201/NC | L0201 |
| L44 | INDUCTOR_0_L0201_1NH-C-0201/NC | 1nH-C-0201/NC | L0201 |
| L49 | INDUCTOR_L0201_2NH-C-0201/NC | 2nH-C-0201/NC | L0201 |
| L50 | INDUCTOR_L0201_2NH-C-0201/NC | 2nH-C-0201/NC | L0201 |
| L51 | INDUCTOR_0_L0201_0R-J-0603 | 0R-J-0603 | L0201 |
| L52 | INDUCTOR_0_L0201_1NH-C-0201 | 1nH-C-0201 | L0201 |
| L53 | INDUCTOR_0_L0201_0R-F-0201 | 0R-F-0201 | L0201 |
| L54 | INDUCTOR_0_L0201_1NH-C-0201 | 1nH-C-0201 | L0201 |
| L56 | INDUCTOR_0_L0201_1NH-C-0201/NC | 1nH-C-0201/NC | L0201 |
| L57 | INDUCTOR_0_L0201_NC/12NH | NC/12nH | L0201 |
| L59 | INDUCTOR_0_L0201_1NH-C-0201/NC | 1nH-C-0201/NC | L0201 |
| L60 | INDUCTOR_0_L0201_NC/12NH | NC/12nH | L0201 |
| L61 | INDUCTOR_0_FB0402_NC/600R/100M | NC/600R/100M | FB0402 |
| L62 | INDUCTOR_0_L0201_0R-F-0201 | 0R-F-0201 | L0201 |
| L63 | INDUCTOR_0_L0201_0R-F-0201 | 0R-F-0201 | L0201 |
| L64 | INDUCTOR_0_R0805_100R-100M-0805 | 100R-100M-0805-3A | R0805 |
| L65 | INDUCTOR_0_R0805_100R-100M-0805 | 100R-100M-0805-3A | R0805 |
| LB1 | SMA/UFLR_4_ANT_2MM_5G_NC/20279- | NC/20279-001E-03 | ANT_2MM_5G |
| LB2 | SMA/UFLR_4_ANT_2MM_5G_NC/20279- | NC/20279-001E-03 | ANT_2MM_5G |
| U1 | SF19A28C_SF19AC28BF_(S1+S2+S3+S | SF19A28C | SF19AC28BF |
| U2 | MT47H16M16BG_3_WBGA84-DDR2X16_E | EM68B16CWQH-25H | WBGA84-DDR2X16 |
| U3 | LM7805_0_SOT_223_ZTP1117SA | ZTP1117SA | SOT_223 |
| U6 | RTC6619SP_0_SOT-363-KCT2821L_KC | KCT2821L | SOT-363-KCT2821L |
| U10 | RTC5639_0_QFN3X3_16PIN_RTC5639_ | KCT8525D | QFN3X3_16PIN_RTC5639 |
| U11 | SY8120B1_1_SOT23_6_TMI3253_S_T | TMI3253_S_T | SOT23_6 |
| U12 | RTC6619SP_0_SOT-363-KCT2821L_KC | KCT2821L | SOT-363-KCT2821L |
| U13 | RTC5639_0_QFN3X3_16PIN_RTC5639_ | KCT8525D | QFN3X3_16PIN_RTC5639 |
| U14 | JW5223_2_SOT23_5_ZTP7108T | ZTP7108T | SOT23_5 |
| U17 | JW5223_2_SOT23_5_ZTP7108T | ZTP7108T | SOT23_5 |
| U20 | LM7805_0_SOT_223_ZTP1117SA | ZTP1117SA | SOT_223 |
| U21 | SY8120B1_0_SOT23_6_TMI3253_S_T | TMI3253_S_T | SOT23_6 |
| U24 | SPI_FLASH_2_WSON8_8X6MM_SO8C_BH | BH25Q64BS | WSON8_8X6MM_SO8C |
| U63 | FC1084DG_0_FILG3601DG_THR_FC108 | FC1084DG | FILG3601DG_THR |
| U64 | FC1084DG_0_FILG3601DG_THR_FC108 | FC1084DG | FILG3601DG_THR |
| U65 | GSW150_GSW150_GSW150 | GSW150 | GSW150 |
| U78 | JW5223_2_SOT23_5_ZTP7108T | ZTP7108T | SOT23_5 |
| U79 | LM7805_0_SOT_223_ZTP1117SA | ZTP1117SA | SOT_223 |
| U80 | RFBPF1608060KFT_0_BPF1608_3P_RF | RFBPF1608060K78Q1C/NC | BPF1608_3P |
| U81 | RFBPF1608060KFT_0_BPF1608_3P_RF | RFBPF1608060K78Q1C/NC | BPF1608_3P |
| U82 | RFBPF1608060KFT_1_FIL162500_SM_ | RFLPF1608060A0T/NC | FIL162500_SM |
| U83 | RFBPF1608060KFT_1_FIL162500_SM_ | RFLPF1608060A0T/NC | FIL162500_SM |
| X2 | CRY_1_XTAL_SMD_3D2X2D5_40MHZ | 40MHz | XTAL_SMD_3D2X2D5 |
| Y2 | CRY_1_XTAL_SMD_3D2X2D5_25MHZ | 25MHz | XTAL_SMD_3D2X2D5 |
