重要提示:PCB作品文件展下载说明
| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | | BK1 | BRACKET_ATX_2X_2P-BRKT_DUAL_ATX_2TAB_PG161,151-XXXX-XXX-151-XXXX-XXX | | BRKT_ATX_2TAB_1_DVID_DP_DP_2_HDMI_3_DP | | CN1 | CON_PCI_EXPRESS_NONPHY-X16-CON_PCIEXP_X16_EDGE,EDGEFINGER,1MM,N/A,N/A,N/A,N/A,NO,NO,50V,1.1A,065-00044-0000-000-065-00044-000A | | CON_FINGER_PEX_164 | | D1 | D_3PIN_CC_SOT23-BAT54C,1PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0016-000-091-0016-000 | | SOT23 | | D2 | D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 | | DIODE_SMD_010X060 | | D3 | D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 | | DIODE_SMD_010X060 | | D4 | D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 | | DIODE_SMD_010X060 | | D5 | D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 | | DIODE_SMD_010X060 | | D6 | D_SOT323-BAT54W,SINGLE,30V,0.6A,1V@0.1A,0.2A,090-0106-000-090-0106-000 | | SOT323 | | D501 | D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 | | DIODE_SMD_010X060 | | D502 | D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 | | DIODE_SMD_010X060 | | D503 | D_SOD523-1N4148WT,SINGLE,80V,0.25A,0.75V@50MA,0.25A,090-0105-000-090-0105-000 | | DIODE_SMD_SOD523_B | | D504 | D_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000 | | DIODE_SMD_SOD523_B | | D505 | D_3PIN_AA_SOT323-BAS70-06W,1PAIR - COMMON ANODE,70V,0.1A,1V@15MA,70MA,090-0287-000-090-0287-000 | | SOT323 | | D506 | D_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000 | | DIODE_SMD_SOD523_B | | D507 | D_3PIN_AA_SOT323-BAS70-06W,1PAIR - COMMON ANODE,70V,0.1A,1V@15MA,70MA,090-0287-000-090-0287-000 | | SOT323 | | D508 | D_3PIN_AA_SOT323-BAS70-06W,1PAIR - COMMON ANODE,70V,0.1A,1V@15MA,70MA,090-0287-000-090-0287-000 | | SOT323 | | G1 | U_GPU_GB4B_256_BGA2228-TU104-400-A1,GPU- DESKTOP,TU104-400-A1-TU104-400-A1 | | BGA_2228_P070_375X375 | | J1 | CON_DISPLAYPORT_NORM-G3167CE04-010-H,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,N/A,N/A,080-1143-000-080-1143-000 | | CON_DP_020_SMT_RA_F_B | | J2 | CON_DISPLAYPORT_NORM_4GND-CONNDPF01505-H,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,40.0V,0.5 A,080-1377-000-080-1377-000 | | CON_DP_020_SMT_RA_F_C | | J3 | CON_DISPLAYPORT_NORM_4GND-CONNDPF01505-H,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,40.0V,0.5 A,080-1377-000-080-1377-000 | | CON_DP_020_SMT_RA_F_C | | J4 | CON_HDMI_HDMI_A_SMD-CONNSMD HDMI FEMALE RA 19 POS 0.50MM PITCH W/SPRING,RECEPTACLE,0.5MM,90,YES,NO,YES,YES,YES,N/A,N/A,080-1B | | CON_HDMI_019_SMT_RA_F_P005_G | | J5 | CON_DVI_D_DVI_D_SHLD-DVI-D_BEIGE,FEMALE,1.905MM,90,YES,YES,NO,NO,NO,N/A,N/A,065-0500-000-065-0500-000 | | CON_DVID_024_RA_F_SHD | | J6 | HDR_1X4_NORM-HDR_1M4,MALE,2.0MM,VERTICAL,YES,YES,YES,800VAC,1A,074-0098-000-074-0098-000 | | CON_WAFER232_004_TH_ST_P020 | | J7 | HDR_2X4_PCIEPWR_8P-CONNTHRU PCI-E POWER FEMALE RA 8 POS 4.20MMPITCH,RECEPTACLE,4.2MM,90,NO,YES,YES,N/A,N/A,075-0286-000-075-A | | CON_PWR_002X004_TH_RA_M_P042 | | L1 | L_SMD_5X5-4.7UH,FERRITE,20%,2.5A,2.8A,0.074OHM,[]@[ ],[ ],N/A,130-1260-000-130-1260-000,4.7UH | 4.7uH | IND_NONRKO_SMD_050X050_F | | L2 | L_SMD_5X5-4.7UH,ALLOYCORE,20%,3.4A,4.1A,0.07992OHM,0@0HZ,0HZ,N/A,130-1241-000-130-1241-000,4.7UH | 4.7uH | IND_NONRKO_SMD_057X052 | | L3 | L_SMD_5X5-4.7UH,ALLOY,20%,3.5A,4A,0.085OHM,40@300KHZ,[],N/A,130-1138-000-130-1138-000,4.7UH | 4.7uH | IND_NONRKO_SMD_055X052 | | L4 | L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-000 | 0.22uH | IND_NONRKO_TH_105X075 | | L5 | L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-000 | 0.22uH | IND_NONRKO_TH_108X080 | | L6 | L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-000 | 0.22uH | IND_NONRKO_TH_105X075 | | L7 | L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-000 | 0.22uH | IND_NONRKO_TH_108X080 | | L8 | L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-000 | 0.22uH | IND_NONRKO_TH_105X075 | | L9 | L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-000 | 0.22uH | IND_NONRKO_TH_108X080 | | L10 | L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-000 | 0.22uH | IND_NONRKO_TH_108X080 | | L11 | L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-000 | 0.22uH | IND_NONRKO_TH_105X075 | | L12 | L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-000 | 0.22uH | IND_NONRKO_TH_108X080 | | L13 | L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-000 | 0.22uH | IND_NONRKO_TH_105X075 | | L14 | L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-000 | 0.22uH | IND_NONRKO_TH_108X080 | | L15 | L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-000 | 0.22uH | IND_NONRKO_TH_105X075 | | L16 | L_TH-1UH,IRON,20%,25A,35A,0.0024OHM,999@999KHZ,999MHZ,N/A,130-1261-000-130-1261-000,1UH | 1uH | IND_NONRKO_TH_100X100_B | | L17 | L_TH-1UH,IRON,20%,25A,35A,0.0024OHM,999@999KHZ,999MHZ,N/A,130-1261-000-130-1261-000,1UH | 1uH | IND_NONRKO_TH_100X100_B | | L18 | L_SMD_5X5-1UH,ALLOYPOWDER,20%,8A,9A,0.017OHM,43@300KHZ,[ ],N/A,130-1139-000-130-1139-000,1UH | 1uH | IND_NONRKO_SMD_055X052 | | L19 | L_7_6X7_6-1UH,IRON,20%,7A,14A,0.0183OHM,[]@[ ],[ ],[ ],130-1025-000-130-1025-000,1UH | 1uH | IND_NONRKO_SMD_073X067 | | L20 | L_7_6X7_6-1UH,IRON,20%,7A,14A,0.0183OHM,[]@[ ],[ ],[ ],130-1025-000-130-1025-000,1UH | 1uH | IND_NONRKO_SMD_073X067 | | L21 | L_TH-1UH,[],20%,16A,18A,0.00324OHM,[ ]@[ ],[ ],[ ],131-0652-000-131-0652-000,1UH | 1uH | IND_NONRKO_TH_082X082 | | LB1 | L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM | 600ohm | IND_SMD_0402 | | LB2 | L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM | 600ohm | IND_SMD_0402 | | LB3 | L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM | 600ohm | IND_SMD_0402 | | LB4 | L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM | 600ohm | IND_SMD_0402 | | LB5 | L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM | 600ohm | IND_SMD_0402 | | LB6 | L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM | 600ohm | IND_SMD_0402 | | LB7 | L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM | 600ohm | IND_SMD_0402 | | LB8 | L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM | 600ohm | IND_SMD_0402 | | LB501 | L_BEAD_0603-30OHM,FERRITE,25%,5A,5A,0.01OHM,[],N/A,N/A,100-0049-000-100-0049-000,30OHM | 30ohm | IND_SMD_0603 | | LB502 | L_BEAD_0603-30OHM,FERRITE,25%,5A,5A,0.01OHM,[],N/A,N/A,100-0049-000-100-0049-000,30OHM | 30ohm | IND_SMD_0603 | | M1 | U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 | | BGA_0180_P075_120X140 | | M2 | U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 | | BGA_0180_P075_120X140 | | M3 | U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 | | BGA_0180_P075_120X140 | | M4 | U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 | | BGA_0180_P075_120X140 | | M9 | U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 | | BGA_0180_P075_120X140 | | M10 | U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 | | BGA_0180_P075_120X140 | | M11 | U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 | | BGA_0180_P075_120X140 | | M12 | U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 | | BGA_0180_P075_120X140 | | MEC1 | MOUNTING_HOLE_X8-PG161_MOUNTING_HOLES | | MECH_PEX_01447X01112_HOLE_PG161 | | MEC501 | STIFFENER_4PIN-GPU_STIFFENER_PG161,320-XXXX-XXX-320-XXXX-XXX | | HSB_GPU_TU106_B_ST_1 | | Q1 | Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B | | SOT323 | | Q2 | Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B | | SOT323 | | Q3 | Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 | | SOT23 | | Q4 | Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 | | SC70_6 | | Q5 | Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B | | SOT323 | | Q6 | Q_FET_N_ENH_SOT323_1G1D1S-PJC138K,50V,1600MOHM@10V/ 2500MOHM@4.5V / 4500MOHM@2.5V,0.36A,1.2A,20V,0.236W,0NC@10V / 1NC@4.5V / B | | SOT323 | | Q7 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q8 | Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 | | SOT23 | | Q9 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q10 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q11 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q12 | Q_FET_N_ENH_SOT323_1G1D1S-PJC138K,50V,1600MOHM@10V/ 2500MOHM@4.5V / 4500MOHM@2.5V,0.36A,1.2A,20V,0.236W,0NC@10V / 1NC@4.5V / B | | SOT323 | | Q13 | Q_FET_N_ENH_PWR_PHASE-QM3816N6,30V/ 30V,7.3MOHM,1.9MOHM@10V / 11.7MOHM,2.9MOHM@4.5V / [ ],[ ]@2.5V,10A /22A,102A / 234A,20V B | | MULTI_DFET_010_SMD_050X060 | | Q14 | Q_FET_N_ENH_PWR_PHASE-QM3816N6,30V/ 30V,7.3MOHM,1.9MOHM@10V / 11.7MOHM,2.9MOHM@4.5V / [ ],[ ]@2.5V,10A /22A,102A / 234A,20V B | | MULTI_DFET_010_SMD_050X060 | | Q501 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q502 | Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B | | SOT323 | | Q503 | Q_NPN_SOT323_1B1C1E-MMBT3904WT1G,60V,[],0.2A,0.2A,6V,0.15W,305-0031-000-305-0031-000 | | SOT323 | | Q504 | Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 | | SOT23 | | Q505 | Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 | | SC70_6 | | Q506 | Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 | | SC70_6 | | Q507 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q508 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q509 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q510 | Q_FET_P_ENH_DFN3X3_DUAL-EMF20B02V,-20V/ -20V,[ ],[ ]@10V / 20MOHM,20MOHM@4.5V / 25MOHM,25MOHM@2.5V,25MOHM /-6A,-34A / -34A,1B | | MULTI_DFET_SMD_030X030 | | Q511 | Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B | | SOT323 | | Q512 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q513 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q514 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q515 | Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B | | SOT323 | | Q516 | Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B | | SOT323 | | Q517 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q518 | Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 | | SC70_6 | | Q519 | Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B | | SC70_6 | | Q520 | Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B | | SOT323 | | Q521 | Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 | | SOT23 | | Q522 | Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 | | SOT23 | | RS1 | R_SENSE_1206_4PIN-0.005OHM,1%,1W,100PPM,215-0327-000-0.005OHM,215-0327-000 | 0.005ohm | RES_04_SMD_032X016 | | RS2 | R_SENSE_2512_VIRTUAL_4PIN-0.005OHM,1%,2W,100PPM,215-0139-000-0.005OHM,215-0139-000 | 0.005ohm | RSENSE_VIRTUAL_04_SMD_2512_C | | RS501 | R_SENSE_2512_VIRTUAL_4PIN-0.005OHM,1%,2W,100PPM,215-0139-000-0.005OHM,215-0139-000 | 0.005ohm | RSENSE_VIRTUAL_04_SMD_2512_C | | RT1 | THERMISTOR_0402-1K_B25/100=0K,50%,0.999W,PTC,093-0032-000-093-0032-000,1K_B25/100=0K | 1k_B25/100=0K | 402 | | RT2 | THERMISTOR_0603-100K_B25/85=4550K,5%,[],NTC,093-0014-000-093-0014-000,100K_B25/85=4550K | 100k_B25/85=4550K | 603 | | RT3 | THERMISTOR_0603-100K_B25/85=4550K,5%,[],NTC,093-0014-000-093-0014-000,100K_B25/85=4550K | 100k_B25/85=4550K | 603 | | RT4 | THERMISTOR_0402-100K_B25/50=4250K,1%,35MW,NTC,093-0042-000-093-0042-000,100K_B25/50=4250K | 100k_B25/50=4250K | 402 | | TP1 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP2 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP3 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP4 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP5 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP6 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP501 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP502 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP503 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | TP504 | LABTESTPOINT_B28-LABTESTPOINT | | LTPT28C49P | | U1 | U_PWR_SW_UL_SOT23_5_DP-GS7615STDB-R,2.5V..5.5V,2.5V..5.5V,0.72A,SWITCH,315-1014-000-315-1014-000 | | SOT23_5 | | U2 | U_PWR_SW_UL_SOT23_5_DP-GS7615STDB-R,2.5V..5.5V,2.5V..5.5V,0.72A,SWITCH,315-1014-000-315-1014-000 | | SOT23_5 | | U3 | U_OPENVREG_TYPE2PLUS_QFN3X3-UP1666QQKF,BUCK,2PH,1MHZ,DYNAMICVID,0MV..2V,1%,2V,20V,60A,1.47W,316-0467-000-2V,316-0467-000 | 2V | QFN020Q_P040_035X035_T017X017_C | | U4 | U_BUCK_FET_1PH_SOT23_8_NOVR-MP1475DJ,BUCK,1PH,500KHZ,NONE,0.807V..5V,2.5%,0.807V,16V,3A,1W,316-0470-000-0.807V,316-0470-000 | 0.807V | SOT23_8 | | U5 | U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 | | QFN033Q_P050_0050_T036X020_T017X011_T014X011 | | U6 | U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 | | QFN033Q_P050_0050_T036X020_T017X011_T014X011 | | U7 | U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 | | QFN033Q_P050_0050_T036X020_T017X011_T014X011 | | U8 | U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 | | QFN033Q_P050_0050_T036X020_T017X011_T014X011 | | U9 | U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 | | QFN033Q_P050_0050_T036X020_T017X011_T014X011 | | U10 | U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 | | QFN033Q_P050_0050_T036X020_T017X011_T014X011 | | U11 | U_MEM_FL_SER_1MX8_SO_8-50MHZ,1.65V..1.95V,W25Q80EWSNIG,170-0268-000-170-0268-000 | | SO08_048X038 | | U12 | U_AND_2IN_SC70-5-NL17SZ08DFT2G,GATES- AND - 2 INPUT,115-1448-000-115-1448-000 | | SC70_5 | | U13 | U_BUCK_FET_1PH_QFN23_PIR-GS9216TQ-R,BUCK,1PH,600KHZ,NONE,0.6V..12V,1%,0.6V,22V,8A,2W,316-0630-000-0.6V,316-0630-000 | 0.6V | QFN023Q_P050_0040_T028X011_T028X014 | | U14 | U_SW_LOAD_SOT363-GS7616SC-R,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1566-000-115-1566-000 | | SC70_6 | | U15 | U_BUCK_FET_1PH_QFN23_PIR-GS9216TQ-R,BUCK,1PH,600KHZ,NONE,0.6V..12V,1%,0.6V,22V,8A,2W,316-0630-000-0.6V,316-0630-000 | 0.6V | QFN023Q_P050_0040_T028X011_T028X014 | | U16 | U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 | | SC70_5 | | U501 | U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 | | SC70_5 | | U502 | U_PWR_SW_UL_SOT23_5_EFU-GS7612S5MA-R,2V..5.5V,2V..5.5V,0.55A,SWITCH,315-1048-000-315-1048-000 | | SOT23_5 | | U503 | U_PWRMTR_NCP4549_QFN32-NCP45491XMNTWG,0MV..26V,2.7V..5.5V,0.5MA,MONITOR,315-1061-000-315-1061-000 | | QFN032Q_P040_0040_T027X027 | | U504 | U_OPENVREG_TYPE4PLUS_QFN5X5-NCP81611MNTXG,BUCK,4PH,1.2MHZ,I2C,0MV..5V,1.5%,2V,20V,316-0641-000-2V,316-0641-000 | 2V | QFN040Q_P040_0050_T035X035_VIAS | | U505 | U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 | | SC70_5 | | U506 | U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 | | SC70_5 | | U507 | U_LDO_UDFN4_NOVR-NCP114AMX330TCG,LOWDROPOUT/FIXED,0.2V@0.3A,3.3V..3.3V,2%,3.3V,5.5V,0.3A,0.4W,315-0999-000-3.3V,315-0999-000 | 3.3V | DFN04_P065_010X010_T005X005_VIAS | | U508 | U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 | | SC70_5 | | U509 | U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 | | SC70_5 | | U510 | U_LDO_UDFN4_NOVR-NCP114AMX330TCG,LOWDROPOUT/FIXED,0.2V@0.3A,3.3V..3.3V,2%,3.3V,5.5V,0.3A,0.4W,315-0999-000-3.3V,315-0999-000 | 3.3V | DFN04_P065_010X010_T005X005_VIAS | | Y1 | XTAL_4PIN_SMD_32X25-27M_NKG,27MHZ,30PPM,2PPM,60PPM,18PF,FUNDAMENTAL,085-0135-000-085-0135-000,27MHZ | 27MHz | XTAL_SMD_4_032X025 |
重要提示:PCB作品文件展下载说明
