查看: 847|回复: 14
Allegro DRC 錯誤代碼Dictionary of DRC Error Marker Codes
  • 打卡等级:常住青年
  • 打卡总天数:23
  • 打卡总奖励:74
  • 最近打卡:2024-08-10 14:49:28
发表于 2024-1-22 12:30 | 显示全部楼层 |阅读模式
[/free]
DRC错误标记由带有两个字母的“领结”符号组成。字母代码指示违反了哪种约束类型。
Net-to-Net Spacing DRC错误标记代码为大写;相反,Same Net Spacing代码是小写的。
DRC错误标记代码定义
下表列出了每种DRC错误标记代码组合及其关联的约束违例。该列表根据DRC错误标记中的字母按字母顺序排列。
CodeConstraintViolation
A – AAcuteangle to cavity edge
B – BBondPad to Bond Pad
B – LBondPad to Line
B – SBondPad to Shape
C – CComponentto cavity edge
Package to package
Soldermask to soldermask
D – CDFAPackage to package
D – DMechanicalDrill Hole to Mechanical Drill Hole
Mechanical Drill Hole to Drill Hole
D – INegativeplane islands
D – LMechanicalDrill Hole to Cline
Drill Hole to Cline
D – PPhaseTolerance Tolerance
Mechanical Drill Hole to Pin
Drill Hole to Pin
D – SMechanicalDrill Hole to Shape
Drill Hole to Shape
D – VMechanicalDrill Hole to Via
Drill Hole to Via
E – DMaxFinal Settle Max
Min First Switch Min
Noise Margin Min
Overshoot Max
Propagation Delay Max
Propagation Delay Min
Propagation Delay Path Type
Relative Propagation Delay Delta
Relative Propagation Delay Path Type
Relative Propagation Delay Scope
E – LLayerSets
Max Exposed Length
Total Etch Length Max
Total Etch Length Min
E – PParallelism
E – SMaxStub Length
E – TVerifySchedule
E – VMaxVia Count
E – XActiveWindow
Max Xtalk
Max Peak Xtalk
Sensitive Window
Maximum Inter Crosstalk
Maximum Intra Crosstalk
F – CBondfinger to component
Bond Pad to Component Edge
Bond Finger to cavity edge
F – FBondPad to Bond Pad (same net)
Bond Pad to Bond Pad (different net)
I – MSingle-lineImpedance Target and Tolerance
J – NAllowTs
K – BBondPad to Route Keepin
Bond Pad to Route Keepout
Bond Pad to Via Keepout
K – CPackageto place keepin
Package to place keepout
K – LLineto Route Keepin
Line to Route Keepout
K – PThruPin to Route Keepin
Thru Pin to Route Keepout
SMD to Route Keepin
SMD to Route Keepout
Test Pin to Route Keepin
Test Pin to Route Keepout
Test Pin to No Probe
K – SShapeto Route Keepin
Shape to Route Keepout
K – VViato Route Keepin
Via to Route Keepout
Via to Via Keepout
BB Via to Route Keepin
BB Via to Route Keepout
BB Via to Via Keepout
Test Via to Route Keepin
Test Via to Route Keepout
Test Via to Via Keepout
Test Via to No Probe
L – LLineto Line
L – SShapeto Line
L – WLineWidth Max
Line Width Min
Neck Max Length
Neck Min Width
M – ASoldermaskalignment
Pad Soldermask Alignment
Symbol Soldermask Alignment
M – CSymbolSoldermask to Pad Soldermask
Minimum Cavity Size
M – LSoldermaskto pad and cline
M – MPadSoldermask to Pad Soldermask
Any Metal to Any Metal Spacing
M – PSoldermaskto Pin
M – SSoldermaskto shape
M – VSoldermaskto Via
Matched Via count violation
N – SNegativePlane to Sliver
O – CObjectexposure to cavity
P – BBondPad to SMD Pin
Bond Pad to Test Pin
Bond Pad to Thru Pin
P – DMechanicalPin Antipad to Drill Hole
P – LLineto SMD Pin
Line to Test Pin
Line to Thru Pin
Mechanical Pin Antipad to Cline
P – MPastemaskpad to pastemask pad
Pastemask to package pastemask
P – PSMDPin to SMD Pin
SMD Pin to Test Pin
Test Pin to Test Pin
Thru Pin to SMD Pin
Thru Pin to Test Pin
Thru Pin to Thru Pin
Mechanical Pin Antipad to Pin
P – SShapeto SMD Pin
Shape to Test Pin
Shape to Thru Pin
Mechanical Pin Antipad to Shape
P – VSMDPin to BB Via
SMD Pin to Test Via
SMD Pin to Thru Via
Test Pin to BB Via
Test Pin to Test Via
Test Pin to Thru Via
Thru Pin to BB Via
Thru Pin to Test Via
Thru Pin to Thru Via
Mechanical Pin Antipad to Via
R – CPackageto room
S – NAllowEtch
S – SShapeto Shape
T – CTestpointloc. to component
Testpoint pad to component
Testpoint under component
V – BBondPad to BB Via
Bond Pad to Test Via
Bond Pad to Thru Via
V – GAllowPad-Pad Connect
BB Via Stagger Max
BB Via Stagger Min
Min BB Via Gap
V – LLineto BB Via
Line to Test Via
Line to Thru Via
V – NVias
Vialist constraint violation
V – SShapeto BB Via
Shape to Test Via
Shape to Thru Via
V – VBBVia to BB Via
BB Via to Test Via
Test Via to Test Via
Thru Via to BB Via
Thru Via to Test Via
Thru Via to Thru Via
W – AMin.bonding wire length
Wire to die edge angle
W – DBondingwire diameter
W – CWireto Cavity Edge Spacing
Wire End to Cavity Edge Spacing
W – EWireend to wire end
W – FWireto bond finger
W – IMax.bonding wire length
W – PWireto pin
W – WWireto wire (same profile)
W – XWireto wire (different profile)
X – DExternallyDetermined Violation
[free]
购买主题 本主题需向作者支付 1 枚金币 才能浏览
  • 打卡等级:以坛为家I
  • 打卡总天数:61
  • 打卡总奖励:196
  • 最近打卡:2024-10-06 16:56:11
发表于 2024-1-22 20:13 | 显示全部楼层
  • 打卡总天数:306
  • 打卡总奖励:1099
  • 最近打卡:2026-09-10 17:29:20
75
社区居民忠实会员社区劳模终身成就奖社区明星宣传大使奖优秀斑竹奖特殊贡献奖原创先锋奖
发表于 2024-1-23 08:40 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:60
  • 打卡总奖励:225
  • 最近打卡:2025-07-29 08:22:46
发表于 2024-1-23 08:55 | 显示全部楼层
  • 打卡总天数:576
  • 打卡月天数:10
  • 打卡总奖励:1653
  • 最近打卡:2026-11-13 13:37:51
189
泰凌微是一家专业音视频的IC代理商、方案提供商和增值服务商
发表于 2024-1-23 09:00 | 显示全部楼层
  • 打卡总天数:581
  • 打卡月天数:10
  • 打卡总奖励:1722
  • 最近打卡:2026-11-13 11:46:05
薄情如漠,深情付九
发表于 2024-1-23 09:01 | 显示全部楼层
薄情如漠,深情付九
  • 打卡等级:常住青年
  • 打卡总天数:20
  • 打卡总奖励:68
  • 最近打卡:2026-04-14 09:02:00
发表于 2024-1-23 09:15 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:80
  • 打卡总奖励:314
  • 最近打卡:2026-06-09 10:12:38
  • 打卡等级:以坛为家I
  • 打卡总天数:80
  • 打卡总奖励:314
  • 打卡等级:以坛为家I
  • 打卡总天数:80
  • 打卡总奖励:314
