- `timescale 1ns / 1ps
- module LED
- input clk, // system clock 50Mhz on board
- input rst_n, // reset ,low active
- output reg[3:0] led // LED,use for control the LED signal on board
- //define the time counter
- reg [31:0] timer;
- // cycle counter:from 0 to 4 sec
- always@(posedge clk or negedge rst_n)
- begin
- if (rst_n == 1'b0)
- timer <= 32'd0; //when the reset signal valid,time counter clearing
- else if (timer == 32'd199_999_999) //4 seconds count(50M*4-1=199999999)
- timer <= 32'd0; //count done,clearing the time counter
- else
- timer <= timer + 32'd1; //timer counter = timer counter + 1
- end
- // LED control
- begin
- led <= 4'b0000; //when the reset signal active
- else if (timer == 32'd49_999_999) //time counter count to 1st sec,LED1 lighten
- led <= 4'b0001;
- else if (timer == 32'd99_999_999) //time counter count to 2nd sec,LED2 lighten
- led <= 4'b0010;
- else if (timer == 32'd149_999_999) //time counter count to 3rd sec,LED3 lighten
- led <= 4'b0100;
- else if (timer == 32'd199_999_999) //time counter count to 4th sec,LED4 lighten
- led <= 4'b1000;
- end
- endmodule
复制代码 |
