| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | DIODE_SCHOTTKY_DIO_POWERDI-323_ | PD3S230HQ-7 | DIO_POWERDI-323_0-7 |
| D2 | DIODE_SCHOTTKY_DIO_POWERDI-323_ | PD3S230HQ-7 | DIO_POWERDI-323_0-7 |
| D3 | DIODE_SCHOTTKY_DIO_POWERDI-323_ | PD3S230HQ-7 | DIO_POWERDI-323_0-7 |
| D4 | DIODE_SCHOTTKY_DIO_POWERDI-323_ | PD3S230HQ-7 | DIO_POWERDI-323_0-7 |
| D5 | DIODE_SCHOTTKY_DIO_POWERDI-323_ | PD3S230HQ-7 | DIO_POWERDI-323_0-7 |
| D6 | DIODE_SCHOTTKY_DIO_POWERDI-323_ | PD3S230HQ-7 | DIO_POWERDI-323_0-7 |
| D7 | DIODE_SCHOTTKY_DIO_POWERDI-323_ | PD3S230HQ-7 | DIO_POWERDI-323_0-7 |
| D8 | DIODE_SCHOTTKY_DIO_POWERDI-323_ | PD3S230HQ-7 | DIO_POWERDI-323_0-7 |
| D9 | TPD2EUSB30D_SOT-3_SOT-3_TPD2EUS | TPD2EUSB30DRTR | SOT-3 |
| D10 | DIODE_SOD323_DIO_SOD323_SD05C-0 | SD05C-01FTG | DIO_SOD323 |
| D11 | TPD2EUSB30D_SOT-3_SOT-3_TPD2EUS | TPD2EUSB30DRTR | SOT-3 |
| D12 | DIODE_SOD323_DIO_SOD323_SD05C-0 | SD05C-01FTG | DIO_SOD323 |
| D13 | DIODE_SOD323_DIO_SOD323_SD05C-0 | SD05C-01FTG | DIO_SOD323 |
| D14 | DIODE_SOD323_DIO_SOD323_SD05C-0 | SD05C-01FTG | DIO_SOD323 |
| D15 | DIODE_PESD_DIO_DFN0402_TPD1E10B | TPD1E10B06DPY | DIO_DFN0402 |
| D16 | DIODE_TVS_DUAL_DIO_SMC_SMCJ64CA | SMCJ64CA | DIO_SMC |
| F1 | FUSE_FUSE_1206_5A | 5A | FUSE_1206 |
| FB1 | INDUCTOR_FERRITE_IND0402_60E | 60E | IND0402 |
| FB2 | INDUCTOR_FERRITE_IND0402_60E | 60E | IND0402 |
| FB3 | INDUCTOR_FERRITE_IND0402_60E | 60E | IND0402 |
| FB4 | INDUCTOR_FERRITE_IND0402_60E | 60E | IND0402 |
| FL1 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL2 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL3 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL4 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL5 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL6 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL7 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL8 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL9 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| FL10 | EMIFILTER_IND_EMIFIL_BLM21P_080 | 30E | EMIFIL_BLM21P_0805_1-1 |
| J1 | CON_USB-B_5_4SH_CON_USBB5_10501 | CON_USB-B_5_F | CON_USBB5_105017-01_S_R_S_2-6 |
| J2 | CON_PWRJACK3_RAPC722_CON_PWRJAC | RAPC722 | CON_PWRJACK3_RAPC722_P_R_T |
| J3 | CON_PMC_30X2_M_CON_PMC2X30_QTH- | CON_PMC_2X30_M | CON_PMC2X30_QTH-30_P_S_S_4-3 |
| J4 | CON_USB-B_5_4SH_CON_USBB5_10501 | CON_USB-B_5_F | CON_USBB5_105017-01_S_R_S_2-6 |
| J5 | CON_SDCARD_8_DM3AT-SF-PEJM_CON_ | DM3AT-SF-PEJM5 | CON_SD8_DM3AT-SF_S_R_S_1-7 |
| J6 | CON_RJ45-14_LPJG16414A4NL_CON_R | CON_RJ45-14_LPJG16414A4NL | CON_RJ45-14_LPJG16414A4NL_S_R_T_13-5 |
| L1 | INDUCTOR_IND_NRS5020_200X200_SM | 4.7uH | IND_NRS5020_200X200_SMD_3-1 |
| L2 | INDUCTOR_IND_NRS5020_200X200_SM | 4.7uH | IND_NRS5020_200X200_SMD_3-1 |
| L3 | INDUCTOR_IND_IHLP2020CZ_230X215 | 10uH | IND_IHLP2020CZ_230X215_SMD |
| L4 | INDUCTOR_IND_IHLP2020CZ_230X215 | 10uH | IND_IHLP2020CZ_230X215_SMD |
| LD1 | DIODE_LED_LED_0603_0-8_LTST-C19 | LTST-C190KGKT | LED_0603_0-8 |
| LD2 | DIODE_LED_LED_0603_0-8_LTST-C19 | LTST-C190KGKT | LED_0603_0-8 |
| LD3 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD4 | DIODE_LED_LED_0603_0-8_LTST-C19 | LTST-C190KGKT | LED_0603_0-8 |
| LD5 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD6 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD7 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD8 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD9 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD10 | DIODE_LED_LED_0603_0-8_LTST-C19 | LTST-C190KGKT | LED_0603_0-8 |
| LD11 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD12 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD13 | DIODE_LED_LED_0603_LTST-C190KRK | LTST-C190KRKT | LED_0603 |
| LD14 | DIODE_LED_LED_0603_0-8_LTST-C19 | LTST-C190KGKT | LED_0603_0-8 |
| LD15 | DIODE_LED_LED_0603_LTST-C191KGK | LTST-C191KGKT | LED_0603 |
| Q1 | NPN_BEC_TO_SOT23-123_MMBT3904-7 | MMBT3904-7-F | TO_SOT23-123 |
| RA1 | RESARR_ISO4_RESA_EXB28V_0402-4_ | 22E | RESA_EXB28V_0402-4_0-5 |
| RA2 | RESARR_ISO4_RESA_EXB28V_0402-4_ | 22E | RESA_EXB28V_0402-4_0-5 |
| RA3 | RESARR_ISO4_RESA_EXB28V_0402-4_ | 22E | RESA_EXB28V_0402-4_0-5 |
| RA4 | RESARR_ISO4_RESA_EXB28V_0402-4_ | 22E | RESA_EXB28V_0402-4_0-5 |
| RA5 | RESARR_ISO4_RESA_741C_0402-4_0- | 51E | RESA_741C_0402-4_0-5 |
| RA6 | RESARR_ISO4_RESA_741C_0402-4_0- | 51E | RESA_741C_0402-4_0-5 |
| RA7 | RESARR_ISO4_RESA_741C_0402-4_0- | 51E | RESA_741C_0402-4_0-5 |
| RA8 | RESARR_ISO4_RESA_741C_0402-4_0- | 51E | RESA_741C_0402-4_0-5 |
| RA9 | RESARR_ISO4_RESA_741C_0402-4_0- | 51E | RESA_741C_0402-4_0-5 |
| RA10 | RESARR_ISO4_RESA_741C_0402-4_0- | 51E | RESA_741C_0402-4_0-5 |
| S1 | SW8_TDA04H0SB1R_SW8_50X300_245X | TDA04H0SB1R | SW8_50X300_245X245_SMD |
| SW1 | SW6_219-3MST_SW6_4161311608_210 | 4.16131E+11 | SW6_4161311608_210X230_SMD_2-7 |
| SW2 | SW8_218-8LPSTR_SW8_218-8LPST_45 | 218-8LPSTR | SW8_218-8LPST_450X230_SMD_2-7 |
| SW3 | SW3_1103_SW3_500SSP1S2M2_510X26 | 500SSP1S2M2QEA | SW3_500SSP1S2M2_510X260_TH_15-1 |
| SW4 | SW4_1571634_SW4_84X163_170X130_ | PTS810 SJG 250 SMTR LFS | SW4_84X163_170X130_SMD |
| SW5 | SW4_1571634_SW4_84X163_170X130_ | PTS810 SJG 250 SMTR LFS | SW4_84X163_170X130_SMD |
| SW6 | SW4_1571634_SW4_84X163_170X130_ | PTS810 SJG 250 SMTR LFS | SW4_84X163_170X130_SMD |
| SW7 | SW4_1571634_SW4_84X163_170X130_ | PTS810 SJG 250 SMTR LFS | SW4_84X163_170X130_SMD |
| TP32 | TESTPOINT_TP_40X80_THRU HOLE | THRU HOLE | TP_40X80 |
| TP33 | TESTPOINT_TP_40X80_THRU HOLE | THRU HOLE | TP_40X80 |
| U1 | LM26400YMHX_HTSSOP16_ETSSOP16_2 | LM26400YMHX | ETSSOP16_25-59_200X180 |
| U2 | LM26400YMHX_HTSSOP16_ETSSOP16_2 | LM26400YMHX | ETSSOP16_25-59_200X180 |
| U3 | FT4232H _LQFP64_LQFP64_19-68_39 | FT4232HL | LQFP64_19-68_390X390 |
| U4 | 93LC56B-I/SN_SOIC8_SOIC8_1-8_93 | 93LC56C-I/SN | SOIC8_1-8 |
| U5 | TPS7A8101DRB_SON8_SON8_25-59_12 | TPS7A8101DRBT | SON8_25-59_120X120 |
| U6 | DP83867IRPAPT_HTQFP64_EQFP64_19 | DP83867IRPAPT | EQFP64_19-68_400X400 |
| U7 | AT24CM02-SSHD_SOIC8_SOIC8_AT24C | AT24CM02 | SOIC8 |
| U8 | OSC6_ASEMPXX_OSC6_ASEMP_130X100 | 100.000MHz | OSC6_ASEMP_130X100_SMD_0-9 |
| U9 | OSC6_ASEMPXX_OSC6_ASEMP_130X100 | 100.000MHz | OSC6_ASEMP_130X100_SMD_0-9 |
| U10 | MT41J128M8JP-125_FBGA78_FBGA78_ | MT41K1G8SN-125 IT:A | FBGA78_31-49_360X520_1-2 |
| U11 | MT41J128M8JP-125_FBGA78_FBGA78_ | MT41K1G8SN-125 IT:A | FBGA78_31-49_360X520_1-2 |
| U12 | LFE5UM-85F-7BG381I_CSBGA381_CAB | LFE5UM-85F-8BG381I | CABGA381_31-49_670X670_1-8 |
| U13 | SN74LVC1G08DRLR_SOT553-5_SOT553 | SN74LVC1G08DRLR | SOT553-5_0-6 |
| U14 | MT25QL128ABA8ESF_SOIC16_SOIC16_ | MT25QL128ABA8ESF-0SIT | SOIC16_W_2-7 |
| U15 | FT2232H_LQFP64_LQFP64_19-68_400 | FT2232HL | LQFP64_19-68_400X400 |
| U16 | TPD6E001RSE_UQFN10_UQFN10_19-68 | TPD6E001RSER | UQFN10_19-68_80X60_0-6 |
| U17 | TPD4E05U06DQAR_USON10_USON10_TP | TPD4E05U06QDQARQ1 | USON10_TPD4E05U_40X100_0-6 |
| U18 | TPD4E05U06DQAR_USON10_USON10_TP | TPD4E05U06QDQARQ1 | USON10_TPD4E05U_40X100_0-6 |
| U19 | TPS51200DRCT_SON10_SON10_19-68_ | TPS51200DRCT | SON10_19-68_125X125_1 |
| U20 | 93LC56B-I/SN_SOIC8_SOIC8_1-8_93 | 93LC56C-I/SN | SOIC8_1-8 |
| Y1 | CRY4_13_XTAL4_86-61X62-99_130X1 | 12.000MHz | XTAL4_86-61X62-99_130X105_SMD_0-6 |
| Y2 | CRY_XTAL_ABM3_205X130_SMD_1-4_2 | 25.000MHz | XTAL_ABM3_205X130_SMD_1-4 |
| Y3 | CRY4_13_XTAL4_86-61X62-99_130X1 | 12.000MHz | XTAL4_86-61X62-99_130X105_SMD_0-6 |
