| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT1001 | C898_ANT_2PAD-2X3-1P9556_C898_A | C898_ANT | 2PAD-2X3-1P9556 |
| D701 | DIODE2_1-1G1A_1SS381 | 1SS381 | 1-1G1A |
| D801 | BACKLIGHT_LED_LED_0603_MS-PM160 | MS-PM1608SBKC | LED_0603 |
| D802 | BACKLIGHT_LED_LED_0603_MS-PM160 | MS-PM1608SBKC | LED_0603 |
| D803 | BACKLIGHT_LED_LED_0603_MS-PM160 | MS-PM1608SBKC | LED_0603 |
| D804 | BACKLIGHT_LED_LED_0603_MS-PM160 | MS-PM1608SBKC | LED_0603 |
| D901 | TVS_DFN1006-2L_DNP | DNP | DFN1006-2L |
| J601 | A-MUB05F-112_ALP-USB5-B05-1_A-M | A-MUB05F-112 | ALP-USB5-B05-1 |
| J602 | SPEAKER_2PAD-MIN_DXSYD302038P-0 | DXSYD302038P-016 | 2PAD-MIN |
| J603 | SPK_2PAD-MIN_DXRYD150623P-001 | DXRYD150623P-001 | 2PAD-MIN |
| J606 | MIC_2PAD-MIN_FTC4015SC2-42L10 | FTC4015SC2-42L10 | 2PAD-MIN |
| J702 | BT08-CR03AB-08_0_BTR-103D226_BT | BT08-CR03AB-08_0 | BTR-103D226 |
| J703 | KWS6193C1R_ALP-SIML615-18A_A-SI | A-SIM06X-132 | ALP-SIML615-18A |
| J704 | C1027B544F_2PAD-MIN_C1027B838F | C1027B838F | 2PAD-MIN |
| J707 | TFC006-LK-1_TFS07X-8K30010-01_T | TFS07X-8k30010-01 | TFS07X-8K30010-01 |
| J801 | LCD_C7_LCD_C7_LCD_M95 | LCD_M95 | LCD_C7 |
| J802 | CAMA_M95_SP0828_SP0820 | SP0820 | SP0828 |
| J1001 | LED_2PAD-MIN_ZY-503WC56 | ZY-503WC56 | 2PAD-MIN |
| J1102 | MM8430-2610_0_RF_S19_PAD_RF_CON | RF_con | RF_S19_PAD |
| L401 | INDUCTOR_MINI-0402_15NH | 15nH | MINI-0402 |
| L405 | INDUCTOR_MINI-0402_15NH | 15nH | MINI-0402 |
| L601 | 1KOHMAT100MHZ_MINI-0402_BLM18EG | BLM18EG221SN1 | MINI-0402 |
| L1001 | BLM15AG601SN1_MINI-0402_BLM15AG | BLM15AG601SN1 | MINI-0402 |
| L1103 | INDUCTOR_MINI-0402_6.8NH | 6.8nH | MINI-0402 |
| L1104 | INDUCTOR_MINI-0402_DNP | DNP | MINI-0402 |
| L1105 | INDUCTOR_MINI-0402_DNP | DNP | MINI-0402 |
| L1106 | INDUCTOR_MINI-0402_DNP | DNP | MINI-0402 |
| L1109 | INDUCTOR_MINI-0402_DNP | DNP | MINI-0402 |
| LP1001 | INDUCTOR_POWER_LPO3310_LQH3NPG0 | 4.7uH | LPO3310_LQH3NPG0 |
| Q4 | EMX1_EMT6_EMX1 | EMX1 | EMT6 |
| Q702 | NPN_EBC_123_SOT-416_2SC4617 | 2SC4617 | SOT-416 |
| Q801 | NPN_EBC_123_SOT-416_2SC4617 | 2SC4617 | SOT-416 |
| Q1002 | EMX1_EMT6_EMX1 | EMX1 | EMT6 |
| RT1101 | THERMISTER_MINI-0402_10K | 10K | MINI-0402 |
| S723 | BUTTON_KEY_0_Q100_SW_LED_SW | LED_SW | Q100_SW |
| S823 | BUTTON_KEY_KEYPAD-5P-1P8-1P5-P5 | Key2_C898 | KEYPAD-5P-1P8-1P5-P5 |
| T100 | T100_THC_1R7_T100 | T100 | THC_1R7 |
| TP203 | TEST_POINT_TP-1P6MM_TESTPOINT | TestPoint | TP-1P6MM |
| TP205 | TEST_POINT_TP-1P6MM_TESTPOINT | TestPoint | TP-1P6MM |
| TP206 | TEST_POINT_TP-1P6MM_TESTPOINT | TestPoint | TP-1P6MM |
| TP207 | TEST_POINT_TP-P5MM_TINY_PAD | TINY_PAD | TP-P5MM |
| TP209 | TEST_POINT_TP-1P6MM_TESTPOINT | TestPoint | TP-1P6MM |
| TP214 | TEST_POINT_TP-1P6MM_TESTPOINT | TestPoint | TP-1P6MM |
| TP216 | TEST_POINT_TP-1P3MM_TESTPOINT | TestPoint | TP-1P3MM |
| TP221 | TEST_POINT_TP-1P6MM_TESTPOINT | TestPoint | TP-1P6MM |
| TP222 | TEST_POINT_TP-1P6MM_TESTPOINT | TestPoint | TP-1P6MM |
| TP310 | TEST_POINT_TP-1P3MM_TESTPOINT | TestPoint | TP-1P3MM |
| TP311 | TEST_POINT_TP-1P3MM_TESTPOINT | TestPoint | TP-1P3MM |
| TP312 | TEST_POINT_TP-1P3MM_TESTPOINT | TestPoint | TP-1P3MM |
| TP313 | TEST_POINT_TP-1P3MM_TESTPOINT | TestPoint | TP-1P3MM |
| TP901 | TEST_POINT_TP-P5MM_TINY_PAD | TINY_PAD | TP-P5MM |
| TP1004 | TEST_POINT_TP-1P3MM_TESTPOINT | TestPoint | TP-1P3MM |
| U201 | 1 | CBP1855 | CBP1855 |
| U301 | MX25L1606E_WSON8_VSOP8_W25Q128F | W25Q128FWPIM | WSON8_VSOP8 |
| U601 | AW8733_AW8743_AW8733 | AW8733 | AW8743 |
| U901 | CPM1000V1_CPM1000-POD_CPM1000 | CPM1000 | CPM1000-POD |
| U1104 | UN06A0200L_ACPM-5201_ACPM-5005 | ACPM-5005 | ACPM-5201 |
| U1106 | FAR-D5PE-881M50-P3EZ_1_DUP1814_ | HDDB05NSB-B11 | DUP1814 |
| V610 | VARISTOR_MINI-0402_AVLC5S02050 | AVLC5S02050 | MINI-0402 |
| V614 | VARISTOR_DFN1006-2L_ES0402V014C | ES0402V014CT | DFN1006-2L |
| V615 | VARISTOR_DFN1006-2L_ES0402V014C | ES0402V014CT | DFN1006-2L |
| V616 | VARISTOR_MINI-0402_SDV1005E140C | SDV1005E140C400NPTF | MINI-0402 |
| V708 | VARISTOR_MINI-0402_ES0402V014CT | ES0402V014CT | MINI-0402 |
| V709 | VARISTOR_MINI-0402_ES0402V014CT | ES0402V014CT | MINI-0402 |
| V812 | VARISTOR_MINI-0402_AVLC5S02050 | AVLC5S02050 | MINI-0402 |
| V906 | VARISTOR_MINI-0402_ESD | ESD | MINI-0402 |
| Y401 | FA-238V_EXS00A-CS03843_EXS00A-C | EXS00A-CS03843-19.2MHz | EXS00A-CS03843 |
