| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT1 | PCB_ANT_MINI-ANT-TYPEB_PCB_ANT | PCB_ANT | MINI-ANT-TYPEB |
| C1 | CAP_C0402_15PF | 15pF | C0402 |
| C2 | CAP_C0402_15PF | 15pF | C0402 |
| C3 | CAP_C0402_1UF | 1uF | C0402 |
| C4 | CAP_C0402_10NF | 10nF | C0402 |
| C5 | CAP_C0402_10UF | 10uF | C0402 |
| C6 | CAP_C0402_0.1UF | 0.1uF | C0402 |
| C7 | CAP_C0402_0.1UF | 0.1uF | C0402 |
| C8 | CAP_C0402_TBD | TBD | C0402 |
| C9 | CAP_C0402_TBD | TBD | C0402 |
| C10 | CAP_C0402_0.1UF | 0.1uF | C0402 |
| C11 | CAP_C0402_1UF | 1uF | C0402 |
| C12 | CAP NP_C0402_1UF 16V | 1uF 16V | C0402 |
| C13 | CAP_C0402_0.1UF | 0.1uF | C0402 |
| C14 | CAP-2.2UF-400V-8*10_CAP8-12_4.7UF-400V | 4.7uF-400V | CAP8-12 |
| C15 | C0603_0_C0603_1UF/16V | 1uF/16V | C0603 |
| C16 | CAP-2.2UF-400V-8*10_CAP8-12_680UF_16V | 680uF_16V | CAP8-12 |
| C22 | C0603_0_C0603_0.1UF-25V | 0.1uF-25V | C0603 |
| C23 | C0603_0_C0603_10UF-25V | 10uF-25V | C0603 |
| C24 | C0603_0_C0603_10UF-25V | 10uF-25V | C0603 |
| CX1 | CAP_X2_CAP_13MM_0.1UF/275V | 0.1uF/275V | X2_CAP_13MM |
| D1 | DIODE BI-DIR TRIG_SOD-523_PESD3V3S1BA-N | PESD3V3S1BA-N | SOD-523 |
| D2 | DIODE_0_SOD123_DIODE | Diode | SOD123 |
| D3 | DIO-1N4148-SOD123F_0_DO-214AC_A7 | A7 | DO-214AC |
| D4 | DIO-1N4148-SOD123F_0_DO-214AC_A7 | A7 | DO-214AC |
| D5 | LED-4-RG-0805_LED_0805_4P_IC_RG-0805 | RG-0805 | LED_0805_4P |
| D6 | BZX84C24/SOT_0_SOD123_BZT52C3V3 | BZT52C3V3 | SOD123 |
| D7 | DIO-1N4148-SOD123F_0_DO-214AC_A7 | A7 | DO-214AC |
| D8 | DIO-1N4148-SOD123F_0_DO-214AC_A7 | A7 | DO-214AC |
| D9 | DIO-1N4148-SOD123F_0_SOD123_ES2J/SMA | ES2J/SMA | SOD123 |
| D10 | DIO-1N4148-SOD123F_0_SOD123_A7 | A7 | SOD123 |
| D11 | LED2_0_LED0805_RED | RED | LED0805 |
| J1 | CON6_HDR_TH_6P_100_VE_CON6 | CON6 | HDR_TH_6P_100_VE |
| J2 | HEADER 1_HOLE-1_5MM_HEADER 1 | HEADER 1 | HOLE-1_5MM |
| J4 | HEADER 1_HOLE-1_5MM_HEADER 1 | HEADER 1 | HOLE-1_5MM |
| J5 | HEADER 1_HOLE-1_5MM_HEADER 1 | HEADER 1 | HOLE-1_5MM |
| J6 | HEADER 1_HOLE-1_5MM_HEADER 1 | HEADER 1 | HOLE-1_5MM |
| L1 | INDUCTOR_L0402_2.0NH | 2.0nH | L0402 |
| L2 | INDUCTOR_L0402_TBD | TBD | L0402 |
| L3 | IND-2.2UH-0805_INDR9-12_150UH | 150uH | INDR9-12 |
| Q1 | A44 NPN_SOT23-3_9013 | 9013 | SOT23-3 |
| Q2 | NPN_SOT23-3_IC_8050 | 8050 | SOT23-3 |
| Q3 | NPN_SOT23-3_IC_8050 | 8050 | SOT23-3 |
| R1 | RESISTOR_0_R0402_0 | 0 | R0402 |
| R2 | RESISTOR_0_R0402_499 | 499 | R0402 |
| R3 | RES_R0402_10K | 10K | R0402 |
| R4 | RES_R0402_10K | 10K | R0402 |
| R5 | RES_R0402_10K | 10K | R0402 |
| R6 | RES_R0402_10K | 10K | R0402 |
| R7 | RES_R0603_4.7K 5% | 4.7K 5% | R0603 |
| R8 | RES_R0603_10K 5% | 10K 5% | R0603 |
| R9 | RES_R1206_0.4R | 0.4R | R1206 |
| R10 | RES_R1206_1.5K | 1.5K | R1206 |
| R11 | RES_R1206_0.4R | 0.4R | R1206 |
| R12 | RES_R0402_1K | 1K | R0402 |
| R13 | R1005_0_R0402_560R-5% | 560R-5% | R0402 |
| R14 | RES_RES_TH_3_VE_10R | 10R | RES_TH_3_VE |
| R15 | RES_R0402_1K | 1K | R0402 |
| R16 | RES_R0402_1K | 1K | R0402 |
| R17 | R1005_0_R0402_3K-5% | 3K-5% | R0402 |
| REL1 | RELAY_HF3FF_HF3FF | HF3FF | HF3FF |
| RT1 | MOV-14D471_RES_TH_5_RO_7D471 | 7D471 | RES_TH_5_RO |
| U1 | X1_1_XTAL3225_40MHZ(10PPM) | 40MHz(10ppm) | XTAL3225 |
| U2 | ESP32-C3_QFN_32_EP5X5_ESP32-C3 | ESP32-C3 | QFN_32_EP5X5 |
| U3 | CHIP-BP2525F_SOT33_5A_BP2525F | BP2525F | SOT33_5A |
| U4 | LM111733_SOT223_AMS111733 | AMS111733 | SOT223 |
