| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| D2 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| D3 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| D4 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| D5 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D6 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D7 | BZX84C6V8LT1G_SOT23_6.8V | 6.8V | SOT23 |
| D8 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D9 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D10 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D11 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D12 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D13 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D14 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D15 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D16 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D17 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D18 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D19 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| D20 | D_DO_214AC_SMA_B130L-13-F | B130L-13-F | DO_214AC_SMA |
| D21 | D_DO_214AC_SMA_B130L-13-F | B130L-13-F | DO_214AC_SMA |
| D22 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| D36 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D37 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D38 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D39 | TPD1E05U06DPY_D0402_1C2A_TPD1E0 | TPD1E05U06DPYR | D0402_1C2A |
| D40 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D41 | D_SCHOTTKY_SOD_323_PMEG3010CEJ | PMEG3010CEJ | SOD_323 |
| D42 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D43 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D44 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D45 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D46 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D47 | ESD122DMX_X2SON3_0D3_0_6X1X0_4M | ESD122DMXR | X2SON3_0D3_0_6X1X0_4MM |
| D48 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| D49 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| D50 | D_SCHOTTKY_SOD_323_PMEG3010CEJ | PMEG3010CEJ | SOD_323 |
| D51 | D_SCHOTTKY_SOD_323_PMEG3010CEJ | PMEG3010CEJ | SOD_323 |
| D52 | DIODE TVS BI-DIR_D0402_TPD1E1B0 | TPD1E1B04DPYR | D0402 |
| J1 | HEADER_4+2P_HEADER4_2P_1D25_SMD | Header 4P 1.25MM | HEADER4_2P_1D25_SMD_10X5_3X3_6MM |
| J2 | SIP3_CON3B35X60_B3B-ZR(LF)(SN) | B3B-ZR(LF)(SN) | CON3B35X60 |
| J3 | SIP3_CON3B35X60_B3B-ZR(LF)(SN) | B3B-ZR(LF)(SN) | CON3B35X60 |
| J4 | PCIE_M.2_KEY E_75PIN_CON_MINIPE | AS0BC27-S40BE-7H | CON_MINIPEX_067_SMT_RA_M2_KEYE_C |
| J5 | USB3.0_TYPE C_24+4P_USB_MTCONN_ | UBF31-2347-1 | USB_MTCONN_UBF31-2347-1 |
| J6 | POWER JACK_CONN3-PWR-DC630_DC63 | DC630-20D01 | CONN3-PWR-DC630 |
| J7 | MINI DISPLAY PORT_20PIN_DP20_0D | 3VM11201-D730-7H | DP20_0D6_9_8X11_8X5_9MM |
| J8 | USB3.0_DUAL TYPE A_18+4P_USB3_1 | UAA111C-84161-4H | USB3_1_2D0_17_5X13_6X15_69MM |
| J9 | RJ45_LPJG0933HENL_RJ45_18P_LPJG | LPJG0933HENL | RJ45_18P_LPJG0801HBNL |
| J10 | HEADER 2X8 1357_HEADER2X8_SMD_1 | Header 2x8 1.27mm | HEADER2X8_SMD_1D27 |
| J11 | HEADER 2X5_1_CONNECT10_1D27_12_ | TC2050-IDC | CONNECT10_1D27_12_4X6_7MM |
| J12 | MICROSD CARD_10+4P_MICRO_SD_15X | YL004-030-001 | MICRO_SD_15X14_3X1_8MM |
| J13 | FPC 22+2P_FPC22_0D5_15_4X5_25X2 | FPC 22P 0.5mm | FPC22_0D5_15_4X5_25X2MM_0D5_DX_NPWB |
| J15 | FPC 22+2P_FPC22_0D5_15_4X5_25X2 | FPC 22P 0.5mm | FPC22_0D5_15_4X5_25X2MM_0D5_DX_NPWB |
| J16 | FPC 22+2P_FPC22_0D5_15_4X5_25X2 | FPC 22P 0.5mm | FPC22_0D5_15_4X5_25X2MM_0D5_DX_NPWB |
| L1 | CL_L2012_90R | 90R | L2012 |
| L2 | L_L7572_XAL7070_1.8UH | 1.8uH | L7572_XAL7070 |
| LED5 | SINGLE LED_LED0603_GREEN | Green | LED0603 |
| LED6 | SINGLE LED_LED0603_GREEN | Green | LED0603 |
| MH1 | MHOLE_MTGH200C125D_PL_HOLE 3.17 | Hole 3.175MM | MTGH200C125D_PL |
| MH2 | MHOLE_MTGH200C125D_PL_HOLE 3.17 | Hole 3.175MM | MTGH200C125D_PL |
| MH3 | MHOLE_MTGH200C125D_PL_HOLE 3.17 | Hole 3.175MM | MTGH200C125D_PL |
| MH4 | MHOLE_PTH_4_45MM_6D5_SMSR3066MT | SMSR3066MTJ | PTH_4_45MM_6D5 |
| MH5 | MHOLE_PTH_4_45MM_6D5_SMSR3066MT | SMSR3066MTJ | PTH_4_45MM_6D5 |
| MH6 | MHOLE_PTH_4_45MM_6D5_SMSR3066MT | SMSR3066MTJ | PTH_4_45MM_6D5 |
| MH7 | MHOLE_PTH_4_45MM_6D5_SMSR3066MT | SMSR3066MTJ | PTH_4_45MM_6D5 |
| MH8 | MHOLE_PTH_4_2MM_5D8_2E0BC21-A40 | 2E0BC21-A40TP-7H | PTH_4_2MM_5D8 |
| MH9 | MHOLE_MTGH200C125D_PL_HOLE 3.17 | Hole 3.175MM | MTGH200C125D_PL |
| P8 | HEADER 2X23_HEADER2X23P_2D54_SM | Header 2x23 2.54mm | HEADER2X23P_2D54_SMD_PTH |
| P9 | HEADER 2X25_SPE_HEADER2X25P_2D5 | Header 2x25 2.54mm | HEADER2X25P_2D54_SMD_PTH |
| Q1 | PMOS_123_SOT23_IRLML6402TRPBF | IRLML6402TRPBF | SOT23 |
| Q2 | NMOS_5P_1S2S3S4G5D_VSON8_0D65_3 | CSD17575Q3 | VSON8_0D65_3_3X3_3X1MM |
| Q3 | NMOS_5P_1S2S3S4G5D_VSON8_0D65_1 | CSD17308Q3 | VSON8_0D65_3_3X3_3X1MM |
| Q4 | NMOS_123_SOT-323-3_BSS138W | BSS138W | SOT-323-3 |
| Q5 | NMOS_123_SOT-323-3_BSS138W | BSS138W | SOT-323-3 |
| Q6 | NMOS_123_SOT-323-3_BSS138W | BSS138W | SOT-323-3 |
| U1 | TPS2121_VQFN12_0D5_2X2_5X1MM_TP | TPS2121RUXR | VQFN12_0D5_2X2_5X1MM |
| U2 | TXS0104E_QFN14_0D5_3_5X3_5X1MM_ | TXS0104ERGYR | QFN14_0D5_3_5X3_5X1MM |
| U3 | LM5141RGE_VQFN24_0D5_4X4X1MM_LM | LM5141RGER | VQFN24_0D5_4X4X1MM |
| U4 | TPS2561_VSON10_0D5_3X3X1MM_TPS2 | TPS2561DRCR | VSON10_0D5_3X3X1MM |
| U5 | TPS22918DBV_SOT23_6_TPS22918DBV | TPS22918DBVR | SOT23_6 |
| U6 | SN74LVC1G08DCKR_DCK5_2P15X1P4_S | SN74LVC1G08DCKR | DCK5_2P15X1P4 |
| U7 | MEM_24LC32_SOT23-5_SOT23-5_24FC | 24FC04HT-I/OT | SOT23-5 |
| U8 | MAX6817EUT_SOT23_6_MAX6817EUT+T | MAX6817EUT+T | SOT23_6 |
| U9 | TPS74801DRCR_VSON10_0D5_3X3X1MM | TPS74801DRCR | VSON10_0D5_3X3X1MM |
| U10 | TPS3808G33DBV_SOT23_6_TPS3808G3 | TPS3808G33DBVR | SOT23_6 |
| U11 | SN74LVC1G07DCK_DCK5_2P15X1P4_SN | SN74LVC1G07DCKR | DCK5_2P15X1P4 |
| U12 | SN74LVC1G07DCK_DCK5_2P15X1P4_SN | SN74LVC1G07DCKR | DCK5_2P15X1P4 |
| U13 | TPD4E05U06DQAR_USON10_0D5_2D5X1 | TPD4E05U06DQAR | USON10_0D5_2D5X1X0D5MM |
| U14 | SN74LVC2G74_SO8_0D5_2_3X2X0_9MM | SN74LVC2G74DCUR | SO8_0D5_2_3X2X0_9MM |
| U15 | DP83867CRRGZ_QFN48_0D5_7X7MM_DP | DP83867CRRGZR | QFN48_0D5_7X7MM |
| U16 | SN74LVC1G08DCKR_DCK5_2P15X1P4_S | SN74LVC1G08DCKR | DCK5_2P15X1P4 |
| U17 | TPD4E05U06DQAR_USON10_0D5_2D5X1 | TPD4E05U06DQAR | USON10_0D5_2D5X1X0D5MM |
| U18 | TPS74801DRCR_VSON10_0D5_3X3X1MM | TPS74801DRCR | VSON10_0D5_3X3X1MM |
| U19 | TDA4VM_FCBGA827_0D8_24X24X2_8MM | TDA4VM88TGBALFR | FCBGA827_0D8_24X24X2_8MM |
| U20 | TUSB8041_QFN64_0D5_9X9X1MM_TUSB | TUSB8041RGCR | QFN64_0D5_9X9X1MM |
| U21 | TUSB322IRWBR_X2QFN12_0D4_1_6X1_ | TUSB322IRWBR | X2QFN12_0D4_1_6X1_6X0_4MM |
| U22 | TPS2553DBV_SOT23_6_TPS2553DBVR | TPS2553DBVR | SOT23_6 |
| U23 | TPS22965DSG_WSON8_0D5_2X2X0_8MM | TPS22965DSGR | WSON8_0D5_2X2X0_8MM |
| U24 | SN74AUP1T17DCKR_SC70_5_SN74LVC1 | SN74LVC1G17DCKR | SC70_5 |
| U25 | LPDDR4_X32_VFBGA200_BGA200_0D65 | Q3222PM1WDGTK-U | BGA200_0D65_15X10X1MM |
| U26 | EMMC_5_1_153-BALL_WFBGA_BGA153_ | EMMC16G-TB29-PZ90 | BGA153_P14_P5_11P5X13 |
| U27 | SN74LVC1G07DCK_DCK5_2P15X1P4_SN | SN74LVC1G07DCKR | DCK5_2P15X1P4 |
| U28 | TPS62813-Q1_VQFNHR9_0D55_3X2X1M | TPS62813QWRWYRQ1 | VQFNHR9_0D55_3X2X1MM |
| U29 | TPS65941-Q1_VQFN56_0D5_8X8X0_9M | TPS65941111RWERQ1 | VQFN56_0D5_8X8X0_9MM |
| U30 | TPS65941-Q1_VQFN56_0D5_8X8X0__1 | TPS65941213RWERQ1 | VQFN56_0D5_8X8X0_9MM |
| U31 | SN74LVC2G241_U_8_DCU_SN74LVC2G2 | SN74LVC2G241DCUR | U_8_DCU |
| U32 | TXS0108E_VQFN-20_TXB0108RGYR | TXB0108RGYR | VQFN-20 |
| U33 | SN74LVC2G241_U_8_DCU_SN74LVC2G2 | SN74LVC2G241DCUR | U_8_DCU |
| U34 | SN74CBTLV1G125DBVR_SOT23-5_SN74 | SN74CBTLV1G125DBVR | SOT23-5 |
| X1 | XTAL_4P_X4_SMD_2_5X2_0MM_25MHZ | 25MHz 18pF | X4_SMD_2_5X2_0MM |
| X2 | XTAL_4P_X4_SMD_2_5X2_0MM_19.200 | 19.2000MHz 8PF | X4_SMD_2_5X2_0MM |
| X3 | XTAL_4P_X4_SMD_2_5X2_0MM_22.579 | 22.5792MHz 8PF | X4_SMD_2_5X2_0MM |
| X4 | XTAL_4P_X4-SMD-3_2X2_5X1_0MM_24 | 24MHz 18pF | X4-SMD-3_2X2_5X1_0MM |
| X5 | XTAL_2P_X2_SMD_3_2X1_5MM_32.768 | 32.768kHz 12.5pF | X2_SMD_3_2X1_5MM |
