| Name | Part Type | PCB Decal | Value |
| ANT1 | ANTENNA_11 | P-JS-TTB25 | ANT / 92138100010F |
| ANT2 | POGO_2_2MM_0_5MM | POGO_2_2MM_0_5MM | ANT / 92138100010F/ NC |
| ANT3 | POGO_2_2MM_0_5MM | POGO_2_2MM_0_5MM | ANT / 92138100010F/ NC |
| ANT4 | POGO_2_2MM_0_5MM | POGO_2_2MM_0_5MM | ANT / 92138100010F/ NC |
| ANT9 | ANTENNA_11 | ANTENNA_11 | ANT / 92138100010F |
| ANT10 | ANTENNA_11 | ANTENNA_11 | ANT / 92138100010F |
| ANT11 | ANTENNA_11 | ANTENNA_11 | ANT / 92138100010F |
| ANT12 | ANTENNA_11 | ANTENNA_11 | ANT / 92138100010F |
| ANT13 | POGO_2_2MM_0_5MM | POGO_2_2MM_0_5MM | ANT / 92138100010F/ NC |
| ANT5002 | ANTENNA_11 | ANTENNA_11 | ANT / 92138100010F |
| B4701 | BED-0402-1K0 | 402 | 1K@100M |
| B5101 | RES-0402-4K70 | 402 | 0R |
| B5102 | RES-0402-4K70 | 402 | 0R |
| C9009 | C0402-4.7UF | C0402-4.7UF | 4.7uF / 6.3V |
| CON2 | SMT_2P_0_8MM | SMT_0_8MM_2P | SMTH_2P_1_25MM |
| CON4 | SMT_2P_0_8MM | SMT_0_8MM_2P | SMTH_2P_1_25MM |
| D1 | DS520-30LED02 | WBFBP-02C | PMEG3005EJ |
| D2103 | D_PZ3D4V2H | D_PZ3D4V2H | Zener_5.1V |
| D2201 | DS520-30LED02 | WBFBP-02C | PMEG3005EJ |
| D4601 | DS520-30LED02 | WBFBP-02C | PMEG3005EJ |
| E4910 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| F4701 | TRPX_/_TP2012-A1255DAT/LF | FILTER/SMD/LFD211G57ME3 | F09-TP2012A1255DAT |
| FB5 | BEAD_0603 | B0603 | BLM18PG300SN1 |
| FB6 | BEAD_0603 | B0603 | BLM18PG300SN1 |
| HOLE1 | PTH1.4 | TP30MIL | |
| HOLE2 | TP1.9 | TP3.502/1.905BAA | |
| HOLE3 | TP1.9 | TP3.502/1.905BAAA | |
| HOLE4 | TP1.9 | TP3.502/1.905BAC | |
| HOLE5 | TP1.9 | TP3.502/1.905 | |
| HOLE8 | TP1.9 | TP3.502/1.905BAB | |
| HOLE9 | TP1.9 | TP3.502/1.905BAD | |
| J1 | SMD_RF_CABLE | SDM_RF_CABL_CUP | |
| J2 | SMT_1MM_18P | SMT_1M_18P | BAR_SCAN |
| J4 | BTB-03F030-04 | BTB-03F030-04A | BTB-OK-03F030-04 |
| J5 | OK-06F060-40 | BTB-OK-06F060-04 | CON / 30 / 24-5804-030-000-829+ |
| J6 | BAR_SCAN | BAR_SCAN | BAR_SCAN |
| J7 | MAIN_BAT_3MM | MAIN_BAT_3MM | MAIN-BAT |
| J8 | TP | Y5B-6P-SMT | TP |
| J9 | TP | Y5B-6P-SMT | TP |
| J10 | TP | Y5B-6P-SMT | TP |
| J11 | SMD_RF_CABLE | SDM_RF_CABL_CUP | |
| J12 | TP | Y5B-6P-SMT | TP |
| J13 | MAIN_BAT_3MM | MAIN_BAT_3MM | MAIN-BAT |
| J14 | BAR_SCAN | BAR_SCAN | BAR_SCAN |
| J15 | SMT_1_25MM_5P_H | SMT_1_25MM_5P_H | SMTH_4P_1_25MM |
| J16 | 20369C3 | 20369C3 | |
| J17 | FH26-27S-0.3SHWA | FH26-27S-0.3SHWA | FH26S-025 |
| J18 | SMT_1_25MM_5P_H | SMT_1_25MM_5P_H | SMTH_4P_1_25MM |
| J19 | SMD_RF_CABLE | SDM_RF_CABL_CUP | |
| J21 | SMT_1_25MM_7P_H | SMT_1_25MM_7P | SMTH_4P_1_25MM |
| J145 | FH26-39S | FH26-39S-0_3SHW | FH26S-039 |
| J1701 | BTB-03F030-04 | BTB-03F030-04B | BTB-OK-03F030-04 |
| J5401 | CON-RF-SWITCH-MM8030 | CON-RF-SWITCH-MM8030 | |
| J5402 | 20369C3 | 20369C3 | |
| J5501 | CON-RF-SWITCH-MM8030 | CON-RF-SWITCH-MM8030 | |
| L1 | FERRITE_BEAD_SMD_0402 | L/IND/SMD/0603 | L / 160 / nH / 0603 |
| L2 | FERRITE_BEAD_SMD_0402 | L/IND/SMD/0603 | L / 160 / nH / 0603 |
| L3 | L_/_MDMK2020T1R0MM_/_SMD2520 | L/IND/SMD/2520 | PL / 2.2 / uH / 2520 |
| L5 | PL_/_1_/_UH_/_2520 | L/IND/SMD/DFE252010F | 1uH |
| L6 | IND0201P_4.3NH | IND0201 | NC |
| L7 | IND0201_NC | IND0201 | NC |
| L15 | L_/_MDMK2020T1R0MM_/_SMD2520 | L/IND/SMD/2520 | PL / 2.2 / uH / 2520 |
| L307 | B | B0402 | BLM15BB750SN1 |
| L308 | B | B0402 | BLM15BB750SN1 |
| L1300 | SL0201-5.6NH-+/-0.3NH-SDCL0603Q5N6ST02 | SL0201 | 5.6NH |
| L1303 | SL0201-6.8NH-+/-5%-SDCL0603Q6N8JT02 | SL0201 | 6.8NH |
| L1309 | SL0201-3.9NH-+/-0.3NH-SDCL0603Q3N9ST02 | SL0201 | 3.9NH |
| L1312 | SL0201-2.7NH-+/-0.3NH-SDCL0603Q2N7ST02 | SL0201 | 2.7NH |
| L1315 | SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02 | SL0201 | 3.3NH |
| L1318 | SL0201-2.7NH-+/-0.3NH-SDCL0603Q2N7ST02 | SL0201 | 2.7NH |
| L1321 | SL0201-2.2NH-+/-0.3NH-SDCL0603Q2N2ST02 | SL0201 | 2.2NH |
| L1324 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1326 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1327 | SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02 | SL0201 | 2.4NH |
| L1330 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1331 | SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02 | SL0201 | 3.0NH |
| L1332 | SL0201-6.2NH-+/-0.3NH-SDCL0603Q6N2ST02 | SL0201 | 6.2NH |
| L1334 | SL0201-10NH-+/-5%-SDCL0603Q10NJT02 | SL0201 | 10NH |
| L1335 | SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02 | SL0201 | 3.0NH |
| L1338 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1340 | SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02 | SL0201 | 3.0NH |
| L1341 | SL0201-7.5NH-+/-5%-SDCL0603Q7N5JT02 | L0201 | 7.5NH |
| L1343 | SL0201-6.8NH-+/-5%-SDCL0603Q6N8JT02 | SL0201 | 6.8NH |
| L1344 | SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02 | SL0201 | 3.0NH |
| L1354 | SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02 | SL0201 | 2.4NH |
| L1411 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1412 | SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02 | SL0201 | 2.4NH |
| L1420 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1426 | SL0201-15NH-+/-5%-SDCL0603Q15NJT02 | SL0201 | 15NH |
| L1429 | SL0201-6.2NH-+/-0.3NH-SDCL0603Q6N2ST02 | SL0201 | 6.2NH |
| L1431 | SL0201-33NH-+/-5%-SDCL0603Q33NJT02 | SL0201 | 33NH |
| L1432 | SL0201-15NH-+/-5%-SDCL0603Q15NJT02 | SL0201 | 15NH |
| L1433 | SL0201-1.8NH-+/-0.3NH-SDCL0603Q1N8ST02 | SL0201 | 1.8NH |
| L1438 | SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02 | SL0201 | 4.3NH |
| L1441 | SL0201-5.6NH-+/-0.3NH-SDCL0603Q5N6ST02 | SL0201 | 5.6NH |
| L1442 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1444 | SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02 | SL0201 | 3.3NH |
| L1445 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1446 | SL0201-6.2NH-+/-0.3NH-SDCL0603Q6N2ST02 | SL0201 | 6.2NH |
| L1447 | SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02 | SL0201 | 4.3NH |
| L1448 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1449 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1450 | SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02 | SL0201 | 2.4NH |
| L1453 | SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02 | SL0201 | 4.3NH |
| L1454 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1456 | SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02 | SL0201 | 3.3NH |
| L1458 | SL0201-5.1NH-+/-0.3NH-SDCL0603Q5N1ST02 | SL0201 | 5.1NH |
| L1459 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1460 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1461 | SL0201-6.2NH-+/-0.3NH-SDCL0603Q6N2ST02 | SL0201 | 6.2NH |
| L1462 | SL0201-2.7NH-+/-0.3NH-SDCL0603Q2N7ST02 | SL0201 | 2.7NH |
| L1464 | SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02 | SL0201 | 3.0NH |
| L1465 | SL0201-5.6NH-+/-0.3NH-SDCL0603Q5N6ST02 | SL0201 | 5.6NH |
| L1466 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1468 | SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02 | SL0201 | 3.0NH |
| L1469 | SL0201-1.8NH-+/-0.3NH-SDCL0603Q1N8ST02 | SL0201 | 1.8NH |
| L1471 | SL0201-6.8NH-+/-5%-SDCL0603Q6N8JT02 | SL0201 | 6.8NH |
| L1472 | SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02 | SL0201 | 4.3NH |
| L1473 | SL0201-27NH-+/-5%-SDCL0603Q27NJT02 | SL0201 | 27NH |
| L1474 | SL0201-15NH-+/-5%-SDCL0603Q15NJT02 | SL0201 | 15NH |
| L1508 | SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02 | SL0201 | 2.4NH |
| L1511 | SL0201-NC | SL0201 | NC |
| L1513 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1514 | SL0201-NC | SL0201 | NC |
| L1515 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1516 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1517 | SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02 | SL0201 | 3.3NH |
| L1519 | SL0201-NC | SL0201 | NC |
| L1521 | SL0201-NC | SL0201 | NC |
| L1522 | SL0201-15NH-+/-5%-SDCL0603Q15NJT02 | SL0201 | 15NH |
| L1523 | SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02 | SL0201 | 2.4NH |
| L1524 | SL0201-NC | SL0201 | NC |
| L1531 | SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02 | SL0201 | 8.2NH |
| L1532 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1533 | SL0201-4.7NH-+/-0.3NH-SDCL0603Q4N7ST02 | SL0201 | 4.7NH |
| L1538 | SL0201-NC | SL0201 | NC |
| L1539 | SL0201-NC | SL0201 | NC |
| L1540 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1542 | SL0201-4.7NH-+/-0.3NH-SDCL0603Q4N7ST02 | SL0201 | 4.7NH |
| L1544 | SL0201-NC | SL0201 | NC |
| L1545 | SL0201-NC | SL0201 | NC |
| L1548 | SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02 | SL0201 | 4.3NH |
| L1550 | SL0201-NC | SL0201 | NC |
| L1551 | SL0201-NC | SL0201 | NC |
| L1552 | SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02 | SL0201 | 1.5NH |
| L1554 | SL0201-5.1NH-+/-0.3NH-SDCL0603Q5N1ST02 | SL0201 | 5.1NH |
| L1558 | SL0201-2.2NH-+/-0.3NH-SDCL0603Q2N2ST02 | SL0201 | 2.2NH |
| L1560 | SL0201-5.1NH-+/-0.3NH-SDCL0603Q5N1ST02 | SL0201 | 5.1NH |
| L1561 | SL0201-1.8NH-+/-0.3NH-SDCL0603Q1N8ST02 | SL0201 | 1.8NH |
| L1565 | SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02 | SL0201 | 3.3NH |
| L1570 | SL0201-15NH-+/-5%-SDCL0603Q15NJT02 | SL0201 | 15NH |
| L1573 | SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02 | SL0201 | 2.4NH |
| L1578 | SL0201-15NH-+/-5%-SDCL0603Q15NJT02 | SL0201 | 15NH |
| L3218 | L_/_3.4_/_NH_/_0201 | IND0201 | 3.4nH 450 mA |
| L3219 | L_/_9.1_/_NH_/_0201 | C0201 | 9.1nH 250 mA |
| L3222 | L_/_4.7_/_NH_/_0201 | C0201 | 4.7nH 350 mA |
| L4601 | PL_/_10_/_UH_/_2520 | L/IND/SMD/CIGT252012LMR47MNE | 10uH/ 252000 |
| L4602 | PL_/_2.2_/_UH_/_2520 | L/IND/SMD/DFE252010F | 2.2uH/252010 |
| L4611 | IND0201P_4.3NH | IND0201 | 5.6nH |
| L4701 | IND0201_NC | IND0201 | NC |
| L4702 | IND0201P_4.3NH | IND0201 | 9.1nH |
| L4703 | IND0201P_4.3NH | IND0201 | NC |
| L4704 | IND0201_NC | IND0201 | 8.2nH |
| L4705 | IND0201P_4.3NH | IND0201 | 1.4nH |
| L4706 | IND0201_NC | IND0201 | NC |
| L4707 | IND0201_NC | IND0201 | NC |
| L4708 | IND0201P_4.3NH | IND0201 | 82nH |
| L4709 | IND0201P_4.3NH | IND0201 | 56nH |
| L4710 | IND0201P_4.3NH | IND0201 | NC |
| L4711 | IND0201_NC | IND0201 | NC |
| L5434 | IND0201P_4.3NH | IND0201 | 3.3nH |
| L5435 | IND0201P_4.3NH | IND0201 | NC |
| L5436 | IND0201P_4.3NH | IND0201 | NC |
| L5437 | IND0201P_4.3NH | IND0201 | 1nH |
| L5438 | IND0201P_4.3NH | IND0201 | 47nH |
| L5439 | IND0201P_4.3NH | IND0201 | NC |
| L5501 | IND0201P_4.3NH | IND0201 | NC |
| L5502 | IND0201P_4.3NH | IND0201 | NC |
| L5526 | IND0201P_4.3NH | IND0201 | NC |
| L6202 | L_/_LQM18NN82NM00 | 402 | L / LQM18NN82NM00 |
| M1306 | SL0201-6.8NH-+/-5%-SDCL0603Q6N8JT02 | SL0201 | 6.8NH |
| M1307 | SC0201-NC-+/-0.25PF-25V | SC0201 | NC |
| M1308 | SC0201-1.8PF-+/-0.25PF-25V | SC0201 | 1.8PF |
| MOTO2 | BAT-PAD | BAT/SMD/XH414HG-IV01E | VIBRATOR |
| NTC1301 | RES-NTC-47K-0402 | R0402 | NTC-100K |
| NTC1302 | RES-NTC-47K-0402 | R0402 | NTC--100K |
| PL1 | L_SMD8085 | SMD8085 | PL / 1.5 / uH /8.0*8.5*3.0 |
| PL2001 | L/IND/SMD/CIGT252012LMR47MNE | L/IND/SMD/CIGT252012LMR47MNE | PL / 0.47 / uH |
| PL2002 | L/IND/SMD/CIGT252012LMR47MNE | L/IND/SMD/CIGT252012LMR47MNE | PL / 0.47 / uH |
| PL2003 | L/IND/SMD/MEMK2520 | L/IND/SMD/MEMK2520 | PL / 1 / uH |
| PL2004 | L/IND/SMD/MEKK2016 | L/IND/SMD/MEKK2016 | PL / 1 / uH |
| PL2006 | L/IND/SMD/MEMK2520 | L/IND/SMD/MEMK2520 | PL / 1 / uH |
| PL2801 | L/IND/SMD/VLS201610E | L/IND/SMD/VLS201610E | PL / 0.33 / uH |
| PL2802 | L/IND/SMD/VLS201610E | L/IND/SMD/VLS201610E | PL / 0.33 / uH |
| PL2803 | PL_/_1_/_UH_/_2016 | L/IND/SMD/VLS201610E | 1uH /2016 |
| Q4 | MMBT3904 | SOT-723 | 3904 |
| Q5 | MMBT3904 | SOT-723 | 3904 |
| Q9 | MMBT3904 | SOT-723 | 3904 |
| Q12 | MMBT3904M | SOT-723 | MMBT3904M |
| Q141 | PNP-SOT-723 | SOT-723 | S9012 |
| R14155 | SR0201-NC-5%-1/20W | SR0201 | NC |
| SH2 | NC/MMD/10MIL | NC/MMD/L1/10MIL | SHORT / 10MIL |
| SW1 | MARK | MARK | NC |
| SW2 | MARK | MARK | NC |
| SW3 | MARK | MARK | NC |
| SW4 | MARK | MARK | NC |
| T4501 | ESD_/_AZ5825-01F | VR0402 | ESD / AZ5825-01F |
| T4502 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| T5106 | ESD_/_AZ5885-01F.R7GR | ESD/2P/P0.85/SMD/AZ5885-01F/MTK0760 | |
| TP9905 | TP30 | TP30 | TP / 30 / mil |
| TV3 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV4 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV5 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV6 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV9 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV10 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV1905 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV1907 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV1908 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV1909 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| TV1910 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| U1 | TXB0104RUTR | UQFN_12 | TXB0104RUTR |
| U2 | TXB0104RUTR | UQFN_12 | TXB0104RUTR |
| U4 | WK2132 | VSSOP16 | |
| U5 | PN553 | VFBGA64_PN553 | |
| U7 | RT9080 | ZQFN-4L | |
| U8 | RT9080 | ZQFN-4L | |
| U9 | RT9080 | ZQFN-4L | |
| U10 | TPS61088 | VQFN20L | |
| U13 | BS3406ADJ/RT8096C | SOT_25 | BS3406ADJ/RT8096C |
| U14 | RT9080 | ZQFN-4L | |
| U15 | RT9080 | ZQFN-4L | |
| U16 | RT9080 | ZQFN-4L | |
| U17 | SGM66052 | SGM66052 | |
| U22 | CJM1216 | DFNWB2X2-6L | AP4435GM |
| U23 | PCA9306 | S-PDSO-G8 | PCA9306DC1 |
| U143 | AP4435GM | SOP-8_208MIL | AP4435GM |
| U902 | MT6631/WSQFN40/SMD/P0.4/5X5 | MT6631/WSQFN40/SMD/P0.4/5X5 | QFN40/MT6631N |
| U1001 | MT6762/VCP | MT6762/VFBGA558/P0.4/B0.24/11.4X11.0 | U / MT6762 |
| U1301 | LPF-4PIN-1608-RFBPF16081G9DM1T79 | LPF-4PIN-1608 | BF1608-L1R9NDC |
| U1302 | SAW-5P-1411-SFDG35AQ102 | SAW-5PIN-1109-UNBALANCE | SAFFB2G35MA0F0A |
| U1303 | SAW-5P-1411-SFDG26AQ102 | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | SAFFB2G59MA3F0A |
| U1401 | SAW-8P-1814-SFX897BYF02 | DUPLEXER-8PIN-1814/2016 | SAYEY897MBA0B0A |
| U1402 | LPF-4PIN-1608-RFBPF16081G9DM1T79 | LPF-4PIN-1608 | RFBPF16081G9DM1T79 |
| U1403 | SAW-8P-1814-SFX806BYH02 | DUPLEXER-8PIN-1814/2016 | SAYEY806MBA0F0A |
| U1404 | LPF-4PIN-0605-RFLPF06050G9D0T | LPF-4PIN-0605 | RFLPF06050G9D0T |
| U1405 | SAW-8P-1814-SAYEY707MBA0F0A | DUPLEXER-8PIN-1814/2016 | SAYEY707MBA0F0A |
| U1406 | IC-SP3T-SWITCH-VC1623-11 | RF1628 | RF1628A |
| U1407 | SAW-8P-1814-SFXG50CY902 | DUPLEXER-8PIN-1814/2016 | SAYRH1G95BA0F0A |
| U1408 | SAW-8P-1814-SFXG80AYM02 | DUPLEXER-8PIN-1814/2016 | SAYEY1G88BC0B0A |
| U1409 | SAW-8P-1814-SFXG47AYM02 | DUPLEXER-8PIN-1814/2016 | SAYEY1G74BC0B0A |
| U1410 | SAW-8P-1814-SAYEY1G73BA0F0AR05 | DUPLEXER-8PIN-1814/2016 | SAYEY1G73BA0F0AR05 |
| U1411 | SAW-8P-1814-SFX836CYA02 | DUPLEXER-8PIN-1814/2016 | SAYEY836MBE0F0A |
| U1412 | SAW-8P-1814-SFXG35BYN02 | DUPLEXER-8PIN-1814/2016 | SAYEY2G53BC0F0A |
| U1501 | SAW-5P-1109-SFHG40AA002 | SAW-5PIN-1109-UNBALANCE | SAFFB2G14AA0F0A |
| U1502 | SAW-5P-1109-SFH942AA002 | SAW-5PIN-1109-UNBALANCE | SAFFB842MAN0F0A |
| U1503 | SAW-5P-1109-SFHG42AA002 | SAW-5PIN-1109-UNBALANCE | SAFFB1G84AB0F0A |
| U1505 | SAW-5P-1109-SAFFB2G65AA0F0A | SAW-5PIN-1109-UNBALANCE | SAFFB2G65AA0F0A |
| U1506 | LPF-4PIN-1608-RFBPF16081G9DM1T79 | LPF-4PIN-1608 | LFB181G91CT9E361 |
| U1507 | SAW-5P-1109-SFHG05AA002 | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | SAFFB2G60AA0F0A |
| U1508 | SAW-5P-1109-SFHG52AA002 | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | SAFFB2G35AA0F0A |
| U1509 | LPF-4PIN-0605-RFLPF06050G9D0T | LPF-4PIN-0605 | RFLPF06050G9D0T |
| U1510 | SAW-5P-1109-SFH806BA002 | SAW-5PIN-1109-UNBALANCE | SAFFB806MAA0F0A |
| U1512 | SAW-5P-1109-SFH737AA002 | SAW-5PIN-1109-UNBALANCE | SAFFB737MAA0F0A |
| U2001 | MT6357/VFBGA209/P0.4/B0.25/7.0X6.6 | MT6357/VFBGA209/P0.4/B0.25/7.0X6.6 | U / MT6357CRV/A |
| U2801 | WLCSP15/P0.4/B0.25/RT5738 | WLCSP15/P0.4/B0.25/RT5738 | U / MT6691OOP/A |
| U2802 | WLCSP15/P0.4/B0.25/RT5738 | WLCSP15/P0.4/B0.25/RT5738 | U / MT6691OOP/A |
| U2803 | U_/_RT5784AGQWF | DFN8/SMD/P0.5/RT5784A/S | NC/RT5784AGQWF |
| U2806 | WL-CSP6/SMD/P0.4/RT9085A | WL-CSP6/SMD/P0.4/RT9085A | U / MT6680P/A |
| U2807 | MP20051 | QFN8_3X3 | NC/RT5784AGQWF |
| U2810 | UDFN4/SMD/P0.65/NCP114 | UDFN4/SMD/P0.65/NCP114 | U / NCP114AMX180TCG |
| U4001 | FBGA254/P0.5/B0.27/11.5X13/12X15 | FBGA254/P0.5/B0.27/11.5X13/12X15 | U / H9HP52ACPMMDAR-KMM |
| U4501 | U_/_MT6371P/ABA-H | WLCSP93/P0.4/B0.25/RT5081 | |
| U4702 | SAFEB1G57KA0F00 | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | SAFEB1G57KE0F00 |
| U4703 | BGU7005 | TSLP6/SMD/P0.4/BGA725L6/S | BGU7005 |
| U4704 | SAW_SAFEA2G45MC0F0A | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | FBAR / ACPF-7124 |
| U5101 | CPA2232 | CPA2232_QFN20 | CPA2232 |
| U5200 | MT6177MV/BCA-H | MT6177M/VFBGA120/P0.4/B0.25/5.0X4.6 | |
| U5300 | PA_/_SKY77590_4 | SKY77643 | |
| U5401 | ASM_/_SKY13492_7 | RF5210 | SKY77916-31 |
| U5500 | SKY13418 | SKY13418 | SKY13418 |
| U5700 | U_/_AK09918C | WLCSP4/P0.4/B0.21/AK09918 | |
| U5703 | KXTJ2-1009 | KXTJ2-1009 | bosc |
| U5706 | IC_BMI120 | BST-BMI120-DS001-05 | BMA250 |
| VR292 | TVS_0402 | TVS_0402 | M1005C080MTAAB |
| X1 | TXCO-3225 | TCXO3225 | X / 27.12 / MHz / FA-128 / NC |
| X2201 | TCVCXO_3 | TCXO/SMD/2.5X2.0/IT2205BE | |
| X3701 | TCVCXO_14 | TCXO3225 | 14.7456MHz |
| Y4701 | OSC/4P/SMD/KT1612A-KT2016K/2-IN | OSC/4P/SMD/KT1612A-KT2016K/2-IN-1 | KT2520P26000ACW28TAA/NC |
