查看: 135|回复: 0
[国标行标] VESA DisplayPort Standard Version 1, Revision 2(DP 1.2 SPEC)
  • 打卡等级:常住青年
  • 打卡总天数:20
  • 打卡总奖励:81
  • 最近打卡:2025-07-08 09:45:21
发表于 2025-6-13 14:44 | 显示全部楼层 |阅读模式
Purpose The purpose of this document is to define a flexible system and apparatus capable of transporting video, audio and other data between a Source Device and a Sink Device over a digital communications interface.
Summary The DisplayPort™ standard specifies an open digital communications interface for use in both internal connections, such as interfaces within a PC or monitor, and external display connections. Suitable external display connections include interfaces between a PC and monitor or projector, between a PC and TV, or between a device such as a DVD player and TV display.
DisplayPort Ver.1.1a is revised to correct errata items in and add clarifications to DisplayPort Standard Version 1, Revision 1.
DisplayPort Ver. 1.2 is revised to add enhancements including higher speed operation, more flexible topology management, multiple streams on a single connection, higher speed Auxiliary Channel communications, improved support for audio, and a new smaller connector. It also corrects errata items in and adds clarifications to DisplayPort Standard Version 1, Revision 1a.
DP-1.2.pdf
7.47 MB, 下载次数: 0, 下载积分: 金币 -1 枚
售价: 2 枚金币  [记录]  [购买]
