| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D2 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D3 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D4 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D5 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D6 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D7 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D8 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D9 | DIODE_0_SOD-123_IN5819 | IN5819 | SOD-123 |
| D10 | DIODE TUNNEL_0_E0402_NC | NC | E0402 |
| D11 | SMD_SHOTTKY_DIODE_3A_DO-214AC_S | SS34 | DO-214AC |
| D12 | DIODE TS_0_SOD-123_ZD27V | ZD27V | SOD-123 |
| ID1 | ID-BOARD_MARK_ID-BOARD | ID-BOARD | MARK |
| ID2 | ID-BOARD_MARK_ID-BOARD | ID-BOARD | MARK |
| ID3 | ID-BOARD_MARK_ID-BOARD | ID-BOARD | MARK |
| ID4 | ID-BOARD_MARK_ID-BOARD | ID-BOARD | MARK |
| J1 | CON8_CON-6P-1_25-SMD-L_6P/1.25 | 6P/1.25 | CON-6P-1_25-SMD-L |
| J2 | IMSA-12004S-120Y901_CON-FPC120P | IMSA-12004S-120Y901 | CON-FPC120P-0_4 |
| J3 | IMSA-12004S-120Y901-S_2_CON-FPC | IMSA-12004S-120Y901-S | CON-FPC120P-0_4 |
| J4 | CON50_3_CON-LVDS-30P-1_0_LVDS-3 | LVDS-30PIN-1_0 | CON-LVDS-30P-1_0 |
| J5 | CON8_CON-FPC6P-0_5_6PIN-0.5MM | 6PIN-0.5MM | CON-FPC6P-0_5 |
| J6 | CON5_0_CON-3P-1_25-SMD-L_3P/1.2 | 3P/1.25 | CON-3P-1_25-SMD-L |
| J7 | CON6_CON-4P-1_25-SMD-L_4P/1.25M | 4P/1.25MM | CON-4P-1_25-SMD-L |
| L1 | INDUCTOR PHENOLIC/SM_IND-YT0420 | 4.7uH/1A | IND-YT0420 |
| L2 | INDUCTOR PHENOLIC/SM_IND-YT0420 | 4.7uH/1A | IND-YT0420 |
| L3 | INDUCTOR PHENOLIC/SM_IND-YT04_1 | 10uH/1A | IND-YT0420 |
| L4 | INDUCTOR PHENOLIC/SM_IND-CD54_2 | 22uH | IND-CD54 |
| L5 | INDUCTOR_0_L0805_BLM21PG300SZ1D | BLM21PG300SZ1D | L0805 |
| Q1 | SOT23-100 3401_SOT23_AO3401A | AO3401A | SOT23 |
| Q2 | 2N3904_0_SOT23_MMBT3904 | MMBT3904 | SOT23 |
| TD1 | RCLAMP0524P_0_RCLAMP0524P_RF307 | RF3077-000 | RCLAMP0524P |
| TD2 | RCLAMP0524P_0_RCLAMP0524P_RF307 | RF3077-000 | RCLAMP0524P |
| TD3 | RCLAMP0524P_0_RCLAMP0524P_RF307 | RF3077-000 | RCLAMP0524P |
| TD4 | RCLAMP0524P_0_RCLAMP0524P_RF307 | RF3077-000 | RCLAMP0524P |
| TD5 | RCLAMP0524P_0_RCLAMP0524P_RF307 | RF3077-000 | RCLAMP0524P |
| TD6 | RCLAMP0524P_0_RCLAMP0524P_RF307 | RF3077-000 | RCLAMP0524P |
| TD7 | RCLAMP0524P_0_RCLAMP0524P_RF307 | RF3077-000 | RCLAMP0524P |
| TD8 | RCLAMP0524P_0_RCLAMP0524P_RF307 | RF3077-000 | RCLAMP0524P |
| U1 | TPS65131_1_QFN24-4X4_TPS65131 | TPS65131 | QFN24-4X4 |
| U2 | HP2301_SOT23-5_HP2301 | HP2301 | SOT23-5 |
| U3 | TMI3408_0_SOT23-6_SGM3749 | SGM3749 | SOT23-6 |
| U4 | NOR FLASH_1_USON8-2X3_W25Q20EW | W25Q20EW | USON8-2X3 |
| U5 | HV9120_2_QFN28-4X4-0_4P-EP2_7_H | HL24CB01A | QFN28-4X4-0_4P-EP2_7 |
