PADS VX 以上版本打开
PADS-260个常用封装库.7z
244.92 KB, 下载次数: 32, 下载积分:金币 -1 枚
| Name | Part Type | PCB Decal | Value | | ANT1 | 2.4G_ANT1 | ANT_PIFA_2G4_1MM | 1pF | | ANT2 | FPC14PIN_0.5MM | FPC14PIN_0.5MM | | | ANT3 | TP45 | TP45 | | | ANT4 | FPC6PIN_0.5MM | FPC6PIN_0.5MM | | | ANT5 | FPC5PIN_0.5MM | FPC5PIN_0.5MM | | | ANT6 | CON2-2.0 | CON2-2.0 | | | ANT7 | TSSOP-20L | TSSOP-20L | | | ANT8 | USB-MICRO1 | USB-MICRO2 | | | ANT9 | USB-D-SMT | USB-D-SMT | | | ANT10 | ANTPCB2 | ANTPCB2G | | | ANT11 | ANT | 2.4G_ANT3 | | | ANT12 | HEADER_8_2_1 | FING_7_2 | | | ANT13 | CON2.0-6P | CON2.0-6P | | | AV-JACK1 | AV-JACK12 | AV-JACK12 | | | B1 | TP | SMT-MARK | | | B2 | TP | SMT-MARK | | | BAT1 | BATTERY | BAT_SOCKET | 3.4V~4.2V | | BT_ANT1 | 2.4G_ANT | 2.4G_ANT | | | C1 | R1206 | R1206 | | | C02 | C0603 | C0603 | | | C2 | C1206 | C1206 | | | C3 | C1210 | C1210 | | | C4 | R1210 | R1210 | | | C5 | L1210 | CD0805 | | | C6 | L1206 | L1206 | | | CE10U/16VB1 | CE10U/16VB | CE10U/16VB | | | CE470U-B1 | CE470U-B | CE470U-B | | | CN1 | CON8_0 | USBHMMINI_-_5P) | USB | | CN2 | FPC4PIN_0.5MM | FPC4PIN_0.5MM | | | CN3 | CON2.0-3P | CON2.0-3P | | | CN8 | HDR1X4 | HDR1X4 | | | CON1 | 2P/2.0DIP | WAFER_2.0PH | 2P/2.0MM | | D1 | C2010 | C2010 | | | D2 | CT_V | CT_V | | | D3 | C2012 | C2012 | | | D4 | RN4_1 | RN4_1 | | | D5 | RN4_2 | RN4_2 | | | D6 | RN4_3 | RN4_3 | | | D7 | RN4_4 | RN4_4 | | | D8 | L0805 | L0805 | | | D9 | 5050RGB | 5050RGB | 5X5RGB | | D10 | L0603 | L0603 | | | D11 | LED-1W | LED-1W | | | D12 | RGBW5050 | RGBW5050 | | | D13 | 5050ARGB | 5050ARGB | | | D15 | SOD-123 | SOD-123 | | | DACVOL1 | VR3P5X14.8MM | VR3P5X14.6MM | 503B | | DACVOL2 | TSSOP16-PP | TSSOP16-PP | | | DC-JACK1 | DC-JACK1 | DC-JACK1 | | | DC-JACK2 | DC-JACK2 | DC-JACK2 | | | DC-JACK3 | DC-JACK3 | DC-JACK3 | | | DC1 | USB-A12/2 | USB-A12/2 | | | DCIN1 | DC-012 | DC-012 | | | DESIGNATOR1 | USB_-XLUV-SMD | USB_-XLUV-SMD | | | DESIGNATOR2 | SW_QQ | SW3P4.4X9MMAAAAAAA | SW SPDT | | E1 | CE_16MM | CE_16MM | | | E2 | C_5MM | C_5MM | | | E3 | C_8MM | C_8MM | | | E4 | C_10MM | C_10MM | | | E5 | BT_ANT12 | BTRFANT | ANT | | E6 | ANTENNA | BT_ANT_F | ANT | | E7 | EC11WS | EC11WS | | | E8 | BT-ANT | ANT-6651 | ANT | | E9 | BT-ANT | BT-ANT-F-T | RF-BT02 | | E10 | AMEMS_4P | AMEMS_4P | MIC3729 | | IC1 | CT_B | CT_B | | | IC2 | CT_C | CT_C | | | IC3 | CT_D | CT_D | | | IC4 | CT_A | CT_A | | | IC5 | C0805 | C0805 | | | IC6 | R0603 | R0603 | | | IC9 | SW_SPDT | SW3P4.4X8.6MM | SW SPDT | | J1 | MICJACK | PJ-316 | MICJACK | | J2 | PHONEJACK_STEREO_SW2 | AV-JACK112 | LINE-IN STEREO | | J3 | DC-023 | DC-023 | | | J4 | TF/CARD | TF01B | TFCard | | J6 | LED12P-8X36MM-S | LED12P-8X36MM-S | | | J7 | LED12P-8X36MM-X | LED12P-8X36MM-X | | | J8 | LED12P-8X36MM-SMT | LED12P-8X36MM-SMT | | | J9 | LED12-18X14MM | LED12-18X14MM | | | J10 | LED12-18X14MM-SMT | LED12-18X14MM-SMT | | | J11 | LED12P-28X50MM | LED12P-28X50MM | | | J12 | D-SS14 | D-SS14 | | | J13 | PHONE-CK-3.5HB | PHONE-CK-3.5HB | | | J14 | BATTERY_CR2032 | BAT_CR2032 | | | J15 | ANT | ANT | | | J16 | FPC7PIN_0.5MM | FPC7PIN_0.5MM | | | J17 | FPC11PIN | FPC11PIN_0.5MM | | | J18 | LGA2X2 | LGA2X2 | | | J19 | CON-SIP-5P | SIP-5P | | | J20 | CON2.0-5P | CON2.0-5P | | | J21 | CON4-2.0 | CON2.0-4P | | | J22 | CON2.0-7P | CON2.0-7P | | | J23 | 1.0MMLS14P | 1.0MMLS14P | CON14 | | J24 | CONRA-2P-200 | CONRA-2P-200 | | | J25 | CONRA-4P-200 | CONRA-4P-200 | | | J26 | CON-5P-PH2.0MM | CON-5P-PH2.0MM | | | J27 | FPC6PINL_0.5MM | FPC6PINL_0.5MM | CON6 | | K1 | MS-22C01 | K-MSS-22C02(2P2T) | | | K2 | 2PIN_1.25MM | 2PIN_1.25MM | | | K3 | 3PIN_1.25MM | 3PIN_1.25MM | | | K4 | 5PIN_1.25MM | 5PIN_1.25MM | | | K5 | 4PIN_1.25MM | 4PIN_1.25MM | | | L1 | R0402 | R0402 | | | L2 | C0402 | C0402 | | | L3 | L0402 | L0402 | | | L4 | BCMF122P900U | BCMF122P900U | | | L5 | INDUCTOR_GX | IND2520SMT | 1uH/4.5A | | L6 | 188LED-5PIN | 188LED-5PIN | | | L7 | 33UH/5A | L10X10 | | | L9 | RGB5_5/3 | LED3/3 | | | LED1 | 1204RGB | 1204RGB | | | LED2 | SMD_CRYSTAL_4PIN | XTAL-3225 | | | LED3 | DMIC | DMIC2 | | | LINEIN1 | PJ-358 | PJ-358 | | | M1 | MIC-4MM-SMT | MIC-4MM-SMT | MIC | | M2 | LCD35-40/44 | LCD35-40/44 | | | M3 | RGB-8MM | RGB-8MM | | | M4 | SC70-6 | SC70-6 | | | M5 | FPC4PIN_1.0MM | FPC4PIN_1.0MM | | | M6 | RF2_2 | RF2_2 | | | M7 | M | MIC_4013 | SMD4013 | | PJ1 | HDR1X10 | HDR1X10 | | | Q1 | SOT-23 | SOT-23 | 2N3906 | | R1 | PLOT2B | VRS6-16MMSMT | | | R02 | R0805 | R0805 | | | R2 | R2010 | R2010 | | | REM1 | REMOTE | IR3 | IRM3638 | | RN1 | RN4 | RN4 | | | S1 | SW_SPDT | SW-SPDT-7PIN | SW SPDT | | S2 | SW-PLJ | SW-PLJ | | | S3 | TF-CARD | TF-CARD | | | S4 | SOT-23-6 | SOT-23-6 | | | S5 | SOT-89 | SOT-89 | | | S6 | SOT23-5 | SOT23-5 | | | S7 | LED-3P-A-DIP | LED-3P-A-DIP | | | S8 | SOP8_SOPL | SOP8_SOPL | | | S9 | SOP-8 | SOP8P | BK1080-SOP 8 | | S10 | SOP16 | SOP16 | | | S11 | QFP-48 | QFP-48 | | | S12 | MSOP-10 | MSOP-10 | | | S13 | VR-SW-5P | VR-SW-5P | | | S14 | QFN-56L-0.4A | QFN-56L-0.4A | | | S15 | LED7P-8X36MM-S | LED7P-8X36MM-S | | | S16 | VR-3P | VR-3P | | | S17 | SW-DAN6 | SK-(1P3T)5PIN | | | S18 | SW-3X4-SMT | SW-3X4-SMT | | | S19 | SW2A-ZHONG | SW2A-ZHONG | | | S20 | SW2P3T | SW2P3T | | | S21 | SW8 | SW-8 | SW | | S22 | LED-3P-K-DIP | LED-3P-K-DIP | | | S23 | SW_8PIN | 12345 | | | S24 | LCD12-0.6MM | LCD12-0.6MM | | | S25 | SW-3X6-2P | SW-3X6-2P | | | S26 | LCD14-4X8-27X53MM | LCD14-4X8-27X53MM | | | S27 | SD-CARD | SD-CARD | | | S28 | LED | LED_0603 | LED | | S29 | LED-0805 | LED-0805 | | | S30 | LED18P-4X8-28X50MM | LED18P-4X8-28X50MM | | | S31 | LED7P-8X36MM-X | LED7P-8X36MM-X | | | S32 | LED7P-8X36MM-SMT | LED7P-8X36MM-SMT | | | S33 | LED_2.5MM_DIP | LED_2.05MM-DIP | | | S34 | LED6P-8X20MM | LED6P-8X20MM | | | S35 | USB-MICRO | USB-MICRO | | | S36 | LED7P-18X14MM-S | LED7P-18X14MM-S | | | S37 | LED7P-18X14MM-X | LED7P-18X14MM-X | | | S38 | SW3-2 | SW3-2 | | | S39 | SLKG-6 | SLKG-6 | | | S40 | BT-CW6635 | BT-CW6635 | | | S41 | BT-CW6637/CW3338 | KABKCW6638 | CW6638 | | S43 | QFN-48L-0.4 | QFN-48L-0.4 | | | S44 | SD-CARD-ZHONG | SDCARD-ZHONG | | | S45 | SD-CARD-C | SD-CARD-C | | | S47 | USB-D-CB | USB-D-CB | | | S48 | USB-MINI | USB-MINI | | | S49 | PHONE-5PIN | EJ-3527A | HEADPHONE_JACK | | S50 | PHONE-4PIN | PHONE-4PIN | | | S51 | MIC-4.5X2.5MM | MIC-4.5X2.5MM | | | S52 | SW-3X6-SMT | SW-3X6-SMT | | | S53 | SW-4.5X4.5-DIP | SW-4.5X4.5-DIP | | | S54 | SW-4.5X4.5-SMT | SW-4.5X4.5-SMT | | | S55 | SW-5X5-Q-SMT | SW-5X5-Q-SMT | | | S56 | SW-6X6-DIP-P | SW-6X6-DIP-P | | | S57 | SW-6X6-GZ | SW-6X6-GZ | | | S58 | SW-6X6-SMT | SW-6X6-SMT | | | S61 | SW_13D | SW_13D | | | SOP-1 | SOP-28 | SOP-28 | | | SOP-2 | TP1.5M | T1.5M | | | SSOP1 | SSOP28 | SSOP28 | | | SW1 | SW-WR02 | SW-VR02 | | | SW2 | CONN8_2 | CONN8_2 | | | SW3 | FQWP-8EPGS-X | KK-4 | | | U1 | BT-V2P-AEC | BT-V2P-AEC | | | U2 | SOP-8L | SOP-8L | | | U3 | AX2226 | SSOP24-0.635 | AX2226 | | U4 | PAM8908 | QFN16P-3X3 | pam8908 | | U5 | YC1051 | QFN-32-4_4-0.4MM-BK-515 | | | U6 | XT26M | XT26M | | | U7 | CON2_2.54MM | CON2_2.54MM | | | U8 | FPC10PIN_0.5MM | FPC10PIN_0.5MM | | | U9 | LM1117 | LM1117 | L1117LG(3V3) | | U10 | BK3256_QFN48 | BK3256_QFN48 | | | U11 | RDA5856_24PIN | SSOP24-G | RDA5856TE24PIN | | U12 | AC6908A_TSSOP20 | TSSOP20 | | | U13 | CONHDR5RA | CONHDR5RA | | | U14 | ESOP10 | ESOP10 | | | U15 | FPC8PIN_0.5MM | FPC8PIN_0.5MM | | | U16 | R12MMVR-1 | R12MMVR-1 | | | U17 | LGA-10-3-3 | LGA-10-3-3 | | | U18 | BK3266_QFN40 | BK3251_QFN40_5X5 | BK3266_QFN40 | | U19 | 6P2-0MM2X3 | 6P2-0MM2X3 | | | U20 | BK3266_QFN32_5 | BK3266_QFN32_4X4 | BK3266 | | U21 | QFN4X4-24 | QFN4X4-24 | | | U22 | HTSSOP-28 | HTSSOP-28 | | | U23 | CON-3P-PH2.0MM | CON-3P-PH2.0MM | | | U24 | DFN3X3_8 | DFN3X3_8 | | | U25 | N066-6448-H28 | N066-6448-H28 | | | U26 | QFN20-3X3 | QFN20-3X3 | | | U27 | CX8576 | QFN-5X5-20 | | | U28 | SOP14 | SOP14 | | | U29 | GX8008_QFN88 | GX8008_QFN88_NRE | | | U30 | MSOP-8 | MSOP-8 | LPA4809 | | U31 | 5050ARGB | 1615RGB | 3528ARGB | | U32 | TPYEC-2.0-16PIN | TPYEC-2.0-16PIN | | | U33 | TYPEC-2.0-6PIN | TYPEC-2.0-6PIN | | | U34 | 1.0MMLS4P | 1.0MMLS4P | | | U35 | 1.0MMLS2P | 1.0MMLS2P | | | U36 | RGLED0402 | RGLED0402 | | | U37 | SW-4 | KEY-3X3X1.5 | | | U38 | XL4005 | TO-263-5 | | | U39 | AMS1117 | SOT-223_-_3 | | | U40 | LP5305 | DFN8-2X2MM | LP5305 | | U41 | CN1.25X2 | CN1.25X2 | | | U42 | CN1.25X3 | CN1.25X3 | | | USB1 | USB_5P | USB-MICRO_-GVWV | | | V1 | SW-6X6-DIP | SW-6X6-DIP | | | V2 | 1.0MMLS5P | 1.0MMLS5P | | | VOL1 | VR3P5X16.5MM | VR3P5X16.5MM | 104B | | VR1 | CES_4MM | CES_4MM | | | VR2 | CES_5MM | CES_5MM | | | VR3 | CES_6MM | CES_6MM | | | VR4 | CES_8MM | CES_8MM | | | VR5 | CES_10MM | CES_10MM | | | VR6 | CE_4MM | CE_4MM | | | VR6P-14MM1 | VR6P-14MM | VR6P-14MM | | | VR7 | CE_5MM | CE_5MM | | | VR8 | CE_6MM | CE_6MM | | | VR9 | CE_8MM | CE_8MM | | | VR10 | CE_10MM | CE_10MM | | | VR11 | VR | VR | VR10K | | VR12 | POTK1 | W131 | 10K | | VR13 | VR-ONSW-V | VR-ONSW-V | ??? | | VRS3-16MM1 | VRS3-16MM | VRS3-16MM | | | VRS6-16MM1 | VRS6-16MM | VRS6-16MM | | | W1 | B50K-VOL | VR-2 | | | X1 | CRYSTAL_4P | SMD3225 | | | Y1 | CRYSTAL | OSC_2X6 | 32.768K | | Y2 | M49S_SMD-26M | XTAL-26MHZ | M49S_SMD-26M | | Y3 | 26MHZ | 32_25 | 24MHZ |
