重要提示:PCB作品文件展下载说明
PCB文件。回复可见下载
| KXG2512 | B1 | BMT2512H12-04 LF | Buzzer | | 4148 | D01, D02, D03, D04, D05, D06, D07, D08 | MINIMELF/SOD-80C | DIODE | | MMBZ27VCLT1 | D09, D10 | SOT-23-123 | TVS | | 7227 | D11 | 7227 | DIODE | | M7 | D12, DA01, DA02, DA03, DA04 | 7227 | DIODE | | 1N4007 | D43 | 1812-1N4007-TX20131220 | DIODE | | S5M | Da3, Da4 | DO-214AB | 1N4004 | | SK110FL | Da6, Ua2D1 | SOD-123FL | DIODE, 1N4004 | | STWD100 | IC0 | SOT-23-5 | ADM8614 | | 1000pF/16V | IC0C1, TU2C1, TU2C2 | 603 | Cap | | MMBT5551 | IC0Q1, Q01, Q02, Q03, Q05, Q07, Q08, Q10 | SOT-23-BEC | NPNN | | S25FL512S | IC1 | SOIC16 | S25FL512S | | MT46H64M32LFCX-6 | IC2 | BGA90-15X9 | MT46H8M32LFB5 | | TPS92690-Q1 | IC3 | HTSSOP16 | TPS92690-Q1 | | white | JA1 | AJ24 | COMPONENT_2 | | gray | JA2 | AJ24 | COMPONENT_2 | | HIF3FC-20PA-2.54DSA | JP1 | CON-10X2-2.54 | CONNECTOR20 | | 7TFT-55PIN | JP4 | FFC55 | 7TFT-55PIN | | B82790 | L2 | B82790 | B82790 | | ACM2012-121-2P-T001 | La1, Lh1 | L7.0*6.0 | TDKZJYS81 | | 22uH | La2 | L10*10 | INDUCTOR | | 220uF/50V | La2C1 | C2-10 | ELECTRO1 | | 10uF | La2C3, Ua2C7 | 1206 | CAP | | 1uF | La2C4, Ua2C6 | 805 | CAP0805 | | 33uH | La3 | L10*10 | INDUCTOR | | R | LD01 | LED3528 | WL_LCD_R | | Y | LD02, LD06 | LED3528 | WL_LCD_Y | | B | LD03 | LED3528 | WL_LCD_B | | 67-21SUGC/B116/TR8(JM) | LD04 | LED3528 | WL_LCD_G | | G | LD05 | LED3528 | WL_LCD_G | | 321611YC | LD07, LD08, LD10 | LED3528 | Y_LED_R, Y_LED_Y | | 3216S9AC | LD11 | LED3528 | Y_LED_R | | 330uH | Le1 | L10*10 | BEAD | | Comment | MARK1, MARK2, MARK3, MARK4 | MARK | MARK | | 8050(TO-92) | Q3, Q4 | SOT23 | NPN | | BCX55 | Q04 | SOT-89-ECB | NPN | | 8550 | Q5 | SOT-23 | PNP | | AF2301 | Q06 | SOT-23-BEC | P-MOSFET | | BUK98150 | Qa5 | SOT-223 | BUK98150 | | SW-PB | S1, S2 | KEY-H | SW-PB | | KXG2512 | Speaker1 | UGSM_3608P | Buzzer | | MMZ1608Y300B | TL1, TL2, TPL1, TPL2 | 603 | Inductor | | MMZ1608Y300B | TPL4, TPL10 | 805 | Inductor | | 47 | TU1 | BGA328-22X22 | CapricornBt_1 | | 1000pF/16V | TU1C1, TU1C5, TU1C6 | C0402 | Cap | | 10uF/16V | TU1C3 | 603 | Cap | | 8pF/50V | TU2C3, TU2C4 | 603 | Cap | | 12pF/50V | TU2C5, TU2C6 | 603 | Cap | | 1M | TU2R3 | 603 | Res3 | | 10M | TU2R5 | 603 | Res3 | | 560 | TU2R6 | 603 | Res3 | | 24LC04B-I/SN | U3 | SO-8 | 24AA02 | | TJA1042T/3 | U7 | SO-8 | TJA1040 | | BD433 | Ua1 | TO-263 | WL_4275 | | TLE8366EV | Ua2 | PG-DSO-8 | L4949ED | | 22nF | Ua2C1 | 603 | CAP0805 | | 220pF | Ua2C2 | 603 | CAP0805 | | 470pF | Ua2C3 | 603 | CAP0805 | | 220nF | Ua2C8 | 805 | CAP0805 | | 47uF | Ua2C9, Ua2C10 | 805 | CAP0805 | | 2.2uF | Ua2C11, Ua2C14 | 603 | CAP0805 | | 1.5K/1% | Ua2R1 | 603 | RES2 | | 11K/1% | Ua2R2 | 603 | RES2 | | 200K | Ua2R3 | 603 | RES2 | | NC | Ua2R4 | 805 | RES2 | | BDxxIA5MEFJ-M | Ua4, Ua5 | HTSOP-J8 | BDxxIA5MEFJ-M | | 0.1uF/50V | Ua4C2, Ua4C3, Ua5C2, Ua5C3 | 805 | CAP | | 30K | Ua4R1 | 805 | RES2 | | 24K | Ua4R2 | 805 | RES2 | | 12K | Ua5R1, Ua5R2 | 805 | RES2 | | 16K | Ua5R3 | 805 | RES2 | | TPIC6C596 | Uu1, Uu2, Uu3 | SO-16 | TPIC6C596 | | 10MHZ | X1 | XTL-6.5 | XTAL | | 32.768K | X2 | NX3215 | XTAL |
重要提示:PCB作品文件展下载说明
