| REFDES | COMP_DEVICE_TYPE | SYM_NAME |
| D1 | JW5116-JW5116 | SO8-150-1 |
| D2 | IP101GR-IP101GR | QFN4X4-32-G2R6X2R6-B |
| D3 | STM32F407VET6-STM32F405RG | SQFP14X14-100-6 |
| D4 | LP3987H-LP3987H | SOT23-5 |
| D5 | RF_BM_S02I-RF_BM_S02I | RF-BM-S02I |
| D6 | SKY65366_21-SKY65366_21 | SKY65536_21 |
| D7 | SKY65366_21-SKY65366_21 | SKY65536_21 |
| D8 | MOB_SRV05_4-CM1213A-04S7 | SC70-6-3-M |
| D9 | MAX202-ADM3202EARN | SO16-150 |
| D10 | LTC1480IS8 | SO8-150 |
| D11 | ESD03C32D_LCD-ESD03C32D_LCD | SOD323-2 |
| D12 | ESD03C32D_LCD-ESD03C32D_LCD | SOD323-2 |
| FV1 | SM1K15CF | SMBF |
| FV2 | SM1K15CF | SMBF |
| FV3 | SM1K15CF | SMBF |
| FV4 | SM1K15CF | SMBF |
| FV5 | SM1K15CF | SMBF |
| FV6 | SM1K15CF | SMBF |
| G1 | E3SB32.0000F12G11M | CO4-2R5X3R2-S-2 |
| G2 | E3SB32.0000F12G11M | CO4-2R5X3R2-S-2 |
| G3 | CRYSTAL_4PIN-CX2520SB25000D0PEA | CO4-2R5X2R0-S |
| G4 | MOB_CRYSTALOSC_2PIN-FC-135 32.A | CO2-3R2X1R5-SM-N |
| G5 | CRYSTAL_4PIN_6-I-F-8M-20-2030-A | CO4-3R2X5R0-SM-1-B |
| GB1 | BATTERY-TM5.913.561 | BATTERY-18R5X15R0-SM |
| HL1 | SML-510MW | 0603D |
| HL2 | SML-510MW | 0603D |
| HL3 | SML-510MW | 0603D |
| HL4 | SML-510MW | 0603D |
| HL5 | SML-510MW | 0603D |
| HL6 | SML-510MW | 0603D |
| HL7 | SML-510MW | 0603D |
| HL8 | SML-510MW | 0603D |
| HL9 | EL-A694B-HG | LED4-4R3X9R0-0R8 |
| HL10 | LNJ312G8TRA | 0603D |
| HL11 | SML-510MW | 0603D |
| L1 | DO3316P-473MLD | IND2SM-9R4X13R0 |
| L2 | INDUCTOR_POWER_-SMRH129-330,33A | IND2SM-12R5X12R5-1 |
| L3 | DO3316P-473MLD | IND2SM-9R4X13R0 |
| L4 | BLM11P600SPT_MURATA | 1608L-C |
| L5 | BLM11P600SPT_MURATA | 1608L-C |
| L6 | LQW15AN33NJ00 | 0402L-C |
| L7 | ELJRF18NJ_PANASONIC | 1005L-C |
| L8 | LQW15AN33NJ00 | 0402L-C |
| L9 | ELJRF15NJ_PANASONIC | 1005L-C |
| L10 | ELJRF18NJ_PANASONIC | 1005L-C |
| L11 | ELJRF15NJ_PANASONIC | 1005L-C |
| L12 | CI-B1005-120JJT_CTC | 1005L-C |
| L13 | CI-B1005-120JJT_CTC | 1005L-C |
| L14 | CI-B1005-120JJT_CTC | 1005L-C |
| L15 | CI-B1005-120JJT_CTC | 1005L-C |
| L16 | HH-1M3216-601J | 3216L-C-1 |
| L18 | HH-1M3216-601J | 3216L-C-1 |
| L19 | BLM11B102S | 1608L-C |
| L20 | BLM11B102S | 1608L-C |
| L21 | BLM11B102S | 1608L-C |
| L22 | BLM11B102S | 1608L-C |
| MR1 | MARK-MARK_1 | MARK1R0 |
| MR2 | MARK-MARK_1 | MARK1R0 |
| MR3 | MARK-MARK_1 | MARK1R0 |
| MR4 | MARK-MARK_1 | MARK1R0 |
| MR5 | MARK-MARK_1 | MARK1R0 |
| MR6 | MARK-MARK_1 | MARK1R0 |
| RT1 | MF-R250-0-10 | RAD5R0-3R2X11R5-0R8 |
| RT2 | SMD125 | SMD125 |
| S1 | DTSA6-5K | SW4TM-7R4X12R4-1 |
| SB1 | RING-HOLE_SM_4R50D2R50 | HOLE_SM_4R50D2R50 |
| SB2 | RING-HOLE_SM_4R50D2R50 | HOLE_SM_4R50D2R50 |
| SB3 | RING-HOLE_SM_4R50D2R50 | HOLE_SM_4R50D2R50 |
| SB4 | RING-HOLE_SM_4R50D2R50 | HOLE_SM_4R50D2R50 |
| SB5 | RING-HOLE_SM_4R50D2R50 | HOLE_SM_4R50D2R50 |
| SB6 | RING-HOLE_SM_4R50D2R50 | HOLE_SM_4R50D2R50 |
| T1 | H1102 | TRAN16SM-7R3X12R7 |
| TP1 | TESTPOINT-TPS | TPS |
| U1 | SX1278-SX1278 | QFN6X6-28 |
| U2 | SX1278-SX1278 | QFN6X6-28 |
| U3 | MOD_COM-BASE | MOD-COM-47X43 |
| U4 | MOB_TUBE_2PIN-4532-091-LF | 4532-091-LF |
| U5 | MOB_TUBE_2PIN-4532-091-LF | 4532-091-LF |
| VD1 | DIODE_TVS_SMB-SM1K33CF | SMBF |
| VD2 | DIODE_SWITCH_SM-MRA4007T3,ON | SMA_D |
| VD3 | DIODE_SWITCH_SM-15MQ040NTR,IR | SMA_D |
| VD4 | DIODE_TVS_SMB-SM1K33CF | SMBF |
| VD5 | DIODE_SWITCH_SM-MRA4007T3,ON | SMA_D |
| VD6 | MMBD4148_FAIRCHILD | SOT23-3 |
| VD7 | MMBD4148_FAIRCHILD | SOT23-3 |
| VD8 | PSOT03C_PROTEK | SOT23-3 |
| VD9 | DIODE_ZENER_SOT23-3-LBZX84C5V1A | SOT23-3 |
| VD10 | DIODE_ZENER_SOT23-3-LBZX84C5V1A | SOT23-3 |
| VD11 | DIODE_ZENER_SOT23-3-LBZX84C5V1A | SOT23-3 |
| VD12 | DIODE_ZENER_SOT23-3-LBZX84C5V1A | SOT23-3 |
| VD13 | DIODEDUAL_TVS-SM1K6VC | SMBF |
| VD14 | DIODEDUAL_TVS-SM1K6VC | SMBF |
| VT1 | NPN-PMBT3904 | SOT23-3 |
| VT2 | IRLML6401TRPBF_IR | SOT23-3 |
| X1 | STD_2R54_3TM-201SS-1*40_1X3 | CON20VP2R54-1X3TM-1 |
| X2 | STD_2R54_3TM-201SS-1*40_1X3 | CON20VP2R54-1X3TM-1 |
| X3 | STD_2R54_3TM-201SS-1*40_1X3 | CON20VP2R54-1X3TM-1 |
| X4 | STD_2R54_3TM-201SS-1*40_1X3 | CON20VP2R54-1X3TM-1 |
| X5 | OQ025551F000G | OQ025551F000G |
| X6 | SMA-50KE | CON10-6R1X6R1-2 |
| X7 | JACK9605-8P8C | CON17-TM6R6-8 |
| X8 | SMA-50KE | CON10-6R1X6R1-2 |
| X9 | E6288-000023 | CON17-TM8R0-8 |
| X10 | STD_2R54_2TM-201SS-1*40_1X2 | CON20VP2R54-1X2TM |
| X11 | STD_2R54_4TM-2211S-40 | CON20VP2R54-1X4TM |
| X12 | STD_2R54_4TM-2211S-40 | CON20VP2R54-1X4TM |
| X13 | STD_2R54_2TM-201SS-1*40_1X2 | CON20VP2R54-1X2TM |
| X14 | STD_3R81_4TM-MC1.5/4-G-3.81 | CON20RP3R81-4TM |
| X15 | PTB350S-01-03-3_JITE | CON20RP3R81-3TM |
| X16 | PTB350S-01-02-3_JITE | CON20RP3R81-2TM |
| X17 | PTB350S-01-02-3_JITE | CON20RP3R81-2TM |
