| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BT1 | CR1220_CR1220_CR1220 | CR1220 | CR1220 |
| CON1 | P35-157-P1Z9_ETH_P35-157-P1Z9 | P35-157-P1Z9 | ETH |
| CON2 | USB-MINI-B_MINIUSBB_USB-MINI-B | USB-MINI-B | MINIUSBB |
| CON3 | HEADER 32X2_254MM-64PIN-2_2.54M | 2.54mm-180D-32x2 | 254MM-64PIN-2 |
| CON4 | HEADER 32X2_254MM-64PIN-2_2.54M | 2.54mm-180D-32x2 | 254MM-64PIN-2 |
| CON5 | HEADER 30X2_200MM-60PIN-2_2.00M | 2.00mm-180D-30X2 | 200MM-60PIN-2 |
| CON6 | CONN RCPT 12X2/SM_200MM-24PIN-B | 2.00mm-180D-12X2 | 200MM-24PIN-BT-NORMAL |
| CON7 | PANASONIC-STANDARD-SD_SD-SOCKET | Panasonic-Standard-SD | SD-SOCKET-PANASONIC-AUTO |
| CON8 | PANASONIC-STANDARD-SD_SD-SOCKET | Panasonic-Standard-SD | SD-SOCKET-PANASONIC-AUTO |
| CON9 | CON20_254MM-20PIN-2_2.54MM 10X2 | 2.54MM 10x2 | 254MM-20PIN-2 |
| CON10 | DSUB9M_DSUB9_DSUB9 | DSUB9 | DSUB9 |
| CON11 | POWERJACK_POWERJACK_POWERJACK | PowerJACK | POWERJACK |
| J1 | SW-BIT-3_SW-BIT-3_MIC_LINE-IN | MIC_LINE-IN | SW-BIT-3 |
| J2 | CON2_254MM-2PIN-1_SPEAK 8OHM | Speak 8ohm | 254MM-2PIN-1 |
| J3 | SW-BIT-S_SW-BIT_SW-BIT-S | SW-BIT-S | SW-BIT |
| J4 | SW-BIT-3_SW-BIT-3_CHANNEL SELEC | Channel select | SW-BIT-3 |
| J5 | CONN TRBLK 3_200MM-3PIN-1_2.00M | 2.00mm-1x3-Jump | 200MM-3PIN-1 |
| J6 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J7 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J8 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J9 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J10 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J11 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J12 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J13 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J14 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J15 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J16 | SW-BIT-S_SW-BIT_EMAC-INT | EMAC-INT | SW-BIT |
| J17 | CON8A_200MM-8PIN-2_2.00MM-4X2 J | 2.00mm-4x2 Jump | 200MM-8PIN-2 |
| J18 | SW-BIT_SW-BIT_WP | WP | SW-BIT |
| J19 | SW-BIT_SW-BIT_PRE | PRE | SW-BIT |
| J20 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J21 | SW-BIT-3_SW-BIT-3_SW-BIT-3 | SW-BIT-3 | SW-BIT-3 |
| J22 | SW-BIT-S_SW-BIT_HOLD | HOLD | SW-BIT |
| J23 | SW-BIT-S_SW-BIT_SW-BIT-S | SW-BIT-S | SW-BIT |
| J24 | SW-BIT-S_SW-BIT_WP | WP | SW-BIT |
| J25 | CON12A_200MM-12PIN-2_2.00MM-6X2 | 2.00mm-6x2-Jump | 200MM-12PIN-2 |
| J26 | SW-BIT-3_SW-BIT-3_RTC_POWER | RTC_Power | SW-BIT-3 |
| J27 | SW-BIT-S_SW-BIT_SW-BIT-S | SW-BIT-S | SW-BIT |
| J28 | SW-BIT-S_SW-BIT_SW-BIT-S | SW-BIT-S | SW-BIT |
| L1 | FB_0603L_FB | FB | 0603L |
| L2 | FB_0603L_FB | FB | 0603L |
| L3 | FB_0603L_FB | FB | 0603L |
| L4 | FB_0603L_FB | FB | 0603L |
| L5 | FB_0805L_FB | FB | 0805L |
| L6 | FB_0805L_FB | FB | 0805L |
| L7 | FB_0805L_FB | FB | 0805L |
| L8 | INDUCTOR FERRITE_1210L_2.2UH | 2.2uH | 1210L |
| L9 | INDUCTOR FERRITE_1210L_2.2UH | 2.2uH | 1210L |
| L10 | INDUCTOR FERRITE_1210L_2.2UH | 2.2uH | 1210L |
| L11 | FB_0805L_FB | FB | 0805L |
| L12 | FB_0805L_FB | FB | 0805L |
| L13 | FB_0402L_FB | FB | 0402L |
| LED1 | LED_D0603_BLUE-0603 | Blue-0603 | D0603 |
| LED2 | LED_D0603_YELLOW-0603 | Yellow-0603 | D0603 |
| LED3 | LED_D0603_YELLOW-0603 | Yellow-0603 | D0603 |
| LED4 | LED_D0603_RED-0603 | Red-0603 | D0603 |
| LS1 | HEADPHONE-3_HEADPHONE-3_HEADPHO | HeadPhone-3 | HEADPHONE-3 |
| M1 | CON2_MIC-4MM_4MM-MICROPHONE | 4mm-Microphone | MIC-4MM |
| Q1 | 2N9012_SOT23S_2N9012 | 2N9012 | SOT23S |
| Q2 | SI2301_SOT23S_SI2301 | SI2301 | SOT23S |
| Q3 | SI2301_SOT23S_SI2301 | SI2301 | SOT23S |
| S1 | KEY-M1_STS-035A_RESET | RESET | STS-035A |
| S2 | KEY-M1_STS-035A_ON/OFF | ON/OFF | STS-035A |
| S3 | KEY-M1_STS-035A_CUT-OFF-POWER | Cut-Off-Power | STS-035A |
| TP1 | TP_TPS_LINE-IN | Line-In | TPS |
| TP2 | TP_TPS_AGND | AGND | TPS |
| TP3 | TP_TPS_SD2WP | SD2WP | TPS |
| U1 | ISD8101_SO8-150E_ISD8101 | ISD8101 | SO8-150E |
| U2 | APL3511A_SOT-23-5_APL3511A | APL3511A | SOT-23-5 |
| U3 | RTL8201F-QFN-32_QFN-32_RTL8201F | RTL8201F-QFN-32 | QFN-32 |
| U4 | W55FA92DDN_LQFP-128_W55FA92DDN | W55FA92DDN | LQFP-128 |
| U5 | HY27US08121A_TSOP4805_HY27US081 | HY27US08121A | TSOP4805 |
| U6 | W25QXXX-16_SO16-300_W25QXXX-16 | W25QXXX-16 | SO16-300 |
| U7 | W25XXX_SO8-208_W25XXX | W25XXX | SO8-208 |
| U8 | ICL-232E_ICL232_ICL-232E | ICL-232E | ICL232 |
| U9 | APL3203_TDFN-8_APL3203 | APL3203 | TDFN-8 |
| U10 | APW7176_TDFN-10_APW7176 | APW7176 | TDFN-10 |
| U11 | APW7102_SOT-23-5_APW7102 | APW7102 | SOT-23-5 |
| U12 | APL5537_SOT-23-6_APL5537 | APL5537 | SOT-23-6 |
| U13 | HD74LV1G08A_SOT-23-5_HD74LV1G08 | HD74LV1G08A | SOT-23-5 |
| X1 | XTAL_9HT9_32.768K | 32.768K | 9HT9 |
| X2 | XTAL_H49S_12MHZ | 12MHz | H49S |
| X3 | XTAL_H49S_25MHZ | 25MHz | H49S |
